  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 226.6k Views 53 Watching
  • skywatchS skywatch
    @Gilles-BILLARD Something is not right with either your set up (wiring etc), settings or installation of arduino IDE/libraries.
    I just tested a 3V pro mini and was able to to back and forth freely between MiniCore and AVR bootloaders without issue. Two blinks for Minicore and one blink for AVR.
    A USB programmer is usually cheaper than an uno, so why not try one and see. That is what I use and the only difference is less cabling and only one arduino in the mix.
    In one photo you show nrf24 - are you using FOTA? Is this connected when bootloading the chip?
    The error you described a week ago about optiboot should not happen and you should not need to change anything. Try reinstalling the MiniCore library again following the instructions to the letter. Have you in any way modified your boards.txt or changed your arduino ide from default settings or installation path in any way?
    G
    G
    Gilles BILLARD
    wrote on last edited by Gilles BILLARD
    #326
    @skywatch When I try to use the red ISP (based on a FT232R ) you can see on the pictures I joined, I receive an error msg like :
    avrdude: Version 6.3-20201216
             System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/avrdude.conf"
             Using Programmer              : usbasp
    avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
    avrdude done.  Thank you
    That is the reason why I used or Po-Mini Or UNO as ISP.
    I tried to change and test many others drivers for my FTDI (for 2 days) unsuccessfully
    are you using FOTA? Is this connected when bootloading the chip? As you can see on one picture, in the programming section, NRF is NOT wired to the programmed Pro-Mini.
    Neither it was when I tried to reprogram the wired Pro-mini because I was using the NRF socket to acces the Arduino pins.
    .....or installation of arduino IDE/libraries I checked that as well and installed the new Adruino IDE 2.0.0 beta.... same problèms :-//
      G
      G
      Gilles BILLARD
      @skywatch said in 💬 Battery Powered Sensors:
      ....... Two blinks for Minicore and one blink for AVR.....>
      Thay is not my case; 1 blink for AVR and NO BLINK for MiniCore !?!?!?
      G 1 Reply Last reply
      • G Gilles BILLARD
        G
        G
        Gilles BILLARD
        @Gilles-BILLARD Now it is OKay with that blinks; 1 for AVR boot and 2 for MiniCore and I can revert from one to the other and vice-versa.
        ( I removed all concerning MiniCore and reload it )
        But sleep() is still giving the same issue
        skywatchS 1 Reply Last reply
        • G Gilles BILLARD
          skywatchS
          skywatchS
          skywatch
          #329
          @Gilles-BILLARD You remembered to connect the nrf before going to sleep?
            G
            G
            Gilles BILLARD
            #330
            skywatch: You remembered to connect the nrf before going to sleep?
            @skywatch Yes, of course;
            I'm 67, retired, and after 9 days (part time) on this issue, I give up !
            I am therefore torn between crushing all that stuff between between a big hammer and my anvil or to discard everything to the trash can.
            These sensors are useless if consuming 20mA H24-7/7 because they they should normally be used outside (in my greenhouses) powered by a battery 18650 + a solar cell.
            • G
              G
              Gilles BILLARD
              #331
              Can anyone let me know if he sees something wrong in that log after a Min-Core bootloader burn in a Pro-Mini 3.3v
              (I do not!)
              I ask because it not the same file as the 1st one (the 1st was including the nb "115200" (bauds?) and now it is "38400" )
              NOTA: Directory is this one:
              C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1\bootloaders\optiboot_flash\bootloaders\atmega328p\8000000L
                       Using Port                    : COM8
                       Programmer Type : STK500
                       Hardware Version: 2
                       Firmware Version: 1.18
                       Topcard         : Unknown
                       Vtarget         : 0.0 V
                       Varef           : 0.0 V
                       Oscillator      : Off
                       SCK period      : 0.1 us
              Reading | ################################################## | 100% 0.04s
              avrdude: erasing chip
              avrdude: reading input file "0x3f"
              Writing | ################################################## | 100% 0.02s
              avrdude: verifying lock memory against 0x3f:
              avrdude: load data lock data from input file 0x3f:
              avrdude: input file 0x3f contains 1 bytes
              avrdude: verifying ...
              avrdude: reading input file "0b11111111"
              avrdude: verifying efuse memory against 0b11111111:
              avrdude: load data efuse data from input file 0b11111111:
              avrdude: input file 0b11111111 contains 1 bytes
              avrdude: reading input file "0b11011110"
              avrdude: verifying hfuse memory against 0b11011110:
              avrdude: load data hfuse data from input file 0b11011110:
              avrdude: input file 0b11011110 contains 1 bytes
              avrdude: reading input file "0xe2"
              avrdude: verifying lfuse memory against 0xe2:
              avrdude: load data lfuse data from input file 0xe2:
              avrdude: input file 0xe2 contains 1 bytes
              avrdude done.  Thank you.
