  3. IR Switch for Luminara Candle Automation (repost with video, photos and final sketch)
ir blasterir code
29 Posts 9 Posters 23.7k Views 4 Watching
  • B Offline
    B Offline
    blacey
    wrote on last edited by blacey
    So, my wife loves her Luminara candles that she can turn on and off with a Luminara remote control so heck, why not tie them into the HA system so they come on at sunset and go off when we go to bed each evening? I built a high-power IR blaster, ginned up a small circuit to decode the Luminara remote control codes using the IRSensor sketch MySensors example provided by @hek, configured the on/off IR codes in the actuator sketch and voila - our Vera 3 is able to control my wife's candles! Video, photos and the sketch are provided below.
    IR Switch Video
    Completed IR Switch Actuator
    IR Switch Actuator Circuit (top)
    IR Switch Actuator Circuit (bottom) - should probably invest in the convenience boards that others have created to avoid excessive wire-wrapping and soldering ;)
    Assembling the IR Blaster - parallel circuit, no forward current resistors to maximize radiant luminance.
    Assembled IR Blaster (top)
    Assembled IR Blaster (bottom)
    IR Switch Sketch
    This was a fun project with a very positive wife factor and I hope others find this useful.
    Cheers.
    UPDATE (2015-MAY-13) I have started a new thread here to flesh out the design of an official IR Blaster -
    • H Offline
      H Offline
      Cool, added your "blaster module" here:
      http://www.mysensors.org/store/#light
      • S Offline
        Salmoides
        Happy wife, happy life. Well done.
        Sal
        • H Offline
          H Offline
          Nice video Bruce!
          • P Offline
            P Offline
            petewill
            @blacey Awesome! I don't know how I missed this before but I love it. Adding this to the list of things to do...
            Just curious, how long to the batteries last in the candles?
            • B Offline
              B Offline
              blacey
              They use two C-size batteries so they last a very long time. With them on the automation system, I expect them to last at least a year because my wife won't leave them running 24/7 anymore ;) In fact, they may last even longer because the candles will be on less per day as we approach summer because the trigger is tied to sunset... My wife has had the candles just under six months without automation and is still on her first set of batteries.
              • P Offline
                P Offline
                petewill
                @blacey awesome, thanks!
                • K Offline
                  K Offline
                  korttoma
                  anyone know if you can buy these in europe?
                  • Tomas
                  B 1 Reply Last reply
                  • K korttoma
                    B Offline
                    B Offline
                    betonishard
                    wrote on last edited by betonishard
                    @korttoma just bought these yesterday on ebay:
                    http://www.ebay.com/itm/Remote-Control-Electronic-LED-Candle-Romantic-Gift-3pcs-LED-Wax-Candles-DX-/251766554387?pt=LH_DefaultDomain_0&hash=item3a9e74bf13
                    I have no idea if this is something useful
                    Worth a try for 8 dollar?
                    • K Offline
                      K Offline
                      korttoma
                      I just received a couple of these:
                      http://www.ebay.com/itm/301578035483?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                      Looks like they are the same candles as Luminara but cheaper, time to build the IR Blaster and find out if I can use the sketch @blacey provided straight of.
                      • Tomas
                      • K Offline
                        K Offline
                        korttoma
                        @blacey would you mind sharing how you connected the IR-Transmitters to the arduino? Is this what the Transistor is for?
                        • Tomas
                        • K korttoma
                          B Offline
                          B Offline
                          blacey
                          @korttoma, yes the transistor is used to drive the IR LEDs. It is a standard NPN transistor (NTE123AP) capable of delivering 600mA of current through the collector.
                          The transistor base lead is connected to the Arduino PWM pin 3 per IRLib, the transistor emitter lead is connected to GND and the transistor collector lead is connected to the IR LED emitters wired in parallel (cathode). It is best practice to place a forward current limiting resistor between IR LEDs anode and VCC but the IRLib drives the LEDs for such short intervals, that you can avoid adding the forward current limiting resistors as I mentioned in the video.
