  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.4k Views 69 Watching
  • badmannenB badmannen
    I just add another note to myself ( And anyone else that lost their hair wondering why the bootloader was lost....)
    DO NOT UPLOAD SKETCH ONLY WITH USBASP ... it deletes the bootloader .
    yes I know it is mentioned on the foru m.. just found it .. but I mention it again...
    badmannenB
    badmannenB
    badmannen
    @badmannen
    and here is a good simple explanation of the fuses
    http://www.martyncurrey.com/category/atmega/
    rPi 3 - UNO R3 - Mini - Nano - custom
      FYI: If you run the ceramic resonator at 8mhz, with the zero wake up fuse setting, you can wake the atmega328p up in less than 4usec. This is a huge power savings compared to all other options.
      badmannenB 1 Reply Last reply
        badmannenB
        badmannenB
        badmannen
        @neverdie aa thanks for the info. Might be useful for some other nodes I will do.
          #487
          @badmannen You're welcome. I even measured it on an oscope just to be sure, so I'm certain it is true.
          • badmannenB
            badmannenB
            badmannen
            This style?
            € 1,09 8%OFF | 20pcs Ceramic Resonators ZTT 4M 6M 8M 10M 12M 16M 4/6/8/10/12/16MHZ DIP-3 Crystal Frequency Element
            https://s.click.aliexpress.com/e/mRfXWk8Nd
              This style?
              @badmannen no. It's built in. You already have it.
                badmannenB
                badmannenB
                badmannen
                @neverdie aa ok sorry got confused there for a second. I'm running the internal, so I guess I will pop them off again now then and burn that fuse for a quicker startup 👍🏻
                  @badmannen yes, it must be the internal resonator.
                  • Grzegorz BG
                    Grzegorz BG
                    Grzegorz B
                    Hello, will there be a good soul that will help improve the program? I know what the error is but I have no idea how to correct it.
                      interruptReturn = sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, ONE_DAY_SLEEP_TIME);
                    when i change
                    PRIMARY_BUTTON_PIN
                    the interruptReturn = 1, but when i change
                    the interruptReturn = 0.
                    My question is how can i chane it to send 1 and 1 by both contactrons.
                    Full code:
                    #define MY_NODE_ID 100
                    #define MY_PARENT_NODE_ID 0
                    #include "Vcc.h"
                    #define SKETCH_NAME "WindowSlimSensor2pcs_smallR"
                    #define PRIMARY_CHILD_ID 1
                    #define PRIMARY_BUTTON_PIN 2
                    #define SECONDARY_CHILD_ID 2
                    #define SECONDARY_BUTTON_PIN 3
                    #define BATTERY_REPORT_DAY 2   // Desired heartbeat interval when inactive. Maximum heartbeat/report interval is equal to this due to the dayCounter.
                    #define BATTERY_REPORT_BY_IRT_CYCLE 10  // Adjust this according to usage frequency.
                    #define ONE_DAY_SLEEP_TIME 86400000
                    //#define BATTERY 3
                    //MyMessage msg3(BATTERY, V_CUSTOM);
                    int dayCounter = 0;
                    int irtCounter = 0;
                    bool interruptReturn=false;
                    const float VccMin   = 1.7;           // Minimum expected Vcc level, in Volts.
                    const float VccMax   = 3.3;           // Maximum expected Vcc level, in Volts.
                    const float VccCorrection = 3.43 / 3.455;  // Measured Vcc by multimeter divided by reported Vcc
                    const int32_t report_interval = 8640000; // 1day -> h * m * s * ms NOTICE: milliseconds, not microseconds!
