  3. JSN-SR04T (distance sensor) Reliability Issue Fix?
24 Posts 8 Posters 9.5k Views 9 Watching
  • Thomas WeeksT
    Thomas WeeksT
    Thomas Weeks
    Refreshing the older thread Trouble with the JSN SR04T..
    I now have the ver 3 of this hardware and I must say.. the output is still flaky as hell. NewPing never worked for me.. and I had to adjust up some of the 4-10nS reading delays up to like 6-10nS.. which seems to at least WORK now.. but still, every few readings I'll still get a minimum distance pulse width from it (works out to around 22cm).. So I'll be reading a stationary wall at like 120cm away.. and it will "glitch" down to 22cm once every few minutes.
    I had to write my own getDistance() funciton that takes like 5 samples and throws away errors.. it's okay.. but even it gets fooled now and then with the sensor output reports minimum distance.
    I've even looked at the echo output on the o-scope and verified that the output will occasionally "jitter" between actual distance pulse width and some false minimum distance.. so I know this is not a software issue.
    I'm now trying localized 5v power bypass capacitors to see if that helps.. but am starting to lose hope in being able to rely on the JSN SR04T for use in a commercial solution.
    Does anyone have a schematic of this thing? I want to try playing with the variable inductor to to see if that can be used to better "tune" whatever it's doing. but am afraid of tweaking a knob I don't understand.
    Any help appreciated.
    T.Weeks
    YveauxY Thomas WeeksT 2 Replies Last reply
    • Thomas WeeksT Thomas Weeks
      T.Weeks
      @Thomas-Weeks said in JSN-SR04T (distance sensor) Reliability Issue Fix?:
      Google: https://www.fi.freelancer.com/u/kingch91/portfolio/Schematic-Design-JSN-SR04T-Ultrasonic-Water-Level-Sensor-5887451?w=f&ngsw-bypass=#
      • bjacobseB
        bjacobseB
        bjacobse
        How does your function work with 5 samples and throws away errors?
        Why not take measures until you get 3 or 5 measures that are identical, and then use this as your measurement?
        Thomas WeeksT 1 Reply Last reply
        • bjacobseB bjacobse
          Thomas WeeksT
          Thomas WeeksT
          Thomas Weeks
          wrote on last edited by Thomas Weeks
          @bjacobse
          You asked:
          I toss readings that differ greatly from the norm.. OR any that are either near the MAX(600cm) or MIN (22cm). Those strategies (plus a read-loop that looks for "good readings" eliminates >99% of the bad readings.
          BC many times, multiple errors (sometimes 10-20 or more) readings register the MAX or MIN values. I've watched the pulse width on an o-scope.. and it IS a hardware, reading reliability issue. In such cases of getting a string of bad readings, I just loop trough and keep taking readings until I get several reliable readings in a row.. and include a watch-dog variable that will break out of the read-again loop if X number of bad readings have been taken.
          I can post the code if people want.
          BTW.. Whomever posted that schematic futher back.. it's NOT a JSN-SR04T. The JSN has no MAX232 , has only ONE sensor element (not two), and the googled schematic is missing the STM STM8S003F3P6 8bit microcontroller and the variable inductor.
          JSN board
          So that previous schematic is a fake. Anyone have the REAL schematic?
          Tweeks
            @bjacobse
            You asked:
            JSN board
            Tweeks
            @Thomas-Weeks I meant Google for it. I just posted the first schematic that came up. You should just look if any seems to match your board (eg the max232 is a nice check) and then trace some signals. If those match, it could very well be the schematic of your board.
            China sensors also often come in multiple revisions, with minor differences, without notice which increases the trouble to find a match.
              T.Weeks
              Thomas WeeksT
              Thomas WeeksT
              Thomas Weeks
              For those interested..
              I found another engineer who reverse engineered the JSN-SR04T v2. Not identical, but close. Here's the v2 schematic:
              Here's the full theory of operation article he wrote (in Vietnamese, google xlate URL) on how to remove the STM 8 bit microcontroller and do your own echo-pulse based on the waveshape of the detection LED driver.
