  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.3k Views 26 Watching
  • monteM
    monteM
    monte
    Mentioned hardware bugs are easily omitted by using custom sleep function.
    Puneit ThukralP 1 Reply Last reply
    • monteM monte
      Puneit ThukralP
      Puneit ThukralP
      Puneit Thukral
      @monte Could you please share the custom sleep function?
      monteM 1 Reply Last reply
      • Puneit ThukralP Puneit Thukral
        monteM
        monteM
        monte
        @Puneit-Thukral you can start looking from here https://forum.mysensors.org/post/92044
        • electrikE
          electrikE
          electrik
          Is it possible to use such a ready made device, and reprogram it with a mysensors sketch?
          https://a.aliexpress.com/_v4kOXD
          • electrikE electrik
            monteM
            monteM
            monte
            wrote on last edited by monte
            #67
            @electrik yes. You will need an SWD programmer, J-link, ST-link or black magic probe will do. But the thing, you've linked isn't NRF5 device. So if you are asking about exactly that device, then answer is no. Only Nordic bluetooth devices are supported by mysensors. The one you've linked uses TI chip.
            electrikE 1 Reply Last reply
            • monteM monte
              electrikE
              electrikE
              electrik
              @monte Thanks. I didn't notice it was not a Nordic one. So if I take such module, I just have to figure out the pins to program and it can be re-used.
              Did you or someone else ever tried this?
              https://nl.aliexpress.com/item/4000389437486.html?spm=a2g0o.productlist.0.0.454562f4dPgTnm&algo_pvid=453cb8be-1c2a-43ea-a56c-61bbbf3a4822&algo_expid=453cb8be-1c2a-43ea-a56c-61bbbf3a4822-26&btsid=2100bdf116156431118194203efa5d&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
              nagelcN 1 Reply Last reply
                nagelcN
                nagelcN
                nagelc
                wrote on last edited by nagelc
                #69
                Hi @electrik
                You can program these ibeacons to work with MySensors.
                I reprogrammed one by soldering some wires to a jlink adapter. Not elegant, but it worked.
                Some type of push pin setup would be good if you are going to actually use these modules.
                The version I got had only a button on the board, and no way to easily add any other sensors, so they weren't very useful. It would be interesting to try the ones with the temperature and acceleromator.
                • A
                  abelson
                  I am using a generic nRF52 dev board with the Arduino nRF52 core. I am trying to get a sample BLE service to display, but it cannot find it on my BLE scanner. After I couldn't get that to work, I decided to make the code even simpler. Since the dev board that I am using has a serial USB out I thought I would just check if I could get a "Hello World!" to the serial monitor... After flashing the soft device, I still couldn't get any output on my serial monitor.
                  Licensed under GNU GPL v2
                  For bug reports, read
                  debug_level: 0
                  0x4000
                  adapter speed: 10000 kHz
                  xPSR: 0x61000000 pc: 0x0001b08e msp: 0x20001188
                  xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
                  ** Programming Started **
                  auto erase enabled
                  target halted due to breakpoint, current mode: Thread
                  xPSR: 0x61000000 pc: 0x2000001e msp: 0xfffffffc
                  wrote 114688 bytes from file C:\Users\Admin\Documents\ArduinoData\packages\sandeepmistry\hardware\nRF5\0.7.0/cores/nRF5/SDK/components/softdevice/s132/hex/s132_nrf52_2.0.1_softdevice.hex in 2.559271s (43.762 KiB/s)
                  ** Programming Finished **
                  ** Verify Started **
                  xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
                  verified 110636 bytes in 0.372659s (289.924 KiB/s)
                  ** Verified OK **
                  ** Resetting Target **
                  shutdown command invoked
                  I am using OpenOCD and an ST-Link v2 to upload my code and it looks like it is uploading successfully. Here is the output when I try to flash the S132 soft device:
                    Serial.begin(9600);
                    Serial.println("Hello World!");
                    delay(1000);
                  I also tried running this code with the MySensors library:
                  #define MY_RADIO_NRF5_ESB
                    Serial.begin(9600);
                    Serial.println("Starting");
                    delay(3000);
                  And got this error:
                  In file included from C:\Users\Admin\Documents\ArduinoData\packages\sandeepmistry\hardware\nRF5\0.7.0\cores\nRF5/Arduino.h:5:0,
                                   from sketch\MyBoardNRF5.ino.cpp:1:
                  c:\users\admin\documents\arduinodata\packages\sandeepmistry\tools\gcc-arm-none-eabi\5_2-2015q4\lib\gcc\arm-none-eabi\5.2.1\include\stdint.h:9:26: fatal error: stdint.h: No such file or directory
                  compilation terminated.
                  exit status 1
                  Error compiling for board MyBoardNRF5 nRF52832.
