  3. Rain Guage
Rain Guage
128 Posts 23 Posters 156.5k Views 21 Watching
  • greglG
    greglG
    gregl
    Wow...Impressed!
    Like Marcel..i thought why not just use weather service? but before i read your reply i already thought of the reason...fun!
    Whats more impressive..and just freaking awesome to be able to email a design file to someone...jump in the car and go and pickup a physical object!!
    How did you find the printer guy?
    • greglG gregl
      Wow...Impressed!
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @gregl
      I used 3dhubs.com.
      They connect you with local folks who have the machines and want to make money with them. Really awesome,
      I had to quote a few before I found the right price, though.
      Check out the website, and put your location in. It will show you all of the local folks that do it.
      (Once I know that this works, I'll post the geometry or a link to it in case anyone wants to make one. I just want to make sure it works with he magnet first.)
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        Thank you again!
        1. For the idea ( and when you think it is ready the files :)
        2. For the suggestion of 3dhubs.com I will certainly use it to make some money with my upcoming printer...
        Fulltime Servoy Developer
        • petewillP
          petewillP
          petewill
          This is awesome! I was also wanting to do this. You beat me to it again (and I'm ok with that) :)
          I live in Colorado and we also have very localized rain. I would like a rain meter so I know when and how often I need to irrigate. I was also thinking it would be useful to use VeraAlerts to announce if a window is open and it's raining.
          How much rain water does it take to tip? From the video it seems like it would need quite a bit to tip. Would it be good to make the buckets(?) a little smaller so it would be more precise? Keep in mind I have no idea how big it is or how these things work in general so I could be way off with the question.
          Great job though! Keep up the great work.
          • petewillP petewill
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            I designed it to about 8ml, I have to calibrate it because of the meniscus, which looks substantial. I can tweak it by raising/lowing the allen cap screws.
            there are 25 cubic inches of water per inch of rain in an 8in gauge. So considering that there are 16.38ml per cubic inch, that gets us to approx 50 tips per inch of rain or 0.02in (0.5mm) resolution. I believe for me that's OK, particularly here i s SoFla where we get a lot of rain.
            I see your point regarding precision but you can easily go smaller. I wonder if I can make a funnel that will actually drop the water to the bottom if we only received 0.5mm of rain. I'll have to apply something to the funnel to lower the surface tension of the droplets, I think. The other consideration is offsetting the mass of the magnet, which is small but dense.
            So unless you get enough water to fall down and tip it, it won't likely record less than say 1mm of rain.
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @BulldogLowell
              Neodymium magnet in and works fine. I had to clean out the countersink hole with a drill to get it in and used E6000 glue to hold it.
              Now onto the hall effect sensor, wiring it up and of course the sketch.
              The 123D Design file is also attached if anyone wants to make one, play with the design, make fun of it, etc. The .stl file is 13Mb, I can email that if you want.
              If you want a print, let me know. I also have a few magnets and sensors, so I can send what you need for the project.
              I think I'm going to design a housing for the electronics too. I'm not sure I can find the right project box for this (I really just want to print more parts :)
              TippingBucket.123dx
              marceltrapmanM N 2 Replies Last reply
                Isn't it enough space in the foot for the electronics?
                Or perhaps make foot a little bigger in v2.0 to fit it there ;)
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  @hek
                  right!
                  While I want to keep the height low, I can modify the foot to include the whole of the electronica for sure. a radius of 4in provides a nice area for a lot of stuff.
                  plus, I was thinking about having the antenna at the bottom of the device...
                  good idea, thanks! It is better that we know that the tipping bucket will work (volumetrically) at this point.
                  time to get onto the rest of the physical design, I guess.
                    Thank you again!
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @marceltrapman said:
                    1. For the suggestion of 3dhubs.com I will certainly use it to make some money with my upcoming printer...
                    Don't forget my "one free part referral" fee!!!
                      @BulldogLowell
                      TippingBucket.123dx
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      @BulldogLowell I have read about techniques to include the magnet while printing.
