  3. Pre-assembled sensor modules
31 Posts 8 Posters 3.8k Views 6 Watching
  • E echi
    Hi! thank you for the answers. I personally have the expertise and I am able to solder. I was thinking of people who just have basic or no knowledge about electronics. It is always a pain to get a working initial set up. In case of communication issue (which is always the case at the first try) you never know where it comes from. Is it the node? is it the gateway? is it hardware? is my code correct? is my power supply correct?
    So I've decided to design a minimalist board that embeds an ATMega328p low power and an nRF24L01p: just the bare minimum. The purpose is to provide a functional board that works for sure out of the box. Actually it is an Arduino Pro Mini fitted with a radio module. The pinout is 100% compatible with Arduino Pro Mini. Users won't have to spend time on assembling the parts and testing the radio, they can directly focus on their sensor.
    Design files are available here.
    I also created a kickstarter just to see. You can buy one or more units and support the project if you are interested.
    I don't know much about openhardware.io but I guess I can share my project there as well.
    tbowmoT
    tbowmoT
    tbowmo
    @echi nice product, but what about rf conformity of the radio? Is there any fcc / ce approval? It's not enough to just slam a radio chip on a board and sell it (unless you are a cheap Chinese eBay seller ;))
    That is one of the main reasons to why I did not incorporate the radio module with sensebender micro, as I do not need to make any radio measurements.
    /Thomas
    • E
      E
      echi
      thank you! this is a really good question. I now understand why you didn't incorporate the radio module. Is it the only reason? Have you investigated ways to certify a product? It is a pity if you can't incorporate the radio but we need to add extra modules that are probably not certified either. I am not willing to become a vendor (just providing a design and a few units). In that case, I don't think I need to make any measurements. Of course if one wants to go further in the industrialization process, it is a mandatory step.
      bjacobseB 1 Reply Last reply
      • E
        E
        echi
        tbowmoT 1 Reply Last reply
        • E echi
          bjacobseB
          bjacobseB
          bjacobse
          @echi Have you checked the price for getting the FCC and radio approvals? it's quite expensive. As it's mandatory to have an independent test company to do actual test on your devices as a part of the documentation. Furthermore you need also to get country approvals (Notified Body) for several countries where you want to sell you product, fortunately as I recall EU only requires approvals in 1 country to be valid in the rest of EU countries.
          This link is from 2014, but gives you an idea what kind of approvals that you MUST get prior selling your stuff
          https://www.quora.com/What-is-the-average-cost-to-get-FCC-and-CE-certification-for-a-very-simple-electronic-gadget?share=1
          • E echi
            tbowmoT
            tbowmoT
            tbowmo
            @echi the thing is, that if you design/sell a board with an radio incorporated, then you are obligated to get fcc certification (for the US), and other approvals for the rest of the world, as @bjacobse explains.
            But if you do not include the radio module, then it's not your problem if an end user use a cheap Chinese radio module together with your product.
            • E
              E
              echi
              So what do you think of the cheap radio modules? Are they certified? Some are sold by sellers based in Europe. Is all this illegal?
              tbowmoT bjacobseB 2 Replies Last reply
              • E echi
                tbowmoT
                tbowmoT
                tbowmo
                @echi for my part I'm not concerned about it, because I'm not the designer/seller of those modules. So if the notified bodies find that they are not compliant, then it's not me that they're gonna bug about it.
                It's all about responsibilities. I'm not making a radio module, so I'm not responsible for the rf part, and as such, they can't sue me for that part.
                / Thomas
                • E echi
                  bjacobseB
                  bjacobseB
                  bjacobse
                  @echi Basically it's quite simple, it's the whole device that needs to comply to the rules, and not ONLY the radio-part of your design.
                  so it's not possible to "buy" a radio approved RF IC and then add this to your own design, and then think this is adequate
                  • E
                    E
                    echi
                    I understand your point. But in the end almost everybody uses non certified radio parts. And a lot of users around here are frustrated because of the hardware issues due to bad radios. That means a lot of wasted time, also for the helpers.
                    tbowmoT Phil WhitmarshP 2 Replies Last reply
                    • E echi
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @echi We are just pointing out potential pitfalls if you are going to sell your pcb pre-assembled to the masses..
