  3. ESP8266Wifi Gateway won't connect
33 Posts 6 Posters 4.6k Views 6 Watching
  • H hard-shovel
    @OldSurferDude If connecting to a MQTT Broker i would have expected you to use the GatewayESP8266MQTTClient sketch.
    as this is already setup with correct Port 1883 for MQTT and the publishing and subscription topics.
    I did a quick test of a GatewayESP8266MQTTClient sketch with mosquitto and it works fine for me.
    OldSurferDudeO
    OldSurferDudeO
    OldSurferDude
    @hard-shovel client worked for me, too. That is, it sent the message "2.3.2" to topic "mygateway1-outx/0/255/0/0/18"
    • H hard-shovel
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      @hard-shovel I tried the client and it did indeed send the MySensors version message. But it does not pass along the messages from the Arduino nodes.
      H 1 Reply Last reply
        H
        H
        hard-shovel
        wrote on last edited by hard-shovel
        #22
        @OldSurferDude have you set the MQTT user and MQTT passwords in the sketch and uncommented them as well?
        #define MY_MQTT_USER "MQTTusername2022"
        #define MY_MQTT_PASSWORD "MQTTpassword2022"
        what does your debug log look like?
        This sample is not connected correctly to the MQTT Broker
        10:33:26.151 -> dhcp client start...
        10:33:26.151 -> 341 TSM:INIT:GW MODE
        10:33:26.199 -> 364 TSM:READY:ID=0,PAR=0,DIS=0
        10:33:26.199 -> 396 MCO:REG:NOT NEEDED
        10:33:26.339 -> 505 GWT:TPC:CONNECTING...
        10:33:27.365 -> 1533 MCO:BGN:STP
        10:33:27.365 -> 1551 MCO:BGN:INIT OK,TSP=1
        10:33:27.412 -> 1579 TSM:READY:NWD REQ
        10:33:27.412 -> 1606 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
        10:33:28.671 -> scandone
        10:33:35.993 -> pm open,type:2 0
        10:33:44.664 -> 18861 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        10:33:44.758 -> 18924 TSF:MSG:BC
        10:33:44.758 -> 18942 TSF:MSG:FPAR REQ,ID=254
        10:33:44.804 -> 18973 TSF:PNG:SEND,TO=0
        10:33:44.804 -> 18998 TSF:CKU:OK
        10:33:44.851 -> 19016 TSF:MSG:GWL OK
        10:33:45.459 -> 19646 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        10:33:46.671 -> 20876 TSF:MSG:READ,254-254-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        10:33:46.766 -> 20939 TSF:MSG:PINGED,ID=254,HP=1
        10:33:46.813 -> 20980 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        10:33:46.860 -> 21057 TSF:MSG:READ,254-254-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        This is working correctly
        10:36:34.908 -> dhcp client start...
        10:36:37.655 -> ip:192.168.1.202,mask:255.255.255.0,gw:192.168.1.254
        10:36:37.702 -> 7014 GWT:TPC:IP=192.168.1.202
        10:36:37.702 -> 7100 GWT:RMQ:CONNECTING...
        10:36:37.749 -> 7144 GWT:RMQ:OK
        10:36:37.795 -> 7161 GWT:TPS:TOPIC=mygateway4-out/0/255/0/0/18,MSG SENT
        10:36:44.792 -> pm open,type:2 0
        10:38:56.629 -> 146027 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
        10:38:56.723 -> 146091 TSF:MSG:BC
        10:38:56.723 -> 146109 TSF:MSG:FPAR REQ,ID=254
        10:38:56.770 -> 146142 TSF:PNG:SEND,TO=0
        10:38:56.770 -> 146168 TSF:CKU:OK
        10:38:56.816 -> 146187 TSF:MSG:GWL OK
        10:38:57.655 -> 147013 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
        10:38:58.683 -> 148042 TSF:MSG:READ,254-254-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
        10:38:58.730 -> 148105 TSF:MSG:PINGED,ID=254,HP=1
        10:38:58.776 -> 148148 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
        10:38:58.869 -> 148226 TSF:MSG:READ,254-254-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        10:38:58.916 -> 148294 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        10:38:59.010 -> 148375 TSF:MSG:READ,254-254-0,s=255,c=0,t=17,pt=0,l=11,sg=0:2.4.0-alpha
        10:38:59.058 -> 148450 GWT:TPS:TOPIC=mygateway4-out/254/255/0/0/17,MSG SENT
        10:38:59.151 -> 148515 TSF:MSG:READ,254-254-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
        10:38:59.197 -> 148578 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/6,MSG SENT
        10:39:00.923 -> 150319 TSF:MSG:READ,254-254-0,s=255,c=3,t=11,pt=0,l=14,sg=0:MockMySensors
        10:39:01.017 -> 150398 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/11,MSG SENT
        10:39:01.064 -> 150462 TSF:MSG:READ,254-254-0,s=255,c=3,t=12,pt=0,l=4,sg=0:v0.5
        10:39:01.157 -> 150529 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/12,MSG SENT
        10:39:01.949 -> 151337 TSF:MSG:READ,254-254-0,s=1,c=0,t=0,pt=0,l=12,sg=0:Outside Door
        10:39:02.044 -> 151410 GWT:TPS:TOPIC=mygateway4-out/254/1/0/0/0,MSG SENT
        10:39:02.091 -> 151471 TSF:MSG:READ,254-254-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
        10:39:02.184 -> 151542 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
        10:39:02.699 -> 152055 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:83
        OldSurferDudeO 2 Replies Last reply
        • H hard-shovel
          OldSurferDudeO
          OldSurferDudeO
          OldSurferDude
          @hard-shovel My MQTT broker does not require them. Should I uncomment and leave them blank?