                    Vcc vcc(VccCorrection);
                    //Vcc vcc;
                    #ifdef MY_DEBUG
                    void before(){
                        Serial.begin(9600);
                          //EXTERNAL pull-ups
                        digitalWrite(PRIMARY_BUTTON_PIN, LOW);
                        digitalWrite(SECONDARY_BUTTON_PIN, LOW);
                        sendSketchInfo(SKETCH_NAME, __DATE__);
                        present(PRIMARY_CHILD_ID, S_DOOR, "Lewe Okno");
                        present(SECONDARY_CHILD_ID, S_DOOR, "Prawe Okno");
                      //  present(BATTERY, S_CUSTOM);
                        uint8_t reedState;
                        uint8_t reedState2;
                        static uint8_t lastReedState = 2;
                        static uint8_t lastReedState2 = 2;
                        sleep(5); // Short delay to allow buttons to properly settle
                        reedState = digitalRead(PRIMARY_BUTTON_PIN);
                        reedState2 = digitalRead(SECONDARY_BUTTON_PIN);
                      if (!interruptReturn) { // Woke up by timer (or first run)
                        dayCounter++;
                        if (dayCounter >= BATTERY_REPORT_DAY) {
                              dayCounter = 0;
                              sendBatteryReport();
                      else {    // Woke up by pin change
                                irtCounter++;
                            sleep(5);
                          if (reedState != lastReedState) {
                            send(msg.set(reedState==HIGH ? 1 : 0));
                            lastReedState = reedState;
                          if (reedState2 != lastReedState2) {
                            send(msg2.set(reedState2==HIGH ? 1 : 0));
                            lastReedState2 = reedState2;
                          if (irtCounter>=BATTERY_REPORT_BY_IRT_CYCLE) {
                            irtCounter=0;
                      // Sleep until something happens with the sensor,   or one sleep_time has passed since last awake.
                    void sendBatteryReport() {
                              uint8_t batteryPercent = (uint8_t)vcc.Read_Perc(VccMin, VccMax);
                    • Grzegorz BG Grzegorz B
                      when i change
                      PRIMARY_BUTTON_PIN
                      Full code:
                      #include "Vcc.h"
                      //#define BATTERY 3
                      int dayCounter = 0;
                      int irtCounter = 0;
                      //Vcc vcc;
                      #ifdef MY_DEBUG
                      void before(){
                          Serial.begin(9600);
                            //EXTERNAL pull-ups
                          uint8_t reedState;
                          uint8_t reedState2;
                          dayCounter++;
                                dayCounter = 0;
                                  irtCounter++;
                              sleep(5);
                              irtCounter=0;
                      Welcome to the forum @Grzegorz-B
                      Change
                      to
                      uint8_t interruptReturn= INTERRUPT_NOT_DEFINED;
                      and
                      to
                      if (interruptReturn== MY_WAKE_UP_BY_TIMER) { // Woke up by timer (or first run)
                      Documentation for the sleep function is available at https://www.mysensors.org/download/sensor_api_20#sleeping
                      Grzegorz BG 1 Reply Last reply
                        Change
                        to
                        and
                        to
                        Grzegorz BG
                        Grzegorz BG
                        Grzegorz B
                        @mfalkvidd Thanks! now its works like a charm :D
                        • K
                          K
                          kiesel
                          Has anybody succeeded Inn creating an rfm69 version of this?
                          caniqueC 1 Reply Last reply
                          • A
                            ar91
                            I built a Temp/Hum sensor using Slim Node few years back on Mys 1.5x and it was working for so long without any issues. Now I am trying to upgrade it to Mys 2.2x. I successfully loaded the bootloader on a new ATMEGA 328P-PU. Bootloader I used is minicore as recommended by @m26872 in his original post. I used the "Arduino as ISP" method to load the bootloader as explained in this tutorial How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5.
                            Here are the settings I used in my Arduino IDE when loading the bootloader,
                            • internal clock 8 Mhz ( again based on the recommendation from the original post)
                            • BOD disabled
                            • Compiler LTO disabled
                            • Variant "328P/328PA"
                            Bootloader Settings
                            Now I am trying to upload the temperature/Hum Sketch using FTDI cable with the jumper set at 3.3v, I am getting the "stk500_recv(): programmer is not responding" error. Here is how I am connecting from FTDI to Slimnode and the same configuration has worked originally when I built the node but now it is failing.
                            Could some experts in this forum please help me to bring my node back to work?
                            Sorry about the long post. Appreciate your help.
                            • K kiesel
                              caniqueC
                              caniqueC
                              canique
                              @kiesel do you mean a copy of the same project or something that does a similar job using an RFM69?
                                maddhin
                                this is an awesome project and after waiting for weeks to get all parts, I finally started building.
                                The problem I am facing is that it seems that I cannot get the board working if I use such a 8-pin connector socket. I am generally OK with NOT using such a socket for sensors that "go into production" but for some sensors where space is not an issue or for boards which I want to use for testing different NRF24s etc, I would like to make the socket work.
                                Does anybody have any tipps on how to make the radio reliably work with a socket? That would be awesome!
