  3. [Tutorial] Raspberry Pi NRF24l01 direct connection
raspberry pinrf24l01
56 Posts 32 Posters 94.6k Views 24 Watching
  • n3roN
    n3roN
    n3ro
    wrote on last edited by n3ro
    Hey folks,
    big THX for the tut.
    But i have some problems after starting the GW.
    My output is only:
    ./PiGatewaySerial
    Starting PiGatewaySerial...
    Protocol version - 1.4
    Created PTY '/dev/pts/1'
    Gateway tty: /dev/ttyMySensorsGateway
    check wires
    and a 100% CPU Load.
    regards,
    n3ro
    issue in GIT:
    https://github.com/mysensors/Raspberry/issues/11
    pimatic + MySensors + Homeduino + z-way
    https://github.com/n3roGit/MySensors_n3ro
    • n3roN
      n3roN
      n3ro
      No ideas?
      • Sander TeunissenS
        Sander TeunissenS
        Sander Teunissen
        the ttyMysensorsGateway can only be accessed as root (user root, group root).
        Other serialports seem to have the group "dialout" attached.
        I am running node-red which is unable the gateway and I guess this has to do with it. Anyone a solution ?
        • A
          Andreas Maurer
          ? Are you using the code that is available on github now?
          This behavior was Change by Holger a month ago. You can configure the Groups in the makefile:
          The standard configuration will build the Serial Gateway with a tty name of
          '/dev/ttyMySensorsGateway' and PTS group ownership of 'tty' the PTS will be group read
          and write. The default install location will be /usr/local/sbin. If you want to change
          that edit the variables in the head of the Makefile.
          Sander TeunissenS 2 Replies Last reply
          • A Andreas Maurer
            Sander TeunissenS
            Sander TeunissenS
            Sander Teunissen
            @Andreas-Maurer Thanks for the quick answer. I used the code from github. I am going to check your suggestions tonight. (right now I am at work ;-)
            Sander.
            • Roberto BrunialtiR
              Roberto BrunialtiR
              Roberto Brunialti
              Sorry for my naive question: does it means I ca use a raspi as a nrd24l01 based gateway?
              Sander TeunissenS 1 Reply Last reply
              • Roberto BrunialtiR Roberto Brunialti
                Sander TeunissenS
                Sander TeunissenS
                Sander Teunissen
                wrote on last edited by Sander Teunissen
                @Roberto-Brunialti Yes. Works perfectly ! (apart from the root access ;-)
                As stated by blksun813 you need to "sudo make install in the librf24-bcm folder". (add the sudo...)
                • A
                  andriej
                  wrote on last edited by andriej
                  I'm currently at work, but there's a question: will it run on orangepi? (bananapi-like clone of RPi)
                  I'll take a look at the code and try to manage... GPIOs are working almost the same (it's compatible).
                  Maybe if I make a diff-file of things changed, you will be able to merge it and do some 'ifs' so code will be clone-compatible?
                  Oh well... The library has -bcm in name so I guess it will be rather hard to get it to work...
                  • A Andreas Maurer
                    Sander TeunissenS
                    Sander TeunissenS
                    Sander Teunissen
                    @Andreas-Maurer
                    to run the gateway:
                    sudo ./PiGatewaySerial (without sudo I get the error below)
                    Could not create a symlink '/dev/ttyMySensorsGateway' to PTY! (13) Permission denied
                    running:
                    ls -l ttyMySensorsGateway
                    gives the following:
                    lrwxrwxrwx 1 root root 10 May  7 17:27 ttyMySensorsGateway -> /dev/pts/2
                    I checked the makefile and it says
                    TTY_GROUPNAME := tty
                    But it doesn't seem to do anything...Any ideas ?
                    • A
                      Andreas Maurer
                      The symlink alwayshas 777. Everyone can use it.
                      Please have a look at /dev/pts/2 This device should have the configured groups.
                      Ok?
                      • A Andreas Maurer
                        Ok?
                        Sander TeunissenS
                        Sander TeunissenS
                        Sander Teunissen
                        Ok?
                        Yes. Ok!
                        It works.
                        Thanks !
                        • SweebeeS
                          SweebeeS
                          Sweebee
                          I tested it on my Rpi B+ its working fine, but the cpu load is always 100%. Is this normal?
                          joaoabsJ 1 Reply Last reply
                            Roberto BrunialtiR
                            Roberto Brunialti
                            An other silly question: can I install a controller into the same raspberry pi (the one with this gateway and nrf )? Are all controllers suitable for such a configuration ?
                            • A
                              Andreas Maurer
                              For my Point of view, every Controller which is able to use the Serial Gateway.
                              • SweebeeS Sweebee
                                joaoabsJ
                                joaoabsJ
                                joaoabs
                                @Sweebee
                                Same here. I'm afraid that with the PI at 100% there is no much use of this code becasue we can't do anything else...
                                Strange that the PI that is much powerfull than an arduino gets so high CPU for something that an arduino nano can do...
                                Could it be something that could be improved?
                                Cheers,
                                Joaoabs
                                • A
                                  Andreas Maurer
                                  I have no problem with it. fhem as controler and mysql as DB is running on the same PI.
                                  The Gateway is not even listed in "top"
                                  • A Andreas Maurer
                                    joaoabsJ
                                    joaoabsJ
                                    joaoabs
                                    @Andreas-Maurer
                                    Do you mean you don't have any problems with the fact the CPU is at 100% or you simply don't have the same sympthom?
                                    Thanks for replying,
                                    Joaoabs
                                    • H
                                      H
                                      hawk_2050
                                      I think the problem with the PiGatewaySerial showing as consuming 100% is not a real problem. I also see the CPU consuming 100% using the top utility, however as soon as you run another process, for example a user python script, on the Pi, you will notice that top will suddenly report that PiGatewaySerial is using only a few percent of the CPU.
                                      Richard
                                        markusand
                                        Hi! I want to use RPi as a controller, with direct radio connection and pimatic. I've followed both posts but not sure how to make it work together. I know @Vladut-Grecu is using the same configuration, could you please point me to the right direction?
                                          Roberto BrunialtiR
                                          Roberto Brunialti
                                          wrote on last edited by Roberto Brunialti
                                          #23
                                          Ok. It seems the gateway is working as i get the same final screen when I run it. But... does it has a verbose mode? How can I know If it is working? I tried with a test node, unfortunately it seems not working ... or simply it does'nt give any feedback...
