  3. [SOLVED] Need help with ESP8266 MQTT Gateway (RFM69HW radio)
18 Posts 4 Posters 1.7k Views 3 Watching
  • W Offline
    W Offline
    willemx
    wrote on last edited by willemx
    I am trying to create a MQTT gateway on a ESP8266 with a RFM69HW radio using the config options from the example sketch:
    #define MY_BAUD_RATE 9600
    #define MY_RADIO_RFM69
    #define MY_IS_RFM69HW
    #define MY_RFM69_IRQ_PIN D1
    #define MY_RFM69_IRQ_NUM MY_RFM69_IRQ_PIN
    #define MY_RFM69_CS_PIN D8
    #define MY_GATEWAY_ESP8266
    This is the debug output from the gateway:
    --- Miniterm on /dev/cu.SLAB_USBtoUART  9600,8,N,1 ---
    --- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H ---
    ␒`␓␀�9���␒�␓␐�)���60 MCO:BGN:INIT GW,CP=RRNGE---,FQ=80,REL=255,VER=2.3.2
    118 TSF:LRT:OK
    133 TSM:INIT
    147 TSF:WUR:MS=0
    167 TSM:INIT:TSP OK
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 1
    cnt
    connected with TOUTATIS, channel 2
    dhcp client start...
    ip:192.168.178.64,mask:255.255.255.0,gw:192.168.178.1
    388 TSM:INIT:GW MODE
    411 TSM:READY:ID=0,PAR=0,DIS=0
    443 MCO:REG:NOT NEEDED
    530 GWT:TPC:CONNECTING...
    1557 MCO:BGN:STP
    1575 MCO:BGN:INIT OK,TSP=1
    1604 TSM:READY:NWD REQ
    1633 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    scandone
    2893 GWT:TPC:IP=192.168.178.64
    2934 GWT:RMQ:CONNECTING...
    2992 GWT:RMQ:OK
    3010 GWT:TPS:TOPIC=mygateway2-out/0/255/0/0/18,MSG SENT
    pm open,type:2 0
    After this line, there is no more output; the gateway just seems to hang.
    I have an arduino node with a RFM69HW radio running trying to connect to the gateway, but it cannot find a parent node: lots of !TSM:FPAR:NO REPLY debug messages
    I am using MySensors V2.3.2 on all nodes.
    I have tried different ESP8266 boards (NodeMCU, Wemos D1) that I know to be good (I have used them succesfully as gateways with NRF24 radio's). Also tried several new RFM69HW boards and various power supplies that I have used succesfully with other working nodes but all with the same results.
    I could use some advice on how to proceed...
    electrikE 1 Reply Last reply
    • W willemx
      118 TSF:LRT:OK
      133 TSM:INIT
      147 TSF:WUR:MS=0
      167 TSM:INIT:TSP OK
      scandone
      state: 0 -> 2 (b0)
      state: 2 -> 3 (0)
      state: 3 -> 5 (10)
      add 0
      aid 1
      cnt
      1557 MCO:BGN:STP
      scandone
      2992 GWT:RMQ:OK
      pm open,type:2 0
      electrikE Offline
      electrikE Offline
      electrik
      @willemx do you see the gateway connecting to the mqtt broker? I.e. do you see the message coming in on mygateway2-out/0/255/0/0/18?
      Btw. Is that a local sensor connected to the gateway?
      • W Offline
        W Offline
        willemx
        Yes, I can see the gateway connecting to the broker. And yes, it is a local sensor that is trying to find the gateway (I just copied the "door/window/button" example sketch for testing)
        • electrikE Offline
          electrikE Offline
          electrik
          It looks like the gateway is stuck in a loop. Could you post your code?
