  3. Rain Guage
Rain Guage
128 Posts 23 Posters 158.9k Views 21 Watching
  • petewillP petewill
    @BulldogLowell Any luck finding the sketch? Sorry to bug you, I was just hoping to get this project completed soon so I can work on the irrigation controller next. It's almost time to start watering the lawn/plants... Thanks!
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @petewill
    Her is an untested go at it, and a very down and dirty update... I will test it probably Wednesday night, when I am back home. Let me know if you can!
     Arduino Tipping Bucket Rain Gauge
     April 26, 2015
     Version 1.01b for MySensors version 1.4.1
     Utilizing a tipping bucket sensor, your Vera home automation controller and the MySensors.org
     gateway you can measure and sense local rain.  This sketch will create two devices on your
     Vera controller.  One will display your total precipitation for the last 24, 48, 72, 96 and 120
     hours.  The other, a sensor that changes state if there is recent rain (up to last 120 hours)
     above a threshold.  Both these settings are user definable.
     * Allows you to set the rain threshold in mm
     * Allows you to determine the interval window up to 120 hours.
     * Displays the last 24, 48, 72, 96 and 120 hours total rain in Variable1 through Variable5
       of the Rain Sensor device
     * Configuration changes to Sensor device updated every 3 hours.
     * SHould run on any Arduino
     * Will retain Tripped/Not Tripped status and data in a power outage, saving small ammount
       of data to EEPROM (Circular Buffer to maximize life of EEPROM)
     * There is a unique setup requirement necessary in order to properly present the Vera device
       variables.  The details are outlined in the sketch below.
     * LED status indicator
     by BulldogLowell@gmail.com for free public use
    #include <EEPROM.h>
    #define RADIO_ID 99
    #define STATE_LOCATION 513 // stay away from EEPROM used with Sensor.h
    #define EEPROM_BUFFER 514  // location of the EEPROM circular buffer
    #define BUFFER_LENGTH 121  // buffer plus the current hour
    MyMessage msgRainRate(1, V_RAINRATE);
    MyMessage msgRain(1, V_RAIN);
    MyMessage msgRainVAR1(1, V_VAR1);
    MyMessage msgRainVAR2(1, V_VAR2);
    MyMessage msgRainVAR3(1, V_VAR3);
    MyMessage msgRainVAR4(1, V_VAR4);
    MyMessage msgRainVAR5(1, V_VAR5);
    MyMessage msgTripped(2, S_MOTION);
    MyMessage msgTrippedVar1(2, V_VAR1);
    MyMessage msgTrippedVar2(2, V_VAR2);
    boolean metric = false;
    int eepromIndex;
    int tipSensorPin = 3;
    int ledPin = 5; //PWM capable required
    unsigned long dataMillis;
    unsigned long serialInterval = 10000UL;
    const unsigned long oneHour = 60000UL;
    unsigned long lastTipTime;
    unsigned long lastBucketInterval;
    unsigned long startMillis;
    int dayBuckets [5] [2] = {
      { V_VAR1, 24 },
      { V_VAR2, 48 },
      { V_VAR3, 72 },
      { V_VAR4, 96 },
      { V_VAR5, 120},
    volatile byte rainBucket [120] ; // 5 days of data
    const unsigned long calibrateFactor = 1UL; //Calibration in milimeters of rain per single tip
    unsigned long rainRate = 0;
    float currentRain = 0;
    boolean wasTipped = false;
    boolean updateVera;
    int rainCount;
    volatile int tipBuffer = 0;
    byte rainWindow = 72;         //default rain window in hours
    int rainSensorThreshold = 15; //default rain sensor sensitivity in mm
    byte hourCount = 24;
    byte state;
    byte oldState = -1;
      gw.begin(getVariables, RADIO_ID);
      pinMode(tipSensorPin, OUTPUT);
      attachInterrupt (1, sensorTipped, CHANGE);
      pinMode(ledPin, OUTPUT);
      digitalWrite(ledPin, HIGH);
      gw.sendSketchInfo("Rain Guage", "1.01b");
      gw.present(1, S_RAIN);
      gw.present(2, S_MOTION);
      Serial.println(F("Sensor Presentation Complete"));
      pinMode(tipSensorPin, INPUT);
      state = EEPROM.read(STATE_LOCATION);    //retreive prior state from EEPROM
      gw.send(msgTripped.set(state), false);  //send state to Vera
      delay(250);                             // recharge the capacitor
      boolean isDataOnEeprom = false;
      for (int i = 0; i < BUFFER_LENGTH; i++)
        byte locator = EEPROM.read(EEPROM_BUFFER + i);
        if (locator == 0xFF)  // found the EEPROM circular buffer index
          eepromIndex = EEPROM_BUFFER + i;
          loadRainArray(eepromIndex);
          isDataOnEeprom = true;
          Serial.println(eepromIndex);
      if (!isDataOnEeprom)
        // load all zeroes to EEPROM?
        // I gotta check this out!!!