                       Using Port                    : COM8
                       Hardware Version: 2
                       Topcard         : Unknown
                       Vtarget         : 0.0 V
                       Varef           : 0.0 V
                       Oscillator      : Off
                       SCK period      : 0.1 us
              Reading | ################################################## | 100% 0.05s
              avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex"
              avrdude: writing flash (32768 bytes):
              avrdude: 32768 bytes of flash written
              avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
              avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
              avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex contains 32768 bytes
              avrdude: 32768 bytes of flash verified
              avrdude: reading input file "0x0f"
              Writing | ################################################## | 100% 0.05s
              avrdude: verifying lock memory against 0x0f:
              avrdude: load data lock data from input file 0x0f:
              avrdude: input file 0x0f contains 1 bytes
              • G Gilles BILLARD
                skywatchS
                skywatchS
                skywatch
                #332
                @Gilles-BILLARD I understnad your frustration - I have been there myself.
                I suggest s simple node to test with, something like the door/window sensor with just one switch.
                Take your promini, remove leds and power regulator (or cut tracks) then burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
                Then add the radio module (you can try another if you have it - what radio modules are you using? - A link or photo might help, there are bad ones and fakes that could be a problem for you). Load your sketch and try again.
                You can measure the current to the whole set up and then just the radio to see if radio is not sleeping. ....
                G 2 Replies Last reply
                  G
                  G
                  Gilles BILLARD
                  #333
                  I'll do that, but for my thermal sensor the test cannot be more simple
                  ......burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
                  I don't have the choice for the baud rate; Where is it located ?
                  I swaped everything I could. (The radio modules that was connected to the single functionning sensor included)
                  Bought from Aliexpress;
                  I have done the whole process hundreds and hundreds of time
                  Yes I'll do that...
                  skywatchS 2 Replies Last reply
                  • G Gilles BILLARD
                    Yes I'll do that...
                    skywatchS
                    skywatchS
                    skywatch
                    @Gilles-BILLARD It's in the sketch when you start serial interface. As an aside have you checked the baud rate the pro mini or uno you are using as a programmer - maybe it is 115200 and that is optimistic for a 3.3V board. Make sure the programmer is using 19200 just to be safe.
                    For inof I am using arduino ide 1.8.13 and musensors 2.3.2 with a £2 aliexpress serial prgrammer and have only encountered warnings about sck (which can safely be ignored)....
                    • G Gilles BILLARD
                      Yes I'll do that...
                      skywatchS
                      skywatchS
                      skywatch
                      @Gilles-BILLARD said in 💬 Battery Powered Sensors:
                      That is not much help.
                        G
                        G
                        Gilles BILLARD
                        #336
                        Ha, OKay; I've aslo supposed a pb from that, so I removed the sérial monitor and baud rate config.
                        And after the bootlaoder burning, the log is OKay.. the MEGA328P ID is also the good one and always the same for all 328
                          G
                          G
                          Gilles BILLARD
                          @skywatch
                          1 board
                          Radio : https://www.amazon.fr/NRF24L01-antenne-module-emetteur-recepteur-sans/dp/B01FLVTY3G/ref=sr_1_21?dchild=1&hvadid=80470576921758&hvbmt=be&hvdev=c&hvqmt=e&keywords=nrf2401&qid=1618066959&sr=8-21
                            G
                            G
                            Gilles BILLARD
                            ...........have you checked the baud rate the pro mini or uno you are using as a programmer - maybe it is 115200 and that is optimistic for a 3.3V board.
                            The programmer is loaded with standard Arduino ISP sketch (19200 default baud rate)
                              G
                              G
                              Gilles BILLARD
                              #339
                              I did that right away and the result is....
                              All's OKay without sleep(xxx):
                              2021-04-10 17:38:22.898 Status: MySensors: Node: 52, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:38:22.899 Status: MySensors: Node: 52, Sketch Version: GB.3.0
                              2021-04-10 17:40:25.515 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:40:31.277 (GiBi-Home) Light/Switch (Security Sensor)
                              Présentation then 2 minutes until I change the input twice
                              But with sleep() included...
