  3. PWM control
PWM control
16 Posts 4 Posters 1.5k Views 3 Watching
  • doodoovaneD Offline
    doodoovaneD Offline
    doodoovane
    Hello everyone,
    The aim here is to control the speed of a 5v fan with PWM of an arduino nano.
    I usualy do it with this code:
    const byte OC1A_PIN = 9;
    const byte OC1B_PIN = 10;
    const word PWM_FREQ_HZ = 25000; //Adjust this value to adjust the frequency
    const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
    byte in = 0;
      pinMode(OC1A_PIN, OUTPUT);
      Serial.begin(9600);
      Serial.println("Demarage du PWM"); // so I can keep track of what is loaded
      // Clear Timer1 control and count registers
      TCCR1A = 0;
      TCCR1B = 0;
      TCNT1  = 0;
      // Set Timer1 configuration
      // COM1A(1:0) = 0b10   (Output A clear rising/set falling)
      // COM1B(1:0) = 0b00   (Output B normal operation)
      // WGM(13:10) = 0b1010 (Phase correct PWM)
      // ICNC1      = 0b0    (Input capture noise canceler disabled)
      // ICES1      = 0b0    (Input capture edge select disabled)
      // CS(12:10)  = 0b001  (Input clock select = clock/1)
      TCCR1A |= (1 << COM1A1) | (1 << WGM11);
      TCCR1B |= (1 << WGM13) | (1 << CS10);
      ICR1 = TCNT1_TOP;
    if (Serial.available()) {       // Check if there's data
        char buf[10];
        int in = Serial.readBytesUntil('\n', buf, sizeof buf - 1);
        buf[in]=0;
        in = atoi(buf);
        if (in > 100)
          in = 100;
        Serial.println(in);// Pass the value of "in" to the pin}
        setPwmDuty(in); //Change this value 0-100 to adjust duty cycle
    void setPwmDuty(byte duty) {
      OCR1A = (word) (duty*TCNT1_TOP)/100;
    Is it possible to do the same with mysensors?
    The next step of this would be to connect the arduino via USB and control it using domoticz.
    Y 1 Reply Last reply
    • doodoovaneD doodoovane
      Hello everyone,
      byte in = 0;
        Serial.begin(9600);
        TCCR1A = 0;
        TCCR1B = 0;
        TCNT1  = 0;
        ICR1 = TCNT1_TOP;
          char buf[10];
          buf[in]=0;
          in = atoi(buf);
          if (in > 100)
            in = 100;
      Y Offline
      Y Offline
      @Dovane-Benattar ofcourse! All the initialization and pwm setting code should be copied to the mysensors sketch, and the serial reading could be replaced by mysensors message handling.
        doodoovaneD Offline
        doodoovane
        Thanks Yveaux! I will give it a try like this
          doodoovaneD Offline
          doodoovane
          @Yveaux thank you for your answer!
          * Copyright (C) 2013-2018 Sensnology AB
          * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
          * The gateway accepts input on serial which will be sent out on radio network.
          * LEDs (OPTIONAL):
          * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
          * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
          * - ERR (red) - fast blink on error during transmission error or receive crc error
          #define MY_RADIO_RF24
          //#define MY_RADIO_NRF5_ESB
          //#define MY_RADIO_RFM95
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          // Set blinking period
          // Flash leds on rx/tx/err
          byte in = 0;
            Serial.begin(9600);
            Serial.print(0);
            TCCR1A = 0;
            TCCR1B = 0;
            TCNT1  = 0;
            ICR1 = TCNT1_TOP;
              char buf[10];
              buf[in]=0;
              in = atoi(buf);
              if (in >= 100)
                in = 100;
          Can you tell me if this could work? (I tried but it does not.. maybe I do something else wrong)
            doodoovaneD Offline
            doodoovane
            Some news, it works now!
            I took some code for a dimmable LED here
            The only problem now is that the fan does a little sound it didn't with the first code.
            here is the code:
            * Copyright (C) 2013-2019 Sensnology AB
            * LEDs (OPTIONAL):
            //#define MY_RADIO_RF24
            #define SN "DimmableLED"
            #define SV "1.1"
            #define LED_PIN 9      // Arduino pin attached to MOSFET Gate pin
            #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
            static int16_t currentLevel = 0;  // Current dim level...