          • W Offline
            W Offline
            willemx
            This is the gateway code: (comments left out)
            #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway2-out"
            #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway2-in"
            #define MY_MQTT_CLIENT_ID "mysensors-2"
            #define MY_WIFI_SSID "TOUTATIS"
            #define MY_WIFI_PASSWORD "XXXXXXXXXXXXXX"
            #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 90
            #define MY_PORT 1883
            #include <ESP8266WiFi.h>
            void setup() {}
            void presentation() {}
            void loop() {}
            This is the sensor node code:
            #define CHILD_ID 3
            #define BUTTON_PIN  3
            Bounce debouncer = Bounce();
            int oldValue=-1;
              pinMode(BUTTON_PIN,INPUT);
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              present(CHILD_ID, S_DOOR);
              debouncer.update();
              int value = debouncer.read();
              if (value != oldValue) {
                 send(msg.set(value==HIGH ? 1 : 0));
                 oldValue = value;
            This is the sensor node log:
             __  __       ____
                    |___/                      2.3.2
            16 MCO:BGN:INIT NODE,CP=RRNNA---,FQ=8,REL=255,VER=2.3.2
            28 TSM:INIT
            28 TSF:WUR:MS=0
            32 TSM:INIT:TSP OK
            34 TSM:FPAR
            38 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            2048 !TSM:FPAR:NO REPLY
            2050 TSM:FPAR
            2054 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            4063 !TSM:FPAR:NO REPLY
            4065 TSM:FPAR
            4069 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            6078 !TSM:FPAR:NO REPLY
            6080 TSM:FPAR
            6084 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            8093 !TSM:FPAR:FAIL
            8095 TSM:FAIL:CNT=1
            8097 TSM:FAIL:DIS
            8099 TSF:TDI:TSL
            18102 TSM:FAIL:RE-INIT
            18104 TSM:INIT
            18106 TSM:INIT:TSP OK
            18110 TSM:FPAR
            18114 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            20123 !TSM:FPAR:NO REPLY
            20125 TSM:FPAR
            20129 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            22138 !TSM:FPAR:NO REPLY
            22140 TSM:FPAR
            22145 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            24154 !TSM:FPAR:NO REPLY
            24156 TSM:FPAR
            24160 ?TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
            26169 !TSM:FPAR:FAIL
            26171 TSM:FAIL:CNT=2
            26173 TSM:FAIL:DIS
            26175 TSF:TDI:TSL
            36179 TSM:FAIL:RE-INIT
            36182 TSM:INIT
            ............repeating endlessly
            And this is the gateway log:
            0�~?�4�Ҷ␞��␄OA␌r��61 MCO:BGN:INIT GW,CP=RRNGE---,FQ=80,REL=255,VER=2.3.2
            118 TSF:LRT:OK
            134 TSM:INIT
            148 TSF:WUR:MS=0
            167 TSM:INIT:TSP OK
            scandone
            state: 0 -> 2 (b0)
            217 TSM:INIT:GW MODE
            239 TSM:READY:ID=0,PAR=0,DIS=0
            state: 2 -> 3 (0)
            290 MCO:REG:NOT NEEDED
            state: 3 -> 5 (10)
            add 0
            aid 4
            cnt
            354 GWT:TPC:CONNECTING...
            scandone
            1441 MCO:BGN:STP
            1459 MCO:BGN:INIT OK,TSP=1
            1487 TSM:READY:NWD REQ
            1515 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            ip:192.168.178.68,mask:255.255.255.0,gw:192.168.178.1
            2209 GWT:TPC:IP=192.168.178.68
            2296 GWT:RMQ:CONNECTING...
            2605 GWT:RMQ:OK
            2622 GWT:TPS:TOPIC=mygateway2-out/0/255/0/0/18,MSG SENT
            pm open,type:2 0
            900148 TSF:SAN:OK
            1201488 TSM:READY:NWD REQ
            1201519 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            1800148 TSF:SRT:OK
            1800168 TSF:SAN:OK
            2401489 TSM:READY:NWD REQ
            2401520 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
            So it appears that the gateway is not hanging after all. It just takes a long time between log messages. It is doing a network discovery broadcast every 20 minutes or so.
            But the gateway and sensor (1 meter distance) node do not connect...