            H
            H
            hard-shovel
            @OldSurferDude You should leave them commented if not required.
            I have just tested with a new install on windows of mosquitto with config file for anonymous access and it is working fine with them commented out.
            what do your gateway debug logs look like?
            • H hard-shovel
              OldSurferDudeO
              OldSurferDudeO
              OldSurferDude
              wrote on last edited by OldSurferDude
              #25
              @hard-shovel This is what I'm getting (with no nodes connecting to gateway)
              MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
              117 TSF:LRT:OK
              133 TSM:INIT
              147 TSF:WUR:MS=0
              170 TSM:INIT:TSP OK
              191 TSM:INIT:GW MODE
              213 TSM:READY:ID=0,PAR=0,DIS=0
              245 MCO:REG:NOT NEEDED
              scandone
              1322 GWT:TIN:CONNECTING...
              2351 GWT:TIN:CONNECTING...
              scandone
              state: 0 -> 2 (b0)
              4097 GWT:TIN:CONNECTING...
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 1
              cnt
              connected with Automation, channel 9
              ip:192.168.1.30,mask:255.255.255.0,gw:192.168.1.193
              4316 GWT:TIN:IP: 192.168.1.30
              4355 GWT:TIN:ETH OK
              4378 MCO:BGN:STP
              4396 MCO:BGN:INIT OK,TSP=1
              4424 TSM:READY:NWD REQ
              4451 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              pm open,type:2 0
              And this comes when a node connects:
              197868 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              197928 TSF:MSG:BC
              197947 TSF:MSG:FPAR REQ,ID=2
              197977 TSF:PNG:SEND,TO=0
              198003 TSF:CKU:OK
              198022 TSF:MSG:GWL OK
              198460 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              200006 TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              200065 TSF:MSG:PINGED,ID=2,HP=1
              200106 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              200244 TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              200309 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              200385 TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
              200456 GWT:TSA:ETH OK
              200481 TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              200545 GWT:TSA:ETH OK
              202529 TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=15,sg=0:BatMoistHumTemp
              202611 GWT:TSA:ETH OK
              202636 TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=9,sg=0:     0.01
              202710 GWT:TSA:ETH OK
              202885 TSF:MSG:READ,2-2-0,s=0,c=0,t=35,pt=0,l=0,sg=0:
              202948 GWT:TSA:ETH OK
              203141 TSF:MSG:READ,2-2-0,s=1,c=0,t=7,pt=0,l=0,sg=0:
              203203 GWT:TSA:ETH OK
              203396 TSF:MSG:READ,2-2-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
              203458 GWT:TSA:ETH OK
              203651 TSF:MSG:READ,2-2-0,s=3,c=0,t=30,pt=0,l=0,sg=0:
              203713 GWT:TSA:ETH OK
              203925 TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              203992 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              204128 TSF:MSG:READ,2-2-0,s=255,c=3,t=0,pt=1,l=1,sg=0:100
              204199 GWT:TSA:ETH OK
              204407 TSF:MSG:READ,2-2-0,s=3,c=1,t=38,pt=7,l=5,sg=0:6.52
              204475 GWT:TSA:ETH OK
              204542 TSF:MSG:READ,2-2-0,s=0,c=1,t=37,pt=2,l=2,sg=0:1023
              204610 GWT:TSA:ETH OK
              • paqorP
                paqorP
                paqor
                wrote on last edited by paqor
                #26
                Hello have with the gateway constantly disconnects after a few days and I can only reactivate it by resetting on the gateway.