      // reset the timers
      dataMillis = millis();
      startMillis = millis();
      lastTipTime = millis() - oneHour;
      gw.request(2, V_VAR1);
      delay(250);
      gw.request(2, V_VAR2);
      delay(250);
      Serial.print(F("Radio Done"));
      analogWrite(ledPin, 20);
      pulseLED();
      // let's constantly check to see if the rain in the past rainWindow hours is greater than rainSensorThreshold
      int measure = 0; // Check to see if we need to show sensor tripped in this block
      for (int i = 0; i < rainWindow; i++)
        measure += rainBucket [i];
      state = (measure >= rainSensorThreshold);
      if (state != oldState)
        delay(250);
        EEPROM.write(STATE_LOCATION, state);
        oldState = state;
      // Now lets reset the rainRate to zero if no tips in the last hour
      if (millis() - lastTipTime >= oneHour)// timeout for rain rate
        if (rainRate != 0)
          rainRate = 0;
          gw.send(msgRainRate.set(0));
          delay(250);
      // if tipped,send updates to VERA
      if (updateVera)
        gw.send(msgRainRate.set(rainRate));
        delay(250);
        updateVera = false;
      if ( (millis() - dataMillis) >= serialInterval)//Comment back in this block to enable Serial prints
        for (int i = 24; i <= 120; i = i + 24)
          updateSerialData(i);
      if (tipBuffer > 0)
        Serial.println(F("Sensor Tipped"));
        rainBucket [0] ++;
        if (rainBucket [0] > 253) rainBucket[0] = 253; // odd occurance but prevent overflow
        int dayTotal = 0;
        for (int i = 0; i < 24; i++)
          dayTotal = dayTotal + rainBucket [i];
        gw.send(msgRain.set(dayTotal));
        delay(250);
        unsigned long tipDelay = millis() - lastTipTime;
        if (tipDelay <= oneHour)
          rainRate = ((oneHour) / tipDelay);
          Serial.print(F("RainRate= "));
          Serial.println(rainRate);
        lastTipTime = millis();
        updateVera = true;
        tipBuffer--;
      if (millis() - startMillis >= oneHour)
        Serial.println("one hour elapsed");
        //EEPROM write last value
        EEPROM.write(eepromIndex, rainBucket[0]);
        eepromIndex++;
        if (eepromIndex > EEPROM_BUFFER + BUFFER_LENGTH) eepromIndex = EEPROM_BUFFER;
        EEPROM.write(eepromIndex, 0xFF);
        for (int i = BUFFER_LENGTH - 1; i >= 0; i--)//cascade an hour of values
          rainBucket [i + 1] = rainBucket [i];
        rainBucket[0] = 0;
        gw.send(msgRain.set(tipCounter(24)));// send 24hr tips
        delay(250);
        transmitRainData(); // send all of the 5 buckets of data to controller
    void sensorTipped()
        tipBuffer++;
    int tipCounter(int hours)
      int tipCount = 0;
      for ( int i = 0; i < hours; i++)
        tipCount = tipCount + rainBucket [i];
      return tipCount;
    void updateSerialData(int x)
      Serial.print(F("Tips last "));
      Serial.print(x);
      Serial.print(F("hours: "));
      int tipCount = 0;
      for (int i = 0; i < x; i++)
      Serial.println(tipCount);
    void loadRainArray(int value)
      for (int i = 0; i < BUFFER_LENGTH - 1; i++)
        value--;
        Serial.println(value);
        if (value < EEPROM_BUFFER)
          value = EEPROM_BUFFER + BUFFER_LENGTH;
        byte rainValue = EEPROM.read(value);
        Serial.println(rainValue);
        if (rainValue < 255)
          rainBucket[i] = rainValue;
          rainBucket [i] = 0;
    void transmitRainData(void)
      int rainUpdateTotal = 0;
        rainUpdateTotal += rainBucket[i];
      gw.send(msgRainVAR1.set(rainUpdateTotal));
      delay(250);
      for (int i = 24; i < 48; i++)
      gw.send(msgRainVAR2.set(rainUpdateTotal));
      delay(250);
      for (int i = 48; i < 72; i++)
      gw.send(msgRainVAR3.set(rainUpdateTotal));
      delay(250);
      for (int i = 72; i < 96; i++)
      gw.send(msgRainVAR4.set(rainUpdateTotal));
      delay(250);
      for (int i = 96; i < 120; i++)
      gw.send(msgRainVAR5.set(rainUpdateTotal));
      delay(250);
      if (message.sensor == 1)
        // nothing to do here
      else if (message.sensor == 2)
        if (message.type == V_VAR1)
          rainWindow = atoi(message.data);
          if (rainWindow > 120)
            rainWindow = 120;
          else if (rainWindow < 6)
            rainWindow = 6;
          if (rainWindow != atoi(message.data))   // if I changed the value back inside the boundries, push that number back to Vera
            gw.send(msgTrippedVar1.set(rainWindow));
          rainSensorThreshold = atoi(message.data);
          if (rainSensorThreshold > 1000)
            rainSensorThreshold = 1000;
          else if (rainSensorThreshold < 1)
            rainSensorThreshold = 1;
          if (rainSensorThreshold != atoi(message.data))  // if I changed the value back inside the boundries, push that number back to Vera
            gw.send(msgTrippedVar2.set(rainSensorThreshold));
    void pulseLED(void)
      static boolean ledState = true;
      static unsigned long pulseStart = millis();
      if (millis() - pulseStart < 500UL)
        digitalWrite(ledPin, !ledState);
    • petewillP
      petewillP
      petewill
      @BulldogLowell Awesome, thank you very much! I know what it's like to lose code that way. I have done the same thing myself...
      Yes, I will test this. I'll do my best to get it tested tonight. I'm combining it with some other sensors (light and temp/humidity) so once I get everything merged I'll be able to upload it.
      I'll let you know what I find.
      Thanks again!
      Pete
      TheekshanaT 1 Reply Last reply
      • petewillP
        petewillP
        petewill
        @BulldogLowell
        Ok, I made the necessary changes for my application and I had a couple of questions along the way.
        • I have never worked with eeprom so I don't pretend to know anything about it (it's now on my list of things to research though). Anyway, I noticed above hek recommended using the "saveState()/loadState() function in the MySensors library". Is that necessary in your code or are we ok as is? It seems to be functioning ok for me when I compile it so maybe not...
        • I would like to trigger my rain sensor as soon as the first bucket has tipped (I have scenes that tell me to close the windows etc. when it's raining). Is changing the rainSensorThreshold value to 1 an appropriate way to do that or should I create another child node for my purposes? Maybe I should use rainRate in my PLEG instead?
        • My tipping bucket was pulled from an existing rain gauge and according to my calculations (which may be off) each bucket is .7mm of rain. I don't know much about unsigned long variables but I'm wondering if I need to change "const unsigned long calibrateFactor" to a float or something?
        Thanks for all your help!!
