  3. We are mostly using fake nRF24L01+'s, but worse fakes are emerging.
47 Posts 17 Posters 68.0k Views 8 Watching
  • bjornhallbergB
    bjornhallbergB
    bjornhallberg
    Unsettling stuff. Thanks for the warning. Makes me wonder exactly how advanced the Chinese clone factories are, I mean, if they are making this relatively advanced IC, is any IC safe from China? Granted that only high volume stuff is worth cloning.
    Another reason to move away from the NRF24 if opportunity arises. Genuine (?) RFM69 are looking better and better.
    • M mainali
      I am a victim of those fake clones. As I was just starting with nrf, it took me 3 days of debugging to figure out that issue is with the RF module itself, it wont send ACK, altogether.I bought 5 of then for $4.1427268738276-453722785.jpg
      The other one I am using is little better but its not a nrf+, I had to disable the isPvariant(), check to solve the check wires problem.1427268971445-657449782.jpg
      pit007P
      pit007P
      pit007
      @mainali The chips on your first picture I got also one time. IMO it is the nRF24L01 without the plus '+' - I detect it by comparing the register resonses with there datsheets.
      • Z
        Z
        Zeph
        Yes, some might be clones of the nRF24L01 (no +). Others have bugs.
        And at least some modules with epoxy blobs rather than chips may also be missing some of the normal external passive components leading to reduced performance - in addition to questionable chips per se. This is almost worse for our sanity - being flakey rather than outright failing some digital aspect (like ESB) 100% of the time.
        One commenter in one of the above referenced threads mentioned having one module which seemed unusually tolerant of the power supply quality - which he believed was a genuine Nordic chip. Maybe the PS issues we've all adapted to are largely due to our using clones (even the relatively good clones).
        • M mainali
          Z
          Z
          Zeph
          wrote on last edited by Zeph
          Well said. We've grown used to the quality clones, now there are "fake" clones on the market.
          Sort of like cheap cheeses. In the US there used to be "natural" cheese, and "pasturized process" cheese (like "American cheese", a sad thing to have named after your nation). Then there was a brand of semi-soft block cheese called "Velveeta" which was labeled as "pasturized process cheese food". And some off-brand variants of that were labeled "imitation pasturized process cheese food". (These were all legal distinctions based on US Gov't standards, and the terminology has since changed).
          So our nRF modules started out at "pasturized process cheese", and now there's "imitation pasturized process cheese food" entering the market - without such honest labeling.
          • MagiskeM
            MagiskeM
            Magiske
            So can we identify the "fakes" vs "real fakes" by dumping chip info or is that 100% faked to?
              Emailed my contact at Nordic about this a month ago.
              There are unfortunately little they can do about the problem. There is almost a zero cost to open an Aliexpress shop and there the chinese goverment/Alibaba does not care enough.
              http://resources.alibaba.com/topic/801220532/What_to_do_if_you_ve_received_fake_products.htm
              • P
                P
                phil83
                Probably we could open a permanent thread where we can post our experiences with different aliexpress shops regarding nrf24l01+?
                Is there a chance to write a short arduino program to check the identity of the nrf chip used? Then we could check the ones we receive and put this experience also in the above mentioned thread?
                ChaoticC 1 Reply Last reply
                  A fake chip test program would be great. If someone would like to take a stab at it many would be happy here.
                  Guess the members could help sending sample fake chips to someone interested in the "fakalyzer"-project.
                  • MagiskeM
                    MagiskeM
                    Magiske
                    Ran the nRF24 GettingStarted and got this from two different nRF24's
                    Standard nRF24L01+
                    STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
                    RX_ADDR_P0-1 = 0xa8a8e1fc62 0xf0f0f0f0d2
                    RX_ADDR_P2-5 = 0xff 0xc4 0xc5 0xc6
                    TX_ADDR = 0xa8a8e1fc00
                    RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
                    EN_AA = 0x3b
                    EN_RXADDR = 0x07
                    RF_CH = 0x4c
                    RF_SETUP = 0x07
                    CONFIG = 0x0f
                    DYNPD/FEATURE = 0x00 0x06
                    Data Rate = 1MBPS
                    Model = nRF24L01+
                    CRC Length = 16 bits
                    PA Power = PA_HIGH
                    nRF24L01+ with Antenna
                    RX_ADDR_P0-1 = 0xe7e7e7e7e7 0xf0f0f0f0d2
                    RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
                    TX_ADDR = 0xe7e7e7e7e7
                    RX_PW_P0-6 = 0x00 0x20 0x00 0x00 0x00 0x00
                    EN_AA = 0x3f
                    EN_RXADDR = 0x03
                    RF_CH = 0x4c
                    RF_SETUP = 0x07
                    CONFIG = 0x0f
                    DYNPD/FEATURE = 0x00 0x00
                    Data Rate = 1MBPS
                    Model = nRF24L01+
                    PA Power = PA_HIGH
                    The one with antenna's adresse looks kind of "strange", but don't know if we can read anything out of this ????
