  3. ESP8266Wifi Gateway won't connect
33 Posts 6 Posters 4.6k Views 6 Watching
    @dpcons @hard-shovel @paqor @chrishiscox @mfalkvidd Hi all,
    I saw this and got excited that I could use my NodeMCUv1.0 as a MySensors Gateway. I made sure I had the latest MySensors library (2.3.2) and ESP8266 board (3.0.2). I successfully ran a couple examples, first file-->examples-->ESP8266-->Blink then file-->examples-->ESP8266-->interactive (with my ssid & pass), the latter with serial monitor at 115200 baud.
    I ensured that my nRF24l01 was functional by connecting it to an Arduino Nano and running the scanner program.
    I connected my nRF24l01 to my NodeMCU, both having pins, using new 10cm 7 conductor ribbon cable. (I have successfully used this type of connection to an RPi)
    The program ... I copied the program from this page and applied my ssid and password. Nothing ... I suspected that this code is a node template, not a the gateway program.
    On that same page was the instruction "Open the WiFi gateway in the Arduino IDE (File -> Sketchbook -> Libraries -> MySensors -> Esp8266Gateway)" I didn't find "Libraries" under "Sketchbook" I a file of the same name at (File -> Sketchbook -> Libraries -> MySensors -> examples --> Esp8266Gateway) which is the same file.
    I tried putting into setup the line
    Serial.println("com check");
    but nothing came out on the console.
    I think I'm at the same place as @dpcons
    update: rechecked my radio with the RF24 "getting started" program and found the radio good. Updated my Arduino IDE. Still not working.
    H
    H
    hard-shovel
    wrote on last edited by hard-shovel
    @OldSurferDude @dpcons Hi all,
    The sample sketch could also be found using (File -> Examples -> MySensors -> Esp8266Gateway
    As MySensors version 2.3.2 and ESP8266 core 3.0.2 combination does not work you need to change one or the other versions.
    The simplest is to roll back the ESP8266 Core version to 2.7.4 and keep the MySensors 2.3.2 version
    (Tools -> Board -> Board Manager)
    Enter ESP8266 in search bar, then click within the ESP8266 data info box, click the select version pulldown.
    Select 2.7.4 and then click Install.
    Other option is to update the MySensors library to the development version 2.4.0-Alpha but that has to be done manually.
    OldSurferDudeO 2 Replies Last reply
    • H hard-shovel
      OldSurferDudeO
      OldSurferDudeO
      OldSurferDude
      wrote on last edited by OldSurferDude
      @hard-shovel Thanks! Now I'm getting output to the monitor. I think I need to set up the IP address and the port 1883 for the MQTT broker. How is that done? I am also getting data from my Arduino node sensors :) I see "controller" but when I change that to my broker's address I get streaming ETH FAIL
      OldSurferDudeO 1 Reply Last reply
        OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        The port was set to 5003 and setting it to 1883 (the default MQTT broker port) it now seems to work
        H 1 Reply Last reply
          H
          H
          hard-shovel
          @OldSurferDude If connecting to a MQTT Broker i would have expected you to use the GatewayESP8266MQTTClient sketch.
          as this is already setup with correct Port 1883 for MQTT and the publishing and subscription topics.
          I did a quick test of a GatewayESP8266MQTTClient sketch with mosquitto and it works fine for me.
          OldSurferDudeO 3 Replies Last reply
          • H hard-shovel
            OldSurferDudeO
            OldSurferDudeO
            OldSurferDude
            @hard-shovel While it all seemed to be working, it appears that the ESP8266 MySensors Gateway was not passing the data onto the MQTT broker. Working, meaning that data from the Arduino sensors were getting to the Gateway, but that data was not getting to the broker. Here are some lines of the debug output:
            6217818 TSF:MSG:READ,133-133-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            6217883 TSF:MSG:BC
            6217903 TSF:MSG:FPAR REQ,ID=133
            6217936 TSF:CKU:OK,FCTRL
            6217962 TSF:MSG:GWL OK
            6218281 !TSF:MSG:SEND,0-0-133-133,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
            Also, as an indication that data was not being passed from the Gateway to the broker, I had reset my MQTT Broker and subsequently monitored it with MQTT explorer. The topic "mysensors-out" was not created.