                      You can do that by designing a hole, stop the printer when the hole is about to be covered, insert the magnet and continue printing.
                      I will think about you once the printer is there (a couple of months from now)...
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        So, I managed to finish a sketch for the Rain Gauge.
                        It creates two devices:
                        1. an information panel that displays last 24hours rain and the current rate of rain. along with 5 buckets of time so that you may see up to 5 days total rainfall.
                          It stores 24, 48, 72, 96 and 120 hrs rain in the Variable1-Variable5 respectively.
                          I customized the Rain Sensor to look more like a rain sensor and be more descriptive on the front panel, using the image from the moisture sensor, which I thought looked better.
                        2. a binary sensor that you can set. Put in the hours you wish to evaluate (1-120) and the rainfall you desire to trip the device. They are entered as Variable1 and Variable 2.
                        images attached, take a look and comments are appreciated.
                        I would like to do more with the presentation of the sensors on the vera UI... I'll do that after I get this all together, if I can.
                        • FrancoisF
                          FrancoisF
                          Francois
                          @BulldogLowell I also busy building an rain gauge. How is your one performing? Now did you set this up in the arduino? How did you do the calculation?
                          Regards
                          Francois
                          • FrancoisF Francois
                            Regards
                            Francois
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @Francois
                            yes is working still, I mentioned how I did the math above...
                            • FrancoisF
                              FrancoisF
                              Francois
                              wrote on last edited by Francois
                              #23
                              @BulldogLowell do you mind sharing the sketch I not seeing in this forum or on the Build pages of MySensor.org
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @Francois
                                Sure, but I have that running at my 'other' house and it is on older version of MySensors (haven't upgraded there yet ;)
                                I'll take a whack at updating if you like... it needs to get done anyway... here it is:
                                 Arduino Tipping Bucket Rain Gauge
                                 June 15, 2014
                                 Version 1.00b
                                 Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
                                 gateway you can measure and sense local rain.  This sketch will create two devices on your
                                 Vera controller.  One will display your total precipitation for the last 24, 48, 72, 96 and 120
                                 hours.  The other, a sensor that changes state if there is recent rain (up to last 120 hours)
                                 above a threshold.  Both these settings are user definable.
                                 * Allows you to set the rain threshold in mm
                                 * Allows you to determine the interval window up to 120 hours.
                                 * Displays the last 24, 48, 72, 96 and 120 hours total rain in Variable1 through Variable5
                                   of the Rain Sensor device
                                 * Configuration changes to Sensor device updated every 3 hours.
                                 * SHould run on any Arduino
                                 * Will retain Tripped/Not Tripped status and data in a power outage, saving small ammount
                                   of data to EEPROM (Circular Buffer to maximize life of EEBPROM
                                 * There is a unique setup requirement necessary in order to properly present the Vera device
                                   variables.  The details are outlined in the sketch below.