                      That is, if you are selling a PCB with radio on, then you are obligated to follow the rules and get the radio verified by a notified body.
                      • mfalkviddM
                        Congratulations on meeting your kickstarter goal @echi
                        • E echi
                          Phil WhitmarshP
                          Phil WhitmarshP
                          Phil Whitmarsh
                          @echi it's too expensive as you can get one from AliExpress a lot cheaper.
                          #Aliexpress £3.33 | Keywish RF-Nano for Arduino Nano V3.0, Micro USB Nano Board ATmega328P QFN32 5V 16M CH340, Integrate NRF24l01+2.4G wireless,Imme
                          https://a.aliexpress.com/_dYIhsQZ
                          A 1 Reply Last reply
                          • Phil WhitmarshP Phil Whitmarsh
                            alex28
                            @Phil-Whitmarsh said in Pre-assembled sensor modules:
                            Yeah and that one is guaranteed to be 100% counterfeit and 100% crap.
                            A module such as the OP designed would have really helped me when I attempted to setup MySensors (see my other thread). I definitely would have bought it. Simply because having a guaranteed functional module with guaranteed original components and certified RF performance is a great selling point. Who cares if it costs a few Euros more. How much do you value your time ? This obsession of always wanting to use the cheapest of cheap low quality stuff from China really puzzles me. You end up spending so much time with a barely functional setup just to save a few bucks. So that's a great initiative @echi .
                            About certification. This is obviously a must have. But I was under the impression that when all your RF circuitry (including PCB antenna, if any) is isolated on a separate third party module that was certified (like for example this one, they claim FCC certification in their specs), then you could use it in your own design without having to reapply for RF certification. Am I wrong ?
                            Phil WhitmarshP tbowmoT 2 Replies Last reply
                            • A alex28
                              Phil WhitmarshP
                              Phil WhitmarshP
                              Phil Whitmarsh
                              @alex28 This is the same seller I have used for many of my purchases AVR's, STM32F's etc. When you're buying hundreds it's not just a few bucks! AliExpress are really good, any issues and you get a refund in a couple of days.
                              I have only had a couple of issues with my hundreds of purchases over the years.
                              • A alex28
                                tbowmoT
                                tbowmoT
                                tbowmo
                                @alex28 It's always the complete product that you need to do certification on. It will probably be easier with a complete module, as the rfm69, but a lot of things can change the RF characteristics. For example the ground plane layout on your own board, chosen MCU, xtal frequency, decoupling etc. and firmware...
                                  @alex28 I agree with you about the "stupid" obsession of getting the cheaper stuff with low quality.
                                  @Phil-Whitmarsh you're confounding mini-Pro design (like the OP did) and nano design. RF-Nano is not a low power board
                                  About RF, this is simple actually, like tbowmo said RF certification (CE/FCC for example) depends on a design.
                                  That means module manufacturers certified their module for a very specific setup:
                                  • gnd size, shape of the board and layout, placement of the module, enclosure or not, etc
                                  • software used during the certification
                                  So as soon as you change one of these params, you'll lose RF certification because RF characteristics will change. Simple as that. Of course, if new design is compatible, it should be straitghtforward to re-certify the new design.
                                  Development boards (like the OP did) are in a "grey zone", regarding certifications, so for developments purposes.
                                  FCC is more strict than CE. With CE, you can easily certify your board if you're able to provide the documents and proof that your board is RF "green" (no bad harmonics etc) , well tuned, and that the firmware is compliant too.
                                  No idea if the OP tuned his board, or just used parts values from a reference schematic. But to me this looks like a development board with no guarantee for RF perf.
                                  • scalzS scalz
                                    alex28
                                    wrote on last edited by alex28
                                    #21
                                    @tbowmo @scalz
                                    Hmm, I'm not so sure about the certification requirements. I'm not a lawyer (and it might be best to consult with one in case of doubts if you want to market your own RF product), but as far as I understand the legalese, if you use an RF module with "Full Modular Certification", you are not required to apply for a RF compliance certification anymore. You are highly encouraged to do self-hosted RF testing. And other compliance testing / certification might still apply (mains voltage use, spurious digital emissions etc). This is for the FCC. EU regulations are probably similar / less restrictive.
