  3. Anyone using/tried the E28-2G4M27S 2.4Ghz LoRa SX1280 27dB module?
249 Posts 10 Posters 76.0k Views 11 Watching
    #179
    From the perspective of having some kind of general purpose platform--not just for testing but as a "go-to" for general use--it would be nice to have some kind of project box or enclosure of some kind for it. That would prevent things in the environment from pushing up against the electronics/PCB and possibly shorting it out. Anyone have any ideas on what form that should take? There's always the option of custom 3D printing something, but if there were a box of the right size already out there, that would be much easier. In that case one could customize the PCB to fit it precisely instead of 3D printing a box to precisely fit the PCB. Having a nice enclosure is one of the things that typically separates store-bought sensors from hobbyist projects.
    By the way, the SHT45 TH sensor that I mentioned in the OP is now available on mouser. Unfortunately, it seems they nearly doubled their asking price over what they had earlier projected, so that's a bit of a disappointment. I guess these days a lot of chips are marked up due to the widespread shortages going on.... The chip itself is quite small, but it only has four landing pads, so I'm thinking that hand soldering it should be manageable. A simple adapter board, like this one for the SHT40, would allow it to easily fit the platform:
    because the platform's pinout already anticipates adding up to two I2C devices without any fuss, like thus:
    FYI, I updated the project page with a bunch of photos.
    L 3 Replies Last reply
      L
      L
      Larson
      wrote on last edited by Larson
      #180
      @NeverDie said in Anyone using/tried the E28-2G4M27S 2.4Ghz LoRa SX1280 27dB module?:
      Looks great! I’ve had good luck at Aliexpress with a variety of boxes like these. Some boxes have mounting lugs on the bottom. Your board has no space for mounting holes. I could help with the redesign??? Then I'd use stand-offs to get to the lugs and suspend the batteries in the air off the bottom. The antenna could be curled inside the box, but I've found that to have a negative impact (probably the polairity thing.
      [Edit: Forgot to say that I've thrown in the little bags of desiccants for good measure. I find them in my pill bottles.]
        L
        L
        Larson
        #181
        @NeverDie I've made progress. I've ordered these items (mostly radios):
        SX1278
        SX1280
        nrf24012mg E01's
        nrf2401+
        Bunch of antenna parts
        TPL5110
        Atmega328's
        I cannot find any SX1262's and after your other post ("Best") I see that this is the darling to have. Any idea of where to find some?
        Fun to see the photos of the current meter in sleep action on your other post.
        One addition I would like to make to your boards is a GPS chip. The idea would be to walk about in a field and collect RSSI and SNR data. Combining these elements would give a pretty good picture of signal vs the 2-dimensions of GPS data - for each radio and different modulations, spreading factors... Trouble here is that there are too many parameters to play with. I see Excel graphics coming into play. I have no experience with GPS, although I own a few of the chips.
          #182
          The ones I've tried so far are these: https://www.ebay.com/itm/202574135410?hash=item2f2a5c0072:g:H9EAAOSwLuldcige Maybe it was luck, but the seller delivered fairly quickly, and they were very well packed. They allegedly contain TCXO's, so that presumably makes them better than those moules which don't have TCXO's.
          I just today received these Ra-01SH, but haven't tried them yet: https://www.aliexpress.com/item/2255800961841511.html?spm=a2g0o.order_list.0.0.20411802pmZPEx&gatewayAdapt=4itemAdapt
          I have custom adapter boards for them though. At the time I ordered them in April they were just $3.31 each, but now the same seller is asking $4.24. Delivery time was pretty long (longer than originally promised). So, you may want to shop around. If this is the new market rate, then I would go for the Dorji boards instead, because for the money you at least get TCXO's with the Dorji's, and they allegedly passed FCC. On the other hand, I've had good luck with Ai-Thinker in the past.
          There are some other brands out there as well, but these are the only two for which I made adapter boards.
          L 1 Reply Last reply
          • L Larson
            SX1278
            SX1280
            nrf24012mg E01's
            nrf2401+
            TPL5110
            Atmega328's
            #183
            @Larson I don't know how well GPS location works indoors, but it if somehow does that would be interesting. If it has gotten small enough and cheap enough and low power enough, it would be interesting for clock synchronization as well, though there are other ways of doing that.
              Wow, I just checked, and GPS receivers have really gotten small, especially as compared to 5 years ago. Just 7mmx7mm in size: https://www.mouser.com/ProductDetail/Quectel/LG77LIAMD?qs=zW32dvEIR3sKRLNP92tehQ%3D%3D
              That's way smaller than the old Adafruit one that I have: https://www.adafruit.com/product/5440
              which is gigantic.
                L
                L
                Larson
                @NeverDie Thanks, once again. Done and purchased (4 1262's, and 2 1276's (ra-01SH)). I don't know why google and I couldn't find the1262's, nor Digikey, nor Ali, nor Amazon. So I'm on the slow road. I don't expect you to wait for me but your records in this forum are a standing education for all that follow. I'm sure I'll have observations/questions if you are still there.
