  3. PWM control
PWM control
16 Posts 4 Posters 1.6k Views 3 Watching
  • doodoovaneD
    doodoovaneD
    doodoovane
    @Yveaux thank you for your answer!
    * Copyright (C) 2013-2018 Sensnology AB
    * Full contributor list: https://github.com/mysensors/MySensors/graphs/contributors
    * The gateway accepts input on serial which will be sent out on radio network.
    * LEDs (OPTIONAL):
    * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
    * - RX (green) - blink fast on radio message received. In inclusion mode will blink fast only on presentation received
    * - ERR (red) - fast blink on error during transmission error or receive crc error
    #define MY_RADIO_RF24
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    // Define a lower baud rate for Arduinos running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    const byte OC1A_PIN = 9;
    const byte OC1B_PIN = 10;
    const word PWM_FREQ_HZ = 25000; //Adjust this value to adjust the frequency
    const word TCNT1_TOP = 16000000/(2*PWM_FREQ_HZ);
    byte in = 0;
     pinMode(OC1A_PIN, OUTPUT);
      Serial.begin(9600);
      Serial.print(0);
      // Clear Timer1 control and count registers
      TCCR1A = 0;
      TCCR1B = 0;
      TCNT1  = 0;
      // Set Timer1 configuration
      // COM1A(1:0) = 0b10   (Output A clear rising/set falling)
      // COM1B(1:0) = 0b00   (Output B normal operation)
      // WGM(13:10) = 0b1010 (Phase correct PWM)
      // ICNC1      = 0b0    (Input capture noise canceler disabled)
      // ICES1      = 0b0    (Input capture edge select disabled)
      // CS(12:10)  = 0b001  (Input clock select = clock/1)
      TCCR1A |= (1 << COM1A1) | (1 << WGM11);
      TCCR1B |= (1 << WGM13) | (1 << CS10);
      ICR1 = TCNT1_TOP;
     if (Serial.available()) {       // Check if there's data
        char buf[10];
        int in = Serial.readBytesUntil('\n', buf, sizeof buf - 1);
        buf[in]=0;
        in = atoi(buf);
        if (in >= 100)
          in = 100;
        Serial.println(in);// Pass the value of "in" to the pin}
        setPwmDuty(in); //Change this value 0-100 to adjust duty cycle
    void setPwmDuty(byte duty) {
      OCR1A = (word) (duty*TCNT1_TOP)/100;
    Can you tell me if this could work? (I tried but it does not.. maybe I do something else wrong)
    • doodoovaneD
      doodoovaneD
      doodoovane
      Some news, it works now!
      I took some code for a dimmable LED here
      The only problem now is that the fan does a little sound it didn't with the first code.
      here is the code:
      * Copyright (C) 2013-2019 Sensnology AB
      * LEDs (OPTIONAL):
      //#define MY_RADIO_RF24
      #define SN "DimmableLED"
      #define SV "1.1"
      #define LED_PIN 9      // Arduino pin attached to MOSFET Gate pin
      #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
      static int16_t currentLevel = 0;  // Current dim level...
      MyMessage dimmerMsg(0, V_DIMMER);
      MyMessage lightMsg(0, V_LIGHT);
       request( 0, V_DIMMER );
       present( 0, S_DIMMER );
          sendSketchInfo(SN, SV);
          if (message.getType() == V_LIGHT || message.getType() == V_DIMMER) {
              requestedLevel *= ( message.getType() == V_LIGHT ? 100 : 1 );
              Serial.print( "Changing level to " );
              Serial.print( ", from " );
              Serial.println( currentLevel );
              fadeToLevel( requestedLevel );
              send(lightMsg.set(currentLevel > 0));
              // hek comment: Is this really nessesary?
              send( dimmerMsg.set(currentLevel) );
       *  This method provides a graceful fade up/down effect
      void fadeToLevel( int toLevel )
          int delta = ( toLevel - currentLevel ) < 0 ? -1 : 1;
          while ( currentLevel != toLevel ) {
              currentLevel += delta;
              analogWrite( LED_PIN, (int)(currentLevel / 100. * 255) );
              delay( FADE_DELAY );
      Do you have any idea why it does this?