            I shut down the ESP8266 MySensors Gateway and restarted the my original one that is running on an RPi. Everything started running as expected.
            Thus, my conclusion.
            OK, so why isn't the ESP8266 MySensors Gateway passing on the data?
            • H hard-shovel
              OldSurferDudeO
              OldSurferDudeO
              OldSurferDude
              @hard-shovel I try the client
              • H hard-shovel
                OldSurferDudeO
                OldSurferDudeO
                OldSurferDude
                @hard-shovel client worked for me, too. That is, it sent the message "2.3.2" to topic "mygateway1-outx/0/255/0/0/18"
                • H hard-shovel
                  OldSurferDudeO
                  OldSurferDudeO
                  OldSurferDude
                  @hard-shovel I tried the client and it did indeed send the MySensors version message. But it does not pass along the messages from the Arduino nodes.
                    H
                    H
                    hard-shovel
                    #22
                    @OldSurferDude have you set the MQTT user and MQTT passwords in the sketch and uncommented them as well?
                    #define MY_MQTT_USER "MQTTusername2022"
                    #define MY_MQTT_PASSWORD "MQTTpassword2022"
                    what does your debug log look like?
                    This sample is not connected correctly to the MQTT Broker
                    10:33:26.151 -> dhcp client start...
                    10:33:26.151 -> 341 TSM:INIT:GW MODE
                    10:33:26.199 -> 364 TSM:READY:ID=0,PAR=0,DIS=0
                    10:33:26.199 -> 396 MCO:REG:NOT NEEDED
                    10:33:26.339 -> 505 GWT:TPC:CONNECTING...
                    10:33:27.365 -> 1533 MCO:BGN:STP
                    10:33:27.365 -> 1551 MCO:BGN:INIT OK,TSP=1
                    10:33:27.412 -> 1579 TSM:READY:NWD REQ
                    10:33:27.412 -> 1606 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                    10:33:28.671 -> scandone
                    10:33:35.993 -> pm open,type:2 0
                    10:33:44.664 -> 18861 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    10:33:44.758 -> 18924 TSF:MSG:BC
                    10:33:44.758 -> 18942 TSF:MSG:FPAR REQ,ID=254
                    10:33:44.804 -> 18973 TSF:PNG:SEND,TO=0
                    10:33:44.804 -> 18998 TSF:CKU:OK
                    10:33:44.851 -> 19016 TSF:MSG:GWL OK
                    10:33:45.459 -> 19646 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    10:33:46.671 -> 20876 TSF:MSG:READ,254-254-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    10:33:46.766 -> 20939 TSF:MSG:PINGED,ID=254,HP=1
                    10:33:46.813 -> 20980 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                    10:33:46.860 -> 21057 TSF:MSG:READ,254-254-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    This is working correctly
                    10:36:34.908 -> dhcp client start...
                    10:36:37.655 -> ip:192.168.1.202,mask:255.255.255.0,gw:192.168.1.254
                    10:36:37.702 -> 7014 GWT:TPC:IP=192.168.1.202
                    10:36:37.702 -> 7100 GWT:RMQ:CONNECTING...
