  3. Raspberry PI killing memory cards
18 Posts 9 Posters 2.0k Views 5 Watching
  • I iancu
    @Yveaux for how long do you use it?
    skywatchS
    skywatchS
    skywatch
    @iancu I had problems and went down the SSD route. Once the pi was set up I copied all to the ssd and enabled ssd boot - it's been working like a charm since then.
    With SSD's at less than £20 now and £5 or less for a usb adaptor cable it is not that expensive. One other thing though is power supply, I cannot emphasise enough how important a quality power supply is to the pi. You could start there first.
    I 1 Reply Last reply
    • skywatchS skywatch
      I
      I
      iancu
      @skywatch i have the original charger. Does it matter if the SSD is external type?
      sundberg84S skywatchS 2 Replies Last reply
      • I iancu
        sundberg84S
        sundberg84S
        @iancu - had the same issue, went with an old desktop and Proxmox VM instead. Might be more expensive unless you have spare parts.
        • I iancu
          skywatchS
          skywatchS
          skywatch
          @iancu SSD will be external anyway as the pi lacks any connectors for internal drives. An external ssd is just an internal ssd with the usb converter in the case rather than in the cable. A bonus is that you can throw away the SD card too (probably a fake one anyway)....
          As for the power supply, it took me many painful years to get to the point I am at now with a lot of quality supplies sourced from reliable UK companies. The old cheaper supplies are still in use, but for other things now that are less sensitive to defieiencies in the power.
            zboblamontZ
            zboblamontZ
            zboblamont
            @skywatch Agreed entirely on the supply quality for the Pi, but disagree with the "bonus" of throwing away the SD. Murphy's Law applies, a RO card allows you to revert to a spare OS card if the drive ever fails...
            The Pi3 has 4xUSB2, the Pi4 uprated to 2xUSB2 + 2xUSB3, the data transfer limits of the Pi3 are lower, but still plenty fast.
            PS - I recall some USB adapters for SSD could cause issues for the Pi, fairly sure it was on a video by the "Swiss guy"...
            skywatchS 1 Reply Last reply
            • zboblamontZ zboblamont
              skywatchS
              skywatchS
              skywatch
              @zboblamont said in Raspberry PI killing memory cards:
              No problem with your view on this, it gives the OP different ideas and approaches to the original issue. All my pi back themselves up to the SSD or server on a weekly or daily schedule. So I don't worry about reverting the system. I use kingston 20Gb SSD's with usb adaptor cables and all running smoothly.....just wait for something to happen now I have said that! ;)
              I just oreder my first pi4 (4Gb) - if it is as good as it seems then a few pi3's will be made into cameras and replaced by pi 4's during the rest of the year. I just wish they put a MCLK out on the pi 4 for pro audio use......ah well......
              Compatability is always going to be an issue is seems. ;(
                zboblamontZ
                zboblamontZ
                zboblamont
                @skywatch :face_palm:
                To be clear it's not system data integrity or recovery I was driving at rather than the OS if switched to an SSD or HDD only system.There is a minor delay in booting the micro-SD and switching over to the HDD, but it is a further escape route from Murphy's Law....
                Plenty of advice to the OP anyway, which is the beauty of the forum.
                  skywatchS
                  skywatchS
                  skywatch
                  @zboblamont No problem with your thoughts on that ;)
                  @iancu Hope the answers here have helped a little for you (or maybe confused the issue even more!).... Let us know what tou decied and how it works for you :)
                  • TmasterT
                    TmasterT
                    Tmaster
                    wrote on last edited by Tmaster
                    my Domoticz its running on a PNY SD card for more than 2 years and didn't die yet. But i almost don't have power cuts . Any case i have another sandisk ultra sd with an clone from the running SD ready to replace this in case of fail.
                    You can buy and replace an raspberry by an fast and more expensive device...but this sd cards cost 3.75€ !!! power consumption of 1.5w- 1.9w in idle... what else can i want from my domotic system! :)
                    edit: i have 4 or 5 sensors transmitting and writing every 15min, so sd write, it's not too heavy,standart usage.
                    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                    • nagelcN
                      nagelcN
                      nagelc
                      I have domoticz and on a rpi with 3 serial gateways. It used to destroy SD cards pretty regularly.
                      I went with this power supply from Adafruit (It is actually 5.25V) and a UPS.
                      https://www.adafruit.com/product/1994
                      Also, I use log2ram.
                      That has finally made my rpi domoticz setup reliable. I have been running about a year without problems. I still back up often. : )
                        I
                        I
                        iancu
                        Thank you all for the advice! I will try first with log2ram, but for long term I want to install an SSD.
                        A nice week to all!
