  3. Best PC platform for running Esxi/Docker at home?
75 Posts 6 Posters 12.5k Views 5 Watching
    #53
    Final report: I tried it out, but having to run a Windows thin-client to connect via Windows Remote Desktop to a Windows VM running on a server was a buzzkill. The hardest case I've tried is watching high definition youtube videos. The server can handle the workload even without a graphics card and still not max out the CPU cores. It works, but the visual fidelity goes down--I guess because it's first displayed on a VM screen inside the VM on the server and then re-encoded and pumped to the thin-client? Not sure if that's what's actually happening but if so maybe there's a way to around that that doesn't inolve a re-encoding. Ideally, being able to losslessly connect to any VM from, say, a chromebook would have been nice.
    Lastly, I have been able to move VM's from one physical machine to another and get them to run. Maybe I'm doing it wrong, but for my first attempt I did it by first "backing up" the VM to the server using ProxMox Backup Server, and then "restoring" the VM to the target machine (in my test case, the same physical machine as the one running ProxMox Backup Server). Doing it this way I encountered two bottlenecks: #1. moving the VM over 1 gigabit ethernet takes a while. However, upgrading to 10-gigabit ethernet or faster might address that. #2 Even longer, than #1, the "restoring" process takes quite a while, even though in my test case it didn't involve sending anything over ethernet. This was a surprise. I'm not sure why the "restoring" takes so long, but it takes much longer than doing the original backup. Unless the "restoring" is doing special magic to adjust the VM to run on the new target machine hardware, then in theory doing just a straight copy of the VM file without any "restoring" should be much, much faster. I'll try that next.
      @NeverDie have you tried proxmox's live migration feature? It works very well for me. Downtime is less than a second when migrating from a datacenter in Germany to a Datacenter in Finland. Migration time depends on network speed and VM size.
        #55
        Reporting back: I'd like to find a BTRFS equivalent to ProxMox, because although I like the reliability that ZFS can, in theory, offer, it's simply not a native linux file system. As a result, if I want to backup VM's to a zpool dataset on, say, a truenas server using ProxMox Backup Server, I have to first reserve a giant fixed size chunk of storage on a Truenas ZFS dataset by creating a ZVOL on it, and then I have to overlay that ZVOL with a linux file system like ext4 so that ProxMox Backup Server can read/write the backups on the ZVOL using iSCSI. However, I've got to believe that doing it this way largely undermines the data integrity that ZFS is offering, and it also means I have a big block of reserved ZVOL storage to handle the worst-case that will be largely underutilized compared to if ProxMox could read/write ZFS datasets natively.
        So, instead of doing that, which I did get to "work", I've decided to set up a regular linux ext4 logical volume on an NVME accessible to ProxMox for storing VM's and creating VM backups, because ProxMox has no trouble reading/writing to an ext4 file system. I have ProxMox write its backups to that linux logical volume, and then I copy those relatively small files (well, small compared to the giant ZVOL I would otherwise have to reserve to contain them) over to a ZFS dataset on a TrueNas server (which is running inside a VM on ProxMox).
        I don't yet know for sure, but I presume (?) BTRFS wouldn't require these kinds of contortions, since BTRFS should be native to the Linux operating system, just like ext4 is.
        Footnote: The above isn't entirely accurate, because I can and do boot proxmox itself on a raidZ1, and ProxMox can happily write and backup VM's to that ZFS drive. However, the gotcha is that, for some reason, when writing directly to a ZFS file system, ProxMox insists on writing both the VMs and VM backups as raw block files instead of a much more compact qcow2. Ironically, if writing to an ext4 file system, Proxmox can write both VM's and VM backups in the qcow2 file format. So, a VM of, say, PopOS might occupy 3GiB as a qcow2 file, but ProxMox would write it as a 32GiB raw file, if that's the size I told ProxMox to allocate when I configured the VM. Or 64Gib if I wanted to cover a possible larger future PopOS configuration. That kind of size discrepancy adds up in a hurry as you create, backup, and manage more and more VM's. I thought automatic file compression might make it a moot point, but it doesn't seem to work as well on raw files as I would have guessed, maybe due to file leftovers within the raw block as files are moved around or shrunk or "deleted" within the disk image. A file system wouldn't see those remnants, but they'd still be in a disk image, and automatic compression on a raw disk image has no way of knowing what's purely leftover junk file remnants vs essential file data that's still in use.