        Pete
        • petewillP
          petewillP
          petewill
          Jim,
          I uploaded the code but it didn't seem to work for me. Do I need to upload some additional files to Vera? When I added the nodes a lot of my devices stopped displaying correctly (not just the newly added ones). They look like this:
          upload-f009544f-e06e-4001-abba-63de772a744f
          When I deleted the rain gauge nodes everything came back:
          upload-2a04de4c-b861-4e84-892d-2ae37591ad0e
          As I was looking at the code I came up with some additional questions:
          • There is a dayBuckets array but it doesn't seem to do anything in the code?
          • I also couldn't find "const unsigned long calibrateFactor" used anywhere.
          I fully admit I'm not a very good with code and I could be missing something. I was just trying to find how the variables were working together and being calculated.
          Thanks for all your help with this! I could not do it without you.
          Pete
          • korttomaK
            korttomaK
            korttoma
            @petewill The reason your MySensor plugin brakes when you add the rain gauge is that the device_files are missing. I don't know if there are any device files for the rain gauge since they are not included in the github branch for the vera plugin.
            You could check under your rain gauge which device_file it is trying to use maybe you can search for it online and hope it exists.
            Worst case is that you need to create them your self.
            • Tomas
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
              #45
              yeah, you need the implemention files:
              D_RainSensor1.xml:
              <?xml version="1.0"?>
              <root xmlns="urn:schemas-upnp-org:device-1-0">
                <specVersion>
                  <major>1</major>
                  <minor>0</minor>
                </specVersion>
                <device>
                  <deviceType>urn:schemas-micasaverde-com:device:RainSensor:1</deviceType>
                  <Category_Num>12</Category_Num>
              	<staticJson>D_RainSensor1.json</staticJson>
                  <serviceList>
                    <service>
                      <serviceType>urn:schemas-upnp-org:service:RainSensor:1</serviceType>
                      <serviceId>urn:upnp-org:serviceId:RainSensor1</serviceId>
                      <SCPDURL>S_RainSensor1.xml</SCPDURL>
                    </service>
                    <service>
                      <serviceType>urn:schemas-micasaverde-com:service:HaDevice:1</serviceType>
                      <serviceId>urn:micasaverde-com:serviceId:HaDevice1</serviceId>
                      <SCPDURL>S_HaDevice1.xml</SCPDURL>
                    </service>
                  </serviceList>
                </device>
              </root>
              and
              D_RainSensor1.json
                  "flashicon": "icons/Humidity_Sensor.swf",
                  "imgIconBody": "",
                  "imgIconDimmable": "",
                  "imgIconTurnable": "",
                  "imgIconMin": "",
                  "imgIconMax": "",
                  "halloIconsDir": "pics\/hallo",
                  "inScene": "0",
                  "DisplayStatus": {},
                  "doc_url": {
                      "doc_language": 1,
                      "doc_manual": 1,
                      "doc_version": 1,
                      "doc_platform": 0,
                      "doc_page": "sensors"
                  "Tabs": [
                          "Label": {
                              "lang_tag": "tabname_control",
                              "text": "Information"
                          "Position": "0",
                          "TabType": "flash",
                          "SceneGroup": [
                                  "id": "1",
                                  "top": "1.5",
                                  "left": "0",
                                  "x": "2",
                                  "y": "2"
                          "ControlGroup": [
                                  "id": "1",
                                  "scenegroup": "1",
                                  "type": "info"
                                  "id": "2",
                                  "scenegroup": "1",
                                  "type": "info"
                          "Control": [
                              "ControlGroup":"1",
                              "ControlPair": "1",
                              "ControlHeader": "1",
                              "top": "1",
                              "left": "0",
                              "x": "1.25",
                              "ControlType": "label",
                              "Label": {
                                  "lang_tag": "rain_rate",
                                  "text": "Rate of Rain"
                              "Display": {
                                  "Top": 20,
                                  "Left": 50,
                                  "Width": 75,
                                  "Height": 20
                              "ControlGroup":"1",
                              "ControlPair": "1",
                              "top": "1",
                              "left": "1.25",
                              "x": "0.75",
                 		     "ControlType": "variable",
                              "Display": {
                                  "Service": "urn:upnp-org:serviceId:RainSensor1",
                                  "Variable": "CurrentRain",
                                  "Top": 20,
                                  "Left": 150,
                                  "Width": 25,
                                  "Height": 20
                              "Label": {
                                  "lang_tag": "total_rain_unit",
                                  "text": "mm/hr"
                              "Display": {
                                  "Top": 20,
                                  "Left": 200,
                                  "Width": 25,
                                  "Height": 20
                              "ControlGroup":"2",
                              "ControlPair": "2",
                              "top": "0",
                              "left": "0",
                              "x": "1.25",
                              "Label": {
                                  "lang_tag": "total_rain",
                                  "text": "24hrs Total:",
                              "Display": {
                                  "Top": 55,
                                  "Left": 50,
                                  "Width": 75,
                                  "Height": 20
                              "ControlGroup":"2",
                              "ControlPair": "2",
                              "top": "0",
                              "left": "1.25",
                              "x": "0.75",
                              "Display": {
                                  "Variable": "CurrentTRain",
                                  "Top": 55,
                                  "Left": 150,
                                  "Width": 25,
                                  "Height": 20
                              "Label": {
                                  "lang_tag": "rain_rate_unit",
                                  "text": "mm"
                              "Display": {
                                  "Top": 55,
                                  "Left": 200,
                                  "Width": 25,
                                  "Height": 20
                              "ControlGroup":"3",
                              "ControlPair": "3",
                              "top": "0",
                              "left": "0",
                              "x": "1.25",
                              "Label": {
                                  "lang_tag": "rain_forty",
                                  "text": "48hrs Total:"
                              "Display": {
                                  "Top": 80,
                                  "Left": 50,
                                  "Width": 75,
                                  "Height": 20
                              "ControlGroup":"3",
                              "ControlPair": "3",
                              "top": "0",
                              "left": "1.25",
                              "x": "0.75",
                              "Display": {
                                  "Service": "urn:upnp-org:serviceId:VContainer1",
