  3. PWM control
PWM control
16 Posts 4 Posters 1.6k Views 3 Watching
  • doodoovaneD doodoovane
    Hello everyone,
    The aim here is to control the speed of a 5v fan with PWM of an arduino nano.
    I usualy do it with this code:
    const byte OC1A_PIN = 9;
    const byte OC1B_PIN = 10;
    const word PWM_FREQ_HZ = 25000; //Adjust this value to adjust the frequency
    const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
    byte in = 0;
      pinMode(OC1A_PIN, OUTPUT);
      Serial.begin(9600);
      Serial.println("Demarage du PWM"); // so I can keep track of what is loaded
      // Clear Timer1 control and count registers
      TCCR1A = 0;
      TCCR1B = 0;
      TCNT1  = 0;
      // Set Timer1 configuration
      // COM1A(1:0) = 0b10   (Output A clear rising/set falling)
      // COM1B(1:0) = 0b00   (Output B normal operation)
      // WGM(13:10) = 0b1010 (Phase correct PWM)
      // ICNC1      = 0b0    (Input capture noise canceler disabled)
      // ICES1      = 0b0    (Input capture edge select disabled)
      // CS(12:10)  = 0b001  (Input clock select = clock/1)
      TCCR1A |= (1 << COM1A1) | (1 << WGM11);
      TCCR1B |= (1 << WGM13) | (1 << CS10);
      ICR1 = TCNT1_TOP;
    if (Serial.available()) {       // Check if there's data
        char buf[10];
        int in = Serial.readBytesUntil('\n', buf, sizeof buf - 1);
        buf[in]=0;
        in = atoi(buf);
        if (in > 100)
          in = 100;
        Serial.println(in);// Pass the value of "in" to the pin}
        setPwmDuty(in); //Change this value 0-100 to adjust duty cycle
    void setPwmDuty(byte duty) {
      OCR1A = (word) (duty*TCNT1_TOP)/100;
    Is it possible to do the same with mysensors?
    The next step of this would be to connect the arduino via USB and control it using domoticz.
    @Dovane-Benattar ofcourse! All the initialization and pwm setting code should be copied to the mysensors sketch, and the serial reading could be replaced by mysensors message handling.
    • doodoovaneD
      doodoovaneD
      doodoovane
      Thanks Yveaux! I will give it a try like this
      • doodoovaneD
        doodoovaneD
        doodoovane
        @Yveaux thank you for your answer!
        * Copyright (C) 2013-2018 Sensnology AB
        * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
        * The gateway accepts input on serial which will be sent out on radio network.
        * LEDs (OPTIONAL):
        * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
        * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
        * - ERR (red) - fast blink on error during transmission error or receive crc error
        #define MY_RADIO_RF24
        //#define MY_RADIO_NRF5_ESB
        //#define MY_RADIO_RFM95
        // Enable serial gateway
        #define MY_GATEWAY_SERIAL
        // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
        #if F_CPU == 8000000L
        #define MY_BAUD_RATE 38400
        // Enable inclusion mode
        // Set blinking period
        // Flash leds on rx/tx/err
        byte in = 0;
          Serial.begin(9600);
          Serial.print(0);
          TCCR1A = 0;
          TCCR1B = 0;
          TCNT1  = 0;
          ICR1 = TCNT1_TOP;
            char buf[10];
            buf[in]=0;
            in = atoi(buf);
            if (in >= 100)
              in = 100;
        Can you tell me if this could work? (I tried but it does not.. maybe I do something else wrong)
        • doodoovaneD
          doodoovaneD
          doodoovane
          Some news, it works now!
          I took some code for a dimmable LED here
          The only problem now is that the fan does a little sound it didn't with the first code.
          here is the code:
          * Copyright (C) 2013-2019 Sensnology AB
          * LEDs (OPTIONAL):
          //#define MY_RADIO_RF24
          #define SN "DimmableLED"
          #define SV "1.1"
          #define LED_PIN 9      // Arduino pin attached to MOSFET Gate pin
          #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
          static int16_t currentLevel = 0;  // Current dim level...