                                    Here's an interesting document from SiLabs. Look at page 15, chapter 3.5.1.1:
                                    "3.5.1.1 How Do Customers use FMA?
                                    • No separate certification with the end product; just label the product and get instant access to the markets.
                                    • The host must be labelled that it includes a certified module.
                                    • An end product using a radio with full modular approval will not need radio certification testing if the restrictions mentioned in themodule grant are met."
                                    They do mention that the module must adhere to certain characteristics to qualify, like a fully shielded RF part. So the RFM I linked to above will probably not work.
                                    Here's a document from the FCC outlining the recommended self-testing procedures, filing and product labeling requirements. Note chapter 3.1:
                                    "Testing of the host product with all the transmitters installed is recommended,to verify that the host product meets all the applicable FCC rules. The radio spectrum is to be investigated with all the transmitters in the final host product functioning to determine that no emissions exceed the highest limit permitted for any one individual transmitter as required by Section 2.947(f). A formal application for certification submission containing the results of this investigation is not required. The host manufacturer is responsible to ensure that when their product operates as intended it does not have any emissions present that are out of compliance that were not present when the transmitters were tested individually."
                                    So if you use pre approved modules, you do not need to re-certify. But you're legally responsible to make sure you're within the regulatory limits. You still need to file with them (and pay them) and label your product appropriatlty.
                                    At least that's what I could gather from quickly trying to parse the legalese :grinning:
                                    That said, the general certification processes, registration and filing fees, etc will still cost you a few thousand Dollars / Euros. But that's nothing compared to RF compliance testing when not using a pre-approved module, which can easily go into the 20k-30k range.
                                      #22
                                      @alex28
                                      I'm not saying we need to certify our homemade devices.
                                      Personnally I don't mind, but just try to make my devices with those constraints in mind.
                                      Certification also depends on firmware, on RF bands etc (CSMA, etc to not spam bands for subghz for example).
                                      Change some characterictics of pcb, gnd size etc, and it can untune center frequency of antenna for sure. Lot of examples in app notes.
                                      Though, from what you read, you can see the "host manufacturer is responsible", and should check by doing tests if it's compliant with his new design. That's what I read.
                                      Like I said, I'm pretty sure OP design is not certified, and maybe not even RF tuned.
                                      But as a development board, it's not a very big problem.
                                      And low range nrf24 is less problematic for regulations, than using a subghz module with untuned antenna (change gnd size, and you have to shorten or add length to antenna, else centerfreq is shifted), with a wrong fw spamming the band, unregulated TX power, or also when you add to the design some AC, relays etc which could introduce some noise (bad SNR etc) , like we can see sometimes in diy, + dupont cables which can acts like antennas too.
                                      • A
                                        Avamander
                                        Pretty sure Arduino wrote about their hassles getting an Arduino board with a radio out onto the market, even when using a module it was a hassle.
                                        I'm wondering though, wouldn't it be possible to sell a PCB that allows just plugging in every component?
                                        • scalzS scalz
                                          @alex28
                                          alex28
                                          #24
                                          @scalz I think you misunderstood my post. This is not about homemade devices, it's about commercial ones. And if I read the documents I linked to right, then the things you mentioned (firmware, PCB arrangements, etc) will not affect certification, as long as you strictly adhere to the application notes of the pre-certified module (ie. don't use it in a way that will make its certification break and don't modify it). As long as you follow those, you don't need to re-certify. You are however legally liable in case you mess up or do something you shouldn't (and you're supposed to self check it).
                                          I'm not sure how this relates to development boards. It might depend on what market you sell to. If you're B2B only, then you can probably sell uncertified modules and have your customers certify them. If you sell to the general consumers (and that probably includes DIY tinkerers), then things are not that simple. But that's just my gut feeling.
                                          @Avamander The OPs idea is a simple easy to use quickstart board for beginners. Requiring them to solder SMD components kinda goes against the whole point of it.