              Here's an interesting tidbit of implementation info that's good to know before you try to use this sensor in a project:
              "Defect:
              • JSN-SR04T has a very large opening angle (> = 75 degrees), so it is NOT suitable for measuring distances in tight spaces. Should only be used in open spaces such as outdoors or large-size tanks - no obstructions .
              • If measured in a confined space, the error is very large due to the reflected wave being impacted and the object or the tank - tank wall."
              Good to know!... I have seen some of this error in the form of echo width "jitter" both in the bad/unreliable data, as well as with the raw signal combing back on the o-scope:
              I'll need to experiment with this in confined spaces.. but the JSN units also seems to have problems with "soft targets" (like people in clothes). You can test this yourself by testing with a plywood sheet (the size of a person) vs a clothed person. If anyone finds a way to get more reliable soft target detection, please share here.
              These JSN-SR04 modules seem to have multiple operating modes.
              On the v2 module, the empty R27 pad controls the echo mode of operation. Here's a best guess regarding the four "operating modes" that I think the author is documenting (attempted to better translate from Vietnamese):
              1. Trigger/Echo ECHO-Pulse Mode (default): (R27 open)
              You send a 10uS pulse on Trigger pin, then 8 x 40KHz pulses are sent out of sensor, if bounce signal returns within 60mS, the duration of the time to return is sent as pulse-width based on the formula:
              Distance = (high time * speed of sound (340M / s)) / 2
              2. Continuous Distance-Data TX Mode: (R27=47k)
              In this working mode, every 100ms will automatically output the measured sensor distance value, in millimeters. Once the module is powered on, it operates in mode 2 immediately, and data will be sent every 100 ms via echo (TX) pins. The data sent includes: 0xFF + H_DATA + L_DATA + SUM. Breakdown:
              • 0xFF: Byte signaling to start sending data.
              • H_Data: 8 bits above of the distance.
              • L_Data: 8 bits below the distance.
              • SUM: Byte checks whether the passed data is correct or not.
              • SUM = 0xFF + H_DATA + L_DATA (H+L = 16bits which represents distances in millimeters.) (assume 9600, n, 8, 1 data on echo pin)
              For example, the sensor sends FF 07 A1 A7 Sum = A7 = (0x07 + 0xA1 + 0xFF) & 0x00FF. 0x07 is the upper 8 bits of the distance. 0xA1 is the lower 8 bits of the distance. The distance value is 0x07A1, converted to 1953mm in decimal
              3 . Standby Distance-Data TX Mode: (R27=120k)
              Same as mode2, but module starts in a disabled, standby mode, waiting for a 0x55 command (on trigger pin, as 9600, n, 8, 1), after which module runs same as mode-2 (continuous distance data TX mode)
              Well that's all useful info!
              Hmm.. No R27 pad on my v3 sensor.. but I wonder what these four jumper pads do :)
              If anyone else gets time to play with these new v3 jumpers.. or figure out how to resolve the "jitter issues", please do share here.
              T.Weeks
              zboblamontZ M M 3 Replies Last reply
                "Defect:
                T.Weeks
                zboblamontZ
                zboblamontZ
                zboblamont
                @Thomas-Weeks Interesting comment on enclosed spaces, I had no such experience - two v2s in separate fluid tanks one of which failed after a year having otherwise worked flawlessly. I looked for 3 consecutive matches on a reading before radioing in.
                One tank is concrete so smooth sides, perhaps 1.5 by 1.2m in plan, depth 1.7m.
                The other is a circular section plastic moulding depth to the bottom ca 1.5m but with internal shoulders I expected to give reflection problems, yet no issues and it's still banging away 2 to 3 years later on 3v3.