            • electrikE Offline
              electrikE Offline
              electrik
              Is the node id assigned automatically? Maybe you can try with a static id?
              • W Offline
                W Offline
                willemx
                Yes, but this cannot be the problem. The node must first find a parent anyway.
                • R Offline
                  R Offline
                  Rolo6442u
                  wrote on last edited by Rolo6442u
                  For comparison, I have a MQTT Gateway running on a Wemos D1 for 2 months now, with a RFM69W. Works perfect. Here is my hardware setup and code, maybe it is of any help to you. Change the networkid, MQTT broker and wifi credentials to your own setup. I use static ID's on my nodes.
                  //#define MY_IS_RFM69HW
                  #define MY_RFM69_NETWORKID 83   // Own network ID, mysensors default is 100
                  // Set MQTT client id
                  // Enable these if your MQTT broker requires username/password
                  // Set WIFI SSID and password
                  #define MY_WIFI_SSID "xxxxxxx"
                  #define MY_WIFI_PASSWORD "xxxxxxxx"
                  // passed to the DHCP server if not static.
                  #define MY_HOSTNAME "ESP8266_MQTT_GW"
                  // MQTT broker ip address.
                  #define MY_CONTROLLER_IP_ADDRESS 10, 0, 0, 47
                  //MQTT broker if using URL instead of ip address.
                  // #define MY_CONTROLLER_URL_ADDRESS "test.mosquitto.org"
                  // Enable inclusion mode
                  //#define MY_INCLUSION_MODE_BUTTON_PIN D1
                  // Set blinking period
                  // Flash leds on rx/tx/err
                  #define MY_DEFAULT_ERR_LED_PIN D4   // Red
                  #define MY_DEFAULT_TX_LED_PIN D3    // Yellow
                  #define MY_DEFAULT_RX_LED_PIN D2    // Green
                  2020-03-15 07_13_27-sPlan 7.0 - [Z__mysensors_GatewayESP8266MQTTClient_GatewayESP8266MQTT.spl7].jpg
                  • W Offline
                    W Offline
                    willemx
                    Thank you for your setup example. It is nearly identical to my setup (only I use RFM69HW's).
                    The only thing I can think of now is that the radio modules must be defective, but I have no means to test this) So I ordered a new batch of RFM69's and hope for the best...
                    [Edit]
                    I see that you do not use the following defines as instructed in link text:
                    I have tried both with and without these defines, but it makes no difference.
                    • electrikE Offline
                      electrikE Offline
                      electrik
                      Did you try to add a capacitor next to the power pins?
                      • W Offline
                        W Offline
                        willemx
                        Yes, I added a capacitor to both radio's.
                        • W willemx
                          T Offline
                          T Offline
                          tekka
                          @willemx And you have 868Mhz modules?
                          • W Offline
                            W Offline
                            willemx
                            Yes, that is what I ordered and also it is marked on the radio PCB's.
                            • W willemx
                              T Offline
                              T Offline
                              tekka
                              @willemx Can you try with the new rfm69 driver & debug verbose mode on both, node & gw - i.e.
                              #define MY_RFM69_NEW_DRIVER
                              #define MY_DEBUG_VERBOSE_RFM69
                              and post the debug logs here.
