  3. Home Assistant
  4. Suddenly after an HA update i get no sensor data anymore
9 Posts 4 Posters 662 Views 3 Watching
    se-O-matic
    After installing the Core Update 2026.7.4 HA did not received any data from all my "MySensors" sensors.
    I use the serial gateway on a raspberry pi 3. The connection to this seems to work:
    "2026-08-04 17:45:39.160 INFO (MainThread) [mysensors.transport] Connected to Serial<id=0x7f54ec9a50, open=True>(port='/dev/ttyUSB0', baudrate=38400, bytesize=8, parity='N', stopbits=1, timeout=0, xonxoff=False, rtscts=False, dsrdtr=False)"
    I get no more messages from mysensors after the startup.
    I tried a reboot as well as a shut down and a complete power cycle.
    I tried to repower the sensors as well. But this doesnt work either.
    Sometimes, about 2 to 3 times per day, i get a message like this:
    2026-08-05 22:29:42.054 DEBUG (MainThread) [mysensors.transport] Receiving ��D������D��w���^y
    2026-08-05 22:29:42.056 WARNING (MainThread) [mysensors.message] Error decoding message from gateway, bad data received: ��D������D��w���^y
    2026-08-05 22:29:42.057 WARNING (MainThread) [mysensors] Not a valid message: not enough values to unpack (expected 5, got 0)
    I tested the serial gateway on my pc. The sensors appear in the serial console:
    8;0;1;0;0;21.59<\n>
    8;1;1;0;1;58.98<\n>
    8;255;3;0;0;85<\n>
    5;0;1;0;0;23.40<\n>
    2;0;1;0;0;19.05<\n>
    2;1;1;0;1;68.34<\n>
    2;255;3;0;0;63<\n>
    I am running out of ideas. On github i also created a issue.
    Has someone an idea how can i debug or fix this?
    As last opportunity i can build a MQTT-Gateway.
    regards,
    Sebastian
    • nagelcN
      nagelcN
      nagelc
      wrote on last edited by nagelc
      I'm not very smart at Home Assistant, but 2 things you could look at:
      Your baud rate is being reported as 38400. My gateways run at 115200. I'm not sure how HA determines what the baud rate should be. Edit: for 8 MHz Arduino, 38400 baud rate is correct, so that probably isn't it.
      In Home Assistant>Settings>System>Hardware, pick the System Hardware tab. That will show all the ports and what is attached to them. Maybe there will be a clue there.
      S 1 Reply Last reply
      • OldSurferDudeO
        OldSurferDudeO
        OldSurferDude
        Let us know how you are doing as you progress.
        Are you running HA on the RPi 3? There have been many reports of HA bloating to beyond the capabilities of the RPi. If this is the case, you'll have to install HA on another computer.
        I run HA in a virtual box which runs under the Ubuntu OS on a refurbished PC. (You can use an old laptop, too.) I believe that you can run HA on a PC "bare metal" too. If you have to go that route, we can help you.
        • nagelcN nagelc
          se-O-matic
          Thanks for your hints. I checked this already. My sensors run at 38400 baud and i see in the debug log, that HA opens the port with the same baud rate.
          yes, i run HA as HASSOS version on the RPI3. This worked very well until the one update do something with the mysensors integration.
          This setup run till this date very smooth with a couple of ZigBee devices over the ZHA integration.
          I already thought about running HA in a docker on my homeserver. This is a tiny HP PC (Old Elitedesk 800 G1 Mini) on which run debian and CasaOs.
          I read about problems to get ZigBee working in a docker environment. I use the SonOff zigbee usb stick. And the mysensors serial gateway is connected over USB, too.
          At least I have two possibilities, which both are very time consuming.
          1. Build a ethernet gateway with or without MQTT. I already have a ethernet board ordered to test this. But i have to build this up an a breadboard for testing and i have to update every mysensors sensor to a fixed ID instead of the automatic assigning.
          2. Migrate my homeserver from CasaOs to Zimas (CasaOs is deprecated ...) (btw, i have to do this anyway) and the test HA in a docker with routing usb devices to the container.
          • OldSurferDudeO
            OldSurferDudeO
            OldSurferDude
            I use old/refurbished pc's desktop or laptop. 4GB RAM is do-able, but 8GB is better. 500GB disk is fine, even 128GB. 4 CPU cores is good, too.
            I install ubuntu linux on the machine. Then I install Virtual Box
            HA has the installation instructions on how to install HAOS into the virtual box. Use half your memory and CPUs
            You have to tunnel your USB port into the Virtual Machine (VM) ... The USB has to be plugged in when you do the VM configuration.
            I have several dongles on mine: USB/serial for MySensors Serial Gateway, Sonoff Z-Wave, Sonoff Zigbee.
            I recently discovered why my one Zigbee device wasn't working ... the dongle fell off the USB extension cable (necessary on Z-Wave, too, to minimize RF interference)
            • OldSurferDudeO
              OldSurferDudeO
              OldSurferDude
              The HA forum has a lot of helpful people, though there is a small cadre of people that are a little arrogant. Thicken your skin and ignore them.
              • H
                H
                HelenMarshMyS
                wrote last edited by
                After an HA update I would first separate a gateway/serial problem from the HA integration. Check Settings > System > Hardware to confirm that the USB device still appears and note its serial device path; make sure the container or VM still passes that device through. Then verify that the gateway port and baud rate match the sketch (many gateways use 115200, while some 8 MHz boards use 38400), and check the HA log for serial-open or permission errors. Stop HA and watch the port with a serial monitor while triggering a sensor; if no lines arrive, test the gateway, USB cable, and power separately. If frames do arrive, compare the integration's node/presentation logs and reload the integration after confirming the update did not rename the port. Also check that no second process has the serial port open.
                  se-O-matic
                  Okay, the jurney go further.
                  I installed a container on ZimaOS (formerly CasaOS) with Homeassistant. After i plugged in my serial gateway to the computer and route the virtual serial port to the container, i could setup myssensors. And all sensors worked so far. But in the meantime ocasionally one sensor value stopped reporting, another value from the same sensor still works. Same behavor as in HASSOS on the RPI3.
                  I think i'm done with the serial gateway. Next step is to build a MQTT gateway. If this fails, i had to replace all mysensors devices :-(
                  • OldSurferDudeO
                    OldSurferDudeO
                    OldSurferDude
                    I have seen this, too, on my MQTT gateway. Try putting a wait() (not delay) after sending each datum. Start with 1000mS, even 5000mS, and work your way down to find what is optimal for your set up.
