  3. BMP280 SPI Adafruit
BMP280 SPI Adafruit
3 Posts 3 Posters 4.1k Views 3 Watching
    Matt
    Hi guys.
    I got this working just now. I couldnt get the BMP to run over I2C, or on marekd's sketch posted here , even after changing it to SPI.
    So I pinched the bulk of his great sketch and tweaked to to run on the adafruit libraries over SPI. Prediction even works now, neato! All the crazy prediction coding is his, no credit for me.
      This is a library for the BMP280 humidity, temperature & pressure sensor
      Designed specifically to work with the Adafruit BMEP280 Breakout
      ----> http://www.adafruit.com/products/2651
      These sensors use I2C or SPI to communicate, 2 or 4 pins are required
      to interface.
      Adafruit invests time and resources providing this open source code,
      please support Adafruit andopen-source hardware by purchasing products
      from Adafruit!
      Written by Limor Fried & Kevin Townsend for Adafruit Industries.
      BSD license, all text above must be included in any redistribution
    #include <Adafruit_Sensor.h>
    #include <Adafruit_BMP280.h>
    #define BMP_SCK 5
    #define BMP_MISO 8
    #define BMP_MOSI 6
    #define BMP_CS 7
    Adafruit_BMP280 bme(BMP_CS, BMP_MOSI, BMP_MISO,  BMP_SCK);
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_PRESS 2
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
      STABLE = 0,           // "Stable Weather Pattern"
      SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
      CLOUDY = 2,           // "Slowly falling L-Pressure ", "Cloudy/Rain "
      UNSTABLE = 3,     // "Quickly rising H-Press",     "Not Stable"
      THUNDERSTORM = 4, // "Quickly falling L-Press",    "Thunderstorm"
      UNKNOWN = 5           // "Unknown (More Time needed)
    // for forecast
      float lastPressure = -1;
      float lastTemp = -1;
      int lastForecast = -1;
      const int LAST_SAMPLES_COUNT = 5;
      float lastPressureSamples[LAST_SAMPLES_COUNT];
      // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
      // get kPa/h be dividing hPa by 10
      #define CONVERSION_FACTOR (1.0/10.0)
      int minuteCount = 0;
      bool firstRound = true;
      // average value is used in forecast algorithm.
      float pressureAvg;
      // average after 2 hours is used as reference value for the next iteration.
      float pressureAvg2;
      float dP_dt;
    // MyMessage to controler
    MyMessage msgT1(CHILD_ID_TEMP, V_TEMP);
    MyMessage msgP1(CHILD_ID_PRESS, V_PRESSURE);
    MyMessage msgF1(CHILD_ID_PRESS, V_FORECAST);
    const unsigned long tUpdate = 60000; // update interval
    //unsigned long t0;
      sendSketchInfo("BMP280", "1.1");
      present(CHILD_ID_PRESS, S_BARO);
      Serial.begin(9600);
      Serial.println(F("BMP280 test"));
      if (!bme.begin()) {
        Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
        while (1);
      ServerUpdate();
        /*int temp = bme.readTemperature();
        long pressure = bme.readPressure();
        send(msgT1.set(temp));
        send(msgP1.set(pressure/100));*/
       sleep(SLEEP_TIME);
       ServerUpdate();
    void ServerUpdate() // used to read sensor data and send it to controler
    double T, P;
    T = bme.readTemperature();
    P = bme.readPressure();
    int forecast = sample(P);
    if (P != 0)
      send(msgT1.set(T, 1));
          send(msgP1.set(P/100, 1));
          send(msgF1.set(weather[forecast]));
    float getLastPressureSamplesAverage()
      float lastPressureSamplesAverage = 0;
      for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
        lastPressureSamplesAverage += lastPressureSamples[i];
      lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
      return lastPressureSamplesAverage;
    int sample(float pressure)
      // Calculate the average of the last n minutes.
