  3. Gateway device
Gateway device
151 Posts 19 Posters 155.2k Views 21 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    I agree. It is the center of the sensorweb. I think it pays to keep it running on full steam. And even if it is running of mains, and certainly is not suitable for battery powered operation, it still will draw a fraction of a lightbulb so hunting milliwatts makes little difference in the long runt I think. Besides, it will be bitter if we end up with performance limitations when we now "solve" the memory limitations.
    • tbowmoT
      tbowmoT
      tbowmo
      well the reason to shift to 3.3v was that it would make things a whole lot easier, when interfacing with the different peripherals. It is not for hunting mA's.
      But I'll dump some simple level shifting in there then.
      axillentA AnticimexA 2 Replies Last reply
      • tbowmoT tbowmo
        axillentA
        axillentA
        axillent
        #28
        @tbowmo ethernet/wifi/nordic at least are tolerant mostly to 5V
        the only complication is to have two supplies
        taking into account many different required things two supplies is not a major complication
        while keeping arduino & atmel....
        but if shift to something else (stm32 for example) 3.3V are sufficient even for 72MHz
        sense and drive
        • tbowmoT tbowmo
          AnticimexA
          AnticimexA
          Anticimex
          @tbowmo I see. But a simple stab to get 3.3V should be fairly cheap. And also "safe". I found that I could not get reliable RF on my Ethernet GW, so I threw in a LE33 just to power the radio (I use the PA-pimped one which is a bit more nitpicky on the supply). Have not had power issues since. So it could be that regulating the RF will be required anyway since I assume that PA-pimped radios will be part of the "offering".
          • tbowmoT
            tbowmoT
            tbowmo
            @axillent
            It's more the external SPI flash, I haven't been able to find any that works above 3.6V, where they specify abolute maximum voltage on any pin to be 4.1V. I haven't looked at the datasheet for ethernet / wifi modules yet, so there also might be some problems there with maximum ratings on input signals.
            @Anticimex
            I have already thrown in a 3.3V supply for the radio, and what else is needing 3.3V to operate.
            Anyways, I have thrown in a resistor / diode "matrix", to do level shifting on SPI signals now..
            • Vladut GrecuV
              Vladut GrecuV
              Vladut Grecu
              wrote on last edited by Vladut Grecu
              #31
              @tbowmo Did you consider using a ESP8266 WIFI Module?
              You can easily program it and get the atmega off the part's list.
              How to directly program an inexpensive ESP8266 WIFI Module @ Hackaday.com
              • tbowmoT
                tbowmoT
                tbowmo
                @Vladut-Grecu
                I fear that it will take too much time, if we have to port the library to the esp8266 cpu core. But you are more than welcome to dig in to it, if you feel for it :)
                Currently the focus is (more or less) on arduino compatible platforms.
                • Vladut GrecuV
                  Vladut GrecuV
                  Vladut Grecu
                  After finish my rpi gateway i think i will focus on the esp. I just wait for some local sellers to drop their prices(Easter, etc)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    I've started using KiCad for this project.. Still it's far from completed (things are progressing more slowly with this one, than the last, as it's a bit more complex and I don't have that much time at hand now..
                    Anyway, I have created a github repository of it, if anyone wants to have a look, https://github.com/tbowmo/MySensorGW
                    Current schematics are here (PDF file)
                    MySensorsGW-schematic.pdf
                    It's still a Work In Progress.. A lot of stuff needs to be ironed out..
                    AnticimexA 1 Reply Last reply
                    • tbowmoT tbowmo
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @tbowmo
                      Looks good. Perhaps add some header to break out a few I/O:s for future feature expansion? Like the SPI bus or i2c for a WiFi module or similar.
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        @Anticimex
                        There will eventually be footprints on there for wifi / ethernet modules.. And Yes I2C should go to a pinheader. SPI is already at a pinheader (kindof). As it's connected to the ISP header :)
                        I'm trying to get a grip on my thoughts, and create some parts for wifi/ethernet modules.. :)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          So decision time..
                          For wired ethernet, it seems that we have 2 options:
                          • w5100
                          • enc28j60
                          I haven't got that much experience with theese devices, so which one should we go ahead with?
                          Wireless, I think that I am settled with esp8266, but if there are anything else out there, that might be better, then please let me know..
                          At the moment I can't really decide which one is better :) So need some help from the community.