                    10:36:37.749 -> 7144 GWT:RMQ:OK
                    10:36:37.795 -> 7161 GWT:TPS:TOPIC=mygateway4-out/0/255/0/0/18,MSG SENT
                    10:36:44.792 -> pm open,type:2 0
                    10:38:56.629 -> 146027 TSF:MSG:READ,254-254-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                    10:38:56.723 -> 146091 TSF:MSG:BC
                    10:38:56.723 -> 146109 TSF:MSG:FPAR REQ,ID=254
                    10:38:56.770 -> 146142 TSF:PNG:SEND,TO=0
                    10:38:56.770 -> 146168 TSF:CKU:OK
                    10:38:56.816 -> 146187 TSF:MSG:GWL OK
                    10:38:57.655 -> 147013 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                    10:38:58.683 -> 148042 TSF:MSG:READ,254-254-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                    10:38:58.730 -> 148105 TSF:MSG:PINGED,ID=254,HP=1
                    10:38:58.776 -> 148148 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                    10:38:58.869 -> 148226 TSF:MSG:READ,254-254-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    10:38:58.916 -> 148294 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                    10:38:59.010 -> 148375 TSF:MSG:READ,254-254-0,s=255,c=0,t=17,pt=0,l=11,sg=0:2.4.0-alpha
                    10:38:59.058 -> 148450 GWT:TPS:TOPIC=mygateway4-out/254/255/0/0/17,MSG SENT
                    10:38:59.151 -> 148515 TSF:MSG:READ,254-254-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    10:38:59.197 -> 148578 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/6,MSG SENT
                    10:39:00.923 -> 150319 TSF:MSG:READ,254-254-0,s=255,c=3,t=11,pt=0,l=14,sg=0:MockMySensors
                    10:39:01.017 -> 150398 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/11,MSG SENT
                    10:39:01.064 -> 150462 TSF:MSG:READ,254-254-0,s=255,c=3,t=12,pt=0,l=4,sg=0:v0.5
                    10:39:01.157 -> 150529 GWT:TPS:TOPIC=mygateway4-out/254/255/3/0/12,MSG SENT
                    10:39:01.949 -> 151337 TSF:MSG:READ,254-254-0,s=1,c=0,t=0,pt=0,l=12,sg=0:Outside Door
                    10:39:02.044 -> 151410 GWT:TPS:TOPIC=mygateway4-out/254/1/0/0/0,MSG SENT
                    10:39:02.091 -> 151471 TSF:MSG:READ,254-254-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                    10:39:02.184 -> 151542 TSF:MSG:SEND,0-0-254-254,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                    10:39:02.699 -> 152055 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:83
                    • H hard-shovel
                      OldSurferDudeO
                      OldSurferDudeO
                      OldSurferDude
                      @hard-shovel My MQTT broker does not require them. Should I uncomment and leave them blank?
                        H
                        H
                        hard-shovel
                        @OldSurferDude You should leave them commented if not required.
                        I have just tested with a new install on windows of mosquitto with config file for anonymous access and it is working fine with them commented out.
                        what do your gateway debug logs look like?
                        • H hard-shovel
                          OldSurferDudeO
                          OldSurferDudeO
                          OldSurferDude
                          #25
                          @hard-shovel This is what I'm getting (with no nodes connecting to gateway)
                          MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
                          117 TSF:LRT:OK
                          133 TSM:INIT
                          147 TSF:WUR:MS=0
                          170 TSM:INIT:TSP OK
                          191 TSM:INIT:GW MODE
                          213 TSM:READY:ID=0,PAR=0,DIS=0
                          245 MCO:REG:NOT NEEDED
                          scandone
                          1322 GWT:TIN:CONNECTING...
                          2351 GWT:TIN:CONNECTING...
                          scandone
                          state: 0 -> 2 (b0)