                                  "Variable": "Variable2",
                                  "Top": 80,
                                  "Left": 150,
                                  "Width": 25,
                                  "Height": 20
                              "Label": {
                                  "lang_tag": "rain_unit",
                                  "text": "mm"
                              "Display": {
                                  "Top": 80,
                                  "Left": 200,
                                  "Width": 25,
                                  "Height": 20
                              "ControlGroup":"4",
                              "ControlPair": "4",
                              "top": "0",
                              "left": "0",
                              "x": "1.25",
                              "Label": {
                                  "lang_tag": "rain_seventy",
                                  "text": "72hrs Total:"
                              "Display": {
                                  "Top": 105,
                                  "Left": 50,
                                  "Width": 75,
                                  "Height": 20
                              "ControlGroup":"4",
                              "ControlPair": "4",
                              "top": "0",
                              "left": "1.25",
                              "x": "0.75",
                              "Display": {
                                  "Variable": "Variable3",
                                  "Top": 105,
                                  "Left": 150,
                                  "Width": 25,
                                  "Height": 20
                              "Label": {
                                  "lang_tag": "rain_unit1",
                                  "text": "mm"
                              "Display": {
                                  "Top": 105,
                                  "Left": 200,
                                  "Width": 25,
                                  "Height": 20
                              "ControlGroup":"5",
                              "ControlPair": "5",
                              "top": "0",
                              "left": "0",
                              "x": "1.25",
                              "Label": {
                                  "text": "96hrs Total:"
                              "Display": {
                                  "Top": 130,
                                  "Left": 50,
                                  "Width": 75,
                                  "Height": 20
                              "ControlGroup":"5",
                              "ControlPair": "5",
                              "top": "0",
                              "left": "1.25",
                              "x": "0.75",
                              "Display": {
                                  "Variable": "Variable4",
                                  "Top": 130,
                                  "Left": 150,
                                  "Width": 25,
                                  "Height": 20
                              "Label": {
                                  "lang_tag": "rain_unit2",
                                  "text": "mm"
                              "Display": {
                                  "Top": 130,
                                  "Left": 200,
                                  "Width": 25,
                                  "Height": 20
                              "ControlGroup":"6",
                              "ControlPair": "6",
                              "top": "0",
                              "left": "0",
                              "x": "1.25",
                              "Label": {
                                  "lang_tag": "rain_hundred",
                                  "text": "120hrs Total:"
                              "Display": {
                                  "Top": 155,
                                  "Left": 50,
                                  "Width": 75,
                                  "Height": 20
                              "ControlGroup":"6",
                              "ControlPair": "6",
                              "top": "0",
                              "left": "1.25",
                              "x": "0.75",
                              "Display": {
                                  "Variable": "Variable5",
                                  "Top": 155,
                                  "Left": 150,
                                  "Width": 25,
                                  "Height": 20
                              "Label": {
                                  "lang_tag": "rain_unit3",
                                  "text": "mm"
                              "Display": {
                                  "Top": 155,
                                  "Left": 200,
                                  "Width": 25,
                                  "Height": 20
                          "Label": {
                              "lang_tag": "advanced",
                              "text": "Advanced"
                          "Position": "1",
                          "TabType": "javascript",
                          "ScriptName": "shared.js",
                          "Function": "advanced_device"
                          "Label": {
                              "lang_tag": "logs",
                              "text": "Logs"
                          "Position": "2",
                          "Function": "device_logs"
                          "Label": {
                              "lang_tag": "notifications",
                              "text": "Notifications"
                          "Position": "3",
                          "Function": "device_notifications"
                  "eventList2": [
                          "id": 1,
                          "label": {
                              "lang_tag": "total_rain_goes_above",
                              "text": "Total rain goes above"
                          "serviceId": "urn:upnp-org:serviceId:RainSensor1",
                          "norepeat": "1",
                          "argumentList": [
                                  "id": 1,
                                  "dataType": "r8",
                                  "name": "CurrentTRain",
                                  "comparisson": ">",
                                  "prefix": {
                                      "text": "Total rain"
                                  "suffix": {
                                      "text": "mm"
                                  "HumanFriendlyText": {
                                      "lang_tag": "hft_total_rain_goes_above",
                                      "text": "Total rain for _DEVICE_NAME_ goes above _ARGUMENT_VALUE_"
                          "id": 2,
                          "label": {
                              "lang_tag": "total_rain_goes_below",
                              "text": "Total rain goes below"
                          "norepeat": "1",
                          "argumentList": [
                                  "id": 1,
                                  "dataType": "r8",
                                  "comparisson": "<",
                                  "prefix": {
                                  "suffix": {
                                      "text": "mm"
                                      "lang_tag": "hft_total_rain_goes_below",
                                      "text": "Total rain for _DEVICE_NAME_ goes below _ARGUMENT_VALUE_"
                          "id": 3,
                          "label": {
                              "lang_tag": "rain_rate_goes_above",
                              "text": "Current rain goes above"
                          "norepeat": "1",
                          "argumentList": [
                                  "id": 1,
                                  "dataType": "r8",
                                  "name": "CurrentRain",
                                  "comparisson": ">",
                                  "prefix": {
                                      "text": "Current rain"
                                  "suffix": {
                                      "text": "mm/hr"
                                      "lang_tag": "hft_rain_rate_goes_above",
                                      "text": "Current rain for _DEVICE_NAME_ goes above _ARGUMENT_VALUE_"
                          "id": 4,
                          "label": {
                              "lang_tag": "rain_rate_goes_below",
