  2. Announcements
  3. 💬 Battery Powered Sensors
battery
347 Posts 55 Posters 233.1k Views 53 Watching
  • G Gilles BILLARD
    @Gilles-BILLARD Now it is OKay with that blinks; 1 for AVR boot and 2 for MiniCore and I can revert from one to the other and vice-versa.
    ( I removed all concerning MiniCore and reload it )
    But sleep() is still giving the same issue
    skywatchS
    skywatchS
    skywatch
    #329
    @Gilles-BILLARD You remembered to connect the nrf before going to sleep?
    G 1 Reply Last reply
    • skywatchS skywatch
      G
      G
      Gilles BILLARD
      wrote on last edited by Gilles BILLARD
      #330
      skywatch: You remembered to connect the nrf before going to sleep?
      @skywatch Yes, of course;
      I'm 67, retired, and after 9 days (part time) on this issue, I give up !
      I am therefore torn between crushing all that stuff between between a big hammer and my anvil or to discard everything to the trash can.
      These sensors are useless if consuming 20mA H24-7/7 because they they should normally be used outside (in my greenhouses) powered by a battery 18650 + a solar cell.
      skywatchS 1 Reply Last reply
      • G
        G
        Gilles BILLARD
        #331
        Can anyone let me know if he sees something wrong in that log after a Min-Core bootloader burn in a Pro-Mini 3.3v
        (I do not!)
        I ask because it not the same file as the 1st one (the 1st was including the nb "115200" (bauds?) and now it is "38400" )
        NOTA: Directory is this one:
        C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1\bootloaders\optiboot_flash\bootloaders\atmega328p\8000000L
        avrdude: Version 6.3-20201216
                 System wide configuration file is "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/avrdude.conf"
                 Using Port                    : COM8
                 Programmer Type : STK500
                 Hardware Version: 2
                 Firmware Version: 1.18
                 Topcard         : Unknown
                 Vtarget         : 0.0 V
                 Varef           : 0.0 V
                 Oscillator      : Off
                 SCK period      : 0.1 us
        Reading | ################################################## | 100% 0.04s
        avrdude: erasing chip
        avrdude: reading input file "0x3f"
        Writing | ################################################## | 100% 0.02s
        avrdude: verifying lock memory against 0x3f:
        avrdude: load data lock data from input file 0x3f:
        avrdude: input file 0x3f contains 1 bytes
        avrdude: verifying ...
        avrdude: reading input file "0b11111111"
        avrdude: verifying efuse memory against 0b11111111:
        avrdude: load data efuse data from input file 0b11111111:
        avrdude: input file 0b11111111 contains 1 bytes
        avrdude: reading input file "0b11011110"
        avrdude: verifying hfuse memory against 0b11011110:
        avrdude: load data hfuse data from input file 0b11011110:
        avrdude: input file 0b11011110 contains 1 bytes
        avrdude: reading input file "0xe2"
        avrdude: verifying lfuse memory against 0xe2:
        avrdude: load data lfuse data from input file 0xe2:
        avrdude: input file 0xe2 contains 1 bytes
        avrdude done.  Thank you.
                 Using Port                    : COM8
                 Hardware Version: 2
                 Topcard         : Unknown
                 Vtarget         : 0.0 V
                 Varef           : 0.0 V
                 Oscillator      : Off
                 SCK period      : 0.1 us
        Reading | ################################################## | 100% 0.05s
        avrdude: reading input file "C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex"
        avrdude: writing flash (32768 bytes):
        avrdude: 32768 bytes of flash written
        avrdude: verifying flash memory against C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
        avrdude: load data flash data from input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex:
        avrdude: input file C:\Users\billa\AppData\Local\Arduino15\packages\MiniCore\hardware\avr\2.1.1/bootloaders/optiboot_flash/bootloaders/atmega328p/8000000L/optiboot_flash_atmega328p_UART0_38400_8000000L_B5.hex contains 32768 bytes
        avrdude: 32768 bytes of flash verified
        avrdude: reading input file "0x0f"
        Writing | ################################################## | 100% 0.05s
        avrdude: verifying lock memory against 0x0f:
        avrdude: load data lock data from input file 0x0f:
        avrdude: input file 0x0f contains 1 bytes
        • G Gilles BILLARD
          skywatchS
          skywatchS
          skywatch
          #332
          @Gilles-BILLARD I understnad your frustration - I have been there myself.
          I suggest s simple node to test with, something like the door/window sensor with just one switch.
