  3. πŸ’¬ Adjustable Boost Converter with Pass-Through
boostboost convertermcp1640step-upvoltage
34 Posts 8 Posters 12.4k Views 7 Watching
    I've tested the board, and it works.
    Please purchase your PCB's for this project from the following link: https://pcbs.io/share/zyLW7
      Here is a photo of the assembled PCB, taken next to a quarter for scale:
        This project is now finished. :smile:
          Setting R1=680K gives a voltage output of 2.674v, which is great for charging 2.7v supercaps.
            #21
            I just now revised the board to expose the Enable pin, so now you can do a pass-through if you wish. I also made it more compact and gave it a ground-plane on the back. Enjoy!
              #22
              i received the upgraded PCB and assembled it. It tests out correctly. The project photo now shows the newest board. Project completed. :)
              For 3.3v output, use R1=976 ohms and R2=562 ohms, as per the datasheet.
                BTW, the same PCB and circuit can also be used with the MCP1640T instead of the MCP1640C if so desired. In that case, the ENABLE pin acts like an ON/OFF switch, instead of an ON/Pass-through switch.
                • KoreshK
                  KoreshK
                  Koresh
                  Just little tip from me :) Use thermal relief instead of direct polygon connection.
                  It is much more useful in such cases.
                  • KoreshK Koresh
                    @Koresh said in πŸ’¬ Adjustable Boost Converter with Pass-Through:
                    Where do I put that exactly?
                    KoreshK 1 Reply Last reply
                      KoreshK
                      KoreshK
                      Koresh
                        Sorry if I'm being dense, but how are the thermal reliefs better? What's their advantage?
                          KoreshK
                          KoreshK
                          Koresh
                          wrote on last edited by Koresh
                          #28
                          @NeverDie It is much easier to solder the wire to pads with relief connection than the wire to directly connected pads. Your soldering point even can be unreliable if your pad is directly connected to very huge polygon and your soldering iron don't have enough power.
                          • B
                            B
                            bilbolodz
                            Please upload it on PCBS.io and provide a direct link
                            B 1 Reply Last reply
                            • B bilbolodz
                              B
                              B
                              bilbolodz
                              I've uploaded it on PCBs.io:
                              https://PCBs.io/share/zagYj
                              ordered but no tested yet. Cost of for PCB: 1,35 USD
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                #31
                                @NeverDie I have got MCP1640CT-I/CHY in SOT-23 (BX5V marking on the chip)
                                Can these be used for this project please?
                                I also have some 8 pins ones, but there are not suitable
                                • alexsh1A alexsh1
                                  @alexsh1
                                  If the pinout is the same, then the PCB should work.
                                    https://www.openhardware.io/view/279/Adjustable-Boost-Converter-with-Pass-Through
                                    Shravan V.KS
                                    Shravan V.KS
                                    Shravan V.K
                                    @openhardware-io
                                    I am having issues can someone help
                                    I am getting output voltage same as input , i removed enable pin supply still i was getting output voltage same as input what might be the issue?
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      Did it work before or is it a new build?
                                      With your input, this post could be even better πŸ’—