                              • W Offline
                                W Offline
                                willemx
                                config on WEMOS D1 gateway:
                                log:
                                0�~?�4�Ҷ␞��␄OAqr��62 MCO:BGN:INIT GW,CP=RPNGE---,FQ=80,REL=255,VER=2.3.2
                                119 TSF:LRT:OK
                                135 TSM:INIT
                                148 TSF:WUR:MS=0
                                166 RFM69:INIT
                                scandone
                                state: 0 -> 2 (b0)
                                state: 2 -> 3 (0)
                                state: 3 -> 5 (10)
                                add 0
                                aid 3
                                cnt
                                383 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                423 RFM69:PTX:LEVEL=5 dBm
                                450 !RFM69:INIT:SANCHK FAIL
                                479 !TSM:INIT:TSP FAIL
                                503 TSM:FAIL:CNT=1
                                523 TSM:FAIL:DIS
                                540 TSF:TDI:TSL
                                557 RFM69:RSL
                                pm open,type:2 0
                                10573 TSM:FAIL:RE-INIT
                                10597 TSM:INIT
                                10612 RFM69:INIT
                                10630 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                10673 RFM69:PTX:LEVEL=5 dBm
                                10702 !RFM69:INIT:SANCHK FAIL
                                10734 !TSM:INIT:TSP FAIL
                                10760 TSM:FAIL:CNT=2
                                10781 TSM:FAIL:DIS
                                10801 TSF:TDI:TSL
                                10820 RFM69:RSL
                                20838 TSM:FAIL:RE-INIT
                                20862 TSM:INIT
                                20877 RFM69:INIT
                                20895 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                20938 RFM69:PTX:LEVEL=5 dBm
                                20967 !RFM69:INIT:SANCHK FAIL
                                20999 !TSM:INIT:TSP FAIL
                                21025 TSM:FAIL:CNT=3
                                21047 TSM:FAIL:DIS
                                21066 TSF:TDI:TSL
                                21085 RFM69:RSL
                                31103 TSM:FAIL:RE-INIT
                                31127 TSM:INIT
                                31142 RFM69:INIT
                                31160 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                31203 RFM69:PTX:LEVEL=5 dBm
                                31232 !RFM69:INIT:SANCHK FAIL
                                31264 !TSM:INIT:TSP FAIL
                                31290 TSM:FAIL:CNT=4
                                31312 TSM:FAIL:DIS
                                31332 TSF:TDI:TSL
                                31350 RFM69:RSL
                                41368 TSM:FAIL:RE-INIT
                                41392 TSM:INIT
                                41407 RFM69:INIT
                                41425 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                41468 RFM69:PTX:LEVEL=5 dBm
                                41497 !RFM69:INIT:SANCHK FAIL
                                41529 !TSM:INIT:TSP FAIL
                                41555 TSM:FAIL:CNT=5
                                41577 TSM:FAIL:DIS
                                41596 TSF:TDI:TSL
                                41615 RFM69:RSL
                                51633 TSM:FAIL:RE-INIT
                                51657 TSM:INIT
                                51672 RFM69:INIT
                                51690 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                51733 RFM69:PTX:LEVEL=5 dBm
                                51762 !RFM69:INIT:SANCHK FAIL
                                51794 !TSM:INIT:TSP FAIL
                                51820 TSM:FAIL:CNT=6
                                51842 TSM:FAIL:DIS
                                51861 TSF:TDI:TSL
                                51880 RFM69:RSL
                                61898 TSM:FAIL:RE-INIT
                                61922 TSM:INIT
                                61937 RFM69:INIT
                                61955 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                61998 RFM69:PTX:LEVEL=5 dBm
                                62027 !RFM69:INIT:SANCHK FAIL
                                62059 !TSM:INIT:TSP FAIL
                                62085 TSM:FAIL:CNT=7
                                62107 TSM:FAIL:DIS
                                62126 TSF:TDI:TSL
                                62145 RFM69:RSL
                                122163 TSM:FAIL:RE-INIT
                                122188 TSM:INIT
                                122204 RFM69:INIT