                  "Defect:
                  T.Weeks
                  mrdisco
                  @Thomas-Weeks I have had great success with these sensors using a stillingwell (32mm plastic pipe with a breath hole and a 3d printed cap to position the sensor) a little experimentation and patience with positioning the sensor
                  Thomas WeeksT zboblamontZ 2 Replies Last reply
                  • M mrdisco
                    Thomas WeeksT
                    Thomas WeeksT
                    Thomas Weeks
                    @mrdisco @zboblamont
                    Thanks for the comments guys.. My application is very different than water level sensing though. I'm using it as a "people-distance" sensor (detecting distance to people's torsos) and our 3D printed case has a hand adjustable angle mount that works well for us:
                    The PROBLEM (for me) is that while the JSN sensor works well against flat, hard, smooth surfaces like plywood or a liquid surface (did all my testing of this on the bench), they seem to be much less reliable with soft surfaces like a clothed torso, a coat on a hangar, a pillow, etc. This soft-surface error appears in the output as distance pulse "jitter" as seen here in the signal pulse width output jumping around:
                    JSN-SR04T Jitter When Distancing "soft" Objects
                    Thus far I'm solving this specific issue in software with a rapid detection loop that throws away known "bad values" (as previously discussed) with a watch-dog loop-break that limit its detection polling duration.
                    I hope that's clear enough.
                    It sounds like the JSN is a perfect sensor for detecting walls (from a car bumper) or other hard/fault car surfaces (<20ft proximity.. maybe along with radar).. and I know most people following these threads seem to be using it for liquid-level measurements (which is really cool).. but one is pushing the JSN's usability with soft target objects.
                    If anyone comes up with a better, more elegant solution for making this sensor more universal in its target detection.. even if done at the sensor hardware or STM micocontroller reflashing side of things.
                    Cheers..
                    TWeeks
                    • M mrdisco
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @mrdisco Would you mind expanding on this as I'm curious - A stilling well, typically 100mm plastic pipe is frequently used in industry with the US firing from the top and the pipe submerged below the surface..
                      When you refer to using 32mm pipe, how high above the fluid surface is the sensor within the 32mm pipe and what in the sensor the range you're measuring ?
                        Cheers..
                        TWeeks
                        Did you consider sensors using different measurement principles, e.g.optical TOF sensors like ST's VL53L0X or radar?
                        • YveauxY Yveaux
                          Thomas WeeksT
                          Thomas WeeksT
                          Thomas Weeks
                          @Yveaux I might like to eventually check out a ToF sensor.. but I'm already at a commercialization stage using this JSN sensor, and it looks like I can mostly compensate for the echo jittering.
                          If anyone has any experience with any other newer, narrow-angle sensors they would recommend (ToF, LiDar), etc), please share. So far I've also tried PIR (motion) sensors (which don't work if my subject stops moving), RFID, and a couple others.
                          Some of my requirements are, it must be:
                          • "Splash & Spray" water resistant (mounted in bathrooms)
                          • Multi-sensor interference proof (4-5 sensors next to each other can't interfere)
                          • Light & IR proof (sun light, heat sources, etc)
                          • EMF (florescent RF noise) proof
                          • Can't be any type of "camera" (used to capture photos)
                          Thoughts?
                          Maybe I should start a separate thread ^^^ on this ^^^.
                          T.Weeks
                          • zboblamontZ zboblamont
                            mrdisco
                            @zboblamont I cut the pipe 200mm longer than the maximum height of the water, drill a 3mm breather
                            near the top cut a slant at the bottom of the pipe for the water to move freely, there is still a little fluctuation in the readings but overall way more stable when not bouncing off the wall of my water butt, also I have noticed at times when the sun shines on the pipe sticking out the top for about an hour in the morning the readings are more erratic. When I get a chance I will photo the setup and show the node-red flow that translates the distance into litres.
                            • M mrdisco
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @mrdisco Ok interesting, may have a play with that, a couple of spare boards doing nothing in the spares.