        Or perhaps the difference is at least partly because a Linux LVM specifically allows for thin provisioning?
        Thin Provisioning
        A number of storages, and the Qemu image format qcow2, support thin provisioning. With thin provisioning activated, only the blocks that the guest system actually use will be written to the storage.
        Say for instance you create a VM with a 32GB hard disk, and after installing the guest system OS, the root file system of the VM contains 3 GB of data. In that case only 3GB are written to the storage, even if the guest VM sees a 32GB hard drive. In this way thin provisioning allows you to create disk images which are larger than the currently available storage blocks. You can create large disk images for your VMs, and when the need arises, add more disks to your storage without resizing the VMs' file systems.
        https://pve.proxmox.com/wiki/Storage
        Or maybe it's just the arbitrary current state of ProxMox development, and this difference will get fixed in the future? I have no idea.
        I'm not really expecting anyone here knows the answer, so this is mostly just a follow-up as to how things went. Although not ideal, I can make do with the workaround I've outlined in this post.
        monteM 1 Reply Last reply
          Thin Provisioning
          monteM
          monteM
          monte
          @NeverDie yep, ZFS is a strange beast for me. I tried to avoid it, because I don't have no hardware nor application to utilize it's potential. But I was also afraid of LVM, and then one time I had to recover proxmox setup that I've messed up when was trying to migrate it to a bigger drive without reinstall. At one moment I thought that I've broken the whole volume group, but somehow I've got it back after few rebuilds from semi-broken backup image :)
          It reminds me the name of this great movie: :)
            #57
            Reporting Back: Good news! Rather than use iSCSI, I found that I could create a SAMBA mount point and then use that to connect with a ZFS dataset on TrueNAS, running on a virtual machine within ProxMox. This allows ProxMox to backup VM's to that as a regular ZFS dataset without having to pre-allocate storage, as was the case with a ZVOL. I've tested this out, and it works. So, it's all good now. I'm once again happy with Proxmox. :slightly_smiling_face: :smile: :smiley:
            BTW, running a SAMBA share has the added advantage of being easily accessible from Windows File Explorer, making it an attractive bonus. Once set up, I'm finding that SAMBA (aka SMB) on TrueNAS for a mix of Linux and Windows machines on one network provides easy file sharing.
            An unrelated but good find: BTRFS on regular linux works great, especially when combined with TimeShift for instant snapshot and rollbacks. A rollback does require a reboot to take effect, but it's nonetheless better than no rollback ability at all.. BTRFS is one of the guided install options on both Ubuntu and Linux Mint Cinnamon. For Microsoft Windows users, I think you'll find that the GUI on Linux Mint Cinnamon is a good match for your Windows intuitions. I'll probably settle on Mint Cinnamon for its stability and intuitive ease of use. The pre-configuring that went into Mint makes it much easier for new Linux users to pick up and immediately start using, as compared to a plain vanilla Debian install, which was my previous go-to because of Debian's high stability.
            Of greater relevance: "Viritual Machine Manager" (VMM) is a QEMU-KVM hypervisor GUI that runs on Mint which looks strikingly similar to ProxMox during the process of configuring a new VM. I was looking into VMM as a BTRFS hypervisor alternative to ZFS ProxMox, and though not exactly apples-to-apples, on first-look VMM does look quite capable. Also, in some ways the VMM GUI looks both more detailed and more polished than ProxMox's GUI. I also looked very briefly (maybe too briefly) at Cockpit and at Gnome Boxes, but my first-impression was both looked like work-in-progress. Are there any other hypervisors, not already mentioned on this thread, that runs on top of BTRFS and is worth considering?
              Since prices for both GPU's and Ryzen 9 5950x CPU's have gone crazy, I ended up ordering a Ryzen 5700G, which is 65w nominal. CPU performance is a little less than the 5800x (at 105w), but the 5700G is priced about the same and has integrated graphics. I'd like to use the 5700G as the host for virtual machines, and I'm wondering now whether the integrated graphics gets shared among multiple virtual machines or whether at most one VM can make use of it. Offhand, I'm not sure how I would even test for that, except maybe with some kind of graphics benchmark.
              • tbowmoT
                tbowmoT
                tbowmo
                I've been looking at building a new server myself.. Currently I have an old hp desktop machine with an I5 / 16Gb of ram, running as server.. Works fine (and it was cheap). But I want to play more with docker / kubernetes, and perhaps do some more machinelearning on zoneminder images, so could use a cpu with a bit more oompf.. Perhaps an nvidia gfx for the ML part..
