  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.2k Views 26 Watching
  • N ncollins
    With all the NRF52 modules from EBYTE I've tried, the only way I can flash them is over SWDIO, SWCLK, GND, VCC via JLink clone.
    And, before flashing is possible, I have to unlock the module by following these directions: https://github.com/micooke/arduino-nRF5-smartwatches/blob/master/nrf52_disable_read_protection.txt
    I
    I
    idanronen
    @ncollins I've been working on turning an stm32f030f4p6 into a blackmagic probe for a few days now. Hit a wall when the compiled firmware came out to 83kb which is over the 64kb on board. Found someone who shrunk it down so it'd fit, and someone claiming it has another 64kb which can be unlocked. I'm just looking for the patience to get back in there, as this whole thing has been a major ordeal
    • I
      I
      idanronen
      Im not sure my flashing with the blackmagic even does anything. The console is unclear:
      Sketch uses 3556 bytes (0%) of program storage space. Maximum is 409600 bytes.
      Remote debugging using \\.\COM11
      Target voltage: ABSENT!
      Available Targets:
      No. Att Driver
       1      Nordic nRF52 M3/M4
       2      Nordic nRF52 Access Port
      Attaching to Remote target
      0xfffffffe in ?? ()
      Reading symbols from nrf1.ino.elf...done.
      Loading section .text, size 0xde4 lma 0x1c000
      Loading section .ARM.exidx, size 0x8 lma 0x1cde4
      Loading section .data, size 0x78 lma 0x1cdec
      Start address 0x1c578, load size 3684
      Transfer rate: 33 KB/sec, 614 bytes/write.
      Temporary breakpoint 1 at 0x1cb8c: file C:\Users\....\AppData\Local\Arduino15\packages\sandeepmistry\hardware\nRF5\0.6.0\cores\nRF5\main.cpp, line 28.
      Starting program: C:\Users\....\AppData\Local\Temp\arduino_build_366086\nrf1.ino.elf
      Note: automatically using hardware breakpoints for read-only addresses.
      Program received signal SIGSEGV, Segmentation fault.
      0x00000000 in ?? ()
      Program complete!
      and i dont see any serial debug information
      • BearWithBeardB
        BearWithBeardB
        BearWithBeard
        wrote on last edited by BearWithBeard
        #54
        I just got my first NRF5 running. I'll note how I got it working in case any of you guys still have troubles:
        Setup
        • OS: Windows 10
        • Programmer: STM32 Blue Pill with the Black Magic Probe firmware
        • NRF5: EByte E73-TBB dev board with a E73-2G4M0S1B (NRF52832)
        • Environment: PlatformIO
        Instructions
        Load the Black Magic Probe firmware with stlink as the probe host onto Blue Pill. You can follow this guide.
        Connect your new BMP to the NRF52 module:
        BMP NRF52 Serial Port
        3V3 3V3
        GND GND
        A5 SWDCLK GDB Server
        B14 SWDIO GBD Server
        A2 RXI UART
        A3 TXO UART
        Note: A2 and A3 are not required for programming. This is how you'd wire up the BMP for "classic" serial debugging. You can use the BMP both for programming and serial communication - no need for a second FTDI module.
        Using the GNU Arm Embedded Toolchain, run arm-none-eabi-gdb in a console and enter the following commands to unlock the NRF52:
        target extended-remote BMP_GDB_SERVER_PORT
        mon swdp_scan
        attach N // N = number of "Nordic nRF52 Access Port" if there are several
        mon erase_mass
        detach
        From the two serial ports the BMP provides, you want to use the GDB Server for BMP_GDB_SERVER_PORT above. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should (usually) be the right choice. If not, try the other one.
        Windows users also must prefix the port with \\.\ if the number is double-digit, e.g. \\.\COM13.
        Now you can start uploading sketches the usual way. Here's my minimal PlatformIO config:
        [env:nrf52_dk]
        platform = nordicnrf52
        board = nrf52_dk
        board_build.variant = generic
        framework = arduino
        upload_protocol = blackmagic
        lib_deps =
        	548 ; MySensors
        And a minimal test sketch for MySensors:
        #include <Arduino.h>
        #define LED 17
        #define MY_RADIO_RF24
        #define MY_RADIO_NRF5_ESB
        #define MY_NODE_ID 182
        #define SKETCH_NAME "NRF52 Test"
        #define SKETCH_VERSION "0.1"
        #define CHILD_ID 1
        MyMessage msg(CHILD_ID, V_VAR1);
          present(CHILD_ID, S_CUSTOM);
          pinMode(LED, OUTPUT);
          static uint8_t num;
          send(msg.set(num));
          ++num;
          digitalWrite(LED, HIGH);
          wait(5000);
          digitalWrite(LED, LOW);
          wait(5000);
        Works like a charm so far! Now, if you please excuse me, I have a whole new microprocessor family to explore. Fun times!
