  3. Gateway device
Gateway device
151 Posts 19 Posters 155.0k Views 21 Watching
  • tbowmoT tbowmo
    well the reason to shift to 3.3v was that it would make things a whole lot easier, when interfacing with the different peripherals. It is not for hunting mA's.
    But I'll dump some simple level shifting in there then.
    AnticimexA
    AnticimexA
    Anticimex
    @tbowmo I see. But a simple stab to get 3.3V should be fairly cheap. And also "safe". I found that I could not get reliable RF on my Ethernet GW, so I threw in a LE33 just to power the radio (I use the PA-pimped one which is a bit more nitpicky on the supply). Have not had power issues since. So it could be that regulating the RF will be required anyway since I assume that PA-pimped radios will be part of the "offering".
    • tbowmoT
      tbowmoT
      tbowmo
      @axillent
      It's more the external SPI flash, I haven't been able to find any that works above 3.6V, where they specify abolute maximum voltage on any pin to be 4.1V. I haven't looked at the datasheet for ethernet / wifi modules yet, so there also might be some problems there with maximum ratings on input signals.
      @Anticimex
      I have already thrown in a 3.3V supply for the radio, and what else is needing 3.3V to operate.
      Anyways, I have thrown in a resistor / diode "matrix", to do level shifting on SPI signals now..
      • Vladut GrecuV
        Vladut GrecuV
        Vladut Grecu
        wrote on last edited by Vladut Grecu
        #31
        @tbowmo Did you consider using a ESP8266 WIFI Module?
        You can easily program it and get the atmega off the part's list.
        How to directly program an inexpensive ESP8266 WIFI Module @ Hackaday.com
        • tbowmoT
          tbowmoT
          tbowmo
          @Vladut-Grecu
          I fear that it will take too much time, if we have to port the library to the esp8266 cpu core. But you are more than welcome to dig in to it, if you feel for it :)
          Currently the focus is (more or less) on arduino compatible platforms.
          • Vladut GrecuV
            Vladut GrecuV
            Vladut Grecu
            After finish my rpi gateway i think i will focus on the esp. I just wait for some local sellers to drop their prices(Easter, etc)
            • tbowmoT
              tbowmoT
              tbowmo
              I've started using KiCad for this project.. Still it's far from completed (things are progressing more slowly with this one, than the last, as it's a bit more complex and I don't have that much time at hand now..
              Anyway, I have created a github repository of it, if anyone wants to have a look, https://github.com/tbowmo/MySensorGW
              Current schematics are here (PDF file)
              MySensorsGW-schematic.pdf
              It's still a Work In Progress.. A lot of stuff needs to be ironed out..
              AnticimexA 1 Reply Last reply
              • tbowmoT tbowmo
                AnticimexA
                AnticimexA
                Anticimex
                @tbowmo
                Looks good. Perhaps add some header to break out a few I/O:s for future feature expansion? Like the SPI bus or i2c for a WiFi module or similar.
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @Anticimex
                  There will eventually be footprints on there for wifi / ethernet modules.. And Yes I2C should go to a pinheader. SPI is already at a pinheader (kindof). As it's connected to the ISP header :)
                  I'm trying to get a grip on my thoughts, and create some parts for wifi/ethernet modules.. :)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    So decision time..
                    For wired ethernet, it seems that we have 2 options:
                    • w5100
                    • enc28j60
                    I haven't got that much experience with theese devices, so which one should we go ahead with?
                    Wireless, I think that I am settled with esp8266, but if there are anything else out there, that might be better, then please let me know..
                    At the moment I can't really decide which one is better :) So need some help from the community.
                    • AnticimexA
                      AnticimexA
                      Anticimex
                      I use the W5100 on my current gateway, and I have not had any significant issues with it (apart from the infamous SPI issue, which is resolved by controlling the SPI_EN signal to the W5100. Apart from that I am happy with it, and it is intelligent enough to allow the necessary software to fit an Arduino Nano. Unfortunately not with DHCP enabled (and signing support enabled). But if the enc28j60 does not require more software, and handles SPI(?) "properly" perhaps it would be the better alternative?
                      • tbowmoT
                        tbowmoT
                        tbowmo
                        Hmm.. seems that W5100 has a complete TCP/IP stack on board, where as the enc82j60 only has MAC hardware, so the tcp/ip stack needs to reside in the host controller.
                        So W5100 it is..
                        And ESP8266 for the wifi (so far)
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          #40
                          been playing around some more with things..
                          currently the PCB is 5x5cm.
                          axillentA 1 Reply Last reply
                          • tbowmoT tbowmo
                            axillentA
                            axillentA
                            axillent
                            @tbowmo thank! it is a good job done!
                            some questions/comments
                            • w5100 SPI fix is already inside modern arduino ethernet shield http://www.arduino.cc/en/uploads/Main/arduino-ethernet-shield-06-schematic.pdf
                              do you think it is needed? what kind of the shield your are looking for?
                            • why not to put 20MHz crystal to give some more performance to the gateway?
