  3. GUIDE - NRF5 / NRF51 / NRF52 for beginners
102 Posts 26 Posters 50.3k Views 26 Watching
  • electrikE electrik
    Is it possible to use such a ready made device, and reprogram it with a mysensors sketch?
    https://a.aliexpress.com/_v4kOXD
    monteM
    monteM
    monte
    wrote on last edited by monte
    #67
    @electrik yes. You will need an SWD programmer, J-link, ST-link or black magic probe will do. But the thing, you've linked isn't NRF5 device. So if you are asking about exactly that device, then answer is no. Only Nordic bluetooth devices are supported by mysensors. The one you've linked uses TI chip.
    electrikE 1 Reply Last reply
    • monteM monte
      electrikE
      electrikE
      electrik
      @monte Thanks. I didn't notice it was not a Nordic one. So if I take such module, I just have to figure out the pins to program and it can be re-used.
      Did you or someone else ever tried this?
      https://nl.aliexpress.com/item/4000389437486.html?spm=a2g0o.productlist.0.0.454562f4dPgTnm&algo_pvid=453cb8be-1c2a-43ea-a56c-61bbbf3a4822&algo_expid=453cb8be-1c2a-43ea-a56c-61bbbf3a4822-26&btsid=2100bdf116156431118194203efa5d&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
      nagelcN 1 Reply Last reply
        nagelcN
        nagelcN
        nagelc
        wrote on last edited by nagelc
        #69
        Hi @electrik
        You can program these ibeacons to work with MySensors.
        I reprogrammed one by soldering some wires to a jlink adapter. Not elegant, but it worked.
        Some type of push pin setup would be good if you are going to actually use these modules.
        The version I got had only a button on the board, and no way to easily add any other sensors, so they weren't very useful. It would be interesting to try the ones with the temperature and acceleromator.
        • A
          abelson
          I am using a generic nRF52 dev board with the Arduino nRF52 core. I am trying to get a sample BLE service to display, but it cannot find it on my BLE scanner. After I couldn't get that to work, I decided to make the code even simpler. Since the dev board that I am using has a serial USB out I thought I would just check if I could get a "Hello World!" to the serial monitor... After flashing the soft device, I still couldn't get any output on my serial monitor.
          Licensed under GNU GPL v2
          For bug reports, read
          debug_level: 0
          0x4000
          adapter speed: 10000 kHz
          xPSR: 0x61000000 pc: 0x0001b08e msp: 0x20001188
          xPSR: 0x01000000 pc: 0xfffffffe msp: 0xfffffffc
          ** Programming Started **
          auto erase enabled
          target halted due to breakpoint, current mode: Thread
          xPSR: 0x61000000 pc: 0x2000001e msp: 0xfffffffc
          wrote 114688 bytes from file C:\Users\Admin\Documents\ArduinoData\packages\sandeepmistry\hardware\nRF5\0.7.0/cores/nRF5/SDK/components/softdevice/s132/hex/s132_nrf52_2.0.1_softdevice.hex in 2.559271s (43.762 KiB/s)
          ** Programming Finished **
          ** Verify Started **
          xPSR: 0x61000000 pc: 0x2000002e msp: 0xfffffffc
          verified 110636 bytes in 0.372659s (289.924 KiB/s)
          ** Verified OK **
          ** Resetting Target **
          shutdown command invoked
          I am using OpenOCD and an ST-Link v2 to upload my code and it looks like it is uploading successfully. Here is the output when I try to flash the S132 soft device:
            Serial.begin(9600);
            Serial.println("Hello World!");
            delay(1000);
          I also tried running this code with the MySensors library:
          #define MY_RADIO_NRF5_ESB
            Serial.begin(9600);
            Serial.println("Starting");
            delay(3000);
          And got this error:
          In file included from C:\Users\Admin\Documents\ArduinoData\packages\sandeepmistry\hardware\nRF5\0.7.0\cores\nRF5/Arduino.h:5:0,
                           from sketch\MyBoardNRF5.ino.cpp:1:
          c:\users\admin\documents\arduinodata\packages\sandeepmistry\tools\gcc-arm-none-eabi\5_2-2015q4\lib\gcc\arm-none-eabi\5.2.1\include\stdint.h:9:26: fatal error: stdint.h: No such file or directory
          compilation terminated.
          exit status 1
          Error compiling for board MyBoardNRF5 nRF52832.