                                 * LED status indicator
                                 by BulldogLowell@gmail.com for free public use
                                #include <EEPROM.h>
                                #include <RF24.h>
                                #include <Sensor.h>
                                #define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h
                                #define EEPROM_BUFFER 514  // location of the EEPROM circular buffer
                                #define BUFFER_LENGTH 121
                                Sensor gw;
                                boolean metric = false;
                                int eepromIndex;
                                int tipSensorPin = 3;
                                int ledPin = 5; //PWM capable required
                                unsigned long dataMillis;
                                unsigned long serialInterval = 10000UL;
                                const unsigned long oneHour = 60000UL;
                                unsigned long lastTipTime;
                                unsigned long lastBucketInterval;
                                unsigned long startMillis;
                                int dayBuckets [5] [2] = {
                                 { V_VAR1, 24 },
                                 { V_VAR2, 48 },
                                 { V_VAR3, 72 },
                                 { V_VAR4, 96 },
                                 { V_VAR5, 120},
                                volatile byte rainBucket [120] ; // 5 days of data
                                const unsigned long calibrateFactor = 1UL; //Calibration in milimeters of rain per single tip
                                unsigned long rainRate = 0;
                                float currentRain = 0;
                                boolean wasTipped = false;
                                boolean updateVera;
                                int rainCount;
                                volatile int tipBuffer = 0;
                                byte rainWindow = 72;//default rain window in hours
                                int rainSensorThreshold = 15;//default rain sensor sensitivity in mm
                                byte hourCount = 24;
                                byte state;
                                byte oldState = -1;
                                unsigned long ledPulseTime = 500UL;
                                unsigned long pulseStart;
                                  gw.begin();
                                  pinMode(tipSensorPin, OUTPUT);
                                  attachInterrupt (1, sensorTipped, CHANGE);
                                  pinMode(ledPin, OUTPUT);
                                  digitalWrite(ledPin, HIGH);
                                  gw.sendSketchInfo("Rain Guage", "1.00b");
                                  gw.sendSensorPresentation(1, S_RAIN);
                                  gw.sendSensorPresentation(2, S_MOTION);
                                  Serial.println(F("Sensor Presentation Complete"));
                                  pinMode(tipSensorPin, INPUT);
                                  state = EEPROM.read(STATE_LOCATION);
                                  for (int i = 0; i < BUFFER_LENGTH; i++)
                                    byte locator = EEPROM.read(EEPROM_BUFFER + i);
                                    if (locator == 0xFF)
                                      eepromIndex = EEPROM_BUFFER + i;
                                      loadRainArray(eepromIndex);
                                      Serial.println(eepromIndex);
                                  gw.sendVariable(2, V_TRIPPED, state);
                                  dataMillis = millis();
                                  startMillis = millis();
                                  lastTipTime = millis() - oneHour;
                                  // uncomment the following block the first time you include this device.  The delays
                                  // are necessary in order to create the five Variable buckets in the correct order.
                                  // Once you create them, you can comment out these lines and re-upload to your arduino
                                  for (int j = 0; j < 5; j++)
                                   delay(2000);
                                   gw.sendVariable(1, dayBuckets[j] [0], 1);
                                   delay(2000);
                                   gw.sendVariable(2,V_VAR1, 1);
                                   delay(2000);
                                   gw.sendVariable(2,V_VAR2, 1);
                                  rainWindow = atoi(gw.getStatus(2, V_VAR1));
                                  delay(2000);
                                  rainSensorThreshold = atoi(gw.getStatus(2, V_VAR2));
                                  gw.sendVariable(1, V_RAINRATE, 0);
                                  Serial.print(F("Radio Done"));
                                  analogWrite(ledPin, 20);
                                  unsigned long measure = 0; // Check to see if we need to show sensor tripped in this block
                                  for (int i = 0; i < rainWindow; i++)
                                    measure = measure + rainBucket [i];
                                  measure >= rainSensorThreshold ? state = 1: state = 0;
                                  if (millis() - pulseStart < ledPulseTime)
                                    analogWrite(ledPin, 255);
                                  if (state != oldState)
                                    EEPROM.write(STATE_LOCATION, state);
                                    oldState = state;
                                  if (millis() - lastTipTime >= oneHour)// timeout for rain rate
                                    if (rainRate != 0)
                                      rainRate = 0;
                                      gw.sendVariable(1, V_RAINRATE, rainRate);
                                  if (updateVera)
                                    updateVera = false;
                                  if ( (millis() - dataMillis) >= serialInterval)//Comment back in this block to enable Serial prints
                                    for (int i = 24; i <= 120; i=i+24)
                                      updateSerialData(i);
                                  if (tipBuffer > 0)
                                    Serial.println(F("Sensor Tipped"));
                                    rainBucket [0] ++;
                                    pulseStart = millis();
                                    if (rainBucket [0] > 253) rainBucket[0] = 253; // odd occurance but prevent overflow
                                    int dayTotal = 0;
                                    for (int i = 0; i < 24; i++)
                                      dayTotal = dayTotal + rainBucket [i];
                                    gw.sendVariable(1, V_RAIN, dayTotal);
                                    unsigned long tipDelay = millis() - lastTipTime;
                                    if (tipDelay <= oneHour)
                                      rainRate = ((oneHour) / tipDelay);
                                      Serial.print(F("RainRate= "));
                                      Serial.println(rainRate);
                                    lastTipTime = millis();
                                    updateVera = true;
                                    tipBuffer--;
                                  if ( (millis()- startMillis) >= oneHour)
                                    Serial.println("one hour elapsed");
                                    //EEPROM write last value
                                    EEPROM.write(eepromIndex, rainBucket[0]);
                                    eepromIndex++;
                                    if (eepromIndex > EEPROM_BUFFER + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER;
                                    EEPROM.write(eepromIndex, 0xFF);
                                    for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values
                                      rainBucket [i + 1] = rainBucket [i];
                                    rainBucket[0] = 0;
                                    gw.sendVariable(1, V_RAIN, tipCounter(24));// send 24hr tips
                                      int total = 0;
                                      for (int i = 0; i < dayBuckets[j][1]; i++)
                                        total = total + rainBucket [i];
                                      gw.sendVariable( 1, dayBuckets[j] [0], total);
                                    hourCount++;
                                    if (hourCount >=3)//8 times daily update the Sensor variables
                                      if (rainWindow < 6)
                                        rainWindow = 6;
                                        gw.sendVariable( 2, V_VAR1, rainWindow);
                                      if (rainWindow > 120)
                                        rainWindow = 120;
                                        gw.sendVariable( 2, V_VAR2, rainWindow);
                                      delay(2000);
                                      if (rainSensorThreshold < 1)
                                        rainSensorThreshold = 1;
                                        gw.sendVariable( 2, V_VAR2, rainSensorThreshold);
                                      if (rainSensorThreshold > 1000)
                                        rainSensorThreshold = 1000;
                                      hourCount = 0;
                                void sensorTipped()
                                    tipBuffer++;
                                unsigned long tipCounter(int x)
                                  int tipCount = 0;
                                  for ( int i = 0; i < x; i++)
                                    tipCount = tipCount + rainBucket [i];
                                  return tipCount;
                                void updateSerialData(int x)
                                  Serial.print(F("Tips last "));
                                  Serial.print(x);
                                  Serial.print(F("hours: "));
                                  int tipCount = 0;
                                  for (int i = 0; i < x; i++)
                                  Serial.println(tipCount);
                                void loadRainArray(int value)
                                  for (int i = 0; i < BUFFER_LENGTH - 1; i++)
                                     value--;
                                     Serial.println(value);
                                     if (value < EEPROM_BUFFER)
                                         value = EEPROM_BUFFER + BUFFER_LENGTH;
                                     byte rainValue = EEPROM.read(value);
                                     Serial.println(rainValue);
                                     if (rainValue < 255)
                                       rainBucket[i] = rainValue;
                                       rainBucket [i] = 0;
                                • T
                                  tomrask
                                  Hey Francois
                                  Thanks for a nice projekt. I am thinking on building one myself. But is it possible to log the rain for everyday and writing the data to a csv file so I can use the data in Excel on Windows.
                                  Hope that you can help my.
                                  Tom
                                  • T tomrask
                                    Hey Francois
                                    Tom
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @tomrask
                                    Tom,
                                    Are you wishing to
                                    1. log to an SD card
                                    2. collect data controller side (e.g. Vera or other controller)
                                    3. transmit data directly to a server
                                    4. something else....?
                                    • BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @hek
                                      are we still required to steer clear of MySensor's EEPROM in addresses 0-512?
                                      hekH 1 Reply Last reply
                                      • T
                                        tomrask
                                        I use a vera light with a USB key where the data can be stored. It vill be better if I the date was on my dropbox og sendt to my NAS.
                                        But I have not fount a way to do it.
                                        Tom
                                          @hek
                                          @hek
                                          Use the saveState()/loadState() function in the MySensors library
