  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • E evb
    Meanwhile I found following forum topic : https://forum.mysensors.org/topic/2067/my-slim-2aa-battery-node. Thanks @m26872 :-)
    @mfalkvidd, I insist ;-) , if modifying these 'official' site articles turns out to be so difficult, can't a new section not be added like for example 'User experiences' or 'Advanced use' or 'Real world examples' or ... ?
    Now we are obliged to read through hours of forum topics, hoping to find more information somewhere.
    On one hand, this is of course instructive, but on the other hand it also wastes a lot of time looking for answers.
    If we already had a starting list of some topics from experienced users, the learning curve would already be smaller.
    I started my battery crusade months ago by ordering some Arduino Pro Mini's from our Chinese supplier AliExpress following the official site article.
    Because I could not obtain the given consumption of current, I began to search further.
    Today after hours of searching and reading on the forum, I realize that this choice was actually not the right one.
    I probably had better ordered the custom PCB from @m26872 and used a barebone 328P, or a Moteino or a Canique or...
    As far as the current of my pro mini is concerned, I'm stuck at a minimum of 133µA.
    • pro mini without power led and power regulator
    • refused using the MiniCore packet to 1.8V BOD and 1MHz internal
      • board : ATmega328
      • clock : internal 1 MHz
      • BOD : BOD 1.8V
      • EEPROM : EEPROM retained
      • Variant : 328P / 328PA
      • Bootloader : Yes (UART0)
    • only one open or closed contact on pin D3 with external pull-up of 1M ohm
    • radio is a RFM69HW
    • sketch is using the mysensors sleep function with interrupt wake up (MySensors lib version 2.3.2).
    To test if it was the radio module not completely sleeping and causing this consumption, I tested the same on a other pro mini (no power led and no power regulator, same refusing), without any external hardware, using the LowPower sketch from https://andreasrohner.at/posts/Electronics/How-to-modify-an-Arduino-Pro-Mini-clone-for-low-power-consumption/
    ==>same measurement : 133µA
    So the radio module is not the raison!
    So what is the cause of this higher consumption?
    The quality of the Chinese clone boards?
    Or is there still external hardware on the board consuming some current? The external crystal still present for example?
    On the pro mini, there is a led connected to the SCK pin. I think that will add an extra of +-1mA when the radio is active?
    But it has nothing to do with the sleep current of 133µA...
    caniqueC
    caniqueC
    canique
    @evb little info regarding the LED on the SCK pin.
    Assuming it is a red LED with a forward voltage of 1.8V, considering the chip is powered with 3.3V and considering the 330 Ohm resistor in series with the LED, the additional current draw when SCK goes high should be about 4.5mA.
    • E
      E
      evb
      @canique you confirm my suspicions. For the moment I have 3 working battery nodes with the pro mini and the RFM69HW. We will see how long the batteries are going to last. Normally it should be one year.
      I'm constrained by the maximum dimensions of the sensor node. The case must go inside the PVC door frame, so it can be maximum 20mm width on 17mm height, the length is not a constraint. :-)
      I had to solder the RFM69HW in line with the pro mini.
      The MK2 boards are unfortunately too wide.
      YveauxY caniqueC 2 Replies Last reply
      • E evb
        @evb how's the range of your node? Being enclosed in aluminum will definitely reduce range.
        E 1 Reply Last reply
        • E evb
          caniqueC
          caniqueC
          canique
          wrote on last edited by canique
          #263
          @evb I can't see it clearly on the picture but this seems like a reed sensor to me.
          Well, usually the transmitter does not have to be at some specific location. There are reed sensors based on magnets (connected with 2 wires to the transmitter). As soon as the magnets are close to each other, a small current flows (or vice versa). They are just attached to the window/door with some sticky adhesive. The transmitter can well be a meter away.
          I can say from experience with Atmega328P, that when drawing ~24uA in sleep and sending every 30 seconds a single battery lasts ~ 1 year.
          This can all be calculated (rough estimates).
          A basic online calculator for this kind of stuff can be found @ https://oregonembedded.com/batterycalc.htm
          • YveauxY Yveaux
            E
            E
            evb
            @Yveaux It is not a aluminium door frame, but a PVC door frame (plastic).
            The problem is that my gateway is in the extension of the brick wall, about 15m away in the garage at the backyard. So I have a 5m brick wall between de node and the gateway :-(
            This means that the reliability of the connection is not good, so I had to place a repeater node between them.
