  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.3k Views 26 Watching
  • Nca78N Nca78
    @idanronen this is a UART to BT module, and from what I understand in the documentation the CP2102 is only here to give you access to the serial port of the module, but not to program it ?
    To program it you will have to use the SWDIO/SWDCLK pins I suppose, and I'm interested to know if it can be reprogrammed because that would make a tiny NRF52832 module for boards that don't require many IOs.
    I
    I
    idanronen
    @Nca78 I feared that might be the case. my task for today was to dig up my st-link and try that, though I hoped I might have done something wrong and the cp2102 can be used to program and not just debug.
    That module is pretty cheap and from what I see with the naked eye, you can disconnect the cp2102 with the jumpers so the power consumption might actually be good enough to use as-is.
    I'll report back to let you know once I've succeeded
    • A
      Avamander
      wrote on last edited by Avamander
      #49
      I tried flashing MySensors onto my nRF52840 Adafruit Feather board but it fails, I opened an issue on GH about it https://github.com/mysensors/MySensors/issues/1424, maybe someone here has any ideas how to get it running on those boards?
      • Nca78N Nca78
        I
        I
        idanronen
        wrote on last edited by idanronen
        #50
        @Nca78 no luck with the st-link v2, though i doubt it is related to the board, but rather my inability. i've tried every option in zadig, installed the st-link driver from their website, and nothing works.
        i get this in arduino ide:
        debug_level: 0
        0x4000
        adapter speed: 10000 kHz
        Error: init mode failed (unable to connect to the target)
        in procedure 'program'
        in procedure 'init' called at file "embedded:startup.tcl", line 473
        in procedure 'ocd_bouncer'
        ** OpenOCD init failed **
        shutdown command invoked
        the selected serial port
        • N
          N
          ncollins
          With all the NRF52 modules from EBYTE I've tried, the only way I can flash them is over SWDIO, SWCLK, GND, VCC via JLink clone.
          And, before flashing is possible, I have to unlock the module by following these directions: https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
          I 1 Reply Last reply
          • N ncollins
            I
            I
            idanronen
            @ncollins I've been working on turning an stm32f030f4p6 into a blackmagic probe for a few days now. Hit a wall when the compiled firmware came out to 83kb which is over the 64kb on board. Found someone who shrunk it down so it'd fit, and someone claiming it has another 64kb which can be unlocked. I'm just looking for the patience to get back in there, as this whole thing has been a major ordeal
            • I
              I
              idanronen
              Im not sure my flashing with the blackmagic even does anything. The console is unclear:
              Sketch uses 3556 bytes (0%) of program storage space. Maximum is 409600 bytes.
              Remote debugging using \\.\COM11
              Target voltage: ABSENT!
              Available Targets:
              No. Att Driver
               1      Nordic nRF52 M3/M4
               2      Nordic nRF52 Access Port
              Attaching to Remote target
              0xfffffffe in ?? ()
              Reading symbols from nrf1.ino.elf...done.
              Loading section .text, size 0xde4 lma 0x1c000
              Loading section .ARM.exidx, size 0x8 lma 0x1cde4
              Loading section .data, size 0x78 lma 0x1cdec
              Start address 0x1c578, load size 3684
              Transfer rate: 33 KB/sec, 614 bytes/write.
              Temporary breakpoint 1 at 0x1cb8c: file C:\Users\....\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.6.0\cores\nRF5\main.cpp, line 28.
              Starting program: C:\Users\....\AppData\Local\Temp\arduino_build_366086\nrf1.ino.elf
              Note: automatically using hardware breakpoints for read-only addresses.
              Program received signal SIGSEGV, Segmentation fault.
              0x00000000 in ?? ()
              Program complete!
              and i dont see any serial debug information
              • BearWithBeardB
                BearWithBeardB
                BearWithBeard
                wrote on last edited by BearWithBeard
                #54
                I just got my first NRF5 running. I'll note how I got it working in case any of you guys still have troubles:
                Setup
                • OS: Windows 10
                • Programmer: STM32 Blue Pill with the Black Magic Probe firmware
                • NRF5: EByte E73-TBB dev board with a E73-2G4M0S1B (NRF52832)
                • Environment: PlatformIO
                Instructions
                Load the Black Magic Probe firmware with stlink as the probe host onto Blue Pill. You can follow this guide.