                              "text": "Current rain goes below"
                          "norepeat": "1",
                          "argumentList": [
                                  "id": 1,
                                  "dataType": "r8",
                                  "comparisson": "<",
                                  "prefix": {
                                  "suffix": {
                                      "text": "mm/hr"
                                      "lang_tag": "hft_rain_rate_goes_below",
                                      "text": "Current rain for _DEVICE_NAME_ goes below _ARGUMENT_VALUE_"
                          "id": 5,
                          "label": {
                              "lang_tag": "battery_level_goes_below",
                              "text": "Battery level goes below"
                          "serviceId": "urn:micasaverde-com:serviceId:HaDevice1",
                          "argumentList": [
                                  "id": 1,
                                  "prefix": {
                                      "lang_tag": "Level",
                                      "text": "Level"
                                  "dataType": "i4",
                                  "name": "BatteryLevel",
                                  "comparisson": "<",
                                  "suffix": {
                                      "lang_tag": "percent_sign",
                                      "text": "%"
                                      "lang_tag": "hft_battery_level_goes_below",
                                      "text": "Battery level for _DEVICE_NAME_ go below _ARGUMENT_VALUE_%"
                  "DeviceType": "urn:schemas-micasaverde-com:device:RainSensor:1"
              S_Rainsensor1.xml:
              <scpd xmlns="urn:schemas-upnp-org:service-1-0">
                <specVersion>
                  <major>1</major>
                  <minor>0</minor>
                </specVersion>
                <serviceStateTable>
                  <stateVariable>
                    <name>CurrentTRain</name>
                    <sendEventsAttribute>yes</sendEventsAttribute>
                    <dataType>r8</dataType>
                    <shortCode>total_rain</shortCode>
                  </stateVariable>
                  <stateVariable>
                    <name>CurrentRain</name>
                    <shortCode>rain_rate</shortCode>
                  </stateVariable>
                </serviceStateTable>
                <actionList>
                  <action>
                    <name>GetCurrentTRain</name>
                    <argumentList>
                      <argument>
                        <name>RainValue</name>
                        <direction>out</direction>
                        <relatedStateVariable>CurrentTRain</relatedStateVariable>
                      </argument>
                    </argumentList>
                  </action>
              	<action>
                    <name>GetCurrentRain</name>
                    <argumentList>
                      <argument>
                        <relatedStateVariable>CurrentRain</relatedStateVariable>
                      </argument>
                    </argumentList>
                  </action>
                </actionList>
              </scpd>
                Jim,
                Pete
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                dayBuckets[] was used in the old code and since I designed 1mm of rain per tip, I never had to implement calibration.
                  @BulldogLowell
                  Pete
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  I developed the code before hek integrated EEPROM in his libraries. This uses a circular buffer, so it would take me some time to reprogram for hek's library, so I just kept using the arduino EEPROM.h library I used to develop the original code.
                  yes, I hardcoded boundaries, which you will will allow a minimum of 1 (one)
                  Sorry, I never put a bucket calibration into my code, I lucked out with the 1mm per tip working.
                  • petewillP
                    petewillP
                    petewill
                    @BulldogLowell Thanks for the responses! Ok, I suspected I was missing some implementation files. Thanks for them. Did you create them from scratch? If so, nice!
                    I will take a look at the code to see if I can implement the calebrateFactor. I will most likely be back with more questions. :) Thanks again.
                    • petewillP
                      petewillP
                      petewill
                      @BulldogLowell
                      I have been doing lots of research and working to understand the code so it will work with the calibrateFactor and I have another question... Why is the "tipSensorPin" set to OUTPUT then INPUT? Does that have to do with the interrupt?
                      attachInterrupt (1, sensorTipped, CHANGE); //* should this be RISING instead??
                      gw.sendSketchInfo(SN, SV);
                      gw.present(CHILD_ID_RAIN, S_RAIN);
                      gw.present(CHILD_ID_TRIPPED_RAIN, S_MOTION);
                      Thanks again for your help! I'll post the full code back here when I have it working in case anyone else wants to use a different size tipping bucket.
                        @BulldogLowell
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        it looks a lot like a bonehead error in the code!!
                        funny how the brain works, I never noticed that...
                        • petewillP
                          petewillP
                          petewill
                          Ok, thanks. I make those constantly...
                          I have been testing the code for the last couple of days and I think this is working but another set of eyes would be good. I added functionality to set the "calibrateFactor" to a decimal. I also updated the save/load EEPROM to work with the MySensors standard. It seems to be working in my testing but I'm no programmer.
                          I also have two questions:
                          1. Is it necessary to save/load "state" to/from EEPROM? It seems that from my testing the state is set when "measure" is calculated in this line: state = (measure >= rainSensorThreshold);. It seems that measure is evaluated when the sensor first loads and rainBucket [] is loaded from EEPROM. Hopefully that makes sense what I'm asking.
                          2. I'm still trying to understand interrupts but I'm wondering if changing to "FALLING" would be more appropriate? Maybe it doesn't matter but I thought I'd check. Here is the line I'm referring to: attachInterrupt (1, sensorTipped, FALLING);
                          Here is the code if you wanted to take a look:
                           April 26, 2015
                          //*No longer need the EEPROM.h?
                          //#include <EEPROM.h>
                          #define NODE_ID 24
                          #define SN "Rain Gauge"
                          #define SV "1.01b"
                          #define CHILD_ID_RAIN 3
                          #define CHILD_ID_TRIPPED_RAIN 4
                          #define STATE_LOCATION 0 // location to save state to EEPROM
                          #define EEPROM_BUFFER 1  // location of the EEPROM circular buffer
                          MyMessage msgRainRate(CHILD_ID_RAIN, V_RAINRATE);
                          MyMessage msgRain(CHILD_ID_RAIN, V_RAIN);
                          MyMessage msgRainVAR1(CHILD_ID_RAIN, V_VAR1);
                          MyMessage msgRainVAR2(CHILD_ID_RAIN, V_VAR2);
                          MyMessage msgRainVAR3(CHILD_ID_RAIN, V_VAR3);
                          MyMessage msgRainVAR4(CHILD_ID_RAIN, V_VAR4);
                          MyMessage msgRainVAR5(CHILD_ID_RAIN, V_VAR5);
                          MyMessage msgTripped(CHILD_ID_TRIPPED_RAIN, V_TRIPPED);
                          MyMessage msgTrippedVar1(CHILD_ID_TRIPPED_RAIN, V_VAR1);
                          MyMessage msgTrippedVar2(CHILD_ID_TRIPPED_RAIN, V_VAR2);
                          int eepromIndex;
                          int tipSensorPin = 3; //Do not change (needed for interrupt)
                          const unsigned long oneHour = 3600000UL;
                          float rainBucket [120] ; // 5 days of data  //*120 hours = 5 days
                          float calibrateFactor = .7; //Calibration in milimeters of rain per single tip.  Note: Limit to one decimal place or data may be truncated when saving to eeprom.
                          float rainRate = 0;
                          int rainSensorThreshold = 10; //default rain sensor sensitivity in mm.  Will be overwritten with msgTrippedVar2.
                          byte state = 0;
                          byte oldState = -1;
                            gw.begin(getVariables, NODE_ID);
                          //  attachInterrupt (1, sensorTipped, CHANGE); //* should this be FALLING instead??
                            digitalWrite(tipSensorPin, HIGH); //ADDED. Activate internal pull-up
                          //  Serial.println(F("Sensor Presentation Complete"));
                            state = gw.loadState(STATE_LOCATION); //retreive prior state from EEPROM
                          //  Serial.print("Tripped State (from EEPROM): ");
                          //  Serial.println(state);
                            gw.send(msgTripped.set(state==1?"1":"0"));
                              byte locator = gw.loadState(EEPROM_BUFFER + i); //New code
                                //Now that we have the buffer index let's populate the rainBucket with data from eeprom
                          //      Serial.print("EEPROM Index ");
                          //      Serial.println(eepromIndex);
                            // reset the timers
                            lastTipTime = millis() - oneHour;  //will this work if millis() starts a 0??
                            gw.request(CHILD_ID_TRIPPED_RAIN, V_VAR1); //Get rainWindow from controller (Vera)
                            delay(250);
                            gw.request(CHILD_ID_TRIPPED_RAIN, V_VAR2); //Get rainSensorThreshold from controller (Vera)
                            delay(250);
                          //  Serial.println("Radio Done");
                          //  analogWrite(ledPin, 20);
                            pulseLED();
                            float measure = 0; // Check to see if we need to show sensor tripped in this block
                          //    Serial.print("measure value (total rainBucket within rainWindow): ");
                          //    Serial.println(measure);
                              delay(250);
                              gw.saveState(STATE_LOCATION, state); //New Code
                          //    Serial.print("State Changed. Tripped State: ");
                              oldState = state;
                              if (rainRate != 0)
                                rainRate = 0;
                                delay(250);
                          ////Comment back in this block to enable Serial prints
                          //  if ( (millis() - dataMillis) >= serialInterval)
                          //    for (int i = 24; i <= 120; i = i + 24)
                          //      updateSerialData(i);
                          //    dataMillis = millis();
                            if (tipBuffer > 0)
                          //     Serial.println("Sensor Tipped");
                              //******Added calibrateFactor calculations here to account for calibrateFactor being different than 1
                              rainBucket [0] += calibrateFactor;
                          //    Serial.print("rainBucket [0] value: ");
                          //    Serial.println(rainBucket [0]);
                              if (rainBucket [0] * calibrateFactor > 253) rainBucket[0] = 253; // odd occurance but prevent overflow}}
                              float dayTotal = 0;
                          //    Serial.print("dayTotal value: ");
                          //    Serial.println(dayTotal);
                              gw.send(msgRain.set(dayTotal,1));
                              delay(250);
                                rainRate = ((oneHour) / tipDelay) * calibrateFactor; //Is my math/logic correct here??
                                gw.send(msgRainRate.set(rainRate, 1));
                          //      Serial.print("RainRate= ");
                          //      Serial.println(rainRate);
                              //If this is the first trip in an hour send .1
                                gw.send(msgRainRate.set(0.1, 1));
                              tipBuffer--;
                          //    Serial.println("One hour elapsed.");
                              //Converting rainBucket to byte.  Note: limited to one decimal place.
                              //Can this math be simplified??
                              float convertRainBucket = rainBucket[0] * 10;
                              if (convertRainBucket  > 253) convertRainBucket = 253; // odd occurance but prevent overflow
                              byte eepromRainBucket = (byte)convertRainBucket;
                              gw.saveState(eepromIndex, eepromRainBucket);
                              eepromIndex++;
                          //    Serial.print("Writing to EEPROM.  Index: ");
                              gw.saveState(eepromIndex, 0xFF);
                              rainBucket[0] = 0;
                              gw.send(msgRain.set(tipCounter(24),1));// send 24hr tips
                              delay(250);
                          void sensorTipped()
                              tipBuffer++;
                          float tipCounter(int hours)
                            float tipCount = 0;
                            return tipCount;
                            Serial.print(x);
                            Serial.print(F(" hours: "));
                            float tipCount = 0;
                              value--;
                              Serial.print("EEPROM location: ");
                              float rainValue = gw.loadState(value);
                                //Convert back to decimal value
                                float decimalRainValue = rainValue/10;
                                rainBucket[i] = decimalRainValue;
                                rainBucket [i] = 0;
                          //    Serial.print("rainBucket[ value: ");
                          //    Serial.print(i);
                          //    Serial.print("] value: ");
                          //    Serial.println(rainBucket[i]);
                            float rainUpdateTotal = 0;
                            gw.send(msgRainVAR1.set(rainUpdateTotal,1));
                            delay(250);
                            gw.send(msgRainVAR2.set(rainUpdateTotal,1));
                            delay(250);
                            gw.send(msgRainVAR3.set(rainUpdateTotal,1));
                            delay(250);
                            gw.send(msgRainVAR4.set(rainUpdateTotal,1));
                            delay(250);
                            gw.send(msgRainVAR5.set(rainUpdateTotal,1));
                            delay(250);
                            if (message.sensor == CHILD_ID_RAIN)
                            else if (message.sensor == CHILD_ID_TRIPPED_RAIN)
                                  rainWindow = 120;
                                  rainWindow = 6;
                          void pulseLED(void)
                          BulldogLowellB 2 Replies Last reply
                            This starts to look really good. Maybe we should lift this into the examples on github?