          Error while flashing SoftDevice.
          java.io.FileNotFoundException: C:\Users\Admin\Documents\ArduinoData\packages\MySensors\hardware\nRF5\0.3.0\softdevices.txt (The system cannot find the file specified)
          monteM 1 Reply Last reply
          • A abelson
            debug_level: 0
            0x4000
            auto erase enabled
            ** Verified OK **
              Serial.begin(9600);
              delay(1000);
              Serial.begin(9600);
              delay(3000);
            And got this error:
            exit status 1
            monteM
            monteM
            monte
            @abelson first you have to flash SD and then chose softdevice in board options and flash your sketch.
            It seems that you are lacking softdevice binary. It seems that your version of sandeepmistry's NRF5 core is pretty outdated, you have 0.3 version when surrent version is 0.7. No wonder that links to softdevice binaries are broken in softdevices.txt. Try updating core to the latest version and/or downloading softevice binary from nordic's site yourself.
            A 1 Reply Last reply
            • monteM monte
              abelson
              @monte that makes sense. Do you know what options I have to do to flash the sketch after I flash the soft device? If I get the above output that I posted, does that mean that the soft device flashed successfully?
              • A abelson
                monteM
                monteM
                monte
                #73
                @abelson no. You need to have softdevice binary on your PC to flash it to NRF board. Please, read my answer above and try to do, what I suggested.
                You need to choose softdevice option if it has been flashed to the board.
                • I idanronen
                  @BearWithBeard said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                  I just got my first NRF5 running. I'll note how I got it working in case any of you guys still have troubles:
                  Setup
                  • OS: Windows 10
                  • Programmer: STM32 Blue Pill with the Black Magic Probe firmware
                  • NRF5: EByte E73-TBB dev board with a E73-2G4M0S1B (NRF52832)
                  • Environment: PlatformIO
                  Instructions
                  Load the Black Magic Probe firmware with stlink as the probe host onto Blue Pill. You can follow this guide.
                  Connect your new BMP to the NRF52 module:
                  BMP NRF52 Serial Port
                  3V3 3V3
                  GND GND
                  A5 SWDCLK GDB Server
                  B14 SWDIO GBD Server
                  A2 TX UART
                  A3 RX UART
                  Note: A2 and A3 are not required for programming. This is how you'd wire up the BMP for "classic" serial debugging. You can use the BMP both for programming and serial communication - no need for a second FTDI module.
                  Using the GNU Arm Embedded Toolchain, run arm-none-eabi-gdb in a console and enter the following commands to unlock the NRF52:
                  target extended-remote BMP_GDB_SERVER_PORT
                  mon swdp_scan
                  attach N // N = number of "Nordic nRF52 Access Port" if there are several
                  mon erase_mass
                  detach
                  From the two serial ports the BMP provides, you want to use the GDB Server for BMP_GDB_SERVER_PORT above. If Windows only provides generic names for both ("USB Serial Device" or something), the one with the lower number should (usually) be the right choice. If not, try the other one.
                  Windows users also must prefix the port with \\.\ if the number is double-digit, e.g. \\.\COM13.
                  Now you can start uploading sketches the usual way. Here's my minimal PlatformIO config:
                  [env:nrf52_dk]
                  platform = nordicnrf52
                  board = nrf52_dk
                  board_build.variant = generic
                  framework = arduino
                  upload_protocol = blackmagic
                  lib_deps =
                  	548 ; MySensors
                  And a minimal test sketch for MySensors:
                  #include <Arduino.h>
                  #define LED 17
                  #define MY_RADIO_RF24
                  #define MY_NODE_ID 182
                  #define SKETCH_NAME "NRF52 Test"
                  #define SKETCH_VERSION "0.1"
                  #define CHILD_ID 1
                  MyMessage msg(CHILD_ID, V_VAR1);
                    present(CHILD_ID, S_CUSTOM);
                    pinMode(LED, OUTPUT);
                    static uint8_t num;
                    send(msg.set(num));
                    ++num;
                    digitalWrite(LED, HIGH);
                    wait(5000);
                    digitalWrite(LED, LOW);
                    wait(5000);
                  Works like a charm so far! Now, if you please excuse me, I have a whole new microprocessor family to explore. Fun times!