                Per my GPS thinking: I was thinking outdoors in an open field. I know your objective was through a reinforced footing, across the house, and up a floor. For that environment I would map the house into a grid with surveyor's cord and walk a defined pattern, clicking a button for every grid point I cross. Then I'd go to the yard with the same idea. My wife tells me I'm hard to live with... imagine that.
                • L Larson
                  #186
                  @Larson According to AI-thinker, the Ra-01SH is an SX1262, not a 1276. The SX1262's are more capable, whereas the 1276's are older generation. https://docs.ai-thinker.com/_media/lora/docs/ra-01sh_specification.pdf AFAIK, the two adafruit modules I got for trial purposes were SX1276's.
                  Since you'll be trying more than just the Ebyte module, let me know if you'd like me to post the other adapter boards also (e.g. for the Dorji SX1262, the Ra-01SH, and the nRF24L01). The work is already done.
                  L 2 Replies Last reply
                    which is gigantic.
                    L
                    L
                    Larson
                    which is gigantic.
                    At some point, like this, bigger is better for me. Imagine the size of the GPS in modern phones. I prefer the Adafruit type that has breakout pins and 'hold-my-hand' tutorials. We live in a golden age. I have to go find my GPS boards that i think I have. It has been some time and I've always wanted some purpose. This may be the time.
                      #188
                      Definitely agree that it's the tutorials that make the adafruit hardware worthwhile, typically much more so than the hardware itself.
                        L
                        L
                        Larson
                        The other adapter boards would be great... but I thought I'd earn my way into it by working with what you have already posted for the SX1280. To date I've been collecting pinouts to study the patterns so I could understand the template(s). What ever you post is a gift and I thank you. I'm sure that others to come will also enjoy. You have built quite a platform and I'm inspired.
                          L
                          L
                          Larson
                          As I'm shoping around I found the Ra-01 Lora, but it was assocaited with the 1276 per this link you offered: https://www.aliexpress.com/item/2255800961841511.html?spm=a2g0o.order_list.0.0.20411802pmZPEx&gatewayAdapt=4itemAdapt&aff_fcid=d9908c021fe34eeeb0ea05b879ca4432-1654498510220-06752-_uYd1nh&aff_fsk=_uYd1nh&aff_platform=api-new-link-generate&sk=_uYd1nh&aff_trace_key=d9908c021fe34eeeb0ea05b879ca4432-1654498510220-06752-_uYd1nh&terminal_id=afb1662bfbca4bd68d5ee03a630ea8c7&afSmartRedirect=y.
                          Given that I haven't studied the datasheets, I don't exactly know the shape-shifting ability of one chip to act as another. Not sure where to go with this one - but I'll know more when they arrive. I'll work on it in the AM when I'm fresher.
                          NeverDieN L 2 Replies Last reply
                          • L Larson
                            @Larson When you hover over the different modules on that webpage, it will tell you the name of the model. They're all different.
                              L
                              L
                              Larson
                              @NeverDie Groovy. And good night. So much to learn.
                                L
                                L
                                Larson
                                Second effort: This link shows a type of box with mounting points on the bottom. It would be nice if there were a PCB footprint for the holes, but I could find none. Using a paper rubbing and a set of calipers one can create their own footprint and build the PCB to that dimension. For any hard wires that must be passed through the box, I've been using cable glands like these for a waterproof enclosure. See the Cave Pearl Project for a different deep-sea approach,
                                  I posted the rest of the radio module adapters to openhardware.io.
                                  • L Larson
                                    L
                                    L
                                    Larson
                                    How confusing. On the EC-Buying Ali Store they show associations of the RA-01 with SX1262, SX1272, and SX1278 in titles on separate pages. Each of these pages show a variations on the RA-01 title (S, H, SH, SC...). I'll take your word for it. So it looks like all 6 radios I ordered last night are SX1262's then.
                                    Found my GPS! It is really big & heavy too.
                                      L
                                      L
                                      Larson
                                      Wow. Thanks. I'll be sure to report back on what I come-up with.
                                        L
                                        L
                                        Larson
                                        @NeverDie Been gone today so unable to play. Thanks again for generously sharing your work. I'm just now starting to look at the files: so cool! I like your broad power traces and skinny signal traces. And the pads on the radio chips are really tiny. I suspect these design choices are not accidental.
                                        Look out OSH Park, here I come.
                                        • L Larson
                                          @Larson One thing Diptrace had that KiCAD lacks is a built-in auto-router. As a result, I manually routed as fast as I could so that I could place the order without delay. I've heard there are auxillary auto-routers. If any of them are any good, it would be a nice tool to have. Drafting the schematics goes pretty fast; it's the routing that soaks up the bulk of the time.