                  Error while flashing SoftDevice.
                  java.io.FileNotFoundException: C:\Users\Admin\Documents\ArduinoData\packages\MySensors\hardware\nRF5\0.3.0\softdevices.txt (The system cannot find the file specified)
                  • A abelson
                    debug_level: 0
                    0x4000
                    auto erase enabled
                    ** Verified OK **
                      Serial.begin(9600);
                      delay(1000);
                      Serial.begin(9600);
                      delay(3000);
                    And got this error:
                    exit status 1
                    monteM
                    monteM
                    monte
                    @abelson first you have to flash SD and then chose softdevice in board options and flash your sketch.
                    It seems that you are lacking softdevice binary. It seems that your version of sandeepmistry's NRF5 core is pretty outdated, you have 0.3 version when surrent version is 0.7. No wonder that links to softdevice binaries are broken in softdevices.txt. Try updating core to the latest version and/or downloading softevice binary from nordic's site yourself.
                    A 1 Reply Last reply
                    • monteM monte
                      abelson
                      @monte that makes sense. Do you know what options I have to do to flash the sketch after I flash the soft device? If I get the above output that I posted, does that mean that the soft device flashed successfully?
                      • A abelson
                        monteM
                        monteM
                        monte
                        #73
                        @abelson no. You need to have softdevice binary on your PC to flash it to NRF board. Please, read my answer above and try to do, what I suggested.
                        You need to choose softdevice option if it has been flashed to the board.
                        • I idanronen
                          @BearWithBeard said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                          I just got my first NRF5 running. I'll note how I got it working in case any of you guys still have troubles:
                          Setup
                          • OS: Windows 10
                          • Programmer: STM32 Blue Pill with the Black Magic Probe firmware
                          • NRF5: EByte E73-TBB dev board with a E73-2G4M0S1B (NRF52832)
                          • Environment: PlatformIO
                          Instructions
                          Load the Black Magic Probe firmware with stlink as the probe host onto Blue Pill. You can follow this guide.
                          Connect your new BMP to the NRF52 module:
                          BMP NRF52 Serial Port
                          3V3 3V3
                          GND GND
                          A5 SWDCLK GDB Server
                          B14 SWDIO GBD Server
                          A2 TX UART
                          A3 RX UART
                          Note: A2 and A3 are not required for programming. This is how you'd wire up the BMP for "classic" serial debugging. You can use the BMP both for programming and serial communication - no need for a second FTDI module.
                          Using the GNU Arm Embedded Toolchain, run arm-none-eabi-gdb in a console and enter the following commands to unlock the NRF52:
                          target extended-remote BMP_GDB_SERVER_PORT
                          mon swdp_scan
                          attach N // N = number of "Nordic nRF52 Access Port" if there are several
                          mon erase_mass
                          detach
                          From the two serial ports the BMP provides, you want to use the GDB Server for BMP_GDB_SERVER_PORT above. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should (usually) be the right choice. If not, try the other one.
                          Windows users also must prefix the port with \\.\ if the number is double-digit, e.g. \\.\COM13.
                          Now you can start uploading sketches the usual way. Here's my minimal PlatformIO config:
                          [env:nrf52_dk]
                          platform = nordicnrf52
                          board = nrf52_dk
                          board_build.variant = generic
                          framework = arduino
                          upload_protocol = blackmagic
                          lib_deps =
                          	548 ; MySensors
                          And a minimal test sketch for MySensors:
                          #include <Arduino.h>
                          #define LED 17
                          #define MY_RADIO_RF24
                          #define MY_NODE_ID 182
                          #define SKETCH_NAME "NRF52 Test"
                          #define SKETCH_VERSION "0.1"
                          #define CHILD_ID 1
                          MyMessage msg(CHILD_ID, V_VAR1);
                            present(CHILD_ID, S_CUSTOM);
                            pinMode(LED, OUTPUT);
                            static uint8_t num;
                            send(msg.set(num));
                            ++num;
                            digitalWrite(LED, HIGH);
                            wait(5000);
                            digitalWrite(LED, LOW);
                            wait(5000);
                          Works like a charm so far! Now, if you please excuse me, I have a whole new microprocessor family to explore. Fun times!
                          For the life of me i cant figure out if im making the BlackMagic properly. I'm moving the boot0 jumper to 1, flashing the 8kb maple (usb flash) DFU file using the st-link application on windows.
                          I move the jumper back to 0, and connect using the micro usb, and i can flash code normally using arudino IDE using the STM32duino bootloader (and if i do so, i see the device communication on a new COM port).
                          From there i cant get anything from these guides to work. the windows STM "flash demonstrator" app doesnt recognize the device, and i dont have a linux machine available at the moment for the dfu-util (and Ubuntu shell on windows wont recognize the usb device). When i try to flash the blackmagic.bin starting at 0x08002000 using the ST-link software it shows it succeeded, but when i return the jumper to 0 and reset the device, this is what i get:
                          The 2 new COM ports appear (COM12,COM13), but i cant seem to flash anything successfully.