                          4097 GWT:TIN:CONNECTING...
                          state: 2 -> 3 (0)
                          state: 3 -> 5 (10)
                          add 0
                          aid 1
                          cnt
                          connected with Automation, channel 9
                          ip:192.168.1.30,mask:255.255.255.0,gw:192.168.1.193
                          4316 GWT:TIN:IP: 192.168.1.30
                          4355 GWT:TIN:ETH OK
                          4378 MCO:BGN:STP
                          4396 MCO:BGN:INIT OK,TSP=1
                          4424 TSM:READY:NWD REQ
                          4451 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                          pm open,type:2 0
                          And this comes when a node connects:
                          197868 TSF:MSG:READ,2-2-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          197928 TSF:MSG:BC
                          197947 TSF:MSG:FPAR REQ,ID=2
                          197977 TSF:PNG:SEND,TO=0
                          198003 TSF:CKU:OK
                          198022 TSF:MSG:GWL OK
                          198460 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          200006 TSF:MSG:READ,2-2-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          200065 TSF:MSG:PINGED,ID=2,HP=1
                          200106 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                          200244 TSF:MSG:READ,2-2-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          200309 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          200385 TSF:MSG:READ,2-2-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.3.2
                          200456 GWT:TSA:ETH OK
                          200481 TSF:MSG:READ,2-2-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          200545 GWT:TSA:ETH OK
                          202529 TSF:MSG:READ,2-2-0,s=255,c=3,t=11,pt=0,l=15,sg=0:BatMoistHumTemp
                          202611 GWT:TSA:ETH OK
                          202636 TSF:MSG:READ,2-2-0,s=255,c=3,t=12,pt=0,l=9,sg=0:     0.01
                          202710 GWT:TSA:ETH OK
                          202885 TSF:MSG:READ,2-2-0,s=0,c=0,t=35,pt=0,l=0,sg=0:
                          202948 GWT:TSA:ETH OK
                          203141 TSF:MSG:READ,2-2-0,s=1,c=0,t=7,pt=0,l=0,sg=0:
                          203203 GWT:TSA:ETH OK
                          203396 TSF:MSG:READ,2-2-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
                          203458 GWT:TSA:ETH OK
                          203651 TSF:MSG:READ,2-2-0,s=3,c=0,t=30,pt=0,l=0,sg=0:
                          203713 GWT:TSA:ETH OK
                          203925 TSF:MSG:READ,2-2-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          203992 TSF:MSG:SEND,0-0-2-2,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                          204128 TSF:MSG:READ,2-2-0,s=255,c=3,t=0,pt=1,l=1,sg=0:100
                          204199 GWT:TSA:ETH OK
                          204407 TSF:MSG:READ,2-2-0,s=3,c=1,t=38,pt=7,l=5,sg=0:6.52
                          204475 GWT:TSA:ETH OK
                          204542 TSF:MSG:READ,2-2-0,s=0,c=1,t=37,pt=2,l=2,sg=0:1023
                          204610 GWT:TSA:ETH OK
                          • paqorP
                            paqorP
                            paqor
                            wrote on last edited by paqor
                            #26
                            Hello have with the gateway constantly disconnects after a few days and I can only reactivate it by resetting on the gateway.
                            Have now inserted a separate power supply with a large electrolytic capacitor 5000 µF-let's see....
                              117 TSF:LRT:OK
                              133 TSM:INIT
                              147 TSF:WUR:MS=0
                              170 TSM:INIT:TSP OK
                              scandone
                              scandone
                              state: 0 -> 2 (b0)
                              state: 2 -> 3 (0)
                              state: 3 -> 5 (10)
                              add 0
                              aid 1
                              cnt
                              4355 GWT:TIN:ETH OK
                              4378 MCO:BGN:STP
                              pm open,type:2 0
                              197928 TSF:MSG:BC
                              198003 TSF:CKU:OK
                              H
                              H
                              hard-shovel
                              #27
                              @OldSurferDude You are getting regular GWT:TSA:ETH OK message which i do not and you have no
                              MSG SENT lines
                              Which MQTT broker are you using?