                                122223 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                122267 RFM69:PTX:LEVEL=5 dBm
                                122298 !RFM69:INIT:SANCHK FAIL
                                122330 !TSM:INIT:TSP FAIL
                                122357 TSM:FAIL:CNT=7
                                122380 TSM:FAIL:DIS
                                122401 TSF:TDI:TSL
                                122421 RFM69:RSL
                                182439 TSM:FAIL:RE-INIT
                                182464 TSM:INIT
                                182480 RFM69:INIT
                                182499 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                182543 RFM69:PTX:LEVEL=5 dBm
                                182574 !RFM69:INIT:SANCHK FAIL
                                182606 !TSM:INIT:TSP FAIL
                                182633 TSM:FAIL:CNT=7
                                182656 TSM:FAIL:DIS
                                182677 TSF:TDI:TSL
                                182697 RFM69:RSL
                                242716 TSM:FAIL:RE-INIT
                                242741 TSM:INIT
                                242757 RFM69:INIT
                                242776 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                242820 RFM69:PTX:LEVEL=5 dBm
                                242851 !RFM69:INIT:SANCHK FAIL
                                242883 !TSM:INIT:TSP FAIL
                                242910 TSM:FAIL:CNT=7
                                242933 TSM:FAIL:DIS
                                242954 TSF:TDI:TSL
                                242974 RFM69:RSL
                                302992 TSM:FAIL:RE-INIT
                                303017 TSM:INIT
                                303033 RFM69:INIT
                                303052 RFM69:INIT:PIN,CS=15,IQP=5,IQN=5
                                303096 RFM69:PTX:LEVEL=5 dBm
                                303127 !RFM69:INIT:SANCHK FAIL
                                303159 !TSM:INIT:TSP FAIL
                                303186 TSM:FAIL:CNT=7
                                303209 TSM:FAIL:DIS
                                303230 TSF:TDI:TSL
                                303250 RFM69:RSL
                                log from Arduino Pro Mini sensor node:
                                 __  __       ____
                                        |___/                      2.3.2
                                16 MCO:BGN:INIT NODE,CP=RPNNA---,FQ=8,REL=255,VER=2.3.2
                                28 TSM:INIT
                                28 TSF:WUR:MS=0
                                30 RFM69:INIT
                                32 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                36 RFM69:PTX:LEVEL=5 dBm
                                38 TSM:INIT:TSP OK
                                40 TSM:INIT:STATID=42
                                45 TSF:SID:OK,ID=42
                                47 TSM:FPAR
                                47 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                                53 RFM69:CSMA:RSSI=-104
                                59 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                2066 !TSM:FPAR:NO REPLY
                                2068 TSM:FPAR
                                2070 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                                2074 RFM69:CSMA:RSSI=-107
                                2080 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                4089 !TSM:FPAR:NO REPLY
                                4091 TSM:FPAR
                                4093 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                                4098 RFM69:CSMA:RSSI=-105
                                4104 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                6113 !TSM:FPAR:NO REPLY
                                6115 TSM:FPAR
                                6117 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                                6121 RFM69:CSMA:RSSI=-106
                                6127 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                8136 !TSM:FPAR:FAIL
                                8138 TSM:FAIL:CNT=1
                                8140 TSM:FAIL:DIS
                                8142 TSF:TDI:TSL
                                8142 RFM69:RSL
                                18145 TSM:FAIL:RE-INIT
                                18147 TSM:INIT
                                18149 RFM69:INIT
                                18151 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                18155 RFM69:PTX:LEVEL=5 dBm
                                18157 TSM:INIT:TSP OK
                                18161 TSM:INIT:STATID=42
                                18163 TSF:SID:OK,ID=42
                                18165 TSM:FPAR