        @doodoovane
        not sure if I get it, but the little sound could be generated by pwm freq.
        Note, your last sketch is not ideal:
        • don't send msg in receive(). it's better to update a variable, and check this variable in loop() for sending a msg, to avoid recursive call to receive()
        • Same for your fading function, it's better to call it from loop(). Receive() should finish as fast as possible.
        • don't use delay() in your fading function, it's a blocking function. It's better to do this async, in a non-blocking way, or use wait() as it can process received msg in background .
        mfalkviddM doodoovaneD 2 Replies Last reply
        • scalzS scalz
          @doodoovane
          @scalz the delay() and send() calls are from the MySensors example, my guess is that doodoovane just followed the example.
            @mfalkvidd
            yep I noticed that. I just provided a few feedbacks for his future sketches :)
            • scalzS scalz
              @doodoovane
              doodoovaneD
              doodoovaneD
              doodoovane
              @scalz that's what I thought but it doesn't make any sound with the first code I posted.
              Something to do with the frequency maybe?
              • doodoovaneD
                doodoovaneD
                doodoovane
                • doodoovaneD
                  doodoovaneD
                  doodoovane
                  Me again!
                  So the problem seemed to be the frequency as I don't have sound anymore.
                  With a little hindsight, I looked back at @Yveaux's messages (here and on another post) and here is what I've tried.
                  * LEDs (OPTIONAL):
                  #include <TimerOne.h>
                  #define SV "1.1"
                   #define PWM_FREQ_HZ (25000)
                  #define PWM_CYCLE_US (1000000/PWM_FREQ_HZ)
                  Timer1.initialize(PWM_CYCLE_US);
                  Timer1.pwm(LED_PIN, 1023);
                          requestedLevel = requestedLevel >= 101 ? 100 : requestedLevel;
                  No more sound, but now Can't get it more than 99% in domoticz... The only way to get 100% is to turn it off and turn it back on. As long as you touch the slider, no more 100%...
                  Any clue of what can cause this?
                  • doodoovaneD doodoovane
                    Me again!
                    * LEDs (OPTIONAL):
                    #define SV "1.1"
                    @doodoovane why do you use analogwrite instead of Timer1.setPwmDuty?
                    Also, the fading should not be required for a fan.
                    Iirr the maximum duty value is 1023. Likely the fan won't be at its maximum speed then, only when you supply it a continuous high 'pulse'. Is that what you mean by 99%?
                    doodoovaneD 1 Reply Last reply
                    • YveauxY Yveaux
                      doodoovaneD
                      doodoovaneD
                      doodoovane
                      @Yveaux said in PWM control:
                      Timer1.setPwmDuty
                      I did but there must be something wrong with my code as the PWM doesn't work anymore.
                      Here is my try:
                      #define SN "Fan_PWM"
                      #define SV "1.3"
                              Timer1.setPwmDuty(LED_PIN, requestedLevel);
                      What I mean by 99% is that the slider of the dimmer when pulled to 100% come back to 99% (as I can see in my switch log) in domoticz. And there is no "100%" input just like if I pulled the slider to 99%...
                      • doodoovaneD
                        doodoovaneD
                        doodoovane
                        Hello everyone,
                        I'm still stuck with my problem as I don't fin any solution.
                        Is there a way to say in the code "if level is at 100%, stop the PWM regulation (full power fan)" ?
                        Thank you for your help
                          Hello everyone,
                          @doodoovane you can change
                          to
                          requestedLevel = requestedLevel > 98 ? 100 : requestedLevel;
                            to
                            doodoovaneD
                            doodoovaneD
                            doodoovane
                            @mfalkvidd said in PWM control:
                            Thank You @mfalkvidd it works that way! Domoticz still showing me his 99% but at least the fan is going 100%.
                            Thank you for your help, sometime thing can get easier :)
