  2. Announcements
  3. 💬 Air Humidity Sensor - Si7021
temperaturehumiditysi7021
28 Posts 13 Posters 6.3k Views 12 Watching
    @bebr could it be temperature related? I have noticed that the voltage in my nodes increase when the sun is shining on them.
    B
    B
    bebr
    wrote on last edited by bebr
    @mfalkvidd I thought of this too, but I opened the windows this morning, 11°C here this morning, and the battery level stayed around 50%.
    Here are some graphs showing it's not temperature related:
    • B
      B
      bebr
      I noticed I used a 10uF/50V capacitor instead of a 0.1uF/5V for LM2936 regulator.
      Could it be the source of my problem?
      I change it last evening, and now the reported battery level seems ok.
      Sorry, I'm noob in electronics :)
      skywatchS 1 Reply Last reply
      • B bebr
        skywatchS
        skywatchS
        skywatch
        @bebr Yes, that would make a big difference. Good that you spotted it though!
        • B
          B
          bebr
          #22
          Even with the 0.1uF capacitor, I had wrong values.
          So, I've gone with the voltage divider method, and it seems more reliable, at least for my case.
          4.7V max to VCC, R1 1M, R2 330k, another 0.1uF capacitor in parallel with R2.
          I don't need a very good accuracy, just a trend in order to know when to change my batteries.
          Thanks for your help.
          • H
            H
            hoggin
            Anyone know why when the temp goes below 32F it jumps all the way down to -100? I have followed this configuration to the T but cannot figure this out. Watching serial output shows the temp at -100 or so whenever the temp is below 32F. As if the conversion is off or something.
            • H hoggin
              @hoggin interesting that nobody has had problems with this before. I checked the code, and the problem is caused by treating a signed integer as unsigned. https://github.com/mysensors/MySensorsArduinoExamples/blob/master/libraries/SI7021/SI7021.cpp#L41
              I think it will work properly if you change unsigned int to int in SI7021.cpp.
              • mfalkviddM
                Suggested fix is available at https://github.com/mysensors/MySensorsArduinoExamples/pull/51
                • H
                  H
                  hoggin
                  FIXED!!! Thanks. I have been struggling.
                  • P
                    P
                    pahe
                    Hello , I have a problem with this shetch . I get from sensor in serial monitor - Temp 128.86C Hum 118.99 ,
                    Can someone help me ? Thanks
                    • H
                      H
                      hoggin
                      My next issue is the humidity seems to be off. It has read as high as 115% humidity. Is this normal or should I be considering a correction? If so, how would I enter a correction. Its a little odd considering it states that the accuracy is much tighter than that.
