1.1k Posts 105 Posters 792.8k Views 98 Watching
  • K
    K
    KevinT
    The motion sensor is used to turn on the lights in the garage via a Sonoff mini.
    Also, I've had the garage door randomly open by itself (power glitches?) a few times over the years. So I'm adding an automation to close the door if no motion is present and it is after midnight.
    • F
      F
      fsgraz
      A collection of the sensors and actuators I buit for my camper in the past year
      the power supply system under the dinette seat
      the battery management system (purchased) data are read via wifi by an ESP32, which reports the info to the GW via nRF24L01+.
      a closed look at 2 sensors.
      the one on the left reads voltage and current from the solar PV panel and to the battery management system
      the one on the right reads voltage and current from/to the start and service batteriers
      both sensors report instant power and energy.
      Fresh water sensor reads the water level, flow and temperature.
      has 4 optcoupled outputs to send the information to the 4 LEDs of the original control panel of the camper
      gray water tank sensor reports water level with an ultrasound sensor. has an optocoupled output to the "full" LED of the original control panel
      bettry supplied temperature and humidity sensor.
      I use it in the fridge but also at home, where I have also one with BME280.
      A fan controller to help the fridge to work better, controlling the condenser temperature using an optical thermometer sensor.
      I have 3 other units, one in the power supply system, one in the closet and one on the roof.
      They are all with a PID controller.
      IMG_20210503_095913.jpg IMG_20210313_153635 (2).jpg IMG_20210313_153612 (2).jpg
      • F
        F
        fsgraz
        the display node for my camper, based on a Arduino Mega clone
        F 1 Reply Last reply
        • siddarth sidS
          siddarth sidS
          siddarth sid
          This thread is really good, kind of addicting to scroll all time.
          Only problem though is the way it is structured. Its really hard to find the same post twice.
          Maybe the admins should consider having a separate section for this !!>?
          • N ncollins
            The latest addition to my coin cell nodes, a PIR motion sensor based on the Ebyte NRF52805 module.
            The PIR sensor is a Senba S16-L221D-2. I'm measuring around 24uA, which is higher than advertised, but with the 6-7uA from the NRF52805, should still get me 3-4 years on a single 2477.
            Amit BTA
            Amit BTA
            Amit BT
            @ncollins said in What did you build today (Pictures) ?:
            Hi, I see you integrated the E104-BT5005A BLE chip in this project.
            I’m trying to use it in a simple robot project and having difficulties to make the RX/TX connection with “RF Connect” IOS app.
            I already wired the chip to the Seeeduino board and I can find and connect the bluetooth on the RF scan list. But I just don’t know the Arduino code to make it send and receive simple massages on the Arduino serial monitor.
            Your help is very much appreciated.
            Amit
            • F fsgraz
              F
              F
              fsgraz
              Some updates in almost one year.
              I moved all the gateways and controller part in a most suitable locationIMG_20220305_110252.jpg
              I've created a dual current sensor for the fuse box and the inverter. Each Current sensors can withstand 90A max, so I used both channels in parallel. The sensors are defined for both Channel 1, 2 and Sum(Ch1+Ch2) to handle this case easily
              Recently I made an updated version of my Photovoltaic monitor since the 20A that the old one could withstand are not enough now, so the new version is capable of 50A max. Still waiting the Hall sensors though...
              Finally, I cleaned up a bit the deployment under the bench
              IMG_20220527_161849.jpg but I am not done yet
                #1061
                I made this CR2032 coincell powered locator beacon using an nRF52805:
                It was my first experience using a TAG-CONNECT to make the programming connections. It's for that reason that I haven't yet attached the battery holder. The TAG-CONNEC provides power during programming (and debugging as well if so desired).
                I have the antenna hanging out over the edge, as per Nordic Semiconductor recommendations, so that it doesn't hover over the ground plane. However, that makes the overall footprint a bit larger, somewhat defeating the point of powering it with a CR2032. I may try making a smaller version where the antenna doesn't overhang just to see how much difference it does or doesn't make. For a device like this, I mostly care about reception rather than transmitting, so maybe for receiving such a change won't make much of a difference.
                Who makes the world's smallest nRF5x module?
                OldSurferDudeO 1 Reply Last reply
                • F fsgraz
                  F
                  F
                  fsgraz
                  Finally I had the time to refine it:
                    OldSurferDudeO
                    OldSurferDudeO
                    OldSurferDude
                    @NeverDie It is my understanding, though I can't wrap my head around it, that it is the length of the conductor that makes the antenna tuned to a certain frequency. If this is the case, you could run your antenna around the edge of your circular pcb which would make the effective radius only slightly bigger.
                      #1064
                      @OldSurferDude said in What did you build today (Pictures) ?:
                      You mean like this?