            MyMessage dimmerMsg(0, V_DIMMER);
            MyMessage lightMsg(0, V_LIGHT);
             request( 0, V_DIMMER );
             present( 0, S_DIMMER );
                sendSketchInfo(SN, SV);
                if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
                    requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
                    Serial.print( "Changing level to " );
                    Serial.print( ", from " );
                    Serial.println( currentLevel );
                    fadeToLevel( requestedLevel );
                    send(lightMsg.set(currentLevel > 0));
                    // hek comment: Is this really nessesary?
                    send( dimmerMsg.set(currentLevel) );
             *  This method provides a graceful fade up/down effect
            void fadeToLevel( int toLevel )
                int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
                while ( currentLevel != toLevel ) {
                    currentLevel += delta;
                    analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
                    delay( FADE_DELAY );
            Do you have any idea why it does this?
            • S Offline
              @doodoovane
              not sure if I get it, but the little sound could be generated by pwm freq.
              Note, your last sketch is not ideal:
              • don't send msg in receive(). it's better to update a variable, and check this variable in loop() for sending a msg, to avoid recursive call to receive()
              • Same for your fading function, it's better to call it from loop(). Receive() should finish as fast as possible.
              • don't use delay() in your fading function, it's a blocking function. It's better to do this async, in a non-blocking way, or use wait() as it can process received msg in background .
              mfalkviddM doodoovaneD 2 Replies Last reply
              • S scalz
                @doodoovane
                @scalz the delay() and send() calls are from the MySensors example, my guess is that doodoovane just followed the example.
                • S Offline
                  @mfalkvidd
                  yep I noticed that. I just provided a few feedbacks for his future sketches :)
                  • S scalz
                    @doodoovane
                    doodoovaneD Offline
                    doodoovaneD Offline
                    doodoovane
                    @scalz that's what I thought but it doesn't make any sound with the first code I posted.
                    Something to do with the frequency maybe?
                      doodoovaneD Offline
                      doodoovane
                        doodoovaneD Offline
                        doodoovane
                        Me again!
                        So the problem seemed to be the frequency as I don't have sound anymore.
                        With a little hindsight, I looked back at @Yveaux's messages (here and on another post) and here is what I've tried.
                        * LEDs (OPTIONAL):
                        #include <TimerOne.h>
                        #define SV "1.1"
                         #define PWM_FREQ_HZ (25000)
                        #define PWM_CYCLE_US (1000000/PWM_FREQ_HZ)
                        Timer1.initialize(PWM_CYCLE_US);
                        Timer1.pwm(LED_PIN, 1023);
                                requestedLevel = requestedLevel >= 101 ? 100 : requestedLevel;
                        No more sound, but now Can't get it more than 99% in domoticz... The only way to get 100% is to turn it off and turn it back on. As long as you touch the slider, no more 100%...
                        Any clue of what can cause this?
                          Me again!
                          * LEDs (OPTIONAL):
                          #define SV "1.1"
                          Y Offline
                          Y Offline
                          @doodoovane why do you use analogwrite instead of Timer1.setPwmDuty?
                          Also, the fading should not be required for a fan.
                          Iirr the maximum duty value is 1023. Likely the fan won't be at its maximum speed then, only when you supply it a continuous high 'pulse'. Is that what you mean by 99%?
                          doodoovaneD 1 Reply Last reply
                          • Y Yveaux
                            doodoovaneD Offline
                            doodoovaneD Offline
                            doodoovane
                            @Yveaux said in PWM control:
                            Timer1.setPwmDuty
                            I did but there must be something wrong with my code as the PWM doesn't work anymore.
                            Here is my try:
                            #define SN "Fan_PWM"
                            #define SV "1.3"
                                    Timer1.setPwmDuty(LED_PIN, requestedLevel);
                            What I mean by 99% is that the slider of the dimmer when pulled to 100% come back to 99% (as I can see in my switch log) in domoticz. And there is no "100%" input just like if I pulled the slider to 99%...
                              doodoovaneD Offline
                              doodoovane
                              Hello everyone,
                              I'm still stuck with my problem as I don't fin any solution.
                              Is there a way to say in the code "if level is at 100%, stop the PWM regulation (full power fan)" ?
                              Thank you for your help
                                Hello everyone,
                                @doodoovane you can change
                                to
                                requestedLevel = requestedLevel > 98 ? 100 : requestedLevel;
                                  to
                                  doodoovaneD Offline
                                  doodoovaneD Offline
                                  doodoovane
                                  @mfalkvidd said in PWM control:
                                  Thank You @mfalkvidd it works that way! Domoticz still showing me his 99% but at least the fan is going 100%.
                                  Thank you for your help, sometime thing can get easier :)