            • caniqueC canique
              E
              E
              evb
              @canique no, the purpose of the node is to know when the door is locked by the bolt, not only closed. What you see are simply 2 battery springs and the bolt of the lock closes the contact.
              I can move the node more upwards the door frame (and I will do it if the radio connection is still not reliable with the repeater).
              In order to preserve domestic peace, I placed the nodes in the door frame, invisible when the door is closed: no visible dangling wires and no visible boxes.
              Maybe an idea for a MK3 version of your board as wide as the RFM69HW ;-)
              • T
                tssk
                Hello
                I created battery powered node running on 2x 1.5V AA batteries with DC-DC step up booster. But the step up booster makes audible noise (very tiny beeping) when the radio is transmitting.
                It is this step up booster https://www.laskarduino.cz/step-up-boost-menic-s-me2108-33v-480ma/
                Is there any way to solve it?
                Tomas
                TheoLT caniqueC BearWithBeardB 3 Replies Last reply
                • T tssk
                  Hello
                  Tomas
                  TheoLT
                  TheoLT
                  TheoL
                  @tssk First things that comes to my mind is that you might draw too much power (but no expert) did you measure it?
                  • T tssk
                    Hello
                    Tomas
                    caniqueC
                    caniqueC
                    canique
                    @tssk There is a name for this noise: it is called "coil whine". In German "Spulenfiepen". It stems from the inductor - I wouldn't know any way to get rid of it.
                    My mainboard or power supply on my PC creates similar noise when the CPU goes in certain doze modes.
                    • T tssk
                      Hello
                      Tomas
                      BearWithBeardB
                      BearWithBeardB
                      BearWithBeard
                      @tssk I heard that people got rid of or at least reduced the coil whine by coating the windings of an audible inductor with non-conductive materials like epoxy resin or even hot glue to reduce the vibrations.
                      Of course, I woudn't mess with expensive PC hardware, but I guess there's not much to loose with a cheap boost module like this.
                      • BearWithBeardB BearWithBeard
                        tssk
                        Thanks all for the response.
                        @BearWithBeard I will start googling about such solution.
                        Do you think using different step up booster might help? Could someone recommend something?
                        • caniqueC
                          caniqueC
                          canique
                          I am biased since I run that website but I can recommend https://www.canique.com/boost
                          I've never heard it making noise.
                          • caniqueC canique
                            tssk
                            wrote on last edited by tssk
                            #272
                            @canique Thanks for the recommendation if I do not find fix for the model I am using I will consider buying it.
                            I will try to hot glue the side with the coil as I found on some pages. Any ideas / warnings? :)
                            • T tssk
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @tssk Most of these boosters have a grounded backplane, perhaps trying to re-orientate the inductor so the backplane acts a shield to direct RF may be an option to try ?
                              If the noise in on the power line I've heard of some managing to block it with a VR circuit if the voltage drop is acceptable, but never tried it.
                              • zboblamontZ zboblamont
                                tssk
                                @zboblamont It is not electrical noise but audio noise I can hear. Sorry if I use improper terms.
                                zboblamontZ skywatchS 2 Replies Last reply
                                • T tssk
                                  zboblamontZ
                                  zboblamontZ
                                  zboblamont
                                  @tssk My misconception.
                                  • T tssk
                                    skywatchS
                                    skywatchS
                                    skywatch
                                    @tssk If the item is not going to be too hot then hot melted candle wax dripped over the coils will probably help.
                                    • TheoLT TheoL
                                      tssk
                                      So I used hot glue and it is better. Now I can hear the squeal only when I put my ear directly to the PCB. Thanks for the tips.
                                      @TheoL I have no idea how to measure that.
                                      I noticed that when the radio is transmitting the LED on the Arduino Pro Mini (not the power one) starts blinking very tiny. I still plan to remove the power LED and voltage regulator from the Arduino.
                                      • T tssk
                                        @tssk the led blinks because it is connected to the same pin as the SCK pin used by the nrf24.
                                          tssk
                                          #279
                                          @mfalkvidd You are right :) I did not know that.
                                          SPI: 10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK). These pins support SPI communication, which, although provided by the underlying hardware, is not currently included in the Arduino language.
                                          LED: 13. There is a built-in LED connected to digital pin 13. When the pin is HIGH value, the LED is on, when the pin is LOW, it's off.
                                          https://www.arduino.cc/en/pmwiki.php?n=Main/ArduinoBoardProMini
                                          Should I remove the LED to save power? Or it is marginal?
