  3. Sump Pit Monitor
Sump Pit Monitor
7 Posts 3 Posters 4.1k Views 3 Watching
  • K Offline
    K Offline
    KevinT
    wrote on last edited by KevinT
    Hi All,
    I recently replaced my sump pit pump and installed a battery backup pump at the same time. Naturally, when I saw all the alarms available on the backup system, I wanted to integrate them into my home automation system. I also wanted to add a water level sensor to get a better idea of how often the pump ran and also create a water level alarm.
    Water level sensor installed.
    I looked at the backup controller and realised it would be difficult to pull signals from it since it isn't easy to disassemble. So, I opted to used photo transistors to read the state of the alarm LEDs.
    The photo transistors are held in place with velcro strips for easy removal.
    My monitoring node consists of an ESP32C3 Super Mini ucontroller configured with 5 digital input channels and 1 analog channel to read the alarm LEDs and water level. I'm using MQTT, for this project, to send the data to Home Assistant.
    Integrated into Home Assistant
    Overall, after a few adjustments, the systems works really well and provides some peace of mind.
    • K KevinT
      Hi All,
      T Offline
      T Offline
      TheoL
      @KevinT That is a great project. How do you measure the water level?
      K 1 Reply Last reply
      • OldSurferDudeO Offline
        OldSurferDude
        I have exactly the same level sensor but not the controller. The level sensor output is essentially a variable resistor. When the float is at the top, the resistance is minimum, at the bottom, maximum. I have the 0-190 ohm sensor.
        My "reader" is an ESP-12F (ESP8266). Put a 470 ohm resistor from 3.3V to the Analog input and one of the leads of the sensor and the other lead to ground. The program is Tasmota configured for analog input
        I power it with this power supply.
        Typically Tasmota devices use the MQTT method of delivering data. and is auto-configured in the Home Assistant controller.
        This could could work great with an Arduino in the MySensors eco-sphere. The could would basically be: read analog, send.
        • T TheoL
          K Offline
          K Offline
          KevinT
          @TheoL Thanks. As @OldSurferDude says, it's an analog sensor I got off AliExpress Fuel level sensor. I chose a 0-190 ohm sensor, 450 mm long. I wired a 100 ohm resistor in series with the sensor and read the voltage with an analog channel. I do a little extra math to linearise the measurement.
          I normally use mysensor nodes, but since this one is always on, I tried using MQTT for a change.
          • K KevinT
            T Offline
            T Offline
            TheoL
            @KevinT Any idea how much current that sensor is drawing? I came across one circuit that consumes 1 micro amps regardless if the tank is empty or full. Still struggling to get it to work. But that's my low knowledge of electronics ;)
              OldSurferDude
              @TheoL that would probably be a hall effect sensor that draws in the microamp range. Per @KevinT 's circuit, it would draw 33mA full and 11.3mA empty, somewhere in between depending on the depth. MySensors and a controller like Home Assistant (with the MySensors Integration) can monitor the battery level as well as the level of the sensor.
                T Offline
                T Offline
                TheoL
                @OldSurferDude So if I get my circuit to work, that would by 22 times less (on average). Well I'm doing too many things at the same time. :)
