  3. 230V power supply to Arduino
67 Posts 25 Posters 78.6k Views 22 Watching
  • axillentA
    axillentA
    axillent
    yes, all cases are printed
    sure, I can share if you need
    the case developed for a particular custom made PCB
    sense and drive
    • axillentA axillent
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      I understand but the design is still a good starting point :)
      Fulltime Servoy Developer
      axillentA 1 Reply Last reply
        axillentA
        axillentA
        axillent
        @marceltrapman sure, just give me some time to publish it on thingerverse
        sense and drive
        • marceltrapmanM
          marceltrapmanM
          marceltrapman
          Nice, thanks...
          • MagiskeM
            MagiskeM
            Magiske
            wrote on last edited by Magiske
            #41
            Was looking into the same and ordered 2 different 230/110v to 5v of ebay to get a cheap 5v powersource. Just got them today.
            The White around $1.5 and the Black was $1.0
            Before wirering everything up, I just added the smaller white's pcb to the black case incl. radio and pro mini. And there is room for a bit more.
            So unless it goes up in flames I will try to create a default sensor node.
            J 1 Reply Last reply
            • Vladut GrecuV
              Vladut GrecuV
              Vladut Grecu
              If you don`t go over 50-60% of the amps that that charger can output, there will be no problems. I suggest you replace the capacitor on the 5V area with a bigger one and change the 220/110v capacitor with a higher quality one. What I figure from your pictures is that the black charger doesn't have a bridge rectifier.. It's safer for you to use one. (Don't forget about the fuse)
              • ferpandoF
                ferpandoF
                ferpando
                Anyone tested one of these cheap power supplies with an osciloscope?
                I got a couple yesterday but not sure if they are good enough
                • gaduG
                  gaduG
                  gadu
                  I've seen these and also got interested. Any input on these is appreciated.
                  • MagiskeM Magiske
                    J
                    J
                    Jan Gatzke
                    @Magiske I am using a power supply similar to the black one. My one has a fake optocoupler. The output voltage is unregulated. Have a close look before using this pcb. ;)
                    • Roberto BrunialtiR
                      Roberto BrunialtiR
                      Roberto Brunialti
                      wrote on last edited by Roberto Brunialti
                      #46
                      May be too big or too expansive... but it is for sure a good (and safe...) product with a 33x22 mm footprint..
                      http://www.mouser.com/ProductDetail/RECOM-Power/RAC01-33SC/?qs=waQl70lBfV2Z5QQrs%2FIAaw%3D%3D
                      • J
                        J
                        Jan Gatzke
                        Does it fit on 2.54 mm prototype boards?
                        • DidiD
                          DidiD
                          Didi
                          Yes it does.
                          Look data sheet http://www.mouser.com/ds/2/468/RAC01_02-SC-16262.pdf
                            Roberto BrunialtiR
                            Roberto Brunialti
                            I've got a couple of them (3.3 and 5 V models), the wired models. Just received. Still to test...
                              #50
                              you can disassemble some components like transformer and cap. So you can make your own mysensors design and you get very small and cheap transformer. I can't find cheaper I think. or maybe on alibaba!
                              I have these http://fr.aliexpress.com/item/AC-220V-DC-3V-10V-5V-9V-1w-1x1w-2w-2x1w-3w-3x1w-Constant-Current-Constant/1900256299.html?recommendVersion=1
                              M axillentA 2 Replies Last reply
                              • scalzS scalz
                                msebbe
                                Can this convert 230v to 5v and supply enough power for say an pro mini with motion sensor?
                                  @msebbe : yes it can.
                                  • scalzS scalz
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @scalz these are constant current. how come they supply constant voltage?
                                      @Moshe Livne: when I tested it, it was with atmel standalone. So I added a voltage regulator. And you can add a little filter if you want..
                                      • scalzS scalz
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @scalz Oh I see. Thanks!
                                        • scalzS scalz
                                          axillentA
                                          axillentA
                                          axillent
                                          I'm using similar one, it is also called 3 x1 W Led driver and by my measurements provides 300mA and 17V without load
                                          I use 220uF to filter its output and I use 78L05 to regulate down to 5V. This can give up to 5V@40mA output. The restriction is a heating desipation rating for 78L05.
                                          For higher loads I would recomment to use DC stepdown. With DC stepdown you can get up to 5V@650mA with 80% efficiency
                                          sense and drive
                                          crocC 1 Reply Last reply
