  3. 💬 Adjustable Boost Converter with Pass-Through
boostboost convertermcp1640step-upvoltage
34 Posts 8 Posters 12.4k Views 7 Watching
  • KoreshK Koresh
    Just little tip from me :) Use thermal relief instead of direct polygon connection.
    It is much more useful in such cases.
    @Koresh said in 💬 Adjustable Boost Converter with Pass-Through:
    Where do I put that exactly?
    KoreshK 1 Reply Last reply
      KoreshK
      KoreshK
      Koresh
        Sorry if I'm being dense, but how are the thermal reliefs better? What's their advantage?
          KoreshK
          KoreshK
          Koresh
          wrote on last edited by Koresh
          #28
          @NeverDie It is much easier to solder the wire to pads with relief connection than the wire to directly connected pads. Your soldering point even can be unreliable if your pad is directly connected to very huge polygon and your soldering iron don't have enough power.
          • B
            B
            bilbolodz
            Please upload it on PCBS.io and provide a direct link
            B 1 Reply Last reply
            • B bilbolodz
              B
              B
              bilbolodz
              I've uploaded it on PCBs.io:
              https://PCBs.io/share/zagYj
              ordered but no tested yet. Cost of for PCB: 1,35 USD
              • alexsh1A
                alexsh1A
                alexsh1
                #31
                @NeverDie I have got MCP1640CT-I/CHY in SOT-23 (BX5V marking on the chip)
                Can these be used for this project please?
                I also have some 8 pins ones, but there are not suitable
                • alexsh1A alexsh1
                  @alexsh1
                  If the pinout is the same, then the PCB should work.
                    https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
                    Shravan V.KS
                    Shravan V.KS
                    Shravan V.K
                    @openhardware-io
                    I am having issues can someone help
                    I am getting output voltage same as input , i removed enable pin supply still i was getting output voltage same as input what might be the issue?
                    • skywatchS
                      skywatchS
                      skywatch
                      Did it work before or is it a new build?