                          I've installed the GNU arm toolchain for windows and tried "target extended-remote \.\COM13" (12 just gets stuck on nothing), and i get:
                          electrikE
                          electrikE
                          electrik
                          • BearWithBeardB BearWithBeard
                            Setup
                            • OS: Windows 10
                            Instructions
                            3V3 3V3
                            GND GND
                            A2 RXI UART
                            A3 TXO UART
                            mon swdp_scan
                            mon erase_mass
                            detach
                            [env:nrf52_dk]
                            board = nrf52_dk
                            framework = arduino
                            lib_deps =
                            	548 ; MySensors
                            #define LED 17
                            #define CHILD_ID 1
                              static uint8_t num;
                              send(msg.set(num));
                              ++num;
                              wait(5000);
                              wait(5000);
                            electrikE
                            electrikE
                            electrik
                            @BearWithBeard
                            Great explanation, thanks!
                            On my windows 10 installation I had to run Zadig to make the programming from platformIO work.
                            • electrikE
                              electrikE
                              electrik
                              @BearWithBeard
                              What did you do to get the serial pins of the Ebyte development board configured correctly, when using the generic board variant in platformIO? I've copied MyBoardNRF5.cpp but this is not used it seems.
                              Also redefining the definitions from variant.h
                              #define PIN_SERIAL_TX (11)
                              #define PIN_SERIAL_RX (12)
                              doesn't give serial output.
                              BearWithBeardB 1 Reply Last reply
                                @BearWithBeard
                                BearWithBeardB
                                BearWithBeardB
                                BearWithBeard
                                @electrik Yeah, I ran into that issue, too. Not sure if that's the proper way to solve it, but I add a custom board directory to the build flags in platformio.ini ...
                                build_flags =
                                	-I $PROJECT_DIR/boards/generic
                                ... and copied the board variant files from .platformio/packages/framework-arduinonordicnrf5/variants/Generic/ to boards/generic/ in my project folder. Changes made in here aren't ignored or overwritten by global PIO definitions.
                                  build_flags =
                                  electrikE
                                  electrikE
                                  electrik
                                  @BearWithBeard Thanks that did it.
                                  Could it be the TX and RX are switched on the BMP in your post?
                                    BearWithBeardB
                                    BearWithBeardB
                                    BearWithBeard
                                    @electrik Good to hear. And yes, I think you are right. I'll swap them and change the naming to RXI and TXO to clarify the directionality. Thanks for the hint!
                                    • I
                                      I
                                      Ivanli
                                      Banned
                                      Great post, thanks a lot for sharing.
                                      • nagelcN
                                        nagelcN
                                        nagelc
                                        With respect to initial erase of NRF52, I have been using @BearWithBeard Black Magic Probe instructions successfully for years. But, my latest set of Minew boards doesn't respond.
                                        I found that there is a new lock procedure from Nordic:
                                        https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/working-with-the-nrf52-series-improved-approtect
                                        I have tried upgrading my gdb and also J-Link EDU and nrfjprog tool chains and have not successfully connected to the new boards yet.
                                        Has anyone had success with unlocking one of these new boards?
                                        • nagelcN nagelc
                                          #82
                                          @nagelc Sorry I don't have an informed answer, but thanks for posting and making us aware of your experience with the minew's! Haven't heard from you in a while. Have you tried upgrading the firmware on the J-link that's part of a DK? I can't say that I have, but the firmware upgradeability was one of the alleged selling features of a DK's J-Link. That potential upgradeability didn't ever seem to matter, but maybe now it does.
                                          As for me, after a long break I'm back to have a run at getting the nRF52805 to work. So far I've got bare metal blinking and bare metal UART working. I'm opting for bare metal code because it's unclear how well anything else will work with the nRF52805, which doesn't seem all that well supported. Soon to get some basic bare metal proprietary radio working, I hope.... If successful, I'll post it to github to memorialize it. There are surprisingly few examples of bare metal code out there, even though that's all the datasheet itself talks about. I guess I can understand why, because I've found some surprising ambiguities in the datasheet. For instance, who would have thought that PSELTXD would refer to an actual pin number and not to a bitmask? From the datasheet I thought for sure it would be a bitmask (like nearly everything else in the datasheet), but no, it's the actual pin number. I mean, why does the datasheet show literally every bit of a 32 bit word is relevant for specifying the pin number? On a different issue, bare metal UART doesn't work quite right without some artificial delays, even if driven by interrupt events, apparently because the actual generated baudrates aren't exactly right (something the datasheet admits). So, there's some finessing involved that you don't see when you're only working from abstracted libraries.
                                          Regardless, the architecture itself remains pretty cool, and I enjoy it a lot!
