  2. Announcements
  3. 💬 Security & Signing
137 Posts 20 Posters 46.7k Views 19 Watching
  • alowhumA alowhum
    This page is not up to date, and this is causing some confusion:
    https://github.com/tsathishkumar/MySController-rs/issues/15
    AnticimexA
    AnticimexA
    Anticimex
    @alowhum but that is not part of the core library, right? So this thread is perhaps not the best place for discussing 3rd party tools.
    • alowhumA
      alowhumA
      alowhum
      #126
      "This thread contains comments for the article "Security & Signing" posted on MySensors.org."
      @Anticimex This thread is the thread attached to a page on MySensors.org about security.
      I pointed to that (awesome) tool on Github as an example that the page has caused some confusion about whether or not MySensors supports encryption.
      AnticimexA 3 Replies Last reply
      • alowhumA alowhum
        AnticimexA
        AnticimexA
        Anticimex
        @alowhum ok, thanks. Well we do. So please notify that author.
        • alowhumA alowhum
          AnticimexA
          AnticimexA
          Anticimex
          @alowhum as for the link back to mysensors documentation, that documentation is about message signing which is not to be confused with encryption. And on the top of the article is links to the latest documentation which should reflect the latest status on both signing and encryption.
          • alowhumA alowhum
            AnticimexA
            AnticimexA
            Anticimex
            @alowhum @hek we should perhaps retire that article or reduce it to a reference to the "actual" documentation instead to reduce the risk of confusion?
              wrote on last edited by hek
              #130
              Yes, maybe we could add a more prominent link in the article to the auto generated documentation. Right now the link easily missed in the ingress.... and it does not link directly to the overview documentation here:
              https://www.mysensors.org/apidocs/group__MySigninggrpPub.html
              I don't think we should scrap the page entirely as it contains the none API technical parts as a good overview.
              • alowhumA
                alowhumA
                alowhum
                @hek said in 💬 Security & Signing:
                That link still only refers to details about signing, and not encryption. So a user wanting to learn about security might still come away with the idea that only signing is supported.
                AnticimexA 1 Reply Last reply
                • alowhumA alowhum
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alowhum yes, it should link here: https://www.mysensors.org/apidocs/group__SecuritySettingGrpPub.html
                  alowhumA 1 Reply Last reply
                  • AnticimexA Anticimex
                    alowhumA
                    alowhumA
                    alowhum
                    @anticimex Great!
                    • YoshuY
                      YoshuY
                      Yoshu
                      Hi All not sure if this should be under gateway or security sections but just wondering If it is possible to run 2 seperate gateways for mysensors netwok
                      • a fully secured network with signing required both node and gateway for all nodes required to send and or receive signed data.
                        -A second unsecured network for gerneral sensor data and equipment not requiring any security
                      • YoshuY Yoshu
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Yoshu it is possible. When you have two gateways, the networks will be completely isolated so you can run one of them secured while the other is not.
                        You might need to distinguish the nodes on in your controller by giving them static unique ID:s unless your controller ties the identifiers to each gateway or it might be difficult to determine which mysensors network a node belong to.
                        L 1 Reply Last reply
                          L
                          L
                          lood29
                          @Anticimex more important is to set different network id or you'll have lot of collisions and lost packets
                          • L lood29
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @lood29 That is correct, assuming the same radio technology is used. Typically, you set up a separate gateway because you want to run a sensor network on a different radio family due to longer distances or similar.