                    • P phil83
                      ChaoticC
                      ChaoticC
                      Chaotic
                      I'd be interested to see a list of "good" sellers from aliexpress and not just for the radios. It seems like the store links just point to the cheapest one with free shipping some times. I haven't bought enough stuff to get burnt (7 orders of which 2 have come in and the rest should be in a week or 2) but it is one of the things that keeps me wary.
                      • P
                        P
                        phil83
                        @chaotic I would also be interested and could contribute to a complete list. But for reading and finding it would be much easier to open several threads dealing with different parts or groups of parts.
                        • pit007P
                          pit007P
                          pit007
                          wrote on last edited by pit007
                          As I get my fakes I open a dispute and add this info - it war clear enough to get my money back ;-):
                          So, the chips differ in the register number 09 (CD/RPD).
                          • P
                            P
                            phil83
                            wrote on last edited by phil83
                            I just used the GettingStarted and got the following reply from a nrf24l01+ with antenna:
                            RF24/examples/GettingStarted/
                            ROLE: Pong back
                            *** PRESS 'T' to begin transmitting to the other node
                            RX_ADDR_P0-1 x00 = 0xe7e7e7e7e7 0xf0f0f0f0d2
                            RX_ADDR_P2-5 x00 = 0xc3 0xc4 0xc5 0xc6
                            RX_PW_P0-6 x00 = 0x00 0x20 0x00 0x00 0x00 0x00
                            EN_AA = 0x3f
                            EN_RXADDR x00 = 0x03
                            RF_CH = 0x4c
                            RF_SETUP x00 = 0x07
                            CONFIG = 0x0f
                            DYNPD/FEATURE x00 = 0x00 0x00
                            Data Rate = 1MBPS
                            Model = nRF24L01+
                            PA Power = PA_HIGH
                            So it's the same like @Magiske.
                            • m26872M
                              m26872M
                              m26872
                              Am I the only one missing references to earlier discussions in this subject? Like this one..
                              • Pradeepa SenanayakeP
                                Pradeepa Senanayake
                                This is the first time I'm putting anything here. I also have been developing a C based library for one of the NRF24L01 (no plus) devices.. I used a Stellaris Launchpad to interface with the chip. Eventhough most of the functionality work correctly I saw the CD (Carrier Detect) is not functioning properly. Once it is high it is always high. To make it low I had to flush the RX buffer. It is really strange. I bought my sensors from e-Bay. So they must be clones :D. Can someone try this CD thing and see whether it is working properly?
                                  Has anyone here found a good vendor for modules that use genuine Nordic NRF24L01+ chips?
                                    You could buy your modules from Itead. They have promised us to only source genuine Nordic chips. They are a little higher in price/shipping but you could also take the opportunity to buy a MySensors Micro board to support the project :)
                                    The ebay/aliexpress shops is a bit of a chance-taking as they might switch sourcing partner at any time.
                                      Fair enough. I just now ordered some allegedly Itead NRF24L01+ modules from an Itead distributor, but I suppose there's a risk the distributor might get greedy and ship me something else. On a different thread, someone mentioned that the Itead modules each come in their own box. Would someone please post a photo of the individualized packaging for the Itead modles? If it's distinctive, it might serve as a kind of "certificate of authenticity." I realize that could be faked also, but it would make it a little harder for someone to fake, and so it's better than nothing.
                                      SparkmanS 1 Reply Last reply
                                        Would the following might work as a way to separate good modules from bad modules, therefore also separate out the fakes?
                                        1. Set up a looping ping-pong link between two "known good" modules and measure the % packet losses.
                                        2. Unplug a reference module and then plug a test modules into the same setup. If the packet loss percentage is significantly worse, then the test module is either bad or a fake.
                                          SparkmanS
                                          SparkmanS
                                          Sparkman
                                          Here's an image:
                                          http://imall.itead.cc/media/catalog/product/cache/1/image/1800x/040ec09b1e35df139433887a97daa66f/i/m/im120606002_2.jpg
                                          Al
