  3. !TSM:FPAR:NO REPLY
!TSM:FPAR:NO REPLY
14 Posts 5 Posters 1.7k Views 5 Watching
  • TRS-80T
    TRS-80T
    TRS-80
    wrote on last edited by TRS-80
    I have had weird things happen that were solved simply by pressing the reset button on the microcontroller. Maybe the radio and/or uC get powered in wrong order, I don't really know. I only discovered this on an otherwise already known working setup that all of a sudden couldn't find the parent for some weird reason. And you seem to already have done all the other basic trobleshooting stuff.
    If you are unsure about hardware, before throwing it away, perhaps run some of your units through ping pong sketch before even loading MySensors. I made a detailed post about evidence based testing here. It can eliminate some doubt, at least it did for me.
    EDIT: As an alternative / in addition to "moving them apart" you can also set the MY_RF24_PA_LEVEL to MIN or LOW if you are testing close to the gateway. I have done this and sometimes it actually improves communication. Remember it is set to HIGH by default. Do so by putting following near top of your sketch:
    DuPont wires can also be bad, or have bad connections...
    If you are using breadboard and/or multiple power supplies, make sure all grounds are tied together...
    I think that covers most of basic stuff?
    • BearWithBeardB
      BearWithBeardB
      BearWithBeard
      @MisterMel said in !TSM:FPAR:NO REPLY:
      I also have an Arduino Nano hooked up to another NRF24 of the same type, but it has !TSM:FPAR:NO REPLY messages in the Serial console
      Are you powering the NRF24 PA-LNA module directly from the 3V3 pin of the Nano? The Nano doesn't have a dedicated voltage regulator for 3.3V on board. 3.3V are provided through an LDO integrated into the USB-UART controller. If it's a genuine FTDI, it can provide up to 50 mA, but if your Nano is a Chinese clone, it's more likely that they are using a CH340 or something like that. This chip may be able to deliver 25 mA or so and might not be able to regulate larger loads properly, which could cause a lot of noise on the 3.3V line - something that NRF24 transceivers don't like at all. Besides that, those black PA-LNA modules may draw up to 150 mA during transmission, which would be far out of spec on higher PA levels and may permanently damage the USB-UART controller.
      That could be the or a reason why your Nano node doesn't seem to be able to reach the GW. Try hooking up a regulated 3.3V power source to the radio in this case.
      TRS-80T M 2 Replies Last reply
      • BearWithBeardB BearWithBeard
        TRS-80T
        TRS-80T
        TRS-80
        @BearWithBeard said in !TSM:FPAR:NO REPLY:
        I had to do a double take when I read this. Then I had to pull one of mine out, because I was sure I thought I saw a regulator on there. And sure enough, I have an AMS1117 right on the bottom side of the board, along with the CH340. And mine are cheap Chinese clones. I can take a pic if you like? So, does this mean that:
        1. Mine are different from the norm? Or,
        2. The Bear is perhaps mistaken?
        I am often impressed by your knowledge and attention to detail, @BearWithBeard, so I'm not sure which case would surprise me more. :D
        BearWithBeardB 1 Reply Last reply
        • TRS-80T TRS-80
          BearWithBeardB
          BearWithBeardB
          BearWithBeard
          @TRS-80 Well, thanks for the kind words - right or wrongly. ;)
          No, you're not wrong here. There is a voltage regulator - but you'll notice "5.0" written on it. The Nano (schematics of rev 3.2) will use it to get regulated 5V if you power it with 6 - 12V directly from the VIN pin.
          • TRS-80T
            TRS-80T
            TRS-80
            Aha! You are right! I never looked closely at the regulator before, but sure enough it says "5.0" on it!
            I learned something today... :)
            OK, I had always heard stuff along these lines (in vague terms) but never explained so explicitly and clearly:
            So, sorry for going offtopic a bit, but I couldn't help but wonder how much "regular" nRF24L01+ draw (especially since I sometimes power them directly from 3.3V on Nano). I guess I could look on the datasheet... Maximum I see there in section 5.1 Power Consumption (p. 14) is 13.5 mA (typical) for receiving at 2 Mbpsl however for the 250kbps that (I think?) MySensors is set at, it says 12.6 mA (typical). Of course clones could differ, but I still think I should be well within acceptable range, especially with supply caps that I always add to the radio... Anyway, something to be aware of for sure...
              MisterMel
              wrote on last edited by MisterMel
              @BearWithBeard Yep, the Arduino is a cheap Chinese clone. It definitely uses a CH340. I just ordered some 3.3v regulators as well. Both the new NRF's and the regulators should be arriving tomorrow.
              The new NRF's are the version without external antenna, so I guess they would probably also work without the regulator, but I'm going to try if I can get the ones with external antenna working with the regulator.
              I also ordered another Arduino Nano (still a clone though), so I'll try that if the regulator doesn't work.
              TRS-80T 1 Reply Last reply
              • M MisterMel
                TRS-80T
                TRS-80T
                TRS-80
                This is how I do my gateway with a Nano, and it has been flawless. Do note however that I am using a combination of capacitors which testing revealed were optimal for my setup. Prior to doing that, I did not have nearly as much success / reliability (as can be read in the thread)!
                • TRS-80T TRS-80
                  @TRS-80 if you wonder how much your nrf consumes, why don't you just measure it? https://forum.mysensors.org/topic/9178/nrf24doctor
                  • YveauxY Yveaux
                    TRS-80T
                    TRS-80T
                    TRS-80
                    @Yveaux,
                    Stop adding on to my list! :D
                    Nice piece of kit! I am sure I will build one sooner or later. It's like a much more portable, easier to use, and more feature filled implementation of my evidence based radio testing method. I even think I have all parts needed on hand (or on the way) already, except for the PCB.
                    Speaking of which, I saw some talk in that thread about PCB design over at GitHub, hopefully that is still available, as I did not see any page on Hardware section about nRF24doctor...?
                      MisterMel
                      It works now! I'm now using the NRF's without external antenna and I've added a AMS1117 3.3v regulator module to the node. The ones with external antenna still don't work, but the it will probably be fine without them.
                      • M MisterMel
                        TRS-80T
                        TRS-80T
                        TRS-80
                        I run all "regular" nRF24 radios, including the gateway, and it works well enough for me. My place is pretty small, but there are masonry walls and walls with metal studs that seem to cut down on range. I found putting the nodes up high on my walls helps a lot.
                        Glad to hear you got it working.
                        One more thing I wanted to re-iterate, for people coming along searching this topic later. I mentioned before, but keep experiencing this as I am working on some nodes the last couple days. Seems to me that fairly often actually, right after (re-)flashing and node boot up for first time on new software, I often get a lot of FPAR errors, which the node does not seem to come out of on it's own. But one or two resets (via on-board button) and then it starts working. Not sure what that is all about, or if others have experienced same, but I thought I would mention it again before people go nuts with other troubleshooting steps, and pulling their hair out. :wink:
