  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.8k Views 30 Watching
  • P
    P
    phil83
    @tbowmo Thanks for the info. I found mouser this morning as well but they charge me 20€ for shipping :-(.
    • tbowmoT
      tbowmoT
      tbowmo
      @phil83
      You just need to make an order big enough, then they drop the handling charge :-)
      • P
        P
        phil83
        Any other Europeans interested in getting some chips from mouser? I could redistribute from Germany via letter. ;-)
        • T
          Tibus
          hello, i'm making some mysensors board that I'll present you a bit later and I've add a place for the Atsha204 sot23-3.
          I can't find it in Europe still and I would like to know if is it possible ton connect it on pin A6 instead of pin A3. I would like to keep the A0 to A5 for the user and use A6 for Atsha204 and A7 for Atcha204 floating point. Can anyone test it for me please?
          Thank's verry much!
          AnticimexA 1 Reply Last reply
          • T Tibus
            Thank's verry much!
            AnticimexA
            AnticimexA
            Anticimex
            @Tibus No, you cant. A6 and A7 are analog-only pins. Also, make sure you order ATSHA204A. Not ATSHA204. ATSHA uses no "floating point". Just single wire digital interface.
            • T
              Tibus
              Ok, So I've to connect it on A3 (default value in mysensor?) and let the A7 floating? The A6 is not used so? (other question : I can't use digitalWrite on A6 pin?)
              Thank's verry much for the details on ATSHA204A instead of ATSHA204. The ATSHA204A is in SOT23-3 too? so the A7 is only use inside the Atmega library?
              • T Tibus
                AnticimexA
                AnticimexA
                Anticimex
                @Tibus A6 and A7 are analog input pins. You can use them as such but not as digital I/O.
                ATSHA204A is identical but more feature-rich compared to ATSHA204. One added feature is a SHA256 which is required for MySensors use. ATSHA204 is discontinued by Atmel. You can connect the ATSHA to any digital I/O pin you like but you will have to patch the config if you pick anything not called "A3".
                • T
                  Tibus
                  Ok, thank's! I've already change every A6 pin connection to A3. Can the user use A3 for analogic even if ATSHA204 is connected on it? or do I have to remove the A3 pin available for the user?
                  • T Tibus
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Tibus You have to check the datasheet of ATSHA204A to see how it handles the datapin when not in use. I would recommend you have any analog cirquitry on dedicated pins though and keep one reserved for the ATSHA.
                    hekH 1 Reply Last reply
                    • AnticimexA Anticimex
                      @Anticimex
                      The "analog" pins can actually be used as digital IO pins.
                        @Anticimex
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @hek Not A6 and A7. They are pure analog.
                          Ok! That's new to me :)
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @hek @tbowmo also found this the "hard" way. There are also some other forum discussions on the topic. It is basically how the AVR is designed.
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @hek @Anticimex
                              Yeah. I put the led on A6 in the first revision of the micro board, and used 2 hours figuring out why the led wouldn't blink ;) it's buried somewhere in the posts in my design thread.
                                mainali
                                I had this concerned from beginning. I will sound like a noon, but I am working on building a custom controller with loads of user configurable interface. For sake of my understanding is there any diagram or video or any resource regarding how to interface the ATSHA204A with arduino @Anticimex .
                                If there is something like that it will be of a great help. I am going to post a video soon of my work in progress app which controls the devices. I am also working on a scenario where someone can use the normal switches(existing ones) to operate the device and app will update accordingly. Still making way through the ACK part and the hops as I am using Ruby to do all the work
                                • M mainali
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @mainali What do you mean? It is the simplest possible interface; one IO pin. You can see schematics in @tbowmo s "Minimal design thoughts" thread or my own GW design.
                                  • sj44kS
                                    sj44kS
                                    sj44k
                                    wrote on last edited by sj44k
                                    #65
                                    @mainali
                                    Does this help you? Sometimes a few pics say more than a 1000 words :)
                                    I made this pic from the Datasheet giving you the pinouts of the ATSHA204A in all known housings.
                                    And the way how to connect is (shamelessly stolen from the GW design of @Anticimex :) )
                                    • sj44kS sj44k
                                      @mainali
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #66
                                      @sj44k @mainali Please note that that picture is incorrect. I have it connected to A3, not A7 (it is mentioned in the thread). Also note that in my design, I use a breakout board for ATSHA so the pin numbering on my breakout does NOT correspond to the SOT23-package.
                                        mainali
                                        Thanks a lot for all the Information
                                        • sj44kS
                                          sj44kS
                                          sj44k
                                          @Anticimex
                                          Thanks for that info, to me it is clear that depending on the used pin in the software one should connect the ATSHA204A corresponding with the software.
                                          Picture does show you being correct how simple it really is to embed the ATSHA204A hardware in the total setup.