        nagelcN Ikes 72000I I electrikE 4 Replies Last reply
        • BearWithBeardB BearWithBeard
          Setup
          • OS: Windows 10
          Instructions
          3V3 3V3
          GND GND
          A2 RXI UART
          A3 TXO UART
          mon swdp_scan
          mon erase_mass
          detach
          [env:nrf52_dk]
          board = nrf52_dk
          framework = arduino
          lib_deps =
          	548 ; MySensors
          #define LED 17
          #define CHILD_ID 1
            static uint8_t num;
            send(msg.set(num));
            ++num;
            wait(5000);
            wait(5000);
          nagelcN
          nagelcN
          nagelc
          @BearWithBeard said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
          From the two ports the BMP provides, you want to use the GDB Server. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should be the right choice.
          Strangely, my BMP uses the higher port number as the GDB server and the lower one as the serial port. I think this is unusual since it is opposite of what most guides say to expect. So, try the higher one if the lower one doesn't work.
            Setup
            • OS: Windows 10
            Instructions
            3V3 3V3
            GND GND
            A2 RXI UART
            A3 TXO UART
            mon swdp_scan
            mon erase_mass
            detach
            [env:nrf52_dk]
            board = nrf52_dk
            framework = arduino
            lib_deps =
            	548 ; MySensors
            #define LED 17
            #define CHILD_ID 1
              static uint8_t num;
              send(msg.set(num));
              ++num;
              wait(5000);
              wait(5000);
            Ikes 72000I
            Ikes 72000I
            Ikes 72000
            Setup
            • OS: Windows 10
            Instructions
            3V3 3V3
            GND GND
            A2 TX UART
            A3 RX UART
            mon swdp_scan
            mon erase_mass
            detach
            [env:nrf52_dk]
            board = nrf52_dk
            framework = arduino
            lib_deps =
            	548 ; MySensors
            #define LED 17
            #define CHILD_ID 1
              static uint8_t num;
              send(msg.set(num));
              ++num;
              wait(5000);
              wait(5000);
            @BearWithBeard just thanks, this method just work fine.
            But just need to use the hightest port number of the BMP.
            • I idanronen
              Does anyone know what settings I need to use for this development board with arduino ide?
              Ebyte E104-BT5032A-TB
              https://a.aliexpress.com/_dT5dMb8
              It has a cp2102 on board which I have the driver for. I've installed the arduino ide nrf52 board, but I can't find a programmer, board, or any other settings which will let me flash it without a Java exception or a timeout. Maybe I need to set the jumpers differently but there's no documentation on that.
              OTA works fine though.
              @idanronen said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
              So, I have finally received mines, and I can program the SoftDevice on them using NRF52 DK and nRF Go Studio. The first time it tells be there is a readback protection and offers a "Recover" option that erases the chip and allows to use it as normal.
              Now I'll try to see what IOs the MOD, WKP, DISC, LINK, DATA, RX, TX, RTS, CTS pins are connected to and that will make a nice little module for modules with limited space and low io pins requirements.
              Great replacement for NRF51822-04 imho: similar surface, better chip, more IOs and similar low price.
                Setup
                • OS: Windows 10
                Instructions
                3V3 3V3
                GND GND
                A2 RXI UART
                A3 TXO UART
                mon swdp_scan
                mon erase_mass
                detach
                [env:nrf52_dk]
                board = nrf52_dk
                framework = arduino
                lib_deps =
                	548 ; MySensors
                #define LED 17
                #define CHILD_ID 1
                  static uint8_t num;
                  send(msg.set(num));
                  ++num;
                  wait(5000);
                  wait(5000);
                I
                I
                idanronen
                wrote on last edited by idanronen
                #58
                Setup
                • OS: Windows 10
                Instructions
                3V3 3V3
                GND GND
                A2 TX UART
                A3 RX UART
                mon swdp_scan
                mon erase_mass
                detach
                [env:nrf52_dk]
                board = nrf52_dk
                framework = arduino
                lib_deps =
                	548 ; MySensors
                #define LED 17
                #define CHILD_ID 1
                  static uint8_t num;
                  send(msg.set(num));
                  ++num;
                  wait(5000);
                  wait(5000);
                For the life of me i cant figure out if im making the BlackMagic properly. I'm moving the boot0 jumper to 1, flashing the 8kb maple (usb flash) DFU file using the st-link application on windows.
                I move the jumper back to 0, and connect using the micro usb, and i can flash code normally using arudino IDE using the STM32duino bootloader (and if i do so, i see the device communication on a new COM port).