                                18167 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                                18173 RFM69:CSMA:RSSI=-107
                                18180 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                20189 !TSM:FPAR:NO REPLY
                                20191 TSM:FPAR
                                20193 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                                20197 RFM69:CSMA:RSSI=-103
                                20203 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                22212 !TSM:FPAR:NO REPLY
                                22214 TSM:FPAR
                                22216 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                                22220 RFM69:CSMA:RSSI=-105
                                22226 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                24236 !TSM:FPAR:NO REPLY
                                24238 TSM:FPAR
                                24240 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                                24244 RFM69:CSMA:RSSI=-109
                                24250 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                26259 !TSM:FPAR:FAIL
                                26261 TSM:FAIL:CNT=2
                                26263 TSM:FAIL:DIS
                                26265 TSF:TDI:TSL
                                26267 RFM69:RSL
                                36270 TSM:FAIL:RE-INIT
                                36272 TSM:INIT
                                36274 RFM69:INIT
                                36276 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                36280 RFM69:PTX:LEVEL=5 dBm
                                36282 TSM:INIT:TSP OK
                                36286 TSM:INIT:STATID=42
                                36288 TSF:SID:OK,ID=42
                                36290 TSM:FPAR
                                36292 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                                36298 RFM69:CSMA:RSSI=-105
                                36304 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                38316 !TSM:FPAR:NO REPLY
                                38318 TSM:FPAR
                                38320 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                                38324 RFM69:CSMA:RSSI=-105
                                38330 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                40339 !TSM:FPAR:NO REPLY
                                40341 TSM:FPAR
                                40343 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                                40347 RFM69:CSMA:RSSI=-102
                                40353 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                42362 !TSM:FPAR:NO REPLY
                                42364 TSM:FPAR
                                42366 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                                42371 RFM69:CSMA:RSSI=-104
                                42377 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                44386 !TSM:FPAR:FAIL
                                44388 TSM:FAIL:CNT=3
                                44390 TSM:FAIL:DIS
                                44392 TSF:TDI:TSL
                                44394 RFM69:RSL
                                54398 TSM:FAIL:RE-INIT
                                54401 TSM:INIT
                                54403 RFM69:INIT
                                54405 RFM69:INIT:PIN,CS=10,IQP=2,IQN=0
                                54409 RFM69:PTX:LEVEL=5 dBm
                                54411 TSM:INIT:TSP OK
                                54415 TSM:INIT:STATID=42
                                54417 TSF:SID:OK,ID=42
                                54419 TSM:FPAR
                                54421 RFM69:SWR:SEND,TO=255,SEQ=0,RETRY=0
                                54427 RFM69:CSMA:RSSI=-105
                                54433 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                56442 !TSM:FPAR:NO REPLY
                                56444 TSM:FPAR
                                56446 RFM69:SWR:SEND,TO=255,SEQ=1,RETRY=0
                                56451 RFM69:CSMA:RSSI=-104
                                56457 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                58466 !TSM:FPAR:NO REPLY
                                58468 TSM:FPAR
                                58470 RFM69:SWR:SEND,TO=255,SEQ=2,RETRY=0
                                58474 RFM69:CSMA:RSSI=-104
                                58480 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                60489 !TSM:FPAR:NO REPLY
                                60491 TSM:FPAR
                                60493 RFM69:SWR:SEND,TO=255,SEQ=3,RETRY=0
                                60497 RFM69:CSMA:RSSI=-102
                                60504 ?TSF:MSG:SEND,42-42-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                62513 !TSM:FPAR:FAIL
