  3. [SOLVED]Atmega 328P reset to start
resetstartingatmega328p
12 Posts 4 Posters 2.1k Views 4 Watching
  • B Offline
    B Offline
    barrydou
    wrote on last edited by barrydou
    Hello
    I just get a Atmega 328P in DIL package. It was configured with external 16Mhz clock.
    I set up it with internal 8mhz and minicore bootloader with Arduino IDE and Arduino as ISP
    Here is the configuration I used
    Burning the bootloader works well. I follow this guide for wiring, and I add a led on D13 with a 1k resistor to GND.
    After burning the bootloader, the led was blinking as usual. I was happy :)
    But, after that, I unplug the arduino as ISP, the clock source, and replug only power source. The led was not blinking anymore. :angry:
    I replug the arduino as ISP (not the clock), and use AVRDUDESS to read fuse, and miracle the led restart to blink :grin:
    Here is the fuses readed
    I unplug everything again, and replug only power source ... no blink :flushed: . And I don't know why, I try to send reset (GND to Reset Pin), and blink started.
    I've tested it and retested it, the led don't start to blink until I send reset.
    Any ideas of why I need to reset to start the arduino ? Is there any fuse or lock that configure it ? Something I miss ?
    Thank you for your help
    skywatchS 1 Reply Last reply
    • alexeliteA Offline
      alexeliteA Offline
      alexelite
      Did you check the voltage on the reset pin? Might be a faulty pullup connection on the reset pin, if your circuit is on a breadboard.
      • B Offline
        B Offline
        barrydou
        Hello
        I have 4.8V on the reset pin (directly mesured on the DIL package). I use a 10k pullup resistor.
        The atmega was on a single board with uno bootloader before. It was working great, and the reset pin was not connected at all (only vcc/gnd/D2/D4 and clock where connected before I put it on the breadborard)
        I've tried with 10k resistor, without resistor (reset floating), with caps. Always the same thing
        • B barrydou
          Hello
          skywatchS Offline
          skywatchS Offline
          skywatch
          @barrydou said in Atmega 328P reset to start:
          Hello
          Whne you burn MiniCore does the led flash TWICE every second? You said the LED was flashing "as usual" - thatis normally ONE blink per second.
          You do have an externa crystal (16MHz as you said) connected for the ATmega?
          The Atmega need external crystal for programming sketch...
          B 1 Reply Last reply
          • skywatchS skywatch
            Hello
            B Offline
            B Offline
            barrydou
            @skywatch
            Yes after flashing MiniCore, the led flash twice per second.
            If I keep only VCC, GND, pullup on Reset and the led on D13, I unplug / replug the power => Nothing, until I force a reset (GND on Reset pin)
            When I force, the led flash twice per second (even without clock, but the fuses are set to 8Mhz Internal)
            • B barrydou
              @skywatch
              skywatchS Offline
              skywatchS Offline
              skywatch
              @skywatch
              That is good!
              How are you removing the power and for how long? Try 30 seconds before reconnect.....
              That is contradictory - it is not 'without clock' if the fuses are set to 8MHx internal - it has 8MHz internal clock running.....OR maybe I mis-understand?
                @skywatch
                That is good!
                B Offline
                B Offline
                barrydou
                @skywatch said in Atmega 328P reset to start:
                @skywatch
                That is good!
                I unplug the vcc dupond cable from breadboard (beetween power source and breadboard). And I plug it again.
                Before this message, I unplug during a few seconds. I try 1 minute now, it's the same.
                Sorry, I mean without external clock. I remove external Quartz and Caps just after flashing the minicore
                • B barrydou
                  @skywatch
                  That is good!
                  skywatchS Offline
                  skywatchS Offline
                  skywatch
                  @barrydou Intereting - I have flashed MiniCore with 8MHz internal, loaded the sketch, removed the xtal and it works as expected.... So no clue what is different with your experience...
                  • B Offline
                    B Offline
                    barrydou
                    I've just found it !
                    I added a 100nf caps between VCC and GND, just near pin 7 and 8, like documented on the MiniCore github page.
                    https://github.com/MCUdude/MiniCore => DIP-28 package ATmega8/48/88/168/328
                    And now, it's work as expected. I just plug VCC and GND, and the led blink twice per second.
                    Don't know why, but it's OK :grinning:
                    Thank you for all your ideas
                    skywatchS B 2 Replies Last reply
                    • B barrydou
                      skywatchS Offline
                      skywatchS Offline
                      skywatch
                      @barrydou Well done, good job!
                      When in doubt, read the manual! - Easy in hindsight, isn't it? ;)
                        B Offline
                        B Offline
                        barrydou
                        @skywatch Yes ... RTFM ... So simple :grin:
                        • B barrydou
                          B Offline
                          B Offline
                          bjacobse
                          @barrydou
                          https://electronics.stackexchange.com/questions/2262/decoupling-capacitors-what-size-and-how-many
                          12.2k