                  For the life of me i cant figure out if im making the BlackMagic properly. I'm moving the boot0 jumper to 1, flashing the 8kb maple (usb flash) DFU file using the st-link application on windows.
                  I move the jumper back to 0, and connect using the micro usb, and i can flash code normally using arudino IDE using the STM32duino bootloader (and if i do so, i see the device communication on a new COM port).
                  From there i cant get anything from these guides to work. the windows STM "flash demonstrator" app doesnt recognize the device, and i dont have a linux machine available at the moment for the dfu-util (and Ubuntu shell on windows wont recognize the usb device). When i try to flash the blackmagic.bin starting at 0x08002000 using the ST-link software it shows it succeeded, but when i return the jumper to 0 and reset the device, this is what i get:
                  The 2 new COM ports appear (COM12,COM13), but i cant seem to flash anything successfully.
                  I've installed the GNU arm toolchain for windows and tried "target extended-remote \.\COM13" (12 just gets stuck on nothing), and i get:
                  electrikE
                  electrikE
                  electrik
                  • BearWithBeardB BearWithBeard
                    Setup
                    • OS: Windows 10
                    Instructions
                    3V3 3V3
                    GND GND
                    A2 RXI UART
                    A3 TXO UART
                    mon swdp_scan
                    mon erase_mass
                    detach
                    [env:nrf52_dk]
                    board = nrf52_dk
                    framework = arduino
                    lib_deps =
                    	548 ; MySensors
                    #define LED 17
                    #define CHILD_ID 1
                      static uint8_t num;
                      send(msg.set(num));
                      ++num;
                      wait(5000);
                      wait(5000);
                    electrikE
                    electrikE
                    electrik
                    @BearWithBeard
                    Great explanation, thanks!
                    On my windows 10 installation I had to run Zadig to make the programming from platformIO work.
                    • electrikE
                      electrikE
                      electrik
                      @BearWithBeard
                      What did you do to get the serial pins of the Ebyte development board configured correctly, when using the generic board variant in platformIO? I've copied MyBoardNRF5.cpp but this is not used it seems.
                      Also redefining the definitions from variant.h
                      #define PIN_SERIAL_TX (11)
                      #define PIN_SERIAL_RX (12)
                      doesn't give serial output.
                      BearWithBeardB 1 Reply Last reply
                        @BearWithBeard
                        BearWithBeardB
                        BearWithBeardB
                        BearWithBeard
                        @electrik Yeah, I ran into that issue, too. Not sure if that's the proper way to solve it, but I add a custom board directory to the build flags in platformio.ini ...
                        build_flags =
                        	-I $PROJECT_DIR/boards/generic
                        ... and copied the board variant files from .platformio/packages/framework-arduinonordicnrf5/variants/Generic/ to boards/generic/ in my project folder. Changes made in here aren't ignored or overwritten by global PIO definitions.
                          build_flags =
                          electrikE
                          electrikE
                          electrik
                          @BearWithBeard Thanks that did it.
                          Could it be the TX and RX are switched on the BMP in your post?
                            BearWithBeardB
                            BearWithBeardB
                            BearWithBeard
                            @electrik Good to hear. And yes, I think you are right. I'll swap them and change the naming to RXI and TXO to clarify the directionality. Thanks for the hint!
                            • I
                              I
                              Ivanli
                              Banned
                              Great post, thanks a lot for sharing.
                              • nagelcN
                                nagelcN
                                nagelc
                                With respect to initial erase of NRF52, I have been using @BearWithBeard Black Magic Probe instructions successfully for years. But, my latest set of Minew boards doesn't respond.
                                I found that there is a new lock procedure from Nordic:
                                https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/working-with-the-nrf52-series-improved-approtect
                                I have tried upgrading my gdb and also J-Link EDU and nrfjprog tool chains and have not successfully connected to the new boards yet.
                                Has anyone had success with unlocking one of these new boards?
                                • nagelcN nagelc
                                  #82
                                  @nagelc Sorry I don't have an informed answer, but thanks for posting and making us aware of your experience with the minew's! Haven't heard from you in a while. Have you tried upgrading the firmware on the J-link that's part of a DK? I can't say that I have, but the firmware upgradeability was one of the alleged selling features of a DK's J-Link. That potential upgradeability didn't ever seem to matter, but maybe now it does.
