  3. Multi Button Relay switch
43 Posts 13 Posters 29.5k Views 8 Watching
  • T Offline
    T Offline
    Terence Faul
    Hi
    Is is possible to attached 4 relays to a node and also control each with a button?
    hekH 1 Reply Last reply
    • T Terence Faul
      Hi
      hekH Offline
      hekH Offline
      @Terence-Faul
      Should be possible. But make sure to feed the relays separately.
      • T Offline
        T Offline
        Terence Faul
        Do you have an example sketch, I am a newby and would not have any idea how to alter the sketch to include buttons and move the relay pins
        B 1 Reply Last reply
        • hekH Offline
          hekH Offline
          No sorry, I don't have any example that matches your needs exactly.
          Best way to learn (I hope that is what you ultimately want?) is to use at the two relay examples provided and try to modify them.
          If you have any specific question about the code don't hesitate to ask.
          • T Terence Faul
            B Offline
            B Offline
            BulldogLowell
            try this (untested but compiles)
            const int relayPin[] = {7, 8, A0, A1};
            const int buttonPin[sizeof(relayPin) / sizeof(relayPin[0])] = {3, 4, 5, 6};
            byte oldValue[sizeof(relayPin) / sizeof(relayPin[0])];
            boolean relayState[sizeof(relayPin) / sizeof(relayPin[0])];
            Bounce debouncer[sizeof(relayPin) / sizeof(relayPin[0])];
            MyMessage msg[sizeof(relayPin) / sizeof(relayPin[0])];//(sensor,type);
              gw.begin(incomingMessage, AUTO, false);
              for (int i = 0; i < sizeof(relayPin) / sizeof(relayPin[0]); i++)
                msg[i].sensor = i;
                msg[i].type = V_LIGHT;
                debouncer[i] = Bounce();
                debouncer[i].interval(5);
                pinMode(buttonPin[i], INPUT_PULLUP);
                digitalWrite(relayPin[i], LOW);
                pinMode(relayPin[i], OUTPUT);
                gw.present(relayPin[i], S_LIGHT);
                delay(250);
              //retreive from EEPROM last states
                relayState[i] = gw.loadState(i);
                digitalWrite(relayPin[i], relayState[i]? HIGH : LOW);
                gw.send(msg[i].set(relayState[i]? true : false), true);
                delay(250);
              for (byte i = 0; i < sizeof(relayPin) / sizeof(relayPin[0]); i++)
                debouncer[i].update();
                byte value = debouncer[i].read();
                if (value != oldValue[i] && value == 0)
                  relayState[i] = !relayState[i];
                  digitalWrite(relayPin[i], relayState[i]);
                oldValue[i] = value;
            void incomingMessage(const MyMessage &message)
              if (message.isAck())
              for (byte i = 0; i< sizeof(relayPin) / sizeof(relayPin[0]); i++)
                if (message.sensor == i)
                  if (message.type == V_LIGHT)
                    relayState[i] = message.getBool();
                    gw.saveState(relayPin[i], relayState[i]);
            • G Offline
              G Offline
              gigi
              there is no problem to put 4 relays.
              you just feed a separate power!!!
              Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
              • T Offline
                T Offline
                Terence Faul
                  // Example sketch för a "light switch" where you can control light or something
                  // else from both vera and a local physical button (connected between digital
                  // pin 3 and GND).
                  // This node also works as a repeader for other nodes
                  #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                  #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  Bounce debouncer = Bounce();
                  int oldValue=0;
                  bool state;
                    gw.sendSketchInfo("Relay & Button", "1.0");
                   // Setup the button
                    pinMode(BUTTON_PIN,INPUT);
                    // Activate internal pull-up
                    debouncer.attach(BUTTON_PIN);
                    debouncer.interval(5);
                    gw.present(CHILD_ID, S_LIGHT);
                    pinMode(RELAY_PIN, OUTPUT);
                    state = gw.loadState(CHILD_ID);
                  *  Example on how to asynchronously check for new messages from gw
                    debouncer.update();
                    // Get the update value
                    int value = debouncer.read();
                    if (value != oldValue && value==0) {
                        gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                    oldValue = value;
                    if (message.isAck()) {
                       // Change relay state
                       state = message.getBool();
                       // Store state in eeprom
                       gw.saveState(CHILD_ID, state);
                B 2 Replies Last reply
                • T Terence Faul
                    // pin 3 and GND).
