  3. Battery operated actuator
wirelessreceiverbattery
21 Posts 10 Posters 13.1k Views 11 Watching
    Great project. I also had the same thought to control my AC and TV but was afraid of power consumption and that I will be forced to power it from wall. But seems like the sleeping periods work great till now.
    I'll suggest that you implement in your project a technique to detect if anybody is at home or not, and if nobody is at home you can increase the sleeping time to wake every 1 or 2 mins or even more for example.
    R
    R
    riataman
    @ahmedadelhosni: A big part of me doing this project is for controlling the ACs when I'm not home (for example if I'm heading home and I want it to be warm/cool when I arrive). I can access the controlling UI from anywhere as long as I have internet. What I was thinking is that I can increase the sleep time during the night when I usually not sending commands.
    I think you can still improve my power consumption, the RF24 library has some delay() calls that could potentially be changed to sleep calls, or just don't do them at all since you'll be sleeping in another moment, would need careful review. Also my arduino pro mini is consuming a bit more current than what I have seen other archive, I never was able to figure out why, probably with a barebones Atmega328 board you can improve on those too.
    Another area that could use more research is the listening time, I'm listening for 15ms and that was the barely necessary in my test, but I kind of remember if you didn't sleep the radio you could get away with shorter listening times, that maybe end up using less power. Also I'm using the 250kbps transmission speed of the RF24 radio, if you go with the 2mbps the time to transmit a packet over the air maybe shorter, I'll be worth investigating that.
    I have two nodes that are connected to the wall and I have found that I don't really need them to be directly pointed to the AC, if you get very bright IR leds and drive them at full voltage/current the IR light will basically bounce in the whole room and that gives you a lot more flexibility in placement.
    The other bit that I have and that I forgot to post is a node that I wired in the switch box and is using current transformers and the EmonLib to monitor the current going to the AC units, that allows me to know if the AC is turned on or off, something very useful when I want to control them remotely. I'll try to post pictures of that tomorrow.
    • T
      ToniA
      @riataman, have you looked at this: https://github.com/mysensors/Arduino/tree/development/libraries/MySensors/examples/HeatpumpIRController, it's based on the HeatpumpIR library I've written? I just added a few new heatpump models yesterday and today into the library...
      Anyway, in my project I'm currently using Arduino Nano + NRF24. I placed this inside the indoor unit's covers, IR led next to the IR eye of the unit, and I even stole the power from the air conditioner, as its logic is running on +5V, which is conveniently the same as the operating voltage of the Nano :) Of course I can't recommend anybody to do that :)
      I just got some Sensebenders this week, so I'm trying to build a way smaller device for the other A/C unit I have.
      R 1 Reply Last reply
      • T ToniA
        R
        R
        riataman
        @ToniA Tony that's way cool and very similar what I'm doing. The split units that I have are GE and Whirlpool. I don't see you having support for those in HeatpumpIR, I hope to find the time to publish my analysis of their protocol (I only decoded it partially, those have long sequences to maintain time/timers but I just hard coded that).
        I was thinking about tapping into the condenser, specially to see if I could find a better way to detect if the unit was on since the indirect method of measuring the current going to the unit has some drawbacks (when the unit is in heat mode and it reaches the target temperature the current that it draws is the same as when its off, so there's no way to tell on/off state at that point).
        At the end I decided against fiddling with the unit itself since my wife wouldn't be very happy if I broke it.
        What kind of UI do you use to control the units? I'm really not using any MySensors code/controllers at all, everything I have is written from scratch (minus sensors libraries) .
        • T
          ToniA
          This is what I'm using as the control interface: http://www.domoticz.com/forum/viewtopic.php?f=34&t=7179#p69647
          It's still under work, but I should be able to have events running on Domoticz, like turn on the A/C if it gets too hot inside the house etc.
          • blaceyB
            blaceyB
            blacey
            I have been looking into battery operated actuators and thinking that the RFM69 radio with its unique low-power listen mode may be the way to go. @tbowmo has created an NRF24L01+ to RFM69HW adapter that provides a fairly seamless integration https://www.openhardware.io/view/16/NRF2RFM69. Here is an excerpt from the RMF69 data sheet, page 39
            4.3. Listen Mode
            The circuit can be set to Listen mode, by setting ListenOn in RegOpMode to 1 while in Standby mode. In this mode, SX1231H spends most of the time in Idle mode, during which only the RC oscillator runs. Periodically the receiver is woken up and listens for an RF signal. If a wanted signal is detected, the receiver is kept on and the data is demodulated. Otherwise, if a wanted signal hasn't been detected after a pre-defined period of time, the receiver is disabled until the next time period. This periodical Rx wake-up requirement is very common in low power applications. On SX1231H it is handled locally by the Listen mode block without using uC resources or energy.
            I don't have time to auger into this aspect of my project right now but want to share it with you guys because it may be a via path to drive power down to something feasible for battery operated actuators. The forthcoming gateway will include pads for an RFM69HW radio so I am giving the RFM69HW serious consideration for my battery actuator projects.
            • R
              R
              riataman
              wrote on last edited by riataman
              Since some people people have found this useful I'm posting an update. Six months have passed and I'm very happy with the results. The nodes using the 4 second sleep are barely now into the nominal voltage of two AA batteries (3V) and I think those can last a copule of years like that.
              The 2 second sleep node is dipping a lot faster, but I suspect that the cause is the Si7021 taking readings every 3minutes that is accelerating the decline, even then I think this one could almost make it to a year.
              • O
                O
                ozrex
                @riataman, any chance you could share the hardware and software used in your project? I'm looking to build a battery operated A/C controller.
                TRS-80T 1 Reply Last reply
                • O ozrex
                  TRS-80T
                  TRS-80T
                  TRS-80
                  wrote on last edited by TRS-80
                  @ozrex,
                  Welcome to the forums.
                  Looks like OP was "Last Online 1 Dec 2019" according to his profile, also this thread itself is quite old. He may or may not return to reply.
                  In case he doesn't, it looks to me (I only scanned the thread) that he was using standard Arduino Pro Mini + nRF24 radios, although with some more custom code he implemented (which can be found in the thread). There was some discussion about nRFM69, but that seems more "WIP" to me and would require following some of the links in the thread and doing more research.
                  Or did you mean the A/C interface part? That would depend on how your A/C is controlled (433mhz? wires? etc.). Need more info there.
                  O 1 Reply Last reply
                  • TRS-80T TRS-80
                    @ozrex,
                    O
                    O
                    ozrex
                    @TRS-80 Thanks for your reply. My A/C is infra-red. I'll take a further look and see how I go. Thanks again!
                    • O ozrex
                      TRS-80T
                      TRS-80T
                      TRS-80
                      @ozrex,
                      I don't want to assume your knowledge level. However the truth is that you will probably need to put together different bits and pieces from various threads in order to come up with your own custom solution (the A/C interface (IR) part, the battery part, etc...).
                      Maybe it is worth it to create your own new thread, or maybe you want to keep researching / trying on your own a little longer first. The latter is admirable, and is the way I usually do it, too. Some times to a fault in my own case. :) Don't suffer along in silence if you are struggling to find the information, make a thread instead. If it becomes too difficult you may give up. We all need some small successes along the way to keep motivated and keep it fun. :)
                      Probably best to create a new thread (I don't want to derail this one too much) but something you might want to look into is OpenMQTTGateway. I use it for my 433mhz, but it also supports RF, BLE, LoRa (and perhaps others in future) all on the same gateway! To me that was the way to go... And so far has been flawless for me.
