  3. Calibrating Humidty
Calibrating Humidty
21 Posts 5 Posters 20.3k Views 2 Watching
  • YveauxY
    Could you repeat the test with 2 sensors exposed to the same humidity?
    E.g. use the first DH11 which gave results very close to 75% together with the DH22 which was very off?
    Then you also know the repeatability of your measurement.
    clippermiamiC 1 Reply Last reply
      Just got some samples of the SHT21 from Sensirion. Damn it's small.
      Just have to figure out how to surface mount it on something.
      • YveauxY Yveaux
        clippermiamiC
        clippermiamiC
        clippermiami
        @Yveaux I want to but i do't have the tools to do it right now.
        • clippermiamiC clippermiami
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          How do they check out at the high end of the scale (i.e. 99-100% RH in a sealed polybag with a damp towel)?
          I tested my Aeons in a temperature/humidity controlled chamber in our lab and got a spread of 10%RH points on two versus known (tested at 72F and 50%RH). I thought that was pretty poor.
          I have not run any tests with my DHT22' but I may based on this.
          Thanks for the info, very helpful.
          Jim
            @hek How are your eyes ??? ;-)
            I once tried soldering wires to one, but it lost a 'leg' in the process... $15 down the drain...
            Better use a small breakout to solder them on!
              Jim
              clippermiamiC
              clippermiamiC
              clippermiami
              wrote on last edited by clippermiami
              @BulldogLowell The results with the DH22 were surprisingly disappointing, I thought they would have better performance. I tried two of them without any correction factor in the sketch and in my 75% humidity test they never got close. They were however consistent so applying a (rather large) correction factor in the code would bring them into "zero" at 75%.
              In my 75% "chamber"
              DH22 # 1 reported 55.8
              DH22 # 2 reported 55.4
              so they are pretty close to each other. A uniform adjustment of say +20 would bring them very close. However in free air the results are different
              My two Aeon 4-in-1 report reading of 55% and 43% so they are pretty far apart as is. Tamiami Airport (General Aviation) is about 5 miles SW of us and it reports the still air outside humidity at 55% both yesterday and today --- so allowing for differences in inside (A/C) vs outside humidity I'd guess the actual inside at somewhere around 40-45%
              In free air inside:
              DH22 # 1 reported 39.0%
              DH22 # 2 reported 38.6%
              so they may be fairly accurate at normal room humidity levels. But applying a +20 correction factor to make them read correctly in the testbed would trow the free air levels way off.
              I've put the DH11 back in the testbed to see what happens.
              Of course at the end of the day I just don't have the benchmark tools to do a proper comparison at home so this is all pretty loose.
              John
              BulldogLowellB YveauxY 2 Replies Last reply
                In my 75% "chamber"
                In free air inside:
                John
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @clippermiami
                wow, I am surprised at the poor results. :(
                repeatable is important, but precision needs accuracy, too
                thanks for this; it is making me re-think some of what I'm doing with sensors.
                  @clippermiami
                  clippermiamiC
                  clippermiamiC
                  clippermiami
                  @BulldogLowell I think it would be good to have a few more folks to do some tests and report the results. I think I will start from scratch on the data as well just to verify my results
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    I could test a couple too, if you want. I'll get them back in the humidity chamber in our lab.
                    I am still thinking about the salt test and wondering how the temperature may play a role (since RH is dependent on temperature). I can't seem to get myself to the point where I understand that the salt/water paste will get any (albeit tiny) air atmosphere to 75%RH independent of temperature, unless that is a "generally at room temperature" qualification.
                    I would like to calculate an offset. I know it is 'correct' at a saturation humidity so I imagine the offset will be some kind of formula off of the results of two or three or more known values.
                    Actually, that would be a great arduino project in itself... develop an offset curve with 3-4 calibration points.
                      In my 75% "chamber"
                      In free air inside:
                      John
                      @clippermiami So the 'inside' reading seems to be closer to the expected value than the 'salt chamber' value. This suggests using just an offset for calibration is not sufficient, but at least gain/offset and possibly an interpolation table are required to get some accuracy...
                      • YveauxY Yveaux
                        clippermiamiC
                        clippermiamiC
                        clippermiami
                        @Yveaux The data sheet for the DHT22 (the DHT11 is in Chinese) says that the sensor is fully calibrated and has in internal lookup table to adjust the values across the entire temperature range. S from that one would assume that the output of the device is linear.
                        I am just finishing up a long (48 hour) test using the salt-water-plastic-bag test jig using the DHT11. Right now it shows 76% humidity and that's after I recompiled the sketch with a a +2% adjustment. In this case +1% adjustment would have put it right on the money at 75%. The 76% value has been stable for the past 24 hours so I am satisfied that the reading is correct and would plan to use a 1% adjustment.
                        This morning I'm going to take it out of the test jig and let it settle to the ambient room humidity and try to judge where I am at. We shall see. But at least i know the DHT11 can correctly hit the expected test value. I may just settle on the DHT11 for my sensors.
                        I'm working on two 3V battery operated Minis' with Hum/Temp/Barometric/Light sensors to go outside and i'm gathering parts for 8-9 battery operated Motion/Humidity/Temp/Light Level sensors for indoor use. All will be powered by CR123A 3V Lithium batts.
                          From that one would assume the output of the device is calibrated, I would say ;-)
                          • YveauxY Yveaux
                            clippermiamiC
                            clippermiamiC
                            clippermiami
                            @Yveaux Good point
                            • epierreE
                              epierreE
                              epierre
                              I have tested the DHT11 for one day with a THGR810 from Oregon (assuming it is pretty calibrated). They were close together.
                              There are some time the DHT11 moved but not the Oregon. Generally it was 1% below so pretty good.
                              On Temperature there is more gap, it varies from 2°C+/-1°C below, it is more puzzling here.
                              I have not yet DHT22 to do this check-up.
                              Would one day adjustment values sent by the gateway to the sensors ;-)
                              z-wave - Vera -> Domoticz
