  3. Concatenated String Doesn't Send Correctly
2 Posts 2 Posters 1.5k Views 2 Watching
    mrmuszynski
    wrote on last edited by mrmuszynski
    Hi all!
    I'm working with sending messages from one of my sensors back to my controller for the first time, and I'm a little stumped...
    I have this message defined:
    MyMessage msg(CHILD_ID_LIGHT, V_VAR1);
    And this code that uses it to send a message to the controller
    void open_scratchpad(int expectedScratchpadValues) {
      send(msg.set("Scratchpad is open"));
      send(msg.set("string " + String(expectedScratchpadValues)));
    I expect to get the following messages back (in this example, expectedScratchpadValues=4):
    2;1;1;0;24;Scratchpad is open
    2;1;1;0;24;string 4
    Instead, I get:
    2;1;1;0;24;0
    But if I do
    Serial.println("string " + String(expectedScratchpadValues)
    then the arduino console correctly prints
    string 4
    Never mind the exact code here. I'm just playing around to learn the messaging protocol, so it really doesn't mean much of anything. I just want to be able to convert ints to strings, concatenate those strings, and then pass that concatenated result back to my controller.
    Thanks for you help!
    V 1 Reply Last reply
    • M mrmuszynski
      Hi all!
      2;1;1;0;24;string 4
      Instead, I get:
      2;1;1;0;24;0
      But if I do
      string 4
      V
      V
      virtualmkr
      wrote on last edited by virtualmkr
      @mrmuszynski
      Hi, there are some setters for message payload types but none for type String, see: Message manipulation.
      You need to convert the resulting String into const char* like this:
      send(msg.set(("string " + String(expectedScratchpadValues)).c_str()));
      But in general I would try to avoid usage of the String data type, especially for the use case in your code example. You could use e.g.:
        char str[80];
        sprintf(str, "string %d", expectedScratchpadValues);
        send(msg.set(str));
      For Arduino String read more e.g. here: The Evils of Arduino Strings
      HTH