                              2021-04-10 17:34:12.251 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:34:12.251 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:34:22.491 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:34:22.486 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:34:22.486 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:34:32.561 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:34:32.556 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:34:32.556 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:34:42.631 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:34:42.626 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:34:42.626 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:34:52.701 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:34:52.696 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:34:52.696 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:35:02.772 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:35:02.767 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:35:02.767 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:35:12.842 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:35:12.837 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:35:12.837 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:35:22.913 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:35:22.908 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:35:22.908 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:35:32.984 (GiBi-Home) Light/Switch (Security Sensor)
                              2021-04-10 17:35:32.979 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                              2021-04-10 17:35:32.980 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                              2021-04-10 17:35:43.055 (GiBi-Home) Light/Switch (Security Sensor)
                              The same kind of reboot up to présentation()
                              So sad !
                              NOTA: The sketch is the one provided as an example in BinarySwitchSensor.ino sketch
                              I've just added sleep( 10000) a the very end.
                              • G
                                G
                                Gilles BILLARD
                                Please, have a look at the time stamps:
                                Tests vs sleep time
                                More or less 10 seconds if sleep time >= 10 000 ms
                                Only a little more than 3 sec if sleep time = 2 000 ms
                                Could it help ?
                                • G Gilles BILLARD
                                  So sad !
                                  skywatchS
                                  skywatchS
                                  skywatch
                                  #341
                                  @Gilles-BILLARD Inoticed the following in the sketch you posted above...
                                    // ************Sleeping test ***************
                                      #ifdef MY_DEBUG
                                          delay(10000); // 10 secondes
                                          sleep(10000);
                                  Delay should be replaced by Wait in mysensors code to avoid blocking.
                                  I always went by the old saying that when you are in a hole, stop digging. I have not seen the behaviour you show before. I can only suggest that you run the EEPROMclear sketch (file>examples>mysensors>cleareepromconfig) and try again. Check the voltage to the promini is stable and the radio has the recommended capacitor. You might be surprised at the difference a good clean power supply can make.
                                  #is the gateway running on the same power supply? IS GW receiving messages? Please provide the FULL debug output on the serial monitor. That snippet doesn't help much.
                                  • G Gilles BILLARD
                                    Tests vs sleep time
                                    Could it help ?
                                    @Gilles-BILLARD I would like to think along to help, but lost you many posts back...
                                    All was ok, so what did you change (and why) and what is the real issue right now?
                                    And as @skywatch indicates, post the full log, sketch and everything. Don't try to filter information yourself, you might miss something.
                                    • G
                                      G
                                      Gilles BILLARD
                                      #343
                                      Finally, I found it….
                                      A big thank you to all those who helped;
                                      Here's my report in case it could be usefull to others (so, they will not waste as much time as I did)
                                      All began with my FTDI refusing to work with the MiniCore library, returning this classic error code: "avrdude: error: could not find USB device with vid-0x16c0 pid-0x5dc vendor'www.fischl.de' product'USBasp' when I wanted to reprogram a ProMini.
                                      So I opted for programming via another ProMini (Arduino as ISP)
                                      The first ProMini was able to receive the MiniCore bootloader and then my sketch without any problem, but the followings did’nt....No error message was reported; I spent 9 days trying hundreds of times changing only one thing at a time... unsuccessfully.
                                      But this morning I tried again using version 2.0.0 of Arduino’s IDE, and here I received an error message; "Impossible to recognize the Arduino as ISP" !!!!
                                      Eureka.... I had the idea to inject the MiniCore BootLoader + the “Arduino ISP” sketch in the 2nd via the IDE Arduino 1.8.13 and then use this very 2nd one to program others; At that moment, everything became normal; The tests were ok and went to "sleep" so I loaded my sketch and everything is good now.
                                      So: If you try to use Arduino as ISP with MiniCore Both Arduinos sould have been burnt with MiniCore BootLoader
                                      Thank you again.
                                      PS: Could the admin delete all my useless posts ?
                                      • YveauxY Yveaux
                                        G
                                        G
                                        Gilles BILLARD
                                        @Yveaux said in 💬 Battery Powered Sensors:
                                        .... All was ok, so what did you change (and why)
                                        A the very beginning, hesitating with the procedure, I've probably burnt the Minicore bootloader in the programming ProMini without noticing it... That's the only explanation I see.
                                        • skywatchS
                                          skywatchS
                                          skywatch
                                          Just completed 1 year of operation of a PIR sensor in the house that trigger 100-200 times a day. It is powered by 2xAA batteries and here is a graph of battery level over the year.
                                          N 1 Reply Last reply