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                    int oldValue=0;
                    bool state;
                     // Setup the button
                      debouncer.update();
                      oldValue = value;
                  B Offline
                  B Offline
                  BulldogLowell
                  yeah, a mistake or two ;)
                    // or you can try:
                    // gw.begin(incomingMessage, <Your_Node_ID>, false); // where Your_Node_ID is a number from 1 to 254
                    delay(250);
                    gw.sendSketchInfo("MultiRelayButton", "0.9b");// <<<<<<<<<<<<<<<<<<< I forgot this, here
                    delay(250);
                      msg[i].sensor = i;
                      gw.present(i, S_LIGHT); // <<<<<<<<<<<<<<<<<<<<<<< I fixed this too...
                      delay(250);
                      delay(250);
                  try and see if it fixes your issues :)
                  • T Terence Faul
                      // pin 3 and GND).
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue=0;
                      bool state;
                       // Setup the button
                        debouncer.update();
                        oldValue = value;
                    B Offline
                    B Offline
                    BulldogLowell
                    @Terence-Faul
                    #define RELAY_ON 1
                    #define RELAY_OFF 0
                      // or you can try:
                      delay(250);
                      delay(250);
                        msg[i].sensor = i;
                        delay(250);
                        digitalWrite(relayPin[i], relayState[i]? RELAY_ON : RELAY_OFF);
                        //gw.send(msg[i].set(relayState[i]? RELAY_ON : RELAY_OFF), true);
                        delay(250);
                          //digitalWrite(relayPin[i], relayState[i]);
                          gw.send(msg[i].set(relayState[i]? false : true), true);
                    • B BulldogLowell
                      @Terence-Faul
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                        // or you can try:
                        delay(250);
                        delay(250);
                          msg[i].sensor = i;
                          delay(250);
                          delay(250);
                      T Offline
                      T Offline
                      Terence Faul
                      wrote on last edited by Terence Faul
                      @BulldogLowell
                      This new one had the relays correct, but the buttons did not work. I compared the old with the new and below now works.
                      Thanks again a million for all the help
                      #define RELAY_ON 0
                      #define RELAY_OFF 1
                        // or you can try:
                        delay(250);
                        delay(250);
                          msg[i].sensor = i;
                          delay(250);
                          delay(250);
                      • T Terence Faul
                        @BulldogLowell
                        #define RELAY_ON 0
                        #define RELAY_OFF 1
                          // or you can try:
                          delay(250);
                          delay(250);
                            msg[i].sensor = i;
                            delay(250);
                            delay(250);
                        T Offline
                        T Offline
                        Terence Faul
                        @Terence-Faul
                        Only one other thing.
                        I notice that when the sensor starts up, each of the relays turn on and then off.
                        This ia all good and well, however i assume in practice this would mean what ever is connected to them will turn on and off as well in the initialisation phase.
                        Also I assume that retrieve from EEPROM means that if the sensor loses power while a relay is on, when it powers up this relay will return to the on state?
                        Can you point me to to code that controls this, if these are lights and the power goes out a better option may be to have the relays all start in the off position so that the lights do not come on in the middle of the night
                        Is this correct?
                        • T Offline
                          T Offline
                          Terence Faul
                          Bulldog
                          So this is as far as I got.
                          Managed to get the relays to start in the off position by Changing LOW for the defined RELAY_OFF.
                          Commented out the EEPROM Section and now when the sensor reboots is starts with all relays in off position.
                          I do not know how to change the EEPROM section I am sur I need to maybe include the RELAY_OFF somewhere in that line.