                Have now inserted a separate power supply with a large electrolytic capacitor 5000 µF-let's see....
                  117 TSF:LRT:OK
                  133 TSM:INIT
                  147 TSF:WUR:MS=0
                  170 TSM:INIT:TSP OK
                  scandone
                  scandone
                  state: 0 -> 2 (b0)
                  state: 2 -> 3 (0)
                  state: 3 -> 5 (10)
                  add 0
                  aid 1
                  cnt
                  4355 GWT:TIN:ETH OK
                  4378 MCO:BGN:STP
                  pm open,type:2 0
                  197928 TSF:MSG:BC
                  198003 TSF:CKU:OK
                  H
                  H
                  hard-shovel
                  #27
                  @OldSurferDude You are getting regular GWT:TSA:ETH OK message which i do not and you have no
                  MSG SENT lines
                  Which MQTT broker are you using?
                  my test setup which i hope matches yours is:
                  MySensors 2.3.2 & ESP8266 core 2.7.4
                  ESP8266 Node MCU with sketch GatewayESP8266MQTTClient
                  MY_BAUD_RATE 9600
                  MY_MQTT_USER & MQTT_PASSWORD commented out
                  MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 195 address of the MQTT broker
                  MY_CONTROLLER_URL_ADDRESS "MQTT-TEST-W10" commented out Use IP or URL not Both
                  MY_PORT 1883
                  MQTT Broker
                  Mosquitto 2.0.15 running as a service on a windows 10 machine
                  listener 1883 anonymous access
                  URL MQTT-TEST-W10
                  When connected to the MQTT Broker and receiving messages from a node the gateway shows
                  09:48:18.962 -> 718935 TSF:MSG:READ,254-254-0,s=1,c=1,t=16,pt=2,l=2,sg=0:0
                  09:48:19.010 -> 718997 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/16,MSG SENT
                  09:48:19.104 -> 719059 TSF:MSG:READ,254-254-0,s=1,c=1,t=15,pt=1,l=1,sg=0:1
                  09:48:19.149 -> 719121 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/15,MSG SENT
                  09:48:19.198 -> 719182 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:83
                  09:48:19.292 -> 719246 GWT:TPS:TOPIC=mygateway5-out/254/255/3/0/0,MSG SENT
                  if a message is sent to the broker the gateway shows
                  10:03:54.285 -> 1654209 GWT:IMQ:TOPIC=mygateway5-in/254/255/1/0/15, MSG RECEIVED
                  10:03:54.331 -> 1654279 TSF:MSG:SEND,0-0-254-254,s=255,c=1,t=15,pt=0,l=1,sg=0,ft=0,st=OK:1
                  10:03:54.423 -> 1654358 TSF:MSG:READ,254-254-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
                  10:03:54.471 -> 1654421 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/16,MSG SENT
                  10:03:54.565 -> 1654483 TSF:MSG:READ,254-254-0,s=1,c=1,t=15,pt=1,l=1,sg=0:1
                  10:03:54.611 -> 1654546 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/15,MSG SENT
                  OldSurferDudeO 1 Reply Last reply
                  • H hard-shovel
                    MSG SENT lines
                    MY_BAUD_RATE 9600
                    MY_PORT 1883
                    MQTT Broker
                    URL MQTT-TEST-W10
                    OldSurferDudeO
                    OldSurferDudeO
                    OldSurferDude
                    @hard-shovel I created a faux nano sensor and used nRF24L01 channel 121 to communicate to the gateway. Here is my NodeMCU ESP8266 code with all comments taken out:
                    #define VER 0.4
                    #define MY_DEBUG true
                    #define MY_BAUD_RATE 9600
                    #define MY_RADIO_RF24
                    #define MY_RF24_CHANNEL 121
                    #define MY_GATEWAY_ESP8266 "Test"
                    #define MY_WIFI_SSID "SSID"
                    #define MY_WIFI_PASSWORD "pass"
                    #define MY_HOSTNAME "ESP8266_GW"
                    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mysensors-out"
                    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mysensors-in"
                    #define MY_PORT 1883
                    #define MY_GATEWAY_MAX_CLIENTS 8
                    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 142
                    void setup() {Serial.print("ESP8266MySensorsGateway version: ");Serial.println(VER); }
                    void presentation(){}
                    void loop(){}
                    On boot, the gateway generates the following debug output:
                    60 MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
                    118 TSF:LRT:OK
                    133 TSM:INIT
                    147 TSF:WUR:MS=0
                    170 TSM:INIT:TSP OK
                    246 MCO:REG:NOT NEEDED
                    scandone
                    2350 GWT:TIN:CONNECTING...
                    scandone
                    state: 0 -> 2 (b0)
                    state: 2 -> 3 (0)
                    state: 3 -> 5 (10)
                    add 0
                    aid 1
                    cnt
                    4354 GWT:TIN:ETH OK
                    4376 MCO:BGN:STP
                    ESP8266MySensorsGateway version: 0.40
                    4394 MCO:BGN:INIT OK,TSP=1
                    4463 TSM:READY:NWD REQ
                    4490 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    6865 TSF:MSG:READ,2-2-0,s=0,c=1,t=37,pt=2,l=2,sg=0:208
                    6933 GWT:TSA:ETH OK
                    The faux node connects to the gateway indicated by this debug code from the gateway (which is repeated for each "reading" (eg. 204):
                    1047590 TSF:MSG:READ,2-2-0,s=0,c=1,t=37,pt=2,l=2,sg=0:204
                    1047656 GWT:TSA:ETH OK
                    Nothing arrives at the MQTT broker. From another machine, I can publish to the broker:
                    mosquitto_pub -h 192.168.1.139 -t test/mztake -m "did it arrive?"
                    and it does arrive at the broker.
                    What am I missing?
                    OSD
                      #define VER 0.4
                      void loop(){}
                      118 TSF:LRT:OK
                      133 TSM:INIT
                      147 TSF:WUR:MS=0
                      170 TSM:INIT:TSP OK
                      scandone
                      scandone
                      state: 0 -> 2 (b0)
                      state: 2 -> 3 (0)
                      state: 3 -> 5 (10)
                      add 0
                      aid 1
                      cnt
                      4354 GWT:TIN:ETH OK
                      4376 MCO:BGN:STP
                      6933 GWT:TSA:ETH OK
                      What am I missing?
                      OSD
                      @OldSurferDude you are (at least) missing #define MY_GATEWAY_MQTT_CLIENT.
                      The sketch you are using is instructing MySensors to create an ethernet gateway.
                      Example sketch for esp8266 mqtt: https://github.com/mysensors/MySensors/blob/master/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino
                        OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        @mfalkvidd said in ESP8266Wifi Gateway won't connect:
                        That was it! Thank you!
                        OSD
                          OldSurferDudeO
                          OldSurferDudeO
                          OldSurferDude
                          @mfalkvidd Because I see that the example has a presentation() routine with the comment "// Present locally attached sensors here" I made the assumption that the gateway could have local sensors. I described a local sensor
                          // local sensor information
                          #define MY_NODE_ID 3
                          #define CHILD_ID_GATEWAY_FAUX_SENSOR 0
                          MyMessage msgFauxSensor(CHILD_ID_GATEWAY_FAUX_SENSOR, V_LEVEL);
                          int fauxSensorValue = 0;
                          and put the data acquisition code in the loop:
                           send(msgFauxSensor.set(fauxSensorValue++));
                           Serial.print("Value sent: ");Serial.println(fauxSensorValue);
                           delay(30000);
                          Lo and Behold! This data was being found on the MQTT broker! Albeit the NODE_ID was not 3 as defined, but 0. This makes sense because the NODE_ID of the gateway is zero.
                          Previously, I had my gateway running on an RPi. My question is, can I put a presentation() routine and data acquisition of the gateway running on my RPi?
                             delay(30000);
                            delay(30000);
                            A delay in the gateway will make the gateway freeze. It will not handle incoming messages (not from the mqtt broker, not for any nodes). Use wait() instead.
                            Yes, it should work. The file to edit is https://github.com/mysensors/MySensors/blob/development/examples_linux/mysgw.cpp
                            Have you forgotten about https://forum.mysensors.org/post/111806 ?
                              delay(30000);
                              OldSurferDudeO
                              OldSurferDudeO
                              OldSurferDude
                              @mfalkvidd Yes, totally forgot about that link you put there. Thanks for reminding me. :)