          Take your promini, remove leds and power regulator (or cut tracks) then burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
          Then add the radio module (you can try another if you have it - what radio modules are you using? - A link or photo might help, there are bad ones and fakes that could be a problem for you). Load your sketch and try again.
          You can measure the current to the whole set up and then just the radio to see if radio is not sleeping. ....
          G 2 Replies Last reply
            G
            G
            Gilles BILLARD
            #333
            @skywatch said in 💬 Battery Powered Sensors:
            I'll do that, but for my thermal sensor the test cannot be more simple
            ......burn MiniCore bootloader with 9600 baud, 3.3V, 8MHz INTERNAL, BoD DISABLED.
            I don't have the choice for the baud rate; Where is it located ?
            I swaped everything I could. (The radio modules that was connected to the single functionning sensor included)
            Bought from Aliexpress;
            I have done the whole process hundreds and hundreds of time
            Yes I'll do that...
            skywatchS 2 Replies Last reply
            • G Gilles BILLARD
              Yes I'll do that...
              skywatchS
              skywatchS
              skywatch
              @Gilles-BILLARD It's in the sketch when you start serial interface. As an aside have you checked the baud rate the pro mini or uno you are using as a programmer - maybe it is 115200 and that is optimistic for a 3.3V board. Make sure the programmer is using 19200 just to be safe.
              For inof I am using arduino ide 1.8.13 and musensors 2.3.2 with a £2 aliexpress serial prgrammer and have only encountered warnings about sck (which can safely be ignored)....
              • G Gilles BILLARD
                Yes I'll do that...
                skywatchS
                skywatchS
                skywatch
                @Gilles-BILLARD said in 💬 Battery Powered Sensors:
                That is not much help.
                  G
                  G
                  Gilles BILLARD
                  #336
                  Ha, OKay; I've aslo supposed a pb from that, so I removed the sérial monitor and baud rate config.
                  And after the bootlaoder burning, the log is OKay.. the MEGA328P ID is also the good one and always the same for all 328
                    G
                    G
                    Gilles BILLARD
                    @skywatch
                    1 board
                    Radio : https://www.amazon.fr/NRF24L01-antenne-module-emetteur-recepteur-sans/dp/B01FLVTY3G/ref=sr_1_21?dchild=1&hvadid=80470576921758&hvbmt=be&hvdev=c&hvqmt=e&keywords=nrf2401&qid=1618066959&sr=8-21
                      G
                      G
                      Gilles BILLARD
                      ...........have you checked the baud rate the pro mini or uno you are using as a programmer - maybe it is 115200 and that is optimistic for a 3.3V board.
                      The programmer is loaded with standard Arduino ISP sketch (19200 default baud rate)
                        G
                        G
                        Gilles BILLARD
                        #339
                        I did that right away and the result is....
                        All's OKay without sleep(xxx):
                        2021-04-10 17:38:22.898 Status: MySensors: Node: 52, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:38:22.899 Status: MySensors: Node: 52, Sketch Version: GB.3.0
                        2021-04-10 17:40:25.515 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:40:31.277 (GiBi-Home) Light/Switch (Security Sensor)
                        Présentation then 2 minutes until I change the input twice
                        But with sleep() included...
                        2021-04-10 17:34:12.251 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:34:12.251 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:34:22.491 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:34:22.486 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:34:22.486 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:34:32.561 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:34:32.556 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:34:32.556 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:34:42.631 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:34:42.626 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:34:42.626 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:34:52.701 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:34:52.696 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:34:52.696 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:35:02.772 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:35:02.767 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:35:02.767 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:35:12.842 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:35:12.837 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:35:12.837 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:35:22.913 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:35:22.908 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:35:22.908 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:35:32.984 (GiBi-Home) Light/Switch (Security Sensor)
                        2021-04-10 17:35:32.979 Status: MySensors: Node: 51, Sketch Name: Temperature Sensor Sleep
                        2021-04-10 17:35:32.980 Status: MySensors: Node: 51, Sketch Version: GB.3.0
                        2021-04-10 17:35:43.055 (GiBi-Home) Light/Switch (Security Sensor)
                        The same kind of reboot up to présentation()
                        So sad !
                        NOTA: The sketch is the one provided as an example in BinarySwitchSensor.ino sketch
                        I've just added sleep( 10000) a the very end.
                        • G
                          G
                          Gilles BILLARD
                          Please, have a look at the time stamps:
                          Tests vs sleep time
                          More or less 10 seconds if sleep time >= 10 000 ms
                          Only a little more than 3 sec if sleep time = 2 000 ms
                          Could it help ?