                              my test setup which i hope matches yours is:
                              MySensors 2.3.2 & ESP8266 core 2.7.4
                              ESP8266 Node MCU with sketch GatewayESP8266MQTTClient
                              MY_BAUD_RATE 9600
                              MY_MQTT_USER & MQTT_PASSWORD commented out
                              MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 195 address of the MQTT broker
                              MY_CONTROLLER_URL_ADDRESS "MQTT-TEST-W10" commented out Use IP or URL not Both
                              MY_PORT 1883
                              MQTT Broker
                              Mosquitto 2.0.15 running as a service on a windows 10 machine
                              listener 1883 anonymous access
                              URL MQTT-TEST-W10
                              When connected to the MQTT Broker and receiving messages from a node the gateway shows
                              09:48:18.962 -> 718935 TSF:MSG:READ,254-254-0,s=1,c=1,t=16,pt=2,l=2,sg=0:0
                              09:48:19.010 -> 718997 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/16,MSG SENT
                              09:48:19.104 -> 719059 TSF:MSG:READ,254-254-0,s=1,c=1,t=15,pt=1,l=1,sg=0:1
                              09:48:19.149 -> 719121 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/15,MSG SENT
                              09:48:19.198 -> 719182 TSF:MSG:READ,254-254-0,s=255,c=3,t=0,pt=1,l=1,sg=0:83
                              09:48:19.292 -> 719246 GWT:TPS:TOPIC=mygateway5-out/254/255/3/0/0,MSG SENT
                              if a message is sent to the broker the gateway shows
                              10:03:54.285 -> 1654209 GWT:IMQ:TOPIC=mygateway5-in/254/255/1/0/15, MSG RECEIVED
                              10:03:54.331 -> 1654279 TSF:MSG:SEND,0-0-254-254,s=255,c=1,t=15,pt=0,l=1,sg=0,ft=0,st=OK:1
                              10:03:54.423 -> 1654358 TSF:MSG:READ,254-254-0,s=1,c=1,t=16,pt=2,l=2,sg=0:1
                              10:03:54.471 -> 1654421 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/16,MSG SENT
                              10:03:54.565 -> 1654483 TSF:MSG:READ,254-254-0,s=1,c=1,t=15,pt=1,l=1,sg=0:1
                              10:03:54.611 -> 1654546 GWT:TPS:TOPIC=mygateway5-out/254/1/1/0/15,MSG SENT
                              • H hard-shovel
                                MSG SENT lines
                                MY_BAUD_RATE 9600
                                MY_PORT 1883
                                MQTT Broker
                                URL MQTT-TEST-W10
                                OldSurferDudeO
                                OldSurferDudeO
                                OldSurferDude
                                @hard-shovel I created a faux nano sensor and used nRF24L01 channel 121 to communicate to the gateway. Here is my NodeMCU ESP8266 code with all comments taken out:
                                #define VER 0.4
                                #define MY_DEBUG true
                                #define MY_BAUD_RATE 9600
                                #define MY_RADIO_RF24
                                #define MY_RF24_CHANNEL 121
                                #define MY_GATEWAY_ESP8266 "Test"
                                #define MY_WIFI_SSID "SSID"
                                #define MY_WIFI_PASSWORD "pass"
                                #define MY_HOSTNAME "ESP8266_GW"
                                #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mysensors-out"
                                #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mysensors-in"
                                #define MY_PORT 1883
                                #define MY_GATEWAY_MAX_CLIENTS 8
                                #define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 142
                                void setup() {Serial.print("ESP8266MySensorsGateway version: ");Serial.println(VER); }
                                void presentation(){}
                                void loop(){}
                                On boot, the gateway generates the following debug output:
