  3. Weather station DHT22, BMP185, SI1145
dht22arduinobmp185pro minisi1145
9 Posts 7 Posters 9.9k Views 5 Watching
  • J Offline
    J Offline
    jesse
    wrote on last edited by jesse
    This project uses an Arduino pro mini 3.3v 8mhz. The power and pin 13 LEDs have been desoldered to save battery life. The battery used is a 18650 lithium and a single 18650 battery bank.
    XAMPP server: http://www.jbcse.com/weather-graph.php
    All sensors and the transceiver powered through an IRL520 mosfet. The Jeelib power library is used to make the arduino sleep for about 10 seconds which uses about 1 mA. Measuring takes about 2 seconds and uses 5 mA.
    Sensors used: DHT22, BMP185, SI1145
    Transceiver used: NRF24L01+
    R E 2 Replies Last reply
    • J jesse
      R Offline
      R Offline
      RJ_Make
      @jesse Nice work
      RJ_Make
      • J jesse
        E Offline
        E Offline
        epierre
        @jesse How do you make a difference between visible and IR light ?
        I've made a bit the same, I'm now working on soil mosture+temp and leaf moisture. The solar flare is missing to have a pro weather station...
        z-wave - Vera -> Domoticz
        J 1 Reply Last reply
        • E epierre
          J Offline
          J Offline
          jesse
          @epierre The SI1145 can measure IR, visible, and UV light: https://learn.adafruit.com/adafruit-si1145-breakout-board-uv-ir-visible-sensor/overview
          Y 1 Reply Last reply
          • J jesse
            Y Offline
            Y Offline
            @jesse said:
            SI1145
            This is a very nice sensor indeed! Didn't know about it.
            Think I'm gonna sample some.
            • D Offline
              doesel33
              Very interesting projekt. Can you show your sketch? I try to build nearly the same, but have some problems with SI1145.
              • Catalina AlquingaC Offline
                Catalina Alquinga
                Saludos disculpa como realizastes las coneciones del BMP185 Y EL SI1145
                A 1 Reply Last reply
                • Catalina AlquingaC Catalina Alquinga
                  A Offline
                  A Offline
                  AWI
                  Google translate from Spanish??:: Greetings apology as its connections realizastes the BMP185 AND SI1145
                  Catalina AlquingaC 1 Reply Last reply
                  • A AWI
                    Catalina Alquinga
                    @AWI
                    I 'm doing a similar project prodias help me make connections as your project and how to perform with I2C