                          • AnticimexA
                            AnticimexA
                            Anticimex
                            I use the W5100 on my current gateway, and I have not had any significant issues with it (apart from the infamous SPI issue, which is resolved by controlling the SPI_EN signal to the W5100. Apart from that I am happy with it, and it is intelligent enough to allow the necessary software to fit an Arduino Nano. Unfortunately not with DHCP enabled (and signing support enabled). But if the enc28j60 does not require more software, and handles SPI(?) "properly" perhaps it would be the better alternative?
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              Hmm.. seems that W5100 has a complete TCP/IP stack on board, where as the enc82j60 only has MAC hardware, so the tcp/ip stack needs to reside in the host controller.
                              So W5100 it is..
                              And ESP8266 for the wifi (so far)
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                #40
                                been playing around some more with things..
                                currently the PCB is 5x5cm.
                                axillentA 1 Reply Last reply
                                • tbowmoT tbowmo
                                  axillentA
                                  axillentA
                                  axillent
                                  @tbowmo thank! it is a good job done!
                                  some questions/comments
                                  • w5100 SPI fix is already inside modern arduino ethernet shield http://www.arduino.cc/en/uploads/Main/arduino-ethernet-shield-06-schematic.pdf
                                    do you think it is needed? what kind of the shield your are looking for?
                                  • why not to put 20MHz crystal to give some more performance to the gateway?
                                  • USB is normally can supply not more than 500mA, are you sure it will be sufficient? DC-jack probably will be also good to have. ESP+wisnet could be hungry for the supply
                                  • why atmega1284? it is not a standard arduino choice but could costs on a level of 1280. atmega128 is the lowest cost 128k AVR. If we are sure 128k will be sufficient in the future I will select atmega128 because of cost or atmega1280 because it is standard for arduino
                                    And also I will consider atmega2560 to have a maximum possible resources (not only flash but also RAM)
                                  sense and drive
                                  tbowmoT 1 Reply Last reply
                                  • axillentA axillent
                                    tbowmoT
                                    tbowmoT
                                    tbowmo
                                    I was looking at the cheap Chinese breakout boards with W5100 chip on, not all of them have the SPI fix onboard, so that's why I implemented it.
                                    Hmmm.. think it was a price thing.. 16Mhz was more common than 20Mhz. But can't remember it right now (it's been a couple of weeks since I put in the 16Mhz xtal)
                                    In my thoughts, it should be either W5100 or ESP8266 mounted, not both at the same time (since both is for "internet" access. Also, most phone chargers are delivering 1A and up. Also, if you connect the thing to a computer via USB, you might not want to use W5100 / ESP8266 to communicate with it, so those power eaters could be left out in that case, leaving only NRF and/or RFM69 as radios.
                                    There are some people that are using atmega1284 with arduino IDE, so it can be used. Solderability is the first reason: atmega1280 is 100pins, while atmega1284 is 44 pins, price: atmega1280 is 15.96$, while atmega1284 is 8-9$. Of course I can see the point in putting in 1280, as it could be swapped for a 2560 if more flash/ram is needed.
                                    Atmega1280 is pincompatible with atmega2560, so they are interchangeable.
                                    Anyways, this is mainly playing around with KiCAD, and creating something that might be usefull along the road :). Design is not locked yet, so I'll take a couple of iterations on it (just like I did on the sensebender micro, with selecting powersource, and sensor types).
                                    • tbowmoT tbowmo
                                      axillentA
                                      axillentA
                                      axillent
                                      @tbowmo 20mhz should cost very similar to 16mhz, price is not an issue in this choice. Frequency is one of the parameter you will need to put inside boards.txt, it could be no issue to replace 16 by 20
                                      ok I see. if soldering is an issue there is also atmega1281/atmega2561 pin compatible having TQFP64 package while been fully compatible with atmega1280/2560 (they do have single datasheet). Their maximum xtal is 16mhz
                                      sense and drive
                                        tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @axillent
                                        As I said, I can't remember why I decided on the 16MHz crystal... it could have been a decision based on baudrate accuracy. But I'm not sure now.
                                        one thought, is the arduino spi library capable of using the extra spi ports on the atmega1280? (The 4 uarts can be reconfigured as spi ports)
                                        Started debating with myself, the benefits of changing cpu :) I'll look further at the data sheets.
                                        • tbowmoT tbowmo
                                          @axillent
                                          axillentA
                                          axillentA
                                          axillent
                                          @tbowmo I'm not sure that arduino SPI library can deal with USART as SPI at all
                                          but it could be no problem to write down a peace of a new code to use USART as SPI
                                          why you need 5 SPI's?)
                                          sense and drive
