  3. Problems with Nano + W5100 (funduino) + NRF24L01 gateway - no access.
2 Posts 2 Posters 352 Views 2 Watching
  • pw44P
    pw44P
    pw44
    wrote on last edited by pw44
    i built the following:
    With the following code:
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_W5100
    //#define MY_W5100_SPI_EN 4
    // radio on the same spi bus.
    #define MY_SOFTSPI
    #ifndef MY_RF24_CE_PIN
    #define MY_RF24_CE_PIN 5
    #ifndef MY_RF24_CS_PIN
    #define MY_RF24_CS_PIN 6
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_IP_ADDRESS 192,168,80,15
    //#define MY_IP_GATEWAY_ADDRESS 192,168,80,1
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Note that most of the Arduino examples use  "DEAD BEEF FEED" for the MAC address.
    #define MY_MAC_ADDRESS 0x00, 0x40, 0xFD, 0xEF, 0x35, 0x76
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
    #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
    #define MY_DEFAULT_TX_LED_PIN  9  // Transmit led pin
    #if defined(MY_USE_UDP)
    #include <EthernetUdp.h>
    #include <Ethernet.h>
    Serial monitor shows:
    0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2
    4 TSM:INIT
    5 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    13 TSM:INIT:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0
    18 MCO:REG:NOT NEEDED
    642 GWT:TIN:IP=255.255.255.255
    1644 MCO:BGN:STP
    1646 MCO:BGN:INIT OK,TSP=1
    1648 TSM:READY:NWD REQ
    1653 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    Log parser shows:
    Node Id	Child Sensor	Command Type	Echo Req/Resp	Type	Payload	Description
    0 MCO:BGN:INIT GW,CP=RNNGA---,FQ=16,REL=255,VER=2.3.2	Core initialization of GW, with capabilities RNNGA---, CPU frequency 16 MHz, library version 2.3.2, release 255
    4 TSM:INIT	Transition to Init state
    5 TSF:WUR:MS=0	Wait until transport ready, timeout 0
    12 TSM:INIT:TSP OK	Transition to Init state:TSP OK
    13 TSM:INIT:GW MODE	Transition to Init state:GW MODE
    15 TSM:READY:ID=0,PAR=0,DIS=0	Transport ready, node id 0, parent node id 0, distance to GW is 0
    18 MCO:REG:NOT NEEDED	No registration needed (i.e. GW)
    Unknown	642 GWT:TIN:IP=255.255.255.255
    1644 MCO:BGN:STP	Callback setup()
    1646 MCO:BGN:INIT OK,TSP=1	Core initialized, transport status 1, (1=initialized, 0=not initialized, NA=not available)
    1648 TSM:READY:NWD REQ	Send transport network discovery request
    1653 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:	Sent Message without radio ACK
    Sender: 0
    Last Node: 0
    Next Node: 255
    Destination: 255
    Sensor Id: 255
    Command: INTERNAL
    Message Type:I_DISCOVER_REQUEST
    Payload Type: P_STRING
    Payload Length: 0
    Signing: 0
    Failed uplink counter: 0
    Status: OK (OK=success, NACK=no radio ACK received)
    Payload:
    but nothing:
    • can't ping to it.
    • arp -a shows the address, but no the mac.
    ANy hint?
    • pw44P pw44
      #define MY_SOFTSPI
      4 TSM:INIT
      5 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      13 TSM:INIT:GW MODE
      1644 MCO:BGN:STP
      Log parser shows:
      Sender: 0
      Last Node: 0
      Next Node: 255
      Destination: 255
      Sensor Id: 255
      Command: INTERNAL
      Payload Length: 0
      Signing: 0
      Payload:
      but nothing:
      • can't ping to it.
      ANy hint?
      For some reason the Gateway uses IP=255.255.255.255 (which is not a valid IP address) instead of the one you specified.
      There is plenty of free ram after compiling the sketch, so ram shouldn't be a problem.
      There have been a few similar reports earlier. https://forum.mysensors.org/post/82366 seems to be the only one that has a suggested solution.
      Which version of the Arduino IDE and which AVR board version are you using?