                          • G Gilles BILLARD
                            So sad !
                            skywatchS
                            skywatchS
                            skywatch
                            #341
                            @Gilles-BILLARD Inoticed the following in the sketch you posted above...
                              // ************Sleeping test ***************
                                #ifdef MY_DEBUG
                                    delay(10000); // 10 secondes
                                    sleep(10000);
                            Delay should be replaced by Wait in mysensors code to avoid blocking.
                            I always went by the old saying that when you are in a hole, stop digging. I have not seen the behaviour you show before. I can only suggest that you run the EEPROMclear sketch (file>examples>mysensors>cleareepromconfig) and try again. Check the voltage to the promini is stable and the radio has the recommended capacitor. You might be surprised at the difference a good clean power supply can make.
                            #is the gateway running on the same power supply? IS GW receiving messages? Please provide the FULL debug output on the serial monitor. That snippet doesn't help much.
                            • G Gilles BILLARD
                              Tests vs sleep time
                              Could it help ?
                              @Gilles-BILLARD I would like to think along to help, but lost you many posts back...
                              All was ok, so what did you change (and why) and what is the real issue right now?
                              And as @skywatch indicates, post the full log, sketch and everything. Don't try to filter information yourself, you might miss something.
                              • G
                                G
                                Gilles BILLARD
                                #343
                                Finally, I found it….
                                A big thank you to all those who helped;
                                Here's my report in case it could be usefull to others (so, they will not waste as much time as I did)
                                All began with my FTDI refusing to work with the MiniCore library, returning this classic error code: "avrdude: error: could not find USB device with vid-0x16c0 pid-0x5dc vendor'www.fischl.de' product'USBasp' when I wanted to reprogram a ProMini.
                                So I opted for programming via another ProMini (Arduino as ISP)
                                The first ProMini was able to receive the MiniCore bootloader and then my sketch without any problem, but the followings did’nt....No error message was reported; I spent 9 days trying hundreds of times changing only one thing at a time... unsuccessfully.
                                But this morning I tried again using version 2.0.0 of Arduino’s IDE, and here I received an error message; "Impossible to recognize the Arduino as ISP" !!!!
                                Eureka.... I had the idea to inject the MiniCore BootLoader + the “Arduino ISP” sketch in the 2nd via the IDE Arduino 1.8.13 and then use this very 2nd one to program others; At that moment, everything became normal; The tests were ok and went to "sleep" so I loaded my sketch and everything is good now.
                                So: If you try to use Arduino as ISP with MiniCore Both Arduinos sould have been burnt with MiniCore BootLoader
                                Thank you again.
                                PS: Could the admin delete all my useless posts ?
                                • YveauxY Yveaux
                                  G
                                  G
                                  Gilles BILLARD
                                  @Yveaux said in 💬 Battery Powered Sensors:
                                  .... All was ok, so what did you change (and why)
                                  A the very beginning, hesitating with the procedure, I've probably burnt the Minicore bootloader in the programming ProMini without noticing it... That's the only explanation I see.
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    Just completed 1 year of operation of a PIR sensor in the house that trigger 100-200 times a day. It is powered by 2xAA batteries and here is a graph of battery level over the year.
                                    N 1 Reply Last reply
                                      N
                                      N
                                      nekitoss
                                      @skywatch If your project is free and open, where i can look at it? At the moment i need to solve same problem. On your graph what will be 0% ? For mine devices it is minimum 1.9v, for few it is 2.2v
                                      • N nekitoss
                                        skywatchS
                                        skywatchS
                                        skywatch
                                        #347
                                        @nekitoss
                                        I used 3.3V pro mini with regulator removed and powered by Vin pin. Also removed leds from the pro mini.
                                        I used minicore bootloader.
                                        I used the small pir sensors and again removed the regulator to power directly from the pro mini outputs.
                                        After that sleep the node and trigger on interrupt.
                                        Send battery level once a day.
                                        Use inbuilt battery level monitor and not external components that constantly drain power to get battery level.
                                        1.8V is 0% on the graph (not visible yet!) but I have had nodes working below 1.7V It's a matter of luck with that it seems.
                                        Hope this helps you on the right track. I'll try and help if you want.
                                        This is the latest image and still going strong after 18 months. Voltage is at 2.903V
                                        Here is photo of the test example - I need to make a case and produce more of them over winter.....
                                        Here is the same build/code of a window sensor. Similar time frame but hardly triggered.....
                                        12.5k