                From there i cant get anything from these guides to work. the windows STM "flash demonstrator" app doesnt recognize the device, and i dont have a linux machine available at the moment for the dfu-util (and Ubuntu shell on windows wont recognize the usb device). When i try to flash the blackmagic.bin starting at 0x08002000 using the ST-link software it shows it succeeded, but when i return the jumper to 0 and reset the device, this is what i get:
                The 2 new COM ports appear (COM12,COM13), but i cant seem to flash anything successfully.
                I've installed the GNU arm toolchain for windows and tried "target extended-remote \.\COM13" (12 just gets stuck on nothing), and i get:
                electrikE 1 Reply Last reply
                • N
                  N
                  novicit
                  @idanronen , I am not an expert but did manage to accomplish what you are doing about a year ago. I can tell you that you are supposed to get two com ports from BMP. Also, where your screen shot says "SW-DP scan failed" means BMP cannot find any 'targets' on the nrf52. You should get back something that looks like this from the scan:
                  Available Targets:
                  No. Att Driver
                  1 ARM Cortex-M
                  I performed this operation on ~10 nrf52832 and only one failed the scan. I never found out how to solve it.
                  Also, your use of the attach command is incorrect. You appear to be trying to attach the com port 13. If the swdp_scan had worked corrrectly, you would then attach the target that shows up in the scan. In my example output, it would be "attach 2" - the nRF52 Access Port.
                  That adds what I know, hope it helps a bit.
                  • electrikE
                    electrikE
                    electrik
                    Hello, I'm using MySensors for some years now and after using the NRF24 and recently the RFM69 I want to explore the NRF5 platform.
                    My idea is to use a NRF52840 as gateway, and NRF52832 as nodes. So I am making a list so I can get started, but was wondering what else I should order besides the NRF5's?
                    I read a programmer is required, for example. What is your experience or advice for this? A ST-link or J-link? Could you share your experiences?
                    Rik
                    N 1 Reply Last reply
                    • electrikE electrik
                      Rik
                      N
                      N
                      ncollins
                      @electrik I believe NRF52832 and 51822 are the only supported NRF modules at this time. Some people have experimented and modified dependent libraries to get NRF52840 to work with MySensors but I'm not sure it's completely working and definitely wouldn't start there.
                      Personally, I like using the Ebyte NRF24 PA+LNA modules for my gateways and repeaters and use the NRF5 modules for end nodes.
                      I'm not even sure you can use NRF5 as a radio for a gateway, if so it might only work as a serial gateway.
                      As for additional items, I bought a jlink clone after having trouble unlocking ebyte modules with a STLink. Then my jlink clone caused issues (old firmware, not updatable) so I ended up buying a real JLink-edu.
                      Other things worth noting: there are a surprising number of hardware bugs with the NRF chips that mostly result in higher power consumption. General advice would be to stay away from NRF51822. EBYTE modules have been consistently reliable, high quality.
                      Puneit ThukralP 1 Reply Last reply
                      • N ncollins
                        Puneit ThukralP
                        Puneit ThukralP
                        Puneit Thukral
                        @ncollins It is possible to use NRF51822 for gateways with serial. I am using it for many months now. We need USB to serial adapter.
                        Also, I do not use JLink or ST-Link for flashing the NRF51 chips. I use raspberry pi with OpenOCD.
                        OpenOCD setup can be overwhelming (it was for me) but I have been able to make it work and replicate for a while now. If someone needs inputs, I am happy to help. Ask here or reach out to me on discord @ Puneit#2433
                        For the very reason you stated - hardware bugs in NR51 chips leading to high power-consumption - they make compact repeater nodes / powered nodes with repeaters.
                        • monteM
                          monteM
                          monte
                          Mentioned hardware bugs are easily omitted by using custom sleep function.
                          • monteM monte
                            Puneit ThukralP
                            Puneit ThukralP
                            Puneit Thukral
                            @monte Could you please share the custom sleep function?
                            monteM 1 Reply Last reply
                            • Puneit ThukralP Puneit Thukral
                              monteM
                              monteM
                              monte
                              @Puneit-Thukral you can start looking from here https://forum.mysensors.org/post/92044
                              • electrikE
                                electrikE
                                electrik
                                Is it possible to use such a ready made device, and reprogram it with a mysensors sketch?
                                https://a.aliexpress.com/_v4kOXD
                                  monteM
                                  monteM
                                  monte
                                  wrote on last edited by monte
                                  #67
                                  @electrik yes. You will need an SWD programmer, J-link, ST-link or black magic probe will do. But the thing, you've linked isn't NRF5 device. So if you are asking about exactly that device, then answer is no. Only Nordic bluetooth devices are supported by mysensors. The one you've linked uses TI chip.