                                60 MCO:BGN:INIT GW,CP=RNNGE---,FQ=80,REL=255,VER=2.3.2
                                118 TSF:LRT:OK
                                133 TSM:INIT
                                147 TSF:WUR:MS=0
                                170 TSM:INIT:TSP OK
                                246 MCO:REG:NOT NEEDED
                                scandone
                                2350 GWT:TIN:CONNECTING...
                                scandone
                                state: 0 -> 2 (b0)
                                state: 2 -> 3 (0)
                                state: 3 -> 5 (10)
                                add 0
                                aid 1
                                cnt
                                4354 GWT:TIN:ETH OK
                                4376 MCO:BGN:STP
                                ESP8266MySensorsGateway version: 0.40
                                4394 MCO:BGN:INIT OK,TSP=1
                                4463 TSM:READY:NWD REQ
                                4490 ?TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
                                6865 TSF:MSG:READ,2-2-0,s=0,c=1,t=37,pt=2,l=2,sg=0:208
                                6933 GWT:TSA:ETH OK
                                The faux node connects to the gateway indicated by this debug code from the gateway (which is repeated for each "reading" (eg. 204):
                                1047590 TSF:MSG:READ,2-2-0,s=0,c=1,t=37,pt=2,l=2,sg=0:204
                                1047656 GWT:TSA:ETH OK
                                Nothing arrives at the MQTT broker. From another machine, I can publish to the broker:
                                mosquitto_pub -h 192.168.1.139 -t test/mztake -m "did it arrive?"
                                and it does arrive at the broker.
                                What am I missing?
                                OSD
                                  #define VER 0.4
                                  void loop(){}
                                  118 TSF:LRT:OK
                                  133 TSM:INIT
                                  147 TSF:WUR:MS=0
                                  170 TSM:INIT:TSP OK
                                  scandone
                                  scandone
                                  state: 0 -> 2 (b0)
                                  state: 2 -> 3 (0)
                                  state: 3 -> 5 (10)
                                  add 0
                                  aid 1
                                  cnt
                                  4354 GWT:TIN:ETH OK
                                  4376 MCO:BGN:STP
                                  6933 GWT:TSA:ETH OK
                                  What am I missing?
                                  OSD
                                  @OldSurferDude you are (at least) missing #define MY_GATEWAY_MQTT_CLIENT.
                                  The sketch you are using is instructing MySensors to create an ethernet gateway.
                                  Example sketch for esp8266 mqtt: https://github.com/mysensors/MySensors/blob/master/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino
                                    OldSurferDudeO
                                    OldSurferDudeO
                                    OldSurferDude
                                    @mfalkvidd said in ESP8266Wifi Gateway won't connect:
                                    That was it! Thank you!
                                    OSD
                                      OldSurferDudeO
                                      OldSurferDudeO
                                      OldSurferDude
                                      @mfalkvidd Because I see that the example has a presentation() routine with the comment "// Present locally attached sensors here" I made the assumption that the gateway could have local sensors. I described a local sensor
                                      // local sensor information
                                      #define MY_NODE_ID 3
                                      #define CHILD_ID_GATEWAY_FAUX_SENSOR 0
                                      MyMessage msgFauxSensor(CHILD_ID_GATEWAY_FAUX_SENSOR, V_LEVEL);
                                      int fauxSensorValue = 0;
                                      and put the data acquisition code in the loop:
                                       send(msgFauxSensor.set(fauxSensorValue++));
                                       Serial.print("Value sent: ");Serial.println(fauxSensorValue);
                                       delay(30000);
                                      Lo and Behold! This data was being found on the MQTT broker! Albeit the NODE_ID was not 3 as defined, but 0. This makes sense because the NODE_ID of the gateway is zero.
                                      Previously, I had my gateway running on an RPi. My question is, can I put a presentation() routine and data acquisition of the gateway running on my RPi?
                                         delay(30000);
                                        delay(30000);
                                        A delay in the gateway will make the gateway freeze. It will not handle incoming messages (not from the mqtt broker, not for any nodes). Use wait() instead.
                                        Yes, it should work. The file to edit is https://github.com/mysensors/MySensors/blob/development/examples_linux/mysgw.cpp
                                        Have you forgotten about https://forum.mysensors.org/post/111806 ?
                                          delay(30000);
                                          OldSurferDudeO
                                          OldSurferDudeO
                                          OldSurferDude
                                          @mfalkvidd Yes, totally forgot about that link you put there. Thanks for reminding me. :)
