  3. [Tutorial] Raspberry Pi NRF24l01 direct connection
raspberry pinrf24l01
56 Posts 32 Posters 94.6k Views 24 Watching
  • Roberto BrunialtiR
    Roberto BrunialtiR
    Roberto Brunialti
    Sorry for my naive question: does it means I ca use a raspi as a nrd24l01 based gateway?
    Sander TeunissenS 1 Reply Last reply
    • Roberto BrunialtiR Roberto Brunialti
      Sander TeunissenS
      Sander TeunissenS
      Sander Teunissen
      wrote on last edited by Sander Teunissen
      @Roberto-Brunialti Yes. Works perfectly ! (apart from the root access ;-)
      As stated by blksun813 you need to "sudo make install in the librf24-bcm folder". (add the sudo...)
      • A
        andriej
        wrote on last edited by andriej
        I'm currently at work, but there's a question: will it run on orangepi? (bananapi-like clone of RPi)
        I'll take a look at the code and try to manage... GPIOs are working almost the same (it's compatible).
        Maybe if I make a diff-file of things changed, you will be able to merge it and do some 'ifs' so code will be clone-compatible?
        Oh well... The library has -bcm in name so I guess it will be rather hard to get it to work...
        • A Andreas Maurer
          ? Are you using the code that is available on github now?
          This behavior was Change by Holger a month ago. You can configure the Groups in the makefile:
          The standard configuration will build the Serial Gateway with a tty name of
          '/dev/ttyMySensorsGateway' and PTS group ownership of 'tty' the PTS will be group read
          and write. The default install location will be /usr/local/sbin. If you want to change
          that edit the variables in the head of the Makefile.
          Sander TeunissenS
          Sander TeunissenS
          Sander Teunissen
          @Andreas-Maurer
          to run the gateway:
          sudo ./PiGatewaySerial (without sudo I get the error below)
          Could not create a symlink '/dev/ttyMySensorsGateway' to PTY! (13) Permission denied
          running:
          ls -l ttyMySensorsGateway
          gives the following:
          lrwxrwxrwx 1 root root 10 May  7 17:27 ttyMySensorsGateway -> /dev/pts/2
          I checked the makefile and it says
          TTY_GROUPNAME := tty
          But it doesn't seem to do anything...Any ideas ?
          • A
            Andreas Maurer
            The symlink alwayshas 777. Everyone can use it.
            Please have a look at /dev/pts/2 This device should have the configured groups.
            Ok?
            • A Andreas Maurer
              Ok?
              Sander TeunissenS
              Sander TeunissenS
              Sander Teunissen
              Ok?
              Yes. Ok!
              It works.
              Thanks !
              • SweebeeS
                SweebeeS
                Sweebee
                I tested it on my Rpi B+ its working fine, but the cpu load is always 100%. Is this normal?
                joaoabsJ 1 Reply Last reply
                  Roberto BrunialtiR
                  Roberto Brunialti
                  An other silly question: can I install a controller into the same raspberry pi (the one with this gateway and nrf )? Are all controllers suitable for such a configuration ?
                  • A
                    Andreas Maurer
                    For my Point of view, every Controller which is able to use the Serial Gateway.
                    • SweebeeS Sweebee
                      joaoabsJ
                      joaoabsJ
                      joaoabs
                      @Sweebee
                      Same here. I'm afraid that with the PI at 100% there is no much use of this code becasue we can't do anything else...
                      Strange that the PI that is much powerfull than an arduino gets so high CPU for something that an arduino nano can do...
                      Could it be something that could be improved?
                      Cheers,
                      Joaoabs
                      • A
                        Andreas Maurer
                        I have no problem with it. fhem as controler and mysql as DB is running on the same PI.
                        The Gateway is not even listed in "top"
                        • A Andreas Maurer
                          joaoabsJ
                          joaoabsJ
                          joaoabs
                          @Andreas-Maurer
                          Do you mean you don't have any problems with the fact the CPU is at 100% or you simply don't have the same sympthom?
                          Thanks for replying,
                          Joaoabs
                          • H
                            H
                            hawk_2050
                            I think the problem with the PiGatewaySerial showing as consuming 100% is not a real problem. I also see the CPU consuming 100% using the top utility, however as soon as you run another process, for example a user python script, on the Pi, you will notice that top will suddenly report that PiGatewaySerial is using only a few percent of the CPU.
                            Richard
                              markusand
                              Hi! I want to use RPi as a controller, with direct radio connection and pimatic. I've followed both posts but not sure how to make it work together. I know @Vladut-Grecu is using the same configuration, could you please point me to the right direction?
                                Roberto BrunialtiR
                                Roberto Brunialti
                                wrote on last edited by Roberto Brunialti
                                #23
                                Ok. It seems the gateway is working as i get the same final screen when I run it. But... does it has a verbose mode? How can I know If it is working? I tried with a test node, unfortunately it seems not working ... or simply it does'nt give any feedback...
                                  minscof
                                  wrote on last edited by minscof
                                  #24
                                  I used this gateway on a wheezy debian (RPI2) for several months and everything was ok. I upgraded my raspbian to jessie, and then the CPU load was always 100%. So I try to revert to wheezy, but i have now the same problem : CPU stays at 100 % .
                                  So there must be a system configuration somewhere to improve this gateway and prevent it to use all the CPU.
                                  Do you have an idea ?
                                  **Solved **: see this post
                                  • D
                                    davy39
                                    I'm trying to setup a direct connection between domoticz and /dev/ttyMySensorsGateway
                                    Waiting for my hardware (no NRF24l01 attached yet), I'm actually playing around with the software part.
                                    I did install Domoticz and MySensorsGateway on the Pi and I'm getting a /dev/ttyMySensorsGateway symlink at boot time.
                                    The problem is that I can't see it on domoticz interface when trying to choose a serial port on "Mysensors gateway USB" device : only /dev/ttyAMA0 ....
                                    Is that because no NRF24 is connected or there is a specific configuration to make /dev/ttyMySensorsGateway appearing as a serial port (chown, udev ....)
                                    Thanks for your help
                                    • fetsF
                                      fetsF
                                      fets
                                      Hi everybody,
                                      I'm new in mysensors world and I would like to use my pi2 with direct connection to nrf24l01.
                                      There is a new release of the arduino library but I can't find the raspberry one.
                                      Somebody knows if it exists and where to find it ?
                                      I also tried to find an example of using raspberry as mqtt gateway without success, any ideabut was not able to find an example
                                        You could probably run the old one.
                                        Ideally I would like to have the same code-base for RPi but someone needs to help implement the HW-implementation-class.
                                        • fetsF
                                          fetsF
                                          fets
                                          Thanks hek, i'll try to use old code but I didn't find anything about raspberry as mqtt client gateway.
                                          If I succeed, and if not too late, i'll try to implement the new library
