  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • T
    tssk
    Hello
    I created battery powered node running on 2x 1.5V AA batteries with DC-DC step up booster. But the step up booster makes audible noise (very tiny beeping) when the radio is transmitting.
    It is this step up booster https://www.laskarduino.cz/step-up-boost-menic-s-me2108-33v-480ma/
    Is there any way to solve it?
    Tomas
    TheoLT caniqueC BearWithBeardB 3 Replies Last reply
    • T tssk
      Hello
      Tomas
      TheoLT
      TheoLT
      TheoL
      @tssk First things that comes to my mind is that you might draw too much power (but no expert) did you measure it?
      • T tssk
        Hello
        Tomas
        caniqueC
        caniqueC
        canique
        @tssk There is a name for this noise: it is called "coil whine". In German "Spulenfiepen". It stems from the inductor - I wouldn't know any way to get rid of it.
        My mainboard or power supply on my PC creates similar noise when the CPU goes in certain doze modes.
        • T tssk
          Hello
          Tomas
          BearWithBeardB
          BearWithBeardB
          BearWithBeard
          @tssk I heard that people got rid of or at least reduced the coil whine by coating the windings of an audible inductor with non-conductive materials like epoxy resin or even hot glue to reduce the vibrations.
          Of course, I woudn't mess with expensive PC hardware, but I guess there's not much to loose with a cheap boost module like this.
          • BearWithBeardB BearWithBeard
            tssk
            Thanks all for the response.
            @BearWithBeard I will start googling about such solution.
            Do you think using different step up booster might help? Could someone recommend something?
            • caniqueC
              caniqueC
              canique
              I am biased since I run that website but I can recommend https://www.canique.com/boost
              I've never heard it making noise.
              • caniqueC canique
                tssk
                wrote on last edited by tssk
                #272
                @canique Thanks for the recommendation if I do not find fix for the model I am using I will consider buying it.
                I will try to hot glue the side with the coil as I found on some pages. Any ideas / warnings? :)
                • T tssk
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @tssk Most of these boosters have a grounded backplane, perhaps trying to re-orientate the inductor so the backplane acts a shield to direct RF may be an option to try ?
                  If the noise in on the power line I've heard of some managing to block it with a VR circuit if the voltage drop is acceptable, but never tried it.
                  • zboblamontZ zboblamont
                    tssk
                    @zboblamont It is not electrical noise but audio noise I can hear. Sorry if I use improper terms.
                    zboblamontZ skywatchS 2 Replies Last reply
                    • T tssk
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @tssk My misconception.
                      • T tssk
                        skywatchS
                        skywatchS
                        skywatch
                        @tssk If the item is not going to be too hot then hot melted candle wax dripped over the coils will probably help.
                        • TheoLT TheoL
                          tssk
                          So I used hot glue and it is better. Now I can hear the squeal only when I put my ear directly to the PCB. Thanks for the tips.
                          @TheoL I have no idea how to measure that.
                          I noticed that when the radio is transmitting the LED on the Arduino Pro Mini (not the power one) starts blinking very tiny. I still plan to remove the power LED and voltage regulator from the Arduino.
                          • T tssk
                            @tssk the led blinks because it is connected to the same pin as the SCK pin used by the nrf24.
                              tssk
                              #279
                              @mfalkvidd You are right :) I did not know that.
                              SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication, which, although provided by the underlying hardware, is not currently included in the Arduino language.
                              LED: 13. There is a built-in LED connected to digital pin 13. When the pin is HIGH value, the LED is on, when the pin is LOW, it's off.
                              https://www.arduino.cc/en/pmwiki.php?n=Main/ArduinoBoardProMini
                              Should I remove the LED to save power? Or it is marginal?
                              • T tssk
                                @tssk it is marginal
                                  tssk
                                  @mfalkvidd Thanks.