                Only problem is that I'm not ready to spend 1000$ or more on hardware, so I'll probably just wait for the prices to drop again..
                (Currently I just run ubuntu server, and then docker on top of that.. No VMs or the like..)
                monteM NeverDieN 2 Replies Last reply
                • tbowmoT tbowmo
                  monteM
                  monteM
                  monte
                  @tbowmo I have Nvidia GT1030 running yolo object detection on camera feeds with 7fps on full model and 20-30fps on yolo-tiny. Considering you don't need to process every frame your cameras produce and 1 or even 0.5 fps per camera is practical enough, you can get this thing going on a budget.
                  tbowmoT 1 Reply Last reply
                  • tbowmoT tbowmo
                    #61
                    @tbowmo For the machine learning part I bet there are cloud based RTX cards you could use, or perhaps AI cloud servers. Last I checked, which was a while ago, Google was offering tensorflow in the cloud for free. I'm using nvidia Now, which is meant for gaming, but as a data point it offers access to a dedicated RTX3080 on a VM for a mere $10 per month. That's a trivially low price compared to buying physical RTX3080 hardware at current market rates.
                      tbowmoT
                      tbowmoT
                      tbowmo
                      @NeverDie i prefer to keep video footage local. Not saying that I need an rtx3080/3090. They're too pricey. Looking more towards 1050ti or the like. Should be enough, if I'm not going for coral tpu. Waiting for a friend to get hold on some tpus, and give his verdict.
                      • monteM monte
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @monte currently I'm at the order of 0.2fps, would be nice with a bit more throughput, as I'm planning for more cameras along the way. (currently I have 2 cameras running 24/7,but have 2 more that I just need to put up..)
                        • tbowmoT tbowmo
                          monteM
                          monteM
                          monte
                          wrote on last edited by monte
                          #64
                          @tbowmo I don't know your setup, but optimizing the code that serves frames to the detector can help more then you may think.
                          • monteM monte
                            tbowmoT
                            tbowmoT
                            tbowmo
                            @monte said in Best PC platform for running Esxi/Docker at home?:
                            I'm using zoneminder, and zmeventserver for this.. All running in docker at the moment.. Haven't had the time for digging in to this machine learning, other than scratch the surface, and trying to apply prior work to my own setup..
                              #66
                              The ryzen 9 5900x seems to be the sweet spot of bang per buck (lots of hefty cores for the price), so I've put an order in for one of those as well.
                              [Edit: I canceled my ryzen 9 5900x order, which seemed perpetually backordered, and decided to buy a ryzen 9 5950x at scalper's prices instead to get it more quickly. Now I understand how the disproportionately high price of the ryzen 9 5950x (as compared to the ryzen 9 5900x) can be justfied: when you take into account the full system cost, rather than just the CPU cost in isolation, the marginal cost per core of the ryzen 9 5950x becomes more or less a wash as compared to the marginal cost per core of the ryzen 9 5900x, if it were underpinned by the same motherboard and memory. If the total sytem cost is even higher (if, say, it's a NAS or running video cards), then the marginal cost per core of the ryzen 9 5950x becomes lower than a 5900x, even considering scalper pricing on the CPU itself.
                              I'll be putting the Ryzen 9 5950x on an ASUS X570 workstation motherboard that comes with 3 PCIe 4.0 slots, where the board's bios is advertised as being capable to divvy up the various pcie lanes in a somewhat flexible manner. So, that should facilitate assigning different graphics cards to different VM's, or possibly adding 10Gbe ethernet and/or a SATA controller with no interference between devices. It's the only motherboard I found with these programmable bifurcation features that also supports ECC memory, though the Asrock X570D4I-2T may have something similar and also looks like a good board, though possibly a bit cramped.
                              Something I want to try: using bifurcation to add more than one nvme card in parallel to get higher throughput. From what I've read, it should be possible to get more than 20gbps. Maybe 28gbps read speed if four pcie 4.0 nvme cards are used in a single pcie 4.0 slot using an inexpensive adapter board? And would I notice significantly faster VM load times with that approach, assuming a VM is somehow spread over the four nvme cards using one of the ZFS raid configurations?]