                                  As for me, after a long break I'm back to have a run at getting the nRF52805 to work. So far I've got bare metal blinking and bare metal UART working. I'm opting for bare metal code because it's unclear how well anything else will work with the nRF52805, which doesn't seem all that well supported. Soon to get some basic bare metal proprietary radio working, I hope.... If successful, I'll post it to github to memorialize it. There are surprisingly few examples of bare metal code out there, even though that's all the datasheet itself talks about. I guess I can understand why, because I've found some surprising ambiguities in the datasheet. For instance, who would have thought that PSELTXD would refer to an actual pin number and not to a bitmask? From the datasheet I thought for sure it would be a bitmask (like nearly everything else in the datasheet), but no, it's the actual pin number. I mean, why does the datasheet show literally every bit of a 32 bit word is relevant for specifying the pin number? On a different issue, bare metal UART doesn't work quite right without some artificial delays, even if driven by interrupt events, apparently because the actual generated baudrates aren't exactly right (something the datasheet admits). So, there's some finessing involved that you don't see when you're only working from abstracted libraries.
                                  Regardless, the architecture itself remains pretty cool, and I enjoy it a lot!
                                  • nagelcN
                                    nagelcN
                                    nagelc
                                    After correcting a wiring error (duh!) I was able to erase using my J-Link Mini EDU.
                                    I used Nordic's nrfjprog:
                                    nrfjprog --family NRF52 --recover
                                    I had to run it twice to get the unlock. I think this makes sense after reading the devzone article.
                                    Once unlocked, I could use my black magic probe for programming. I expect the blackmagic folks haven't had time to adapt to the new lock scheme yet.
                                      nagelcN
                                      nagelcN
                                      nagelc
                                      @NeverDie Interesting chip for a sensor node. All the other NRF52s have way more capability than we are likely to use in a low power sensor node. The 52805 seems to have just enough. Hope you are able to make some progress.
                                      • nagelcN nagelc
                                        #85
                                        @nagelc said in GUIDE - NRF5 / NRF51 / NRF52 for beginners:
                                        For future reference, yet another way you can also erase your chip is using the "Programmer" app that you can install into "nRF Connect for Desktop" program. Just connect and press the "Erase All" button:
                                        I find that I have to do this in order to unlock the chip for the first time prior to enabling the reset pin with the code:
                                          // Note: if chip has never been mass erased, then most likely PSELRESET[0] and PSELRESET[1] are both zero.
                                          // When that is the case, the chip is locked and neither can be set to 21.
                                          if (((NRF_UICR-> PSELRESET[0])==0xFFFFFFFF) && ((NRF_UICR-> PSELRESET[1])==0xFFFFFFFF)) { //if the two RESET registers were erased by a mass erase
                                            //Note:  BOTH registers must be set to 21, or else PIN00.21 will not function as a RESET pin.
                                            NRF_UICR-> PSELRESET[0]= 21;  //designate pin P0.21 as the RESET pin
                                            NRF_UICR-> PSELRESET[1]= 21;  //designate pin P0.21 as the RESET pin
                                          #86
                                          Well, I take it back. Although the above method worked for doing an "erase-all" and unlock the nRF52832 that's built into the nRF52-DK, it isn't doing anything to unlock a nRF52805 that's externally connected to an nRF52-DK. "Erase all" does seem to erase the program that on the nRF52805, but it nonetheless doesn't allow access to the reset registers NRF_UICR-> PSELRESET[0] and NRF_UICR-> PSELRESET[1]. I say that because, for instance, NRF_UICR-> PSELRESET[0] and NRF_UICR-> PSELRESET[1] are still zero after the "erase all" instead of 0xFFFFFFFF, and attempting to write them both to 21 fails.
                                          I also tried nrfjprog:
                                          nrfjprog --erase all
                                          nrfjprog --recover
                                          nrfjprog --resetpinenable
                                          nrfjprog --family UNKNOWN --recover
                                          nrfjprog --eraseuicr
                                          and after each try the nRF52805 still has the reset registers impervious to writing.
                                          Well, I see that the nRF52805 has been blessed with some kind of fancy new access port protection (APPROTECT), but reading the value of NRF_UICR->APPROTECT, it is currently at 0xFFFFFFFF, which means that APPROTECT is disabled.
                                          So, not sure what to do about this one.