                          #define RELAY_ON 0  //switch around for realy HIGH/LOW state
                          #define RELAY_OFF 1
                            // or you can try:
                            delay(250);
                            delay(250);
                              msg[i].sensor = i;
                              digitalWrite(relayPin[i], RELAY_OFF); //Start State of Relays
                              delay(250);
                          //  for (int i = 0; i < sizeof(relayPin) / sizeof(relayPin[0]); i++)//>>>>>>> I'm sure that this is causing all relays to turn on and off at startup
                          //    relayState[i] = gw.loadState(i);
                          //    digitalWrite(relayPin[i], relayState[i]? RELAY_ON:RELAY_OFF);
                          //    gw.send(msg[i].set(relayState[i]? true : false), true);
                          //    delay(250);
                          • T Terence Faul
                            Bulldog
                            #define RELAY_OFF 1
                              // or you can try:
                              delay(250);
                              delay(250);
                                msg[i].sensor = i;
                                delay(250);
                            //    delay(250);
                            B Offline
                            B Offline
                            BulldogLowell
                            if you are not relying on settings saved to EEPROM to recover its state after a power cycle, you can also comment our or remove this line:
                            it saves the state of the relay each time it gets changed.
                            glad to see you are learning and have it working just the way you like.
                            • T Offline
                              T Offline
                              Terence Faul
                              Thanks a stack, it is slow.
                              If I did want to restore the relay state how would I change the code?
                              At the moment if I leave that code in when the arduino boots it cycles each relay on and then off, instead of just restoring the previous state
                              • A Offline
                                A Offline
                                Anthony Straw
                                go for SSR instead of hk mechical relay it will stop working after 10,000 clicked ... cheap brand
                                • jeylitesJ Offline
                                  jeylitesJ Offline
                                  jeylites
                                  I got the same question as @Terence-Faul, How to change the code to have the Relay to restore its previous state. I tried a couple of things but can't seem to get it to work. Thanks @BulldogLowell for the script !
                                  • B Offline
                                    B Offline
                                    BulldogLowell
                                    @jeylites ,
                                    so, try to look over the example just above the one that worked for @Terence-Faul
                                    It included saving states to EEPROM and retrieving them in setup( ).
                                    • C Offline
                                      C Offline
                                      C.r.a.z.y.
                                      How do you seperate relay power?
                                      What is your solution to drop 220v AC to 5v DC?
                                      jeylitesJ 1 Reply Last reply
                                      • C C.r.a.z.y.
                                        jeylitesJ Offline
                                        jeylitesJ Offline
                                        jeylites
                                        @C.r.a.z.y. You could get a USB power adapter... see Ebay link below. On my current setup, I'm using a 2.1A+1A Dual USB 2-Ports. I use the the 1A port for the Arduino and the 2.1A port for the relays. On the relay board, you have VCC, IN1 & GND. IN1 gets connected to the Arduino, VCC to the second power supply or power port. The GND is shared between both power ports. Hope that helps!
                                        http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2141725.m570.l1313.TR12.TRC2.A0.H0.XUSB+Wall+Charger+.TRS0&_nkw=USB+Wall+Charger+&ghostText=&_sacat=0
                                        • jeylitesJ jeylites
                                          jeylitesJ Offline
                                          jeylitesJ Offline
                                          jeylites
                                          wrote on last edited by jeylites
                                          @BulldogLowell
                                          I have gone through the script like 8 times with no luck at all. Are you suggesting the mistake in in the EEPROM retrieval section ?
                                          #define RELAY_ON 1 //switch around for realy HIGH/LOW state
                                          #define RELAY_OFF 0
                                          // or you can try:
                                          delay(250);
                                          delay(250);
                                          msg[i].sensor = i;
                                          delay(250);
                                          //gw.send(msg[i].set(relayState[i]? true : false), true);
                                          delay(250);
                                          #define RELAY_OFF 0
                                            // or you can try:
                                            delay(250);
                                            delay(250);
                                              msg[i].sensor = i;
                                              delay(250);
                                              delay(250);
                                          A 1 Reply Last reply