                                #67
                                I'm fairly happy with ProxMox, but FreeBSD's Bhyve hypervisor can clone (or snapshot) a VM in less than a second--even if running on a 10 year old laptop computer--whereas ProxMox cannot (even if, as I have done, I install ZFS as the file system everywhere used by ProxMox). Is it because the FreeBSD ZFS is either more complete or more tightly integrated? Anyone here done a compare/contrast of Bhyve vs ProxMox? I'm also intrigued because FreeBSD/Bhyve has "jails" for added security of VM's. Also, FreeBSD is a more complete OS, and so I suspect the entire thing is better scrubbed than the way Linux distros are thrown together, with each distro incorporating different packages.
                                Apple built its current OS on top of FreeBSD rather than Linux, so that's at least a minimal endorsement of FreeBSD, even if it were to turn out that the main reason Apple chose FreeBSD over Linux was due to FreeBSD's more favorable licensing terms.
                                  monteM
                                  monteM
                                  monte
                                  @NeverDie said in Best PC platform for running Esxi/Docker at home?:
                                  Haven't you heard the last controversy about wireguard driver merged into FreeBSD core by Pfsense, which had awful quality and was written by some pretty shady person? And it was only a few day before the new release of FreeBSD, when the author of wireguard wrote a letter about it and stopped the commit from being released with the kernel.
                                  https://arstechnica.com/gadgets/2021/03/in-kernel-wireguard-is-on-its-way-to-freebsd-and-the-pfsense-router/
                                  Can't find the long story I've read about it, but this article can explain the matter good enough.
                                  I would say that broader adoption and even segmentation in some way, help more to make robust opensource OS.
                                    #69
                                    OK, reporting back: it turned out to be a wild goose chase all because at time index 3:10 this guy:
                                    https://youtu.be/uV61mVYsFM8
                                    appeared to demonstrate that he could clone a VM using Bhyve in about 1 second on a 10-year old laptop, whereas proxmox was taking him around 2 minutes to clone a VM. That's the claim that sent me off on this red herring.
                                    Well, after digging into it, I've come to the conclusion that he wasn't truly cloning a VM but rather cloning a containerized VM. That option is also available in proxmox.
                                    Either way, I'm hoping that when my Beast computer (above) is set up then ProxMox will be able to do rapid clone clones of either type, and that's why I'm pushing toward the high end specs, especially with regard to pushing ultra high nvme read and write speeds over pcie-4.0 using some kind of RAID configuration. If I can clone a VM in about a second, then for my purposes usability improves tremendously.
                                    Also, it turns out that Trunas "jails" are apparently just the FreeBSD equivalent of linux or docker containers, so after realizing that I'm skeptical as to whether they offer any actual improvement in security vs what proxmox or linux offers.
                                      monteM
                                      monteM
                                      monte
                                      @NeverDie may I ask, why do you need such speeds? How frequent are you going to clone VM's and how many of them are you going to have? Is this a home setup?
                                      • monteM monte
                                        #71
                                        I'm merely interesting in trying out something similar to Qubes OS--perhaps approximated using ProxMox--which on dated hardware I found was just too slow at spawning/cloning new VM's to be practical. I figure a one second delay for new spawns would be tolerable. Not sure where the exact cut-off of tolerability would be, but I figure one second probably wouldn't be too bothersome.
                                        Also, sharpening the language of my earlier post, the TL;DR was that I'm now pretty confident the guy in the video was creating "linked clones" in Bhyve rather than "full clones," which is fine, but this wasn't clear in the video, which seems to have confusingly compared Bhyve linked-clone spawn times to ProxMox full-clone spawn times--which, of course, made Bhyve appear far better than it actually is.
                                        I wasn't fully aware of "linked clones" previously, and they maybe are a good way to go, especially if you have a kind of "golden image" VM from which to spawn linked clones afterward. Proxmox can do linked clones too, not just Bhyve. Not entirely sure what the security ramifications are of using linked clones as opposed to full-clones though. I suppose full-clones would be the better of the two, but linked-clones might (?) be an acceptable trade-off in exchange for greatly reduced spawn times. Either way, admittedly, it may be overkill.
                                          #72
                                          Closing-the-loop: https://looking-glass.io/ looks cool for tying it all together without sacrificing latency in user interaction. With pcie-5.0 deploying in the second half of this year, you'll get nvme's with even higher throughput. We're at one of those magic points in time where a lot of technology trends are coming together and reinforcing/leveraging each other. It's all pretty awesome.