                                  • monteM monte
                                    electrikE
                                    electrikE
                                    electrik
                                    @monte Thanks. I didn't notice it was not a Nordic one. So if I take such module, I just have to figure out the pins to program and it can be re-used.
                                    Did you or someone else ever tried this?
                                    https://nl.aliexpress.com/item/4000389437486.html?spm=a2g0o.productlist.0.0.454562f4dPgTnm&algo_pvid=453cb8be-1c2a-43ea-a56c-61bbbf3a4822&algo_expid=453cb8be-1c2a-43ea-a56c-61bbbf3a4822-26&btsid=2100bdf116156431118194203efa5d&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
                                    nagelcN 1 Reply Last reply
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      wrote on last edited by nagelc
                                      #69
                                      Hi @electrik
                                      You can program these ibeacons to work with MySensors.
                                      I reprogrammed one by soldering some wires to a jlink adapter. Not elegant, but it worked.
                                      Some type of push pin setup would be good if you are going to actually use these modules.
                                      The version I got had only a button on the board, and no way to easily add any other sensors, so they weren't very useful. It would be interesting to try the ones with the temperature and acceleromator.
                                      • A
                                        abelson
                                        I am using a generic nRF52 dev board with the Arduino nRF52 core. I am trying to get a sample BLE service to display, but it cannot find it on my BLE scanner. After I couldn't get that to work, I decided to make the code even simpler. Since the dev board that I am using has a serial USB out I thought I would just check if I could get a "Hello World!" to the serial monitor... After flashing the soft device, I still couldn't get any output on my serial monitor.
                                        Licensed under GNU GPL v2
                                        For bug reports, read
                                        debug_level: 0
                                        0x4000
                                        adapter speed: 10000 kHz
                                        xPSR: 0x61000000 pc: 0x0001b08e msp: 0x20001188
                                        xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
                                        ** Programming Started **
                                        auto erase enabled
                                        target halted due to breakpoint, current mode: Thread
                                        xPSR: 0x61000000 pc: 0x2000001e msp: 0xfffffffc
                                        wrote 114688 bytes from file C:\Users\Admin\Documents\ArduinoData\packages\sandeepmistry\hardware\nRF5\0.7.0/cores/nRF5/SDK/components/softdevice/s132/hex/s132_nrf52_2.0.1_softdevice.hex in 2.559271s (43.762 KiB/s)
                                        ** Programming Finished **
                                        ** Verify Started **
                                        xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
                                        verified 110636 bytes in 0.372659s (289.924 KiB/s)
                                        ** Verified OK **
                                        ** Resetting Target **
                                        shutdown command invoked
                                        I am using OpenOCD and an ST-Link v2 to upload my code and it looks like it is uploading successfully. Here is the output when I try to flash the S132 soft device:
                                          Serial.begin(9600);
                                          Serial.println("Hello World!");
                                          delay(1000);
                                        I also tried running this code with the MySensors library:
                                          Serial.begin(9600);
                                          Serial.println("Starting");
                                          delay(3000);
                                        And got this error:
                                        In file included from C:\Users\Admin\Documents\ArduinoData\packages\sandeepmistry\hardware\nRF5\0.7.0\cores\nRF5/Arduino.h:5:0,
                                                         from sketch\MyBoardNRF5.ino.cpp:1:
                                        c:\users\admin\documents\arduinodata\packages\sandeepmistry\tools\gcc-arm-none-eabi\5_2-2015q4\lib\gcc\arm-none-eabi\5.2.1\include\stdint.h:9:26: fatal error: stdint.h: No such file or directory
                                        compilation terminated.
                                        exit status 1
                                        Error compiling for board MyBoardNRF5 nRF52832.
                                        Error while flashing SoftDevice.
                                        java.io.FileNotFoundException: C:\Users\Admin\Documents\ArduinoData\packages\MySensors\hardware\nRF5\0.3.0\softdevices.txt (The system cannot find the file specified)
                                        • A abelson
                                          debug_level: 0
                                          0x4000
                                          auto erase enabled
                                          ** Verified OK **
                                            Serial.begin(9600);
                                            delay(1000);
                                            Serial.begin(9600);
                                            delay(3000);
                                          And got this error:
                                          exit status 1
                                          monteM
                                          monteM
                                          monte
                                          @abelson first you have to flash SD and then chose softdevice in board options and flash your sketch.
                                          It seems that you are lacking softdevice binary. It seems that your version of sandeepmistry's NRF5 core is pretty outdated, you have 0.3 version when surrent version is 0.7. No wonder that links to softdevice binaries are broken in softdevices.txt. Try updating core to the latest version and/or downloading softevice binary from nordic's site yourself.
                                          A 1 Reply Last reply