                                  • T
                                    tssk
                                    #282
                                    Hello
                                    I would like to ask for help with passive battery powered node I created with following components:
                                    • Arduino pro mini 8MHz - voltage regulator and power LED removed
                                    • SX1276 based 868MHz LoRa radio
                                    • BME680 sensor
                                    • DC-DC 3.3V step-up booster
                                    I created a battery measuring circuit according to scheme on this page ( https://www.mysensors.org/build/battery ).
                                    The problem is the two fresh new AA batteries lasted less than 14 days and stopped when the circuit measured 36%.
                                    2x1.5V AA Aerocell following start and end values:
                                    09.02.2021 16:45 102% (start) : 1.610V and 1.610V
                                    22.02.2021 04:15 36% (end) : 1.001V and -0.150V
                                    The node code is sleeping for 6 minutes between each sensing and sending data.
                                    sleep(180000);
                                    14 days seems very short to me. Is that normal? Is there something I can to make it last longer?
                                    mfalkviddM skywatchS 2 Replies Last reply
                                    • T tssk
                                      Hello
                                      • BME680 sensor
                                      sleep(180000);
                                      #283
                                      @tssk could you post your sketch? Some things that could draw power:
                                      • bme not turned off properly when sleeping the node
                                      • lora transmits can take a long time, depending on which settings are used
                                      Which booster are you using? A good booster will use almost no power when the node is sleeping. A bad booster will consume almost as much as if the node was not sleeping, so the performance of the booster will make a huge difference.
                                      • T tssk
                                        Hello
                                        • BME680 sensor
                                        sleep(180000);
                                        skywatchS
                                        skywatchS
                                        skywatch
                                        #284
                                        @tssk Sending 240 messages a day is quite a lot for a battery node. I think you will need higher capacity batteries with that frequency of sending (is it really essential to send that often I wonder?).
                                        Anyway, I am also testing battery nodes and as far as I can see the lora and bme are likely taking a lot of power. They must be 'put to sleep' as much as possible. AFAIK lora is an abbreviation of 'long range' and therefore means 'more power'. Can you test the current drawn by just the radio in sleep and transmitting?
                                        Also, bootloader - I highly recommend using the minicore bootloader with internal 8MHz, bod as you wish (I ususally disable) and try again. My sleeping nodes use less than 5uA in sleep and I am trying to get that even lower this week.
                                        Also check the value of pull-upresistors on the boards, they can be on the low side and perhaps better with higher value external ones (something I hope to test tomorrow as it happens).
                                        Also temperature and humidity will have an effect. I put one test node on a colder NE facing window which has slept all the time except a twice daily battery check and send value only if changed. It is the only node to have changed from 100% to 99% in a week, so the colder window is clearly having an effect on the battery life in this situation.
                                        As @mfalkvidd implied I would get rid of the stepup booster if at all possible, they are not so efficient and can produce a lot of noise on the power line. Can you go to 3xAA batteries? What about an 18650 li-on or two in parallel?
                                        Finally check solder joints. A dry joint or cold joint may look OK but measure them with a meter just to make sure.
                                          tssk
                                          @mfalkvidd
                                          • I did not know that I need to turn BME off ů how to do that?
                                          • Only thing I found is that Arduino has deepSleep() - but I am not sure if I can use it.
                                          • I am using the default Bw125Cr45Sf128 but thinking about testing Bw125Cr48Sf4096 to achieve greater range.
                                          • Booster is the whining one - https://www.laskarduino.cz/step-up-boost-menic-s-me2108-33v-480ma/
                                          • Is there a way I can measure power draw with multimeter?