                Connect your new BMP to the NRF52 module:
                BMP NRF52 Serial Port
                3V3 3V3
                GND GND
                A5 SWDCLK GDB Server
                B14 SWDIO GBD Server
                A2 RXI UART
                A3 TXO UART
                Note: A2 and A3 are not required for programming. This is how you'd wire up the BMP for "classic" serial debugging. You can use the BMP both for programming and serial communication - no need for a second FTDI module.
                Using the GNU Arm Embedded Toolchain, run arm-none-eabi-gdb in a console and enter the following commands to unlock the NRF52:
                target extended-remote BMP_GDB_SERVER_PORT
                mon swdp_scan
                attach N // N = number of "Nordic nRF52 Access Port" if there are several
                mon erase_mass
                detach
                From the two serial ports the BMP provides, you want to use the GDB Server for BMP_GDB_SERVER_PORT above. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should (usually) be the right choice. If not, try the other one.
                Windows users also must prefix the port with \\.\ if the number is double-digit, e.g. \\.\COM13.
                Now you can start uploading sketches the usual way. Here's my minimal PlatformIO config:
                [env:nrf52_dk]
                platform = nordicnrf52
                board = nrf52_dk
                board_build.variant = generic
                framework = arduino
                upload_protocol = blackmagic
                lib_deps =
                	548 ; MySensors
                And a minimal test sketch for MySensors:
                #include <Arduino.h>
                #define LED 17
                #define MY_RADIO_RF24
                #define MY_RADIO_NRF5_ESB
                #define MY_NODE_ID 182
                #define SKETCH_NAME "NRF52 Test"
                #define SKETCH_VERSION "0.1"
                #define CHILD_ID 1
                MyMessage msg(CHILD_ID, V_VAR1);
                  present(CHILD_ID, S_CUSTOM);
                  pinMode(LED, OUTPUT);
                  static uint8_t num;
                  send(msg.set(num));
                  ++num;
                  digitalWrite(LED, HIGH);
                  wait(5000);
                  digitalWrite(LED, LOW);
                  wait(5000);
                Works like a charm so far! Now, if you please excuse me, I have a whole new microprocessor family to explore. Fun times!
                nagelcN Ikes 72000I I electrikE 4 Replies Last reply
                • BearWithBeardB BearWithBeard
                  Setup
                  • OS: Windows 10
                  Instructions
                  3V3 3V3
                  GND GND
                  A2 RXI UART
                  A3 TXO UART
                  mon swdp_scan
                  mon erase_mass
                  detach
                  [env:nrf52_dk]
                  board = nrf52_dk
                  framework = arduino
                  lib_deps =
                  	548 ; MySensors
                  #define LED 17
                  #define CHILD_ID 1
                    static uint8_t num;
                    send(msg.set(num));
                    ++num;
                    wait(5000);
                    wait(5000);
                  nagelcN
                  nagelcN
                  nagelc
                  @BearWithBeard said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                  From the two ports the BMP provides, you want to use the GDB Server. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should be the right choice.
                  Strangely, my BMP uses the higher port number as the GDB server and the lower one as the serial port. I think this is unusual since it is opposite of what most guides say to expect. So, try the higher one if the lower one doesn't work.