                          • K Offline
                            K Offline
                            korttoma
                            Thanks @blacey for the clarification. I sort of overlooked the fact that there was a video, sorry. My consirns was about the current limiting resistor but if you say the IR LEDs can take it I believe you. Thanks again for this project ;)
                            • Tomas
                            • B Offline
                              B Offline
                              blacey
                              @korttoma - sorry you missed the video ;) I have it on my to-do list to draw a proper schematic for the IR blaster board and the actuator but I just haven't had time yet. I would like to post one in this thread to make it easier for people to build their own IR actuator. Maybe you will get there first ;)
                              jeylitesJ 1 Reply Last reply
                              • B blacey
                                jeylitesJ Offline
                                jeylitesJ Offline
                                jeylites
                                @blacey what program are you using to capture the IR codes from the remote ?
                                • jeylitesJ jeylites
                                  B Offline
                                  B Offline
                                  blacey
                                  @jeylites I used the IRSensor sketch in the MySensors examples.
                                  • B blacey
                                    jeylitesJ Offline
                                    jeylitesJ Offline
                                    jeylites
                                    @blacey Nice. I'm using IR Recorder from the library. I asked because you had a fancy setup in the video :) Very neat setup!
                                    • jeylitesJ Offline
                                      jeylitesJ Offline
                                      jeylites
                                      wrote on last edited by jeylites
                                      Hello @blacey , I got a question... If I'm going to add another IR into the sketch, how do I go about doing this? So two independent sensors into one. This is what I have done so far. Correct me if I'm wrong. Should I be changing something in IRsend irsend ....?
                                      And is your IR LED connected to Pin 1 or Pin3?
                                       * Binary IR Switch sketch that controls Luminara Candles
                                       * Sketch inspired by, and a derivative work of, Hek's IR Sensor example sketch
                                      #include <IRLib.h>
                                      int RECV_PIN =  8;
                                      #define CHILD1  3 // Arduino Pin 3
                                      #define CHILD2  4 // Arduino Pin 4
                                      MyMessage switchMsg1(CHILD1, V_VAR1);
                                      MyMessage switchMsg2(CHILD2, V_VAR1);
                                      // IR LED must be connexted to Arduino PWM pin 3
                                      IRsend irsend;
                                      #define switchOnIRcode  0x00ff629d  // Luminara On  IR code
                                      #define switchOffIRcode 0x00ffa857  // Luminara Off IR code
                                        gw.begin(incomingMessage);
                                        gw.sendSketchInfo("IR Switch", "1.0");
                                        // Register a sensors to gw. Use binary light for test purposes.
                                        gw.present(CHILD1, S_LIGHT);
                                        gw.present(CHILD2, S_LIGHT);
                                        // Sync switch state to gateway state upon reset / power-up
                                        gw.request(CHILD1, V_LIGHT);
                                        gw.request(CHILD2, V_LIGHT);
                                        if (message.type==V_LIGHT) {
                                           int incomingRelayStatus = message.getInt();
                                           // Emit the IR ON/OFF code
                                           irsend.send(NEC, (incomingRelayStatus == 1 ? switchOnIRcode : switchOffIRcode), 32);
                                           // Sync gateway of the light switch state
                                           gw.send(switchMsg1.set(incomingRelayStatus));
                                           gw.send(switchMsg2.set(incomingRelayStatus));
                                        #include <IRLib.h>
                                        int RECV_PIN =  8;
                                        IRsend irsend;
                                        B Offline
                                        B Offline
                                        blacey
                                        @jeylites My IR LEDs are connected to Pin 3 because that is what IR Lib requires. Your sketch looks close but you will need to define separate switchOnIRcode and switchOffIRcode codes for your respective lights. Then in the incomingMessage loop, send the appropriate code based upon the child ID. If you plan to have a large number of child IDs, I would create an array indexed by child ID to hold the on/off IR codes and then simply invoke ir.send() passing the onOffCode[childID] to it. Does that make sense?
                                        Also, I just started another thread for an official IR Blaster board that you might want to review. I plan to provide multiple device support out of the box...
                                        • jeylitesJ Offline
                                          jeylitesJ Offline
                                          jeylites
                                          @blacey I think I get what you're saying on #define but don't know how to associate child id with ir code. Do you have a sample or something ?
                                          IR blaster - you working on looks great. Next project is to use that to control my AV system.
                                          Thank you!
                                          12.2k