                                62515 TSM:FAIL:CNT=4
                                62517 TSM:FAIL:DIS
                                62519 TSF:TDI:TSL
                                62521 RFM69:RSL
                                72525 TSM:FAIL:RE-INIT!
                                • W willemx
                                  log:
                                  119 TSF:LRT:OK
                                  135 TSM:INIT
                                  148 TSF:WUR:MS=0
                                  166 RFM69:INIT
                                  scandone
                                  state: 0 -> 2 (b0)
                                  state: 2 -> 3 (0)
                                  state: 3 -> 5 (10)
                                  add 0
                                  aid 3
                                  cnt
                                  503 TSM:FAIL:CNT=1
                                  523 TSM:FAIL:DIS
                                  540 TSF:TDI:TSL
                                  557 RFM69:RSL
                                  pm open,type:2 0
                                  10597 TSM:INIT
                                  10612 RFM69:INIT
                                  10781 TSM:FAIL:DIS
                                  10801 TSF:TDI:TSL
                                  10820 RFM69:RSL
                                  20862 TSM:INIT
                                  20877 RFM69:INIT
                                  21047 TSM:FAIL:DIS
                                  21066 TSF:TDI:TSL
                                  21085 RFM69:RSL
                                  31127 TSM:INIT
                                  31142 RFM69:INIT
                                  31312 TSM:FAIL:DIS
                                  31332 TSF:TDI:TSL
                                  31350 RFM69:RSL
                                  41392 TSM:INIT
                                  41407 RFM69:INIT
                                  41577 TSM:FAIL:DIS
                                  41596 TSF:TDI:TSL
                                  41615 RFM69:RSL
                                  51657 TSM:INIT
                                  51672 RFM69:INIT
                                  51842 TSM:FAIL:DIS
                                  51861 TSF:TDI:TSL
                                  51880 RFM69:RSL
                                  61922 TSM:INIT
                                  61937 RFM69:INIT
                                  62107 TSM:FAIL:DIS
                                  62126 TSF:TDI:TSL
                                  62145 RFM69:RSL
                                  122188 TSM:INIT
                                  122204 RFM69:INIT
                                  122380 TSM:FAIL:DIS
                                  122401 TSF:TDI:TSL
                                  122421 RFM69:RSL
                                  182464 TSM:INIT
                                  182480 RFM69:INIT
                                  182656 TSM:FAIL:DIS
                                  182677 TSF:TDI:TSL
                                  182697 RFM69:RSL
                                  242741 TSM:INIT
                                  242757 RFM69:INIT
                                  242933 TSM:FAIL:DIS
                                  242954 TSF:TDI:TSL
                                  242974 RFM69:RSL
                                  303017 TSM:INIT
                                  303033 RFM69:INIT
                                  303209 TSM:FAIL:DIS
                                  303230 TSF:TDI:TSL
                                  303250 RFM69:RSL
                                   __  __       ____
                                          |___/                      2.3.2
                                  28 TSM:INIT
                                  28 TSF:WUR:MS=0
                                  30 RFM69:INIT
                                  38 TSM:INIT:TSP OK
                                  45 TSF:SID:OK,ID=42
                                  47 TSM:FPAR
                                  2068 TSM:FPAR
                                  4091 TSM:FPAR
                                  6115 TSM:FPAR
                                  8136 !TSM:FPAR:FAIL
                                  8138 TSM:FAIL:CNT=1
                                  8140 TSM:FAIL:DIS
                                  8142 TSF:TDI:TSL
                                  8142 RFM69:RSL
                                  18147 TSM:INIT
                                  18149 RFM69:INIT
                                  18165 TSM:FPAR
                                  20191 TSM:FPAR
                                  22214 TSM:FPAR
                                  24238 TSM:FPAR
                                  26263 TSM:FAIL:DIS
                                  26265 TSF:TDI:TSL
                                  26267 RFM69:RSL
                                  36272 TSM:INIT
                                  36274 RFM69:INIT
                                  36290 TSM:FPAR
                                  38318 TSM:FPAR
                                  40341 TSM:FPAR
                                  42364 TSM:FPAR
                                  44390 TSM:FAIL:DIS
                                  44392 TSF:TDI:TSL
                                  44394 RFM69:RSL
                                  54401 TSM:INIT
                                  54403 RFM69:INIT
                                  54419 TSM:FPAR
                                  56444 TSM:FPAR
                                  58468 TSM:FPAR
                                  60491 TSM:FPAR
                                  62517 TSM:FAIL:DIS
                                  62519 TSF:TDI:TSL
                                  62521 RFM69:RSL
                                  T Offline
                                  T Offline
                                  tekka
                                  wrote on last edited by tekka
                                  @willemx said in Need help with ESP8266 MQTT Gateway (RFM69HW radio):
                                  There is a problem with the rfm69 module and/or wiring on your GW - can you exchange the rfm69 module with the one from the node and post the logs?
                                  • W Offline
                                    W Offline
                                    willemx
                                    :tada: :tada: :tada:
                                    You were right; there was a minuscule piece of wire strand between two contacts and after removing it all is fine now.
                                    Also checked all the radio's again which is easy now I have a working configuration and there was indeed one defective radio module.
                                    Thanks everyone for unblocking me!
                                    • W willemx
                                      T Offline
                                      T Offline
                                      tekka
                                      @willemx Excellent! Have fun! :+1:
