  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.8k Views 30 Watching
  • T Tibus
    Ok, So I've to connect it on A3 (default value in mysensor?) and let the A7 floating? The A6 is not used so? (other question : I can't use digitalWrite on A6 pin?)
    Thank's verry much for the details on ATSHA204A instead of ATSHA204. The ATSHA204A is in SOT23-3 too? so the A7 is only use inside the Atmega library?
    AnticimexA
    AnticimexA
    Anticimex
    @Tibus A6 and A7 are analog input pins. You can use them as such but not as digital I/O.
    ATSHA204A is identical but more feature-rich compared to ATSHA204. One added feature is a SHA256 which is required for MySensors use. ATSHA204 is discontinued by Atmel. You can connect the ATSHA to any digital I/O pin you like but you will have to patch the config if you pick anything not called "A3".
    • T
      Tibus
      Ok, thank's! I've already change every A6 pin connection to A3. Can the user use A3 for analogic even if ATSHA204 is connected on it? or do I have to remove the A3 pin available for the user?
      AnticimexA 1 Reply Last reply
      • T Tibus
        AnticimexA
        AnticimexA
        Anticimex
        @Tibus You have to check the datasheet of ATSHA204A to see how it handles the datapin when not in use. I would recommend you have any analog cirquitry on dedicated pins though and keep one reserved for the ATSHA.
        hekH 1 Reply Last reply
        • AnticimexA Anticimex
          @Anticimex
          The "analog" pins can actually be used as digital IO pins.
            @Anticimex
            AnticimexA
            AnticimexA
            Anticimex
            @hek Not A6 and A7. They are pure analog.
              Ok! That's new to me :)
                AnticimexA
                AnticimexA
                Anticimex
                @hek @tbowmo also found this the "hard" way. There are also some other forum discussions on the topic. It is basically how the AVR is designed.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @hek @Anticimex
                  Yeah. I put the led on A6 in the first revision of the micro board, and used 2 hours figuring out why the led wouldn't blink ;) it's buried somewhere in the posts in my design thread.
                    mainali
                    I had this concerned from beginning. I will sound like a noon, but I am working on building a custom controller with loads of user configurable interface. For sake of my understanding is there any diagram or video or any resource regarding how to interface the ATSHA204A with arduino @Anticimex .
                    If there is something like that it will be of a great help. I am going to post a video soon of my work in progress app which controls the devices. I am also working on a scenario where someone can use the normal switches(existing ones) to operate the device and app will update accordingly. Still making way through the ACK part and the hops as I am using Ruby to do all the work
                    • M mainali
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @mainali What do you mean? It is the simplest possible interface; one IO pin. You can see schematics in @tbowmo s "Minimal design thoughts" thread or my own GW design.
                      • sj44kS
                        sj44kS
                        sj44k
                        wrote on last edited by sj44k
                        #65
                        @mainali
                        Does this help you? Sometimes a few pics say more than a 1000 words :)
                        I made this pic from the Datasheet giving you the pinouts of the ATSHA204A in all known housings.
                        And the way how to connect is (shamelessly stolen from the GW design of @Anticimex :) )
                        • sj44kS sj44k
                          @mainali
                          AnticimexA
                          AnticimexA
                          Anticimex
                          #66
                          @sj44k @mainali Please note that that picture is incorrect. I have it connected to A3, not A7 (it is mentioned in the thread). Also note that in my design, I use a breakout board for ATSHA so the pin numbering on my breakout does NOT correspond to the SOT23-package.
                            mainali
                            Thanks a lot for all the Information
                            • sj44kS
                              sj44kS
                              sj44k
                              @Anticimex
                              Thanks for that info, to me it is clear that depending on the used pin in the software one should connect the ATSHA204A corresponding with the software.
                              Picture does show you being correct how simple it really is to embed the ATSHA204A hardware in the total setup.
                              • D
                                Dirk_H
                                wrote on last edited by Dirk_H
                                #69
                                @phil83
                                I fear you've already ordered the ATSHA204A ? I'm also in Germany so that would be easy.
                                If not - I'd take 10 pcs. They cost close to nothing -> nice :)
                                @Anticimex
                                I don't agree with "This is an unlikely usecase because it is really no reason to sign sensor values. If you for some reason want to obfuscate sensor data, encryption is a better alternative."
                                I think of Sensors used for Alarm-Systems. You need to trust the sensor reading because otherwise the attacker might jam the original Sensor and send his own Sensor data to let the alarm-system think the window is still closed (e.g.).
                                One more question: Are the Serials in the ATSHA in ascending order (i.e. when you have a reel of ICs is each S/N old S/N+1 ?) If this is the case, would it be possible to steal a keyfob to get a valid signing device, read the serial, use that S/N +1, sign the message and get still access to the garage door? I.e. do something one could call "S/N spoofing"? (I know that it is much easier to just break the garage door with a crowbar, but I'm intrested in this - at least hypotheticaly :))
                                Unfourtunately I don't have much time at the moment to try it out by myself, but I'm still really excited about your work and effort!
                                • D Dirk_H
                                  @phil83
                                  @Anticimex
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @Dirk_H The signing solution can be applied to both sensors and gateways. If you feel the need to have the gateway require signed messages from nodes, there is nothing to prevent it. I have already thought of that scenario and implemented support for it.
                                  Regarding jamming, no security system can prevent that.
                                  Regarding the generation of serials, you have to contact Atmel about that. And you still need to obtain the preshared key in order to generate properly signed messages. Neither the key nor the serial is ever sent over the air in clear text.
                                  • FotoFieberF
                                    FotoFieberF
                                    FotoFieber
                                    @Anticimex
                                    Thank you very much for this solution.
                                    I think your solution is the best compromise, if you don't want to transmit more data.
                                    The drawback is, that it isn't really as secure as AES 256 or above. It is a compromise.
                                    What about a solution
                                    • where the original message is untouched without a signature
                                    • a consumer requests an AES 256 signature of this message, if he really needs it
                                    • a second/third signature message is sent to the consumer with full AES 256 signature
                                    In this solution, you could use different keys for different nodes and the risk of stolen keys would be minimized.
                                    • FotoFieberF FotoFieber
                                      @Anticimex
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      #72
                                      @FotoFieber
                                      I think sha256 is pretty secure enough :)
                                      Regarding splitting signature and message, I am not too fond of that, because it opens up a lot of attack vectors and it also put requirements on the sender to be able to retain a sent message. Potentially a lot of nodes sends data back and forth, so what happens if, for instance, the gateway sends a message to one node, then sends another message to another node, and then the first node sends a message requesting a signature on a message the gateway no longer has. We have to remember that ram memory is very limited so there are limits in what we can do with message management, unfortunately.
                                      But all feedback is appreciated! Thanks!
                                      • FotoFieberF
                                        FotoFieberF
                                        FotoFieber
                                        @Anticimex
                                        sha256 is secure enough. But if I understand the implementation correctly, you use the space at the end of the payload for the signature and not the full signature.
                                        Another thing to consider is that the strength of the signature is inversely proportional to the payload size.
                                        If I calculate it right, the length of the signature is less or equal (23 bytes) 184 bit.
                                        With a payload of 4 bytes, which would probably be the usual payload I have here, there would be left only 160 bit (20 bytes).
                                        In comparison a HMAC_SHA256 uses 256 bit,
                                        Or did I miss something?
                                        It could be implemented quite simple:
                                        1. Node sends data to gateway which in my case is published to MQTT
                                        2. some consumer likes to have this signed and sends the node the message back with a sign request
                                        3. the node looks at the message and checks, if the value inside the message is still valid. When ok, it sends a HMAC splitted in two messages. If not, it ignores the message or sends NOK.
                                        The problem with this implementation would be, that the node hast to be active to get the singing request.
                                        Maybe it would be better to just send two other messages with the HMAC after the data.
                                        I would suggest to implement the check of the HMAC where it is needed, not in the gateway, In my case, this would be node-red.
                                          @Anticimex
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          #74
                                          @FotoFieber
                                          Regarding the weakened security based on the message size, you are correct.
                                          But I still disagree on splitting the messages because it will mean that some messages will fail to be signed (depending on network load) and it is no good to have a solution that adds uncertainty in that respect. And I definitely do not want to add restrictions on which types of nodes are capable on signing and which are not. Having the gateway signing messages is a very real application in use cases like locks and such.
                                          The opposite is also equally valid, some nodes might send "important" data. The gateway needs to be able to authenticate such nodes (keyfobs etc).
                                          We have to weigh complexity vs resources, and currently we are pretty much at the limit of our capabilities. An ethernet or mqtt gateway running on an Arduino nano can today barely fit HW support for signing. SW signing does not fit. So we can't really get more complex with the solution without also stepping up the HW platform we execute on.