                              Situation here is a below ground 3,000 litre tank, the head mounted in a 3/4" reducer on the end of 1/2" gun barrel, no false echoes, surprising given the moulded tank has internal shoulders.
                              Though the gun-barrel proved robust, what I neglected to consider was condensation forming on the pipe when temperatures drop, occasionally forming a large drip on the sensor face, notably when it drops below -10c. Water is usually ca 5c.
                              Fitted a little formed foam this year held by a tie around the head to see if it cures or limits the issue, no fun wiping a drip off in winter.
                              I let the Arduino Node work out litres available and % used which it sends in every hour to Domoticz, now on year two of 2xAA so pretty happy with it.
                                Cheers..
                                TWeeks
                                Thomas WeeksT
                                Thomas WeeksT
                                Thomas Weeks
                                For anyone interested in this.. I found that ultrasonic sensors, while accurate on solid surfaces.. detecting distance of "soft" objects like torsos with clothing in front of it can create "ghosting", or massive jitter (at best) at certain distances and angles. This can be seen in the o-scope image above. As soon as I put a piece of plywood on my chest, the signal is rock solid. So yes, tracking the depth of water (a solid, mostly smooth surface) works great.. detecting people walking and distances reliably is problematic. Some of it can be lessened via software filtering, but not all.
                                For those looking for a soft-body distance measurements.. this IR LIDAR TOF sensor works VERY well.. is sub-CM accurate(!!) and is sunlight resistant, and quick as hell.
                                Link -
                                https://www.aliexpress.com/item/1005001643925191.html
                                plus.. it's TINY!
                                T.Weeks
                                rvendrameR 1 Reply Last reply
                                  Link -
                                  plus.. it's TINY!
                                  T.Weeks
                                  rvendrameR
                                  rvendrameR
                                  rvendrame
                                  wrote on last edited by rvendrame
                                  @Thomas-Weeks , in your scenario do you have to deal with condensation (water vapor moisture) on sensor head? I replaced my ultrassonic SN04T by a time-of-flight VL5310X , but still getting many erratic readings when drips form on sensor face...
                                  ESP8266 GW + mySensors 2.3.2
                                  Alexa / Google Home
                                  • rvendrameR rvendrame
                                    Thomas WeeksT
                                    Thomas WeeksT
                                    Thomas Weeks
                                    @rvendrame Again.. I'm not measuring water.. I'm measuring people in a climate controlled environment. No problems with condensation. But I can see how condensation would wreak havoc on an IR laser TOF sensor. Why did you have to move away from the JSN04T? It seems pretty solid candidate for your application.
                                    Tweeks
                                      Tweeks
                                      rvendrameR
                                      rvendrameR
                                      rvendrame
                                      @Thomas-Weeks I'm looking for alternatives, as I started with JSN04T. Scope is to measure house's water tank (2000 litres). The sensor is fixed at a hole in the tank cover (on top).
                                      The tank stays at roof. Once sun in at its peak, a lot of vapor and condesantion appears in the tank, and the sensor face gets completely covered by water drops. Both JSN04T and VL5310X then start to give very out-of-range readings. (and this happens almost every day, for multiple hours).
                                      Alexa / Google Home
                                        zboblamontZ
                                        zboblamontZ
                                        zboblamont
                                        @rvendrame Timely - I haven't put it into operation yet as only just finished the plumbing mods in the pump well for a 5psi water pressure sensor. Because I've saddled the sensor to the pump suction line I'll have to inhibit readings when the pump runs, hence delayed operation.
                                        5psi is equivalent to 3.516m head, so you will measure over 80% of the ADC range giving a resolution of 4.25mm..
                                        My 3,000 litre underground water tank suffers the same issue over condensation when winters drop below -5.
                                        Hope this helps.
                                          "Defect:
                                          T.Weeks
                                          Mahesh_s
                                          @Thomas-Weeks please tell me what type of signal i generate for the PB5 pin ? and how to replace the inbuilt stm8 to ESP32 microcontroller