                    Setup
                    • OS: Windows 10
                    Instructions
                    3V3 3V3
                    GND GND
                    A2 RXI UART
                    A3 TXO UART
                    mon swdp_scan
                    mon erase_mass
                    detach
                    [env:nrf52_dk]
                    board = nrf52_dk
                    framework = arduino
                    lib_deps =
                    	548 ; MySensors
                    #define LED 17
                    #define CHILD_ID 1
                      static uint8_t num;
                      send(msg.set(num));
                      ++num;
                      wait(5000);
                      wait(5000);
                    Ikes 72000I
                    Ikes 72000I
                    Ikes 72000
                    Setup
                    • OS: Windows 10
                    Instructions
                    3V3 3V3
                    GND GND
                    A2 TX UART
                    A3 RX UART
                    mon swdp_scan
                    mon erase_mass
                    detach
                    [env:nrf52_dk]
                    board = nrf52_dk
                    framework = arduino
                    lib_deps =
                    	548 ; MySensors
                    #define LED 17
                    #define CHILD_ID 1
                      static uint8_t num;
                      send(msg.set(num));
                      ++num;
                      wait(5000);
                      wait(5000);
                    @BearWithBeard just thanks, this method just work fine.
                    But just need to use the hightest port number of the BMP.
                    • I idanronen
                      Does anyone know what settings I need to use for this development board with arduino ide?
                      Ebyte E104-BT5032A-TB
                      https://a.aliexpress.com/_dT5dMb8
                      It has a cp2102 on board which I have the driver for. I've installed the arduino ide nrf52 board, but I can't find a programmer, board, or any other settings which will let me flash it without a Java exception or a timeout. Maybe I need to set the jumpers differently but there's no documentation on that.
                      OTA works fine though.
                      @idanronen said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                      So, I have finally received mines, and I can program the SoftDevice on them using NRF52 DK and nRF Go Studio. The first time it tells be there is a readback protection and offers a "Recover" option that erases the chip and allows to use it as normal.
                      Now I'll try to see what IOs the MOD, WKP, DISC, LINK, DATA, RX, TX, RTS, CTS pins are connected to and that will make a nice little module for modules with limited space and low io pins requirements.
                      Great replacement for NRF51822-04 imho: similar surface, better chip, more IOs and similar low price.
                        Setup
                        • OS: Windows 10
                        Instructions
                        3V3 3V3
                        GND GND
                        A2 RXI UART
                        A3 TXO UART
                        mon swdp_scan
                        mon erase_mass
                        detach
                        [env:nrf52_dk]
                        board = nrf52_dk
                        framework = arduino
                        lib_deps =
                        	548 ; MySensors
                        #define LED 17
                        #define CHILD_ID 1
                          static uint8_t num;
                          send(msg.set(num));
                          ++num;
                          wait(5000);
                          wait(5000);
                        I
                        I
                        idanronen
                        #58
                        Setup
                        • OS: Windows 10
                        Instructions
                        3V3 3V3
                        GND GND
                        A2 TX UART
                        A3 RX UART
                        mon swdp_scan
                        mon erase_mass
                        detach
                        [env:nrf52_dk]
                        board = nrf52_dk
                        framework = arduino
                        lib_deps =
                        	548 ; MySensors
                        #define LED 17
                        #define CHILD_ID 1
                          static uint8_t num;
                          send(msg.set(num));
                          ++num;
                          wait(5000);
                          wait(5000);
                        For the life of me i cant figure out if im making the BlackMagic properly. I'm moving the boot0 jumper to 1, flashing the 8kb maple (usb flash) DFU file using the st-link application on windows.
                        I move the jumper back to 0, and connect using the micro usb, and i can flash code normally using arudino IDE using the STM32duino bootloader (and if i do so, i see the device communication on a new COM port).
                        From there i cant get anything from these guides to work. the windows STM "flash demonstrator" app doesnt recognize the device, and i dont have a linux machine available at the moment for the dfu-util (and Ubuntu shell on windows wont recognize the usb device). When i try to flash the blackmagic.bin starting at 0x08002000 using the ST-link software it shows it succeeded, but when i return the jumper to 0 and reset the device, this is what i get:
                        The 2 new COM ports appear (COM12,COM13), but i cant seem to flash anything successfully.