                                          // Enable debug prints
                                          // Enable passive mode
                                          #define MY_PASSIVE_NODE
                                          // Passive mode requires static node ID
                                          #define MY_NODE_ID 100
                                          //#define MY_RADIO_RF24
                                          //#define MY_RADIO_NRF5_ESB
                                          #define MY_RADIO_RFM95
                                          #define MY_RFM95_FREQUENCY (RFM95_868MHZ)
                                          //#define MY_RFM95_MODEM_CONFIGRUATION RFM95_BW31_25CR48SF512
                                          #define MY_RFM95_CS_PIN 8
                                          #define MY_RFM95_IRQ_PIN 2
                                          #include <Adafruit_Sensor.h>
                                          #include "Adafruit_BME680.h"
                                          #define BME_SCK 13
                                          #define BME_MISO 12
                                          #define BME_MOSI 11
                                          #define BME_CS 10
                                          //#define SEALEVELPRESSURE_HPA (1013.25)
                                          // Initialize general message
                                          MyMessage msgTemp( 1, V_TEMP );
                                          MyMessage msgHumi( 2, V_HUM );
                                          MyMessage msgAirq( 3, V_LEVEL );
                                          //Adafruit_BME680 bme; // I2C
                                          Adafruit_BME680 bme(BME_CS); // hardware SPI
                                          //Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO,  BME_SCK);
                                            analogReference(INTERNAL);
                                            if (!bme.begin()) {
                                              Serial.println( "ERR: BME680 not found" );
                                              while (1);
                                            // Set up oversampling and filter initialization
                                            bme.setTemperatureOversampling(BME680_OS_8X);
                                            //bme.setPressureOversampling(BME680_OS_4X);
                                            bme.setHumidityOversampling(BME680_OS_2X);
                                            bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
                                            bme.setGasHeater(320, 150); // 320*C for 150 ms
                                            delay(2000);
                                          	sendSketchInfo("Room sensor", "4.0");
                                            wait(100);
                                          	present( 1, S_TEMP );
                                            wait(100);
                                            present( 2, S_HUM );
                                            wait(100);
                                            present( 3, S_AIR_QUALITY );
                                            int batt = analogRead( A3 );
                                            int battP = batt / 10;
                                            #ifdef MY_DEBUG
                                                float battV  = batt * 0.003363075;
                                                Serial.print( "Battery Voltage: " );
                                                Serial.print( battV );
                                                Serial.println(" V");
                                                Serial.print( "Battery percent: " );
                                                Serial.print( battP );
                                                Serial.println(" %");
                                            wait(100);
                                            sendBatteryLevel( battP );
                                            if (! bme.performReading()) {
                                              Serial.println( "ERR: BME680 reading failed" );
                                              return;
                                            float temp = bme.temperature;
                                            #ifdef MY_DEBUG
                                              Serial.print( "DBG: Temperature = " );
                                              Serial.print( temp );
                                              Serial.println( " C" );
                                            wait(100);
                                            send(msgTemp.set( temp, 2 ));
                                            float pres = bme.pressure/100.00;
                                            #ifdef MY_DEBUG
                                              Serial.print( "DBG: Pressure = " );
                                              Serial.print( pres );
                                              Serial.println( " hPa" );
                                            wait(100);
                                            send(msgPres.set(pres,2));
                                            float humi = bme.humidity;
                                            #ifdef MY_DEBUG
                                              Serial.print( "DBG: Humidity = " );
                                              Serial.print( humi );
                                              Serial.println( " %" );
                                            wait(100);
                                            send(msgHumi.set( humi, 2 ));
                                            float alti = bme.readAltitude(SEALEVELPRESSURE_HPA);
                                            #ifdef MY_DEBUG
                                              Serial.print( "DBG: Approx. Altitude = " );
                                              Serial.print( alti );
                                              Serial.println( " m" );
                                            wait(100);
                                            send(msgPosi.set(alti,2));
                                            float airq = bme.gas_resistance / 1000.0;
                                            #ifdef MY_DEBUG
                                              Serial.print("DBG: Gas Resistance = ");
                                              Serial.print( gas );
                                              Serial.println(" KOhms");
                                            wait(100);
                                            send(msgAirq.set( airq, 2 ));
                                            sleep(10000);
                                          	//sleep(180000);