                            Just wish someone could sell the tipping bucket hardware. :)
                               April 26, 2015
                              #define NODE_ID 24
                              #define SV "1.01b"
                              int eepromIndex;
                              float rainRate = 0;
                              byte state = 0;
                              byte oldState = -1;
                                // reset the timers
                                delay(250);
                                delay(250);
                                pulseLED();
                                  delay(250);
                                  oldState = state;
                                  if (rainRate != 0)
                                    rainRate = 0;
                                    delay(250);
                                if (tipBuffer > 0)
                                  float dayTotal = 0;
                                  delay(250);
                                  tipBuffer--;
                                  eepromIndex++;
                                  rainBucket[0] = 0;
                                  delay(250);
                              void sensorTipped()
                                  tipBuffer++;
                                float tipCount = 0;
                                return tipCount;
                                Serial.print(x);
                                float tipCount = 0;
                                  value--;
                                    rainBucket [i] = 0;
                              //    Serial.print(i);
                                delay(250);
                                delay(250);
                                delay(250);
                                delay(250);
                                delay(250);
                                      rainWindow = 120;
                                      rainWindow = 6;
                              void pulseLED(void)
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @petewill
                              Pete, let me look it all over again and see if we can get the calibration working. I think the EEPROM part can be updated for @hek 's addition into the mySensors library.
                              @hek maybe we can do a 100% printed design for the collector/funnel and mechanism. and offer that on github as well.
                              hekH petewillP 2 Replies Last reply
                                @petewill
                                Good idea. We could probably just place the stl-file in the folder together with ino-file. Let me know when you feel ready.
                                  @petewill
                                  petewillP
                                  petewillP
                                  petewill
                                  Great! I think it should be working now (it did in my testing) but it could probably be cleaned up to work more efficiently.
                                  That would be great! I was also hoping to make a step by step video of how I got mine all set up (with Jim's permission of course). That way pretty much any collector could be used when the calibration setting is changed. I was able to find one really cheap at a local store. The 3d print option would be really cool though.
                                  @BulldogLowell one thing I forgot to mention in my post above is that I don't think the rainWindow and rainSensorThreshold are pulled from Vera except for when it's initially powered on. I thought I remember reading somewhere that it was designed to check every 3 hours. Maybe I'm remembering incorrectly though. I can make the change if you want but I wanted to check with you first.
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    #56
                                    yeah, we need to add the:
                                    into a millis( ) timer, once an hour works, I'd think.
                                    Try that out in here:
                                    Once you get it done, let's take @hek 's idea and put it into github. I can clean it up, get Serial printing on a toggle and we can straighten out all the questions you had in the code.
                                    Thanks for pushing this forward, it is good to get more eyes on it (remember, I may need to reinstall in my working sensor someday!)
                                    @hek,
                                    i think @korttoma has NetAtmo, maybe he will give us some rough dimensions for that size (the one I make was the standard eight inch diameter used by the US weather services, but a more portable version may be better). @korttoma?
                                    Once I get that, I will work on a 3D printable design (for many to contribute I hope).
                                    @petewill
                                    we also need to create image files for the Sensor, but for now, if you want to do the tutorial, I say go for it!
                                       April 26, 2015
                                      #define NODE_ID 24
                                      #define SV "1.01b"
                                      int eepromIndex;
                                      float rainRate = 0;
                                      byte state = 0;
                                      byte oldState = -1;
                                        // reset the timers
                                        delay(250);
                                        delay(250);
                                        pulseLED();
                                          delay(250);
                                          oldState = state;
                                          if (rainRate != 0)
                                            rainRate = 0;
                                            delay(250);
                                        if (tipBuffer > 0)
                                          float dayTotal = 0;
                                          delay(250);
                                          tipBuffer--;
                                          eepromIndex++;
                                          rainBucket[0] = 0;
                                          delay(250);
                                      void sensorTipped()
                                          tipBuffer++;
                                        float tipCount = 0;
                                        return tipCount;
                                        Serial.print(x);
                                        float tipCount = 0;
                                          value--;
                                            rainBucket [i] = 0;
                                      //    Serial.print(i);
                                        delay(250);
                                        delay(250);
                                        delay(250);
                                        delay(250);
                                        delay(250);
                                              rainWindow = 120;
                                              rainWindow = 6;
                                      void pulseLED(void)
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      #57
                                      Pete,
                                      I had a whack of combining your desire to use floats, and my desire not to use floats!
                                      Essentially we are storing in hundredths of a mm or hundredths of an inch, and dividing the values down when we transmit to Vera.
                                      you set the calibration in hundredths of a unit per tip here:
                                      #define CALIBRATE_FACTOR 5 // e.g. 5 is .05mm (or 5 hundredths of an inch if imperial) per tip
                                      Take a look at this and let me know if you like it, note it is untested and I still have to test the circular buffer storing ints instead of bytes.
                                       April 26, 2015
                                       Version 1.02b for MySensors version 1.4.1
                                       * Configuration changes to Sensor device updated every hour
                                       by @BulldogLowell and @PeteWill for free public use
                                      #include <math.h>
                                      #define NODE_ID 24
                                      #define SKETCH_NAME "Rain Gauge"
                                      #define SKETCH_VERSION "1.02b"
                                      #define DEBUG_ON  // comment out this line to disable serial debug
                                      #define CALIBRATE_FACTOR 100 // e.g. 5 is .05mm (or 5 hundredths of an inch if imperial) per tip
                                      #ifdef  DEBUG_ON
                                      boolean metric = true;
                                      int eepromIndex;
                                      int tipSensorPin = 3; // Must be interrupt capable pin
                                      int ledPin = 5; // PWM capable pin required
                                      unsigned int rainBucket [120] ; /* 120 hours = 5 days of data */
                                      unsigned int rainRate = 0;
                                      int rainSensorThreshold = 50; //default rain sensor sensitivity in hundredths.  Will be overwritten with msgTrippedVar2.