                        I've installed the GNU arm toolchain for windows and tried "target extended-remote \.\COM13" (12 just gets stuck on nothing), and i get:
                        electrikE 1 Reply Last reply
                        • N
                          N
                          novicit
                          @idanronen , I am not an expert but did manage to accomplish what you are doing about a year ago. I can tell you that you are supposed to get two com ports from BMP. Also, where your screen shot says "SW-DP scan failed" means BMP cannot find any 'targets' on the nrf52. You should get back something that looks like this from the scan:
                          Available Targets:
                          No. Att Driver
                          1 ARM Cortex-M
                          I performed this operation on ~10 nrf52832 and only one failed the scan. I never found out how to solve it.
                          Also, your use of the attach command is incorrect. You appear to be trying to attach the com port 13. If the swdp_scan had worked corrrectly, you would then attach the target that shows up in the scan. In my example output, it would be "attach 2" - the nRF52 Access Port.
                          That adds what I know, hope it helps a bit.
                          • electrikE
                            electrikE
                            electrik
                            Hello, I'm using MySensors for some years now and after using the NRF24 and recently the RFM69 I want to explore the NRF5 platform.
                            My idea is to use a NRF52840 as gateway, and NRF52832 as nodes. So I am making a list so I can get started, but was wondering what else I should order besides the NRF5's?
                            I read a programmer is required, for example. What is your experience or advice for this? A ST-link or J-link? Could you share your experiences?
                            Rik
                            N 1 Reply Last reply
                            • electrikE electrik
                              Rik
                              N
                              N
                              ncollins
                              @electrik I believe NRF52832 and 51822 are the only supported NRF modules at this time. Some people have experimented and modified dependent libraries to get NRF52840 to work with MySensors but I'm not sure it's completely working and definitely wouldn't start there.
                              Personally, I like using the Ebyte NRF24 PA+LNA modules for my gateways and repeaters and use the NRF5 modules for end nodes.
                              I'm not even sure you can use NRF5 as a radio for a gateway, if so it might only work as a serial gateway.
                              As for additional items, I bought a jlink clone after having trouble unlocking ebyte modules with a STLink. Then my jlink clone caused issues (old firmware, not updatable) so I ended up buying a real JLink-edu.
                              Other things worth noting: there are a surprising number of hardware bugs with the NRF chips that mostly result in higher power consumption. General advice would be to stay away from NRF51822. EBYTE modules have been consistently reliable, high quality.
                              Puneit ThukralP 1 Reply Last reply
                              • N ncollins
                                Puneit ThukralP
                                Puneit ThukralP
                                Puneit Thukral
                                @ncollins It is possible to use NRF51822 for gateways with serial. I am using it for many months now. We need USB to serial adapter.
                                Also, I do not use JLink or ST-Link for flashing the NRF51 chips. I use raspberry pi with OpenOCD.
                                OpenOCD setup can be overwhelming (it was for me) but I have been able to make it work and replicate for a while now. If someone needs inputs, I am happy to help. Ask here or reach out to me on discord @ Puneit#2433
                                For the very reason you stated - hardware bugs in NR51 chips leading to high power-consumption - they make compact repeater nodes / powered nodes with repeaters.
                                • monteM
                                  monteM
                                  monte
                                  Mentioned hardware bugs are easily omitted by using custom sleep function.
                                  • monteM monte
                                    Puneit ThukralP
                                    Puneit ThukralP
                                    Puneit Thukral
                                    @monte Could you please share the custom sleep function?
                                    monteM 1 Reply Last reply
                                    • Puneit ThukralP Puneit Thukral
                                      monteM
                                      monteM
                                      monte
                                      @Puneit-Thukral you can start looking from here https://forum.mysensors.org/post/92044
                                      • electrikE
                                        electrikE
                                        electrik
                                        Is it possible to use such a ready made device, and reprogram it with a mysensors sketch?
                                        https://a.aliexpress.com/_v4kOXD
                                          monteM
                                          monteM
                                          monte
                                          wrote on last edited by monte
                                          #67
                                          @electrik yes. You will need an SWD programmer, J-link, ST-link or black magic probe will do. But the thing, you've linked isn't NRF5 device. So if you are asking about exactly that device, then answer is no. Only Nordic bluetooth devices are supported by mysensors. The one you've linked uses TI chip.
