  3. [Tutorial] Raspberry Pi NRF24l01 direct connection
raspberry pinrf24l01
56 Posts 32 Posters 94.6k Views 24 Watching
  • Sander TeunissenS
    Sander TeunissenS
    Sander Teunissen
    the ttyMysensorsGateway can only be accessed as root (user root, group root).
    Other serialports seem to have the group "dialout" attached.
    I am running node-red which is unable the gateway and I guess this has to do with it. Anyone a solution ?
    • A
      Andreas Maurer
      ? Are you using the code that is available on github now?
      This behavior was Change by Holger a month ago. You can configure the Groups in the makefile:
      The standard configuration will build the Serial Gateway with a tty name of
      '/dev/ttyMySensorsGateway' and PTS group ownership of 'tty' the PTS will be group read
      and write. The default install location will be /usr/local/sbin. If you want to change
      that edit the variables in the head of the Makefile.
      Sander TeunissenS 2 Replies Last reply
      • A Andreas Maurer
        Sander TeunissenS
        Sander TeunissenS
        Sander Teunissen
        @Andreas-Maurer Thanks for the quick answer. I used the code from github. I am going to check your suggestions tonight. (right now I am at work ;-)
        Sander.
        • Roberto BrunialtiR
          Roberto BrunialtiR
          Roberto Brunialti
          Sorry for my naive question: does it means I ca use a raspi as a nrd24l01 based gateway?
          Sander TeunissenS 1 Reply Last reply
          • Roberto BrunialtiR Roberto Brunialti
            Sander TeunissenS
            Sander TeunissenS
            Sander Teunissen
            wrote on last edited by Sander Teunissen
            @Roberto-Brunialti Yes. Works perfectly ! (apart from the root access ;-)
            As stated by blksun813 you need to "sudo make install in the librf24-bcm folder". (add the sudo...)
            • A
              andriej
              wrote on last edited by andriej
              I'm currently at work, but there's a question: will it run on orangepi? (bananapi-like clone of RPi)
              I'll take a look at the code and try to manage... GPIOs are working almost the same (it's compatible).
              Maybe if I make a diff-file of things changed, you will be able to merge it and do some 'ifs' so code will be clone-compatible?
              Oh well... The library has -bcm in name so I guess it will be rather hard to get it to work...
              • A Andreas Maurer
                Sander TeunissenS
                Sander TeunissenS
                Sander Teunissen
                @Andreas-Maurer
                to run the gateway:
                sudo ./PiGatewaySerial (without sudo I get the error below)
                Could not create a symlink '/dev/ttyMySensorsGateway' to PTY! (13) Permission denied
                running:
                ls -l ttyMySensorsGateway
                gives the following:
                lrwxrwxrwx 1 root root 10 May  7 17:27 ttyMySensorsGateway -> /dev/pts/2
                I checked the makefile and it says
                TTY_GROUPNAME := tty
                But it doesn't seem to do anything...Any ideas ?
                • A
                  Andreas Maurer
                  The symlink alwayshas 777. Everyone can use it.
                  Please have a look at /dev/pts/2 This device should have the configured groups.
                  Ok?
                  • A Andreas Maurer
                    Ok?
                    Sander TeunissenS
                    Sander TeunissenS
                    Sander Teunissen
                    Ok?
                    Yes. Ok!
                    It works.
                    Thanks !
                    • SweebeeS
                      SweebeeS
                      Sweebee
                      I tested it on my Rpi B+ its working fine, but the cpu load is always 100%. Is this normal?
                      joaoabsJ 1 Reply Last reply
                        Roberto BrunialtiR
                        Roberto Brunialti
                        An other silly question: can I install a controller into the same raspberry pi (the one with this gateway and nrf )? Are all controllers suitable for such a configuration ?
                        • A
                          Andreas Maurer
                          For my Point of view, every Controller which is able to use the Serial Gateway.
                          • SweebeeS Sweebee
                            joaoabsJ
                            joaoabsJ
                            joaoabs
                            @Sweebee
                            Same here. I'm afraid that with the PI at 100% there is no much use of this code becasue we can't do anything else...
                            Strange that the PI that is much powerfull than an arduino gets so high CPU for something that an arduino nano can do...
                            Could it be something that could be improved?
                            Cheers,
                            Joaoabs
                            • A
                              Andreas Maurer
                              I have no problem with it. fhem as controler and mysql as DB is running on the same PI.
                              The Gateway is not even listed in "top"
                              • A Andreas Maurer
                                joaoabsJ
                                joaoabsJ
                                joaoabs
                                @Andreas-Maurer
                                Do you mean you don't have any problems with the fact the CPU is at 100% or you simply don't have the same sympthom?
                                Thanks for replying,
                                Joaoabs
                                • H
                                  H
                                  hawk_2050
                                  I think the problem with the PiGatewaySerial showing as consuming 100% is not a real problem. I also see the CPU consuming 100% using the top utility, however as soon as you run another process, for example a user python script, on the Pi, you will notice that top will suddenly report that PiGatewaySerial is using only a few percent of the CPU.
                                  Richard
                                    markusand
                                    Hi! I want to use RPi as a controller, with direct radio connection and pimatic. I've followed both posts but not sure how to make it work together. I know @Vladut-Grecu is using the same configuration, could you please point me to the right direction?
                                      Roberto BrunialtiR
                                      Roberto Brunialti
                                      wrote on last edited by Roberto Brunialti
                                      #23
                                      Ok. It seems the gateway is working as i get the same final screen when I run it. But... does it has a verbose mode? How can I know If it is working? I tried with a test node, unfortunately it seems not working ... or simply it does'nt give any feedback...
                                        minscof
                                        wrote on last edited by minscof
                                        #24
                                        I used this gateway on a wheezy debian (RPI2) for several months and everything was ok. I upgraded my raspbian to jessie, and then the CPU load was always 100%. So I try to revert to wheezy, but i have now the same problem : CPU stays at 100 % .
                                        So there must be a system configuration somewhere to improve this gateway and prevent it to use all the CPU.
                                        Do you have an idea ?
                                        **Solved **: see this post
                                        • D
                                          davy39
                                          I'm trying to setup a direct connection between domoticz and /dev/ttyMySensorsGateway
                                          Waiting for my hardware (no NRF24l01 attached yet), I'm actually playing around with the software part.
                                          I did install Domoticz and MySensorsGateway on the Pi and I'm getting a /dev/ttyMySensorsGateway symlink at boot time.
                                          The problem is that I can't see it on domoticz interface when trying to choose a serial port on "Mysensors gateway USB" device : only /dev/ttyAMA0 ....
                                          Is that because no NRF24 is connected or there is a specific configuration to make /dev/ttyMySensorsGateway appearing as a serial port (chown, udev ....)
                                          Thanks for your help
