  3. Security
Security
89 Posts 20 Posters 68.9k Views 7 Watching
    To get started, someone could investigate some of the points in the list posted above :)
    • D
      Dennis van Velzen
      I think AES is the way to go...
      https://github.com/qistoph/ArduinoAES256
      Otherwise here's a list with cycle information:
      http://www.das-labor.org/wiki/AVR-Crypto-Lib/en
      • axillentA
        axillentA
        axillent
        currently project focused on the functionality, not security
        we have to choose one or other as a priority
        sure project is not designed for critical application like arduino is not designed for critical applications too
        software encryption on arduino with combination with NRF24L01+ is possible but cost of this (in time spend and resources required) at current stage of the projects seems not a fair solution
        my view to this - somewhere in the future as a next stage of the project development
        probably the encryption should be optional keeping simple and cheap devices running
        it seams it will be better to use a hardware encryption, for example XMEGA family from Atmel provide such a functionality, but it is not arduino compatible today
        sense and drive
        • D
          Dennis van Velzen
          Okay, I agree... but this discourages me somehow to use this wireless product as a HA solution. Like for example KAKU (klik aan uit) a one way wireless product operating at 433MHz, mainly for dimming and switching appliances and widely used in The Netherlands implemented an easy hashing solution which makes it a little less "funorable" for somebody to control your appliances...
          Just thinking in a simple fast solution... for this...
          axillentA hekH 2 Replies Last reply
          • D Dennis van Velzen
            axillentA
            axillentA
            axillent
            @Dennis-van-Velzen some one need to be very hungry of you to hack you applications))
            because he will need to 1. knew about mysensors 2. be arduino fan 3. knew radio channel used by you 4. knew your device configuration
            currently we absolutely safe from random things because 1. nrf24 has its own hardware CRC check 2. we duplicate CRC check on top of it
            sense and drive
              @Dennis-van-Velzen
              We're open to contribution in this area. But I would prefer that someone with good insight in security had time to make a somewhat thorough investigation and proposed a solution that brings in real security.
              Already today you can easy select your own radio channel and base radio-id to "hide" your communication from your neighbor.
              #define BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
              • D
                Dennis van Velzen
                Ok ok... I am involved with some IT security on daily basis. Like programming low level, did some logic analyzing, assembly of electronics and certainly will order a couple of these RF modules to integrate them in my upcoming HA project.
                So If I have the parts here I will take a look at security and I fitting some simple additional security layer. Or maybe just introduce some intrusion logic. To be continued I will watch this topic regularly...
                  axillentA
                  axillentA
                  axillent
                  @Dennis-van-Velzen intrusion is simple
                  but you need to know a few parameters which are hard to investigate
                  in general (if intruder do not knew that you are using MySensors) a complex radio sniffer hardware/software is needed
                  in case he/she knews about MySensor he/she still will need a complex radio sniffering if you will change BASE_RADIO_ID and radio channel
                  any you own customization (like hidden logic for message acceptance) to the MySensors source will make intrusion too expensive for regular people
                  a true security I believe requires DES/AES key exchange. Arduino hardware do not support this, software version require too many reqources
                  sense and drive
                    @Dennis-van-Velzen
                    Looking forward to your findings! :+1:
                    • epierreE
                      epierreE
                      epierre
                      There are some posts here to search...
                      link text
                      Here is the blys for arduino with Rolling code: link text
                      Here is some info on Oregon Rolling code : link text
                      Here is an arduino clone to receive LA Crosse link text
                      Here is the OOK pde on rotating codes for 433Mhz protocols for Oregon: link text it is either 24 bits or 32 bits in the header.
                      Here i the OOK pde for RFM12B link text
                      z-wave - Vera -> Domoticz
                        MadMac
                        Another option is to use different type of radio, like the RFM69W which has onboard AES encryption.
                        Some of the security aspects raised here are already covered here: http://lowpowerlab.com/blog/2013/10/02/raspberrypi-home-automation-gateway . There are 5 articles in total.
                        The author also created a arduino library for the RFM69W. (http://lowpowerlab.com/blog/2013/06/20/rfm69-library)
                        How difficult would it be to support this radio ?
                          Looks like they're using some sw-encryption in the library for the 12B-version. This could perhaps be an option in the MySensors library.
                          https://github.com/LowPowerLab/RFM12B/blob/master/RFM12B.cpp#L389
                          epierreE 1 Reply Last reply
                            epierreE
                            epierreE
                            epierre
                            @hek do you think their hardware has some power usage optimization a-lurker discussed previsouly ?
                              Sorry, don't remember which discussion you are referring to.
                                epierreE
                                epierreE
                                epierre
                                @hek This was this one on : battery usage , I don't know if with custom duino they solve this ?