                            • USB is normally can supply not more than 500mA, are you sure it will be sufficient? DC-jack probably will be also good to have. ESP+wisnet could be hungry for the supply
                            • why atmega1284? it is not a standard arduino choice but could costs on a level of 1280. atmega128 is the lowest cost 128k AVR. If we are sure 128k will be sufficient in the future I will select atmega128 because of cost or atmega1280 because it is standard for arduino
                              And also I will consider atmega2560 to have a maximum possible resources (not only flash but also RAM)
                            sense and drive
                            tbowmoT 1 Reply Last reply
                            • axillentA axillent
                              tbowmoT
                              tbowmoT
                              tbowmo
                              I was looking at the cheap Chinese breakout boards with W5100 chip on, not all of them have the SPI fix onboard, so that's why I implemented it.
                              Hmmm.. think it was a price thing.. 16Mhz was more common than 20Mhz. But can't remember it right now (it's been a couple of weeks since I put in the 16Mhz xtal)
                              In my thoughts, it should be either W5100 or ESP8266 mounted, not both at the same time (since both is for "internet" access. Also, most phone chargers are delivering 1A and up. Also, if you connect the thing to a computer via USB, you might not want to use W5100 / ESP8266 to communicate with it, so those power eaters could be left out in that case, leaving only NRF and/or RFM69 as radios.
                              There are some people that are using atmega1284 with arduino IDE, so it can be used. Solderability is the first reason: atmega1280 is 100pins, while atmega1284 is 44 pins, price: atmega1280 is 15.96$, while atmega1284 is 8-9$. Of course I can see the point in putting in 1280, as it could be swapped for a 2560 if more flash/ram is needed.
                              Atmega1280 is pincompatible with atmega2560, so they are interchangeable.
                              Anyways, this is mainly playing around with KiCAD, and creating something that might be usefull along the road :). Design is not locked yet, so I'll take a couple of iterations on it (just like I did on the sensebender micro, with selecting powersource, and sensor types).
                              • tbowmoT tbowmo
                                axillentA
                                axillentA
                                axillent
                                @tbowmo 20mhz should cost very similar to 16mhz, price is not an issue in this choice. Frequency is one of the parameter you will need to put inside boards.txt, it could be no issue to replace 16 by 20
                                ok I see. if soldering is an issue there is also atmega1281/atmega2561 pin compatible having TQFP64 package while been fully compatible with atmega1280/2560 (they do have single datasheet). Their maximum xtal is 16mhz
                                sense and drive
                                  tbowmoT
                                  tbowmoT
                                  tbowmo
                                  @axillent
                                  As I said, I can't remember why I decided on the 16MHz crystal... it could have been a decision based on baudrate accuracy. But I'm not sure now.
                                  one thought, is the arduino spi library capable of using the extra spi ports on the atmega1280? (The 4 uarts can be reconfigured as spi ports)
                                  Started debating with myself, the benefits of changing cpu :) I'll look further at the data sheets.
                                  • tbowmoT tbowmo
                                    @axillent
                                    axillentA
                                    axillentA
                                    axillent
                                    @tbowmo I'm not sure that arduino SPI library can deal with USART as SPI at all
                                    but it could be no problem to write down a peace of a new code to use USART as SPI
                                    why you need 5 SPI's?)
                                    sense and drive
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @axillent
                                      Just a thought on versatility, that's all :) you could have ethernet hanging on one SPI channel, and NRF / RFM on another, giving higher throughput (Ok, I know that it might not be necessary in this project at the moment..)
                                      Btw. just had a look at the datasheets for atmegas. 1280 / 2560 / 1281/2561 has 8Kb ram, while 1284 has 16Kb. Also operating frequency, 1284 is specified up to 20Mhz, while 1280/2560 etc. is only 16Mhz.
                                      So many parameters to choose from :)
                                      • tbowmoT tbowmo
                                        @axillent
                                        axillentA
                                        axillentA
                                        axillent
                                        #47
                                        ohh) the logic coming from PC world not working here. regardless how many SPIs you will initiate MCU will handle them in a sequence.
                                        but any way it could be a benefit
                                        for example you can avoid SPI fix if there will be exclusive SPI port used for wiznet
                                        on other hand it is good. atmega644/1284 are from later generation having more features. 16k RAM is a very good thing, gateway potentially could be hungry on RAM usage. The disadvantage is missing 256k version
                                        for last resort I will ask @hek to request quotes from partners to understand better the price difference.
                                        sense and drive
                                          tbowmoT
                                          tbowmoT
                                          tbowmo
                                          as they are in HW, they operate independently. So you can have two channels receiving at the same time, and another transmitting. The CPU just needs to put the bytes into the tx buffers, and pick up from the RX buffers.
                                          Yes, when I started looking at the GW, I had in mind using multiple SPI ports just for this. I know that we can use Soft SPI, but i would rather have it as HW implemented as it would offload the MCU for handling the SPI signals.
                                          Anyway, the SPI fix is a single gate that is placed on the board. the cost is at 0.5$ as far as I remember (mouser prices).
                                          I had thought about the same, asking our HW partners in china for the price differences.