                      I get the impression that somehow the antenna positioning relative to the ground plane might figure into it as well:
                      Perhaps that stands in the way of wrapping the antenna completely around the circumference? I can't claim to have any deep understanding of how antennas are supposed to be designed. In the past I noticed that TI sold a sample set of canonical antenna designs, so then you could try them all out and see what suits you: https://www.ti.com/lit/an/swra161b/swra161b.pdf?ts=1661617962454&ref_url=https%253A%252F%252Fwww.google.com%252F
                        You mean like this?
                        OldSurferDudeO
                        OldSurferDudeO
                        OldSurferDude
                        @NeverDie That isn't what I was thinking but after a bit of research, that's better than what I was thinking. ;)
                        PCB antennae work better at > 868MHz(pg 7). A 2.4GHz signal should have an antenna length of 3.1cm The nRFl01 spec shows a PCB with an antenna that is about that length but I measure the board I have and the antenna is about 4.6cm(?) Here(pg 10) you'll find a design, though I'm not sure for what frequency as the length adds up to 4.03cm. As you can see, you must not have the ground plane near the antenna.
                        Here, RonM9 modifies an nRF24l01 making the antenna a dipole. I tried this and did show some improvement, but not the success he had. His wires were ~5.0cm, but bends them in the opposite directions at the edge of the pcb. Does that make the antenna length about 4cm?
                        The antenna for a longer wave length (lower frequency) will be proportionally longer.
                        I'd like to do the same testing as RonM9, but I've got some other pressing projects. ;)
                        I hope this helps your research.
                        OSD
                        • nagelcN nagelc
                          @berkseo
                          Hey. Our own berkseo is on Hackaday. Congrats!
                          https://hackaday.com/2021/03/11/nrf52-weather-station-gives-forecast-with-style/
                          berkseoB
                          berkseoB
                          berkseo
                          #1066
                          Now this project looks like this:
                          https://www.instagram.com/p/CkikRzAtECe/?utm_source=ig_web_button_share_sheet
                          • monteM
                            monteM
                            monte
                            wrote on last edited by monte
                            #1067
                            From left to right:
                            • Home Assistant server with built-in NRF24 radio and OLED display based on Orange Pi Zero
                            • MQTT Mysensors gateway with ESP8285
                            • 4 channel triac dimmer with oled display and UI for operating in standalone mode.
                            TheoLT 1 Reply Last reply
                            • monteM monte
                              From left to right:
                              TheoLT
                              TheoLT
                              TheoL
                              @monte do you have a schematis for that dimmer? If so I'm interested in it
                              monteM 1 Reply Last reply
                              • TheoLT TheoL
                                monteM
                                monteM
                                monte
                                #1069
                                @TheoL there is nothing special in it :) In fact it's an old design that was waiting for the code to be written for a long time. And there are some issues with it. It seems that external interrupts for zero-crossing make NRF24 ACK fail most of the time. And if I were to make another one of this, I would add some low cost mcu to do the dimming part alone. I have dimmers with EPS8266 that uses Attiny13A for triac control, but I wouldn't try to make it control 4 channels.
                                Also the time of Atmega328 has passed, I guess. They are marked "Not recommended for new designs" by the manufacturer and I have struggled to fit everything I wanted (UI mostly) in it's memory. I ended up disabling serial output in mysensors and everywhere else, decreasing message buffer size and scraping bytes everywhere else I could to make it work stable without crashing.
                                I'm not sure if I will continue to make new designs for mysensors, but I think I will use NRF51822, as they are so cheap now at aliexpress, and you can add PA LNA to help with signal strength (theoretically, I haven't tried it). Another way is to use NRF52840 for all new designs, even they are 4-5 times more expensive than 51822 but later you can write a firmware for it to use Zigbee of Thread/Matter and use the same design with new functionality.
                                • TheoLT
                                  TheoLT
                                  TheoL
                                  As much as I love the 328 I think I should make the change to a different board :) for me they fit my needs as I try to keep the logic in my nodes as small as possible. I have one rule though: Manual first, for actuators my nodes need to support manual control.
                                  Thanx for the schematics, I'll have a look at. Can you control led light bulbs with this schematics?
                                  • TheoLT TheoL
                                    monteM
                                    monteM
                                    monte
                                    @TheoL this is a basic triac control scheme, so it is leading edge type dimmer. I have led bulbs, that work with it, but they are clearly marked as dimmable. The downside of these bulbs is that they are very sensible to the slightest voltage fluctuations. I have not the most stable voltage on one of my phases, so it is very visible, unlike with the incandescent bulbs, that are connected to the same power source.
                                    • monteM monte
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @monte I had a gut feeling about it, since dimmable led bulbs like trailing edge. I'll keep looking for a good 220v led bulb dimmer schematic.
                                      • TheoLT TheoL
                                        monteM
                                        monteM
                                        monte
                                        #1073
                                        @TheoL that's not the dimmer's fault a far as I am concerned. It behaves the same way at full brightness. It's just a cheap chinese driver in it.