                                  Normal Pro Mini boards was discussed. The optimizations is described in the Battery Powering section on the documentation site.
                                    epierreE
                                    epierreE
                                    epierre
                                    @hek Yes I saw it, I just wondered if he applied this to his motuino ? nothing is said on this... I just wondered... off topic, is there a possibility to have three batteries and have a regulation pushing to 3.3V in to have greater sensor life ?
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      One way to off-load the microcontroller would be to use an off-chip security solution. Atmel actually offers something like this.
                                      I have used a similar device when I worked on an Apple accessory. Apple uses a challenge-response mechanism using an authentication chip to identify genuine devices in order to unlock certain aspects of the protocol API to iOS (reading contacts, etc). That device used I2C and I managed to integrate it with a PIC12, so it can be done with minimum HW resources.
                                      I have not looked deeper into how the AES chips actually work (with respect to key management, etc), but I would imagine it could be an adequate tool for the job.
                                      If I get the time, I'll look deeper into this.
                                        I agree that security is important. But it is also hard to do it right. Especially with the Arduinos fairly limited resources.
                                        It would be great if someone would have time to research the options we have and perhaps do some tests.
                                        I'm particularly interested in:
                                        • Speed (how large keys kan we use and how does the Arduino hardware cope with calculations)
                                        • How much would the message header need to grow
                                        • How do we stop replay attacks?
                                        • How could a key exchange be look like when a new sensor wakes up?
                                        • How should we route encrypted messages? (keep header unencryped?)
                                        • Is it possible to utilize PA_MIN radio transmit power when exchanging keys?
                                        • Support for both encrypted and unencrypted data in the same radio network would also be good.
                                        Here is a link that popped up during previous discussions.
                                        AES- http://utter.chaos.org.uk/~markt/AES-library.zip
                                        X
                                        X
                                        xop
                                        wrote on last edited by xop
                                        #27
                                        @hek
                                        Speed - according this http://forum.arduino.cc/index.php/topic,88890.0.html atmegas are capable of performing AES 128bit encryption in under 1 ms, seems promising at first glance
                                        Message length - I suspect the simplest way is to make them 16 bytes
                                        Protection against replay attacks - I think using nonces and checking message integrity with some kind of crc could do the trick
                                        Key exchange - wouldn't pre-shared key solve this issue?
                                        Also I'm not sure if encryption is really a must for this project. As far as I understand the most important thing is to prevent unauthorised control, and for this kind for things there are lots of MAC algorightms which are much less resource hungry than AES. Any opinions?
                                        • Z
                                          Z
                                          Zeph
                                          wrote on last edited by Zeph
                                          #28
                                          In another thread it was mentioned that the JeeNode (which uses the RF12b or RF69) already offers XXTEA encryption of on-air packets using an ATMega328p. So it's definitely do-able within our resources, and XX-TEA is probably sufficient - who's going to spend the resources to crack that just to turn on some lights?
                                          There are a lot of protocol questions tho, and the answer depends on your imagined scenario - what are you protecting against, how much incentive is there for an attacker, how serious is your exposure if they get through, etc. There is no one-size-fits-all security design; instead you design it to fit certain scenarios and not others.
                                          So let's start by accumulating a list of "attack scenarios", then deciding which ones we want to thwart, and design from there.
                                          Scenario 1: A major terrorist is using MySensors in their home automation, and the Mission Impossible team asks the NSA to crack the system so they can turn off his/her hot tub pumps at a given time to get the target to enter the fuse box room at exactly 7:02 while an agent slips a note to the luscious companion waiting it the hot tub.
                                          Low priority. Not low hanging fruit. :-)
                                          but more seriously
                                          Accidental interference with bogus packets (from noise or other devices) being received as legitimate, as happens with 433 MHz devices. The use of 127 channels at 3 speeds with 5 byte addresses and 2 byte hardware CRC makes this unlikely.
                                          Accidental jamming - change channels.
                                          Deliberate jamming, Not much we can do on the protocol level to avoid denial of service attacks. Let's skip that.
                                          A neighbor uses MySensors and they accidnetally discover they can monitor your packets. (Not likely to mean much unless they are using MySensors). Change addresses or channels.
                                          A neighbor not using MySensors wants to monitor your packets; they can program nRF chips to do so. They will have to do some reverse engineering to figure out what the contents mean (if unfamiliar with MySensors). Is this a problem?
                                          A technically sophisticated neighbor wants to control your actuators: turn on your lights, open your blinds, etc They scan to find your channel and speed, they use SDR or other tricks to discover your address, and then they can then monitor all your packets. They know or find MySensors on the web and decipher the packets. They then monitor and discover the packet which opens your blinds in the morning, and can resend that packet at a time of their choosing. Is this the key attack we want the design to block?
                                          What are some others? What do we need the design to handle?