                                      byte state = 0;
                                      byte oldState = -1;
                                        SERIAL_START(115200);
                                        pinMode(tipSensorPin, INPUT_PULLUP);
                                        attachInterrupt (1, sensorTipped, FALLING);  // depending on location of the hall effect sensor may need CHANGE
                                        DEBUG_PRINT(F("Previous Tripped State (from EEPROM): "));
                                        DEBUG_PRINTLN(state ? "Tripped" : "Not Tripped");
                                        gw.send(msgTripped.set(state));
                                          byte locator = gw.loadState(EEPROM_BUFFER + 2 * i); //<<<<<<<<<<<
                                            eepromIndex = EEPROM_BUFFER + 2 * i;
                                            DEBUG_PRINT("EEPROM Index ");
                                            DEBUG_PRINTLN(eepromIndex);
                                        if (!isDataOnEeprom) // Added for the first time it is run on a new arduino
                                          eepromIndex = 1;
                                          gw.saveState(eepromIndex + 1, 0x00);
                                        // reset the timers
                                        delay(250);
                                        delay(250);
                                        DEBUG_PRINTLN(F("Radio Setup Complete!"));
                                        if (state)
                                          prettyFade();  // breath if tripped
                                          slowFlash();   // blink if not tripped
                                          DEBUG_PRINT(F("measure value (total rainBucket within rainWindow): "));
                                          DEBUG_PRINTLN(measure);
                                          delay(250);
                                          DEBUG_PRINT(F("State Changed. Tripped State: "));
                                          DEBUG_PRINTLN(state);
                                          oldState = state;
                                          if (rainRate != 0)
                                            rainRate = 0;
                                            delay(250);
                                      #ifdef DEBUG_ON
                                        if (tipBuffer > 0)
                                          DEBUG_PRINTLN(F("Sensor Tipped"));
                                          DEBUG_PRINT(F("rainBucket [0] value: "));
                                          DEBUG_PRINTLN(rainBucket [0]);
                                          int dayTotal = 0;
                                          DEBUG_PRINT(F("dayTotal value: "));
                                          DEBUG_PRINTLN(dayTotal);
                                          gw.send(msgRain.set(dayTotal, 1));
                                          delay(250);
                                            DEBUG_PRINT(F("RainRate= "));
                                            DEBUG_PRINTLN(rainRate);
                                            gw.send(msgRainRate.set( (float) CALIBRATE_FACTOR / 100.0, 1));//<<<<<<<<<<<<<<calibrate?
                                          tipBuffer--;
                                          DEBUG_PRINTLN(F("One hour elapsed."));
                                          gw.saveState(eepromIndex, highByte(rainBucket[0]));
                                          gw.saveState(eepromIndex + 1, lowByte(rainBucket[0]));
                                          eepromIndex++;
                                          DEBUG_PRINT(F("Writing to EEPROM.  Index: "));
                                          rainBucket[0] = 0;
                                          gw.send(msgRain.set(tipCounter(24), 1)); // send 24hr tips
                                          delay(250);
                                          delay(250);
                                          delay(250);
                                      void sensorTipped()
                                          rainBucket[0] += CALIBRATE_FACTOR; // adds CALIBRATE_FACTOR hundredths of unit each tip
                                        float tipCount = 0;
                                        return tipCount;
                                        DEBUG_PRINT(F("Tips last "));
                                        DEBUG_PRINT(x);
                                        DEBUG_PRINTLN(F(" hours: "));
                                        int tipCount = 0;
                                        DEBUG_PRINTLN(tipCount);
                                          value--;
                                          DEBUG_PRINT("EEPROM location: ");
                                          DEBUG_PRINTLN(value);
                                          byte rainValueHigh = gw.loadState(value);
                                          byte rainValueLow = gw.loadState(value + 1);
                                          int rainValue = (rainValueHigh << 8) & rainValueLow;
                                          DEBUG_PRINT(F("rainBucket[ value: "));
                                          DEBUG_PRINT(i);
                                          DEBUG_PRINT(F("] value: "));
                                          DEBUG_PRINTLN(rainBucket[i]);
                                        gw.send(msgRainVAR1.set(( float) rainUpdateTotal / 100.0 , 1));
                                        delay(250);
                                        gw.send(msgRainVAR2.set( (float) rainUpdateTotal / 100.0 , 1));
                                        delay(250);
                                        gw.send(msgRainVAR3.set( (float) rainUpdateTotal / 100.0 , 1));
                                        delay(250);
                                        gw.send(msgRainVAR4.set( (float) rainUpdateTotal / 100.0 , 1));
                                        delay(250);
                                        gw.send(msgRainVAR5.set( (float) rainUpdateTotal / 100.0 , 1));
                                        delay(250);
                                              rainWindow = 120;
                                            else if (rainWindow < 1)
                                              rainWindow = 1;
                                            if (rainSensorThreshold > 10000)
                                              rainSensorThreshold = 10000;
                                      void prettyFade(void)
                                        float val = (exp(sin(millis() / 2000.0 * PI)) - 0.36787944) * 108.0;
                                        analogWrite(ledPin, val);
                                      void slowFlash(void)
                                        if (millis() - pulseStart < 100UL)
                                      EDIT, modified some serial.print()s that needed editing for the debug toggle
                                      • petewillP
                                        petewillP
                                        petewill
                                        @BulldogLowell
                                        Thanks for the comments and sorry for the delayed response. It was a busy weekend and I didn't get much time in front of the computer.
                                        Haha! I only used floats because I don't know any better. I'm curious, why the dislike of floats?
                                        Is this something you would like me to do since you made it way better :) I'm happy to do it but I don't want to overstep. I consider this your handy work that I'm just happy to use.
                                        Great! I will take a look some time this week. I mounted my gauge on the house today because we were supposed to get some rain and I wanted to see how it worked in real life. Unfortunately we didn't get any... Hopefully we will get some in the next couple of days before I pull it off to do some more testing.
                                        I was thinking of going through how I made my gauge by using an existing rain gauge. I'd go over how to do the calculations for the tipping bucket calibration, uploading the files to Vera and how I added the MySensors stuff to the existing gauge. I will definitely mention the 3d printing option as well
                                        Thanks for your help!.
                                          @BulldogLowell
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          their four-byte size on arduino make for a huge eeprom storage buffer that we really don't need, we will never have negative rain and we'd never be interested in precision below 0.01 inches or milimeters.
                                          terrific, glad to see it make its way into the real world!
                                          petewillP 1 Reply Last reply