          MyMessage dimmerMsg(0, V_DIMMER);
          MyMessage lightMsg(0, V_LIGHT);
           request( 0, V_DIMMER );
           present( 0, S_DIMMER );
              sendSketchInfo(SN, SV);
              if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
                  requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
                  Serial.print( "Changing level to " );
                  Serial.print( ", from " );
                  Serial.println( currentLevel );
                  fadeToLevel( requestedLevel );
                  send(lightMsg.set(currentLevel > 0));
                  // hek comment: Is this really nessesary?
                  send( dimmerMsg.set(currentLevel) );
           *  This method provides a graceful fade up/down effect
          void fadeToLevel( int toLevel )
              int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
              while ( currentLevel != toLevel ) {
                  currentLevel += delta;
                  analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
                  delay( FADE_DELAY );
          Do you have any idea why it does this?
            @doodoovane
            not sure if I get it, but the little sound could be generated by pwm freq.
            Note, your last sketch is not ideal:
            • don't send msg in receive(). it's better to update a variable, and check this variable in loop() for sending a msg, to avoid recursive call to receive()
            • Same for your fading function, it's better to call it from loop(). Receive() should finish as fast as possible.
            • don't use delay() in your fading function, it's a blocking function. It's better to do this async, in a non-blocking way, or use wait() as it can process received msg in background .
            mfalkviddM doodoovaneD 2 Replies Last reply
            • scalzS scalz
              @doodoovane
              @scalz the delay() and send() calls are from the MySensors example, my guess is that doodoovane just followed the example.
                @mfalkvidd
                yep I noticed that. I just provided a few feedbacks for his future sketches :)
                • scalzS scalz
                  @doodoovane
                  doodoovaneD
                  doodoovaneD
                  doodoovane
                  @scalz that's what I thought but it doesn't make any sound with the first code I posted.
                  Something to do with the frequency maybe?
                  • doodoovaneD
                    doodoovaneD
                    doodoovane
                    • doodoovaneD
                      doodoovaneD
                      doodoovane
                      Me again!
                      So the problem seemed to be the frequency as I don't have sound anymore.
                      With a little hindsight, I looked back at @Yveaux's messages (here and on another post) and here is what I've tried.
                      * LEDs (OPTIONAL):
                      #include <TimerOne.h>
                      #define SV "1.1"
                       #define PWM_FREQ_HZ (25000)
                      #define PWM_CYCLE_US (1000000/PWM_FREQ_HZ)
                      Timer1.initialize(PWM_CYCLE_US);
                      Timer1.pwm(LED_PIN, 1023);
                              requestedLevel = requestedLevel >= 101 ? 100 : requestedLevel;
                      No more sound, but now Can't get it more than 99% in domoticz... The only way to get 100% is to turn it off and turn it back on. As long as you touch the slider, no more 100%...
                      Any clue of what can cause this?
                        Me again!
                        * LEDs (OPTIONAL):
                        #define SV "1.1"
                        @doodoovane why do you use analogwrite instead of Timer1.setPwmDuty?
                        Also, the fading should not be required for a fan.
                        Iirr the maximum duty value is 1023. Likely the fan won't be at its maximum speed then, only when you supply it a continuous high 'pulse'. Is that what you mean by 99%?
                        doodoovaneD 1 Reply Last reply
                        • YveauxY Yveaux
                          doodoovaneD
                          doodoovaneD
                          doodoovane
                          @Yveaux said in PWM control:
                          Timer1.setPwmDuty
                          I did but there must be something wrong with my code as the PWM doesn't work anymore.
                          Here is my try:
                          #define SN "Fan_PWM"
                          #define SV "1.3"
                                  Timer1.setPwmDuty(LED_PIN, requestedLevel);
                          What I mean by 99% is that the slider of the dimmer when pulled to 100% come back to 99% (as I can see in my switch log) in domoticz. And there is no "100%" input just like if I pulled the slider to 99%...
                          • doodoovaneD
                            doodoovaneD
                            doodoovane
                            Hello everyone,
                            I'm still stuck with my problem as I don't fin any solution.
                            Is there a way to say in the code "if level is at 100%, stop the PWM regulation (full power fan)" ?
                            Thank you for your help
                              Hello everyone,
                              @doodoovane you can change
                              to
                              requestedLevel = requestedLevel > 98 ? 100 : requestedLevel;
                                to
                                doodoovaneD
                                doodoovaneD
                                doodoovane
                                @mfalkvidd said in PWM control:
                                Thank You @mfalkvidd it works that way! Domoticz still showing me his 99% but at least the fan is going 100%.
                                Thank you for your help, sometime thing can get easier :)
