  3. NRF24L01+ and NRF24L01+PA-LNA problems - testing in progress
11 Posts 7 Posters 1.6k Views 8 Watching
  • pw44P
    pw44P
    pw44
    wrote on last edited by pw44
    Hi all,
    i found this link:
    https://medium.com/@alencarrebeca/working-with-nrf24l01-communicating-with-nrf24l01-pa-na-b1466b4f3223
    It seams to explain some of the problems i'm having.
    Can anyone confirm this?
    Thank you in advance.
    pw44P 1 Reply Last reply
    • pw44P pw44
      Hi all,
      i found this link:
      pw44P
      pw44P
      pw44
      @pw44 - well, today i dismantled both gateways and built the ESP8266 (Wemos D1 mini) with NRF24L01+ (board antenna) and a sensor (door) with a nano v3 with NRF24L01+ (board antenna).
      working with no problem until now.
      seams that NRF24L01+ (board antenna) to NRF24L01+ PA LNA does not work as expected......
      Will continue testing and post the results.
      • monteM
        monteM
        monte
        I have NRF24L01 PA LNA on my gateway and plain NRF24L01+ on my nodes for years. No problem with compatibility between them. You might just have faulty PA LNA module.
        • monteM monte
          pw44P
          pw44P
          pw44
          @monte thx for your answer.
          which kind of gateway do you have? serial, rj45 or wifi?
          the problem i had with all 4 NRF24L01 PA LNA i have.
          monteM 1 Reply Last reply
          • pw44P pw44
            monteM
            monteM
            monte
            wrote on last edited by monte
            @pw44 I have two different setups with Raspberry Pi gateways. One uses black noname PA LNA with external antenna, the other one uses Ebyte E01-ML01SP4 with antenna on a pigtail.
            You can try shielding PA LNA modules with some aluminium foil and electrical tape. And don't forget about proper filtering of the power rail with big enough caps, and/or changing power supply to see if it makes any difference.
            • W
              W
              wiredfrank
              i always had problem with that nrf pa lna, i suggest to get this one nRF24L01 PA LNA from Aliexpress
              and thank me later. those type you have in your link are nothing but problem, i have few if anyone wants let me know pay me shipping and they are yours.
              mfalkviddM markjgabbM 2 Replies Last reply
              • W wiredfrank
                @wiredfrank could you expand on which link you are referring to? Where is the link shown? I can't find it.
                • W wiredfrank
                  markjgabbM
                  markjgabbM
                  markjgabb
                  @wiredfrank 100% agree. Dodgy antennas have been the bane of my existence with mysensors. When needing the long range. DO. NOT. CHEAP. OUT.
                  • alowhumA
                    alowhumA
                    alowhum
                    What @wiredfrank said. Don't use these unshielded PA device in the first place.
                    • W
                      W
                      wiredfrank
                      @mfalkvidd i was referring to un-shielded NRF24L01+PA-LNA radio modules. for me they never worked and even those ones worked had very power reception even in same room.
                      • G
                        G
                        grumpazoid
                        wrote on last edited by grumpazoid
                        I have two cheapo ebay NRF24L01+PA+LNA. As has been posted elsewhere nearly all are fake. I only use one at a time for my gateway. I had to do lots of fiddling to get them to communicate with my nodes . This included shielding and using an aluminium plate as a ground plane (someone criticized this but it worked for me). Ive posted about it somewhere on here. More recently I took delivery of a shielded Ebyte module and it has worked great. I have loads of the cheap NRF24L01+ modules in my nodes. Some I have added 12.5cm antennas and some dipole antennas. It does make a difference if drop outs are a problem on the more distant ones.
                        Raspberry Pi 3B - Domoticz + Node Red
                        Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
                        Arduino Mega, RFLink 433Mhz
                        Sonoff/ESP8266/Tasmota switches