      int index = minuteCount % LAST_SAMPLES_COUNT;
      lastPressureSamples[index] = pressure;
      minuteCount++;
      if (minuteCount > 185)
        minuteCount = 6;
      if (minuteCount == 5)
        pressureAvg = getLastPressureSamplesAverage();
      else if (minuteCount == 35)
        float lastPressureAvg = getLastPressureSamplesAverage();
        float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
        if (firstRound) // first time initial 3 hour
          dP_dt = change * 2; // note this is for t = 0.5hour
        else
          dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
      else if (minuteCount == 65)
        if (firstRound) //first time initial 3 hour
          dP_dt = change; //note this is for t = 1 hour
        else
          dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
      else if (minuteCount == 95)
          dP_dt = change / 1.5; // note this is for t = 1.5 hour
        else
          dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
      else if (minuteCount == 125)
        pressureAvg2 = lastPressureAvg; // store for later use.
          dP_dt = change / 2; // note this is for t = 2 hour
        else
          dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
      else if (minuteCount == 155)
          dP_dt = change / 2.5; // note this is for t = 2.5 hour
        else
          dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
      else if (minuteCount == 185)
          dP_dt = change / 3; // note this is for t = 3 hour
        else
          dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
        pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
        firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
      int forecast = UNKNOWN;
      if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
        forecast = UNKNOWN;
      else if (dP_dt < (-0.25))
        forecast = THUNDERSTORM;
      else if (dP_dt > 0.25)
        forecast = UNSTABLE;
      else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
        forecast = CLOUDY;
      else if ((dP_dt > 0.05) && (dP_dt < 0.25))
        forecast = SUNNY;
      else if ((dP_dt > (-0.05)) && (dP_dt < 0.05))
        forecast = STABLE;
      else
        forecast = UNKNOWN;
      // uncomment when debugging
      //Serial.print(F("Forecast at minute "));
      //Serial.print(minuteCount);
      //Serial.print(F(" dP/dt = "));
      //Serial.print(dP_dt);
      //Serial.print(F("kPa/h --> "));
      //Serial.println(weather[forecast]);
      return forecast;
    TheoLT 1 Reply Last reply
    • M Matt
      Hi guys.
        to interface.
        from Adafruit!
      #define BMP_SCK 5
      #define BMP_MISO 8
      #define BMP_MOSI 6
      #define BMP_CS 7
      enum FORECAST
      // for forecast
        float pressureAvg;
        float pressureAvg2;
        float dP_dt;
      //unsigned long t0;
        Serial.begin(9600);
        if (!bme.begin()) {
          while (1);
        ServerUpdate();
         sleep(SLEEP_TIME);
         ServerUpdate();
      double T, P;
      if (P != 0)
        minuteCount++;
          minuteCount = 6;
          else
          else
          else
          else
          else
          else
          forecast = UNKNOWN;
          forecast = CLOUDY;
          forecast = SUNNY;
          forecast = STABLE;
        else
          forecast = UNKNOWN;
        return forecast;
      TheoLT
      TheoLT
      TheoL
      Hi @Matt
      Thanx your for your posting. Hopefully others can benefit from this.
        mareinki
        Hallo!
        Ich habe gerade meinen Aduino Nano mit einem GY-BME/P-280 verbunden über SPI verbunden.
        Im Sketch habe ich nur die PINS geändert und zwar auf:
        #define BMP_SCK 13
        #define BMP_MISO 12
        #define BMP_MOSI 11
        #define BMP_CS 10
        Ich bekomme aber bei der Ausgabe am seriellen Monitor nur "Hyroglyphen" zB 5��,�lh����}����'�O8��m�h,�
        Mit einem anderen Sketch funktioniert der Sensor einwandfrei. Auch mit einem anderen Nano dasselbe Ergebnis.
        Hat jemand eine Idee was das Problem sein könnte?
        Zusatzfrage da ich in C++ nicht so firm bin: Könnte es sein, dass MY_DEBUG oder MY_RADIO_NRF24 das problem verursacht. Was machen diese Definitionen eigentlich?
        Grüße
